2017's came with an LED strip as DRL's. Before 2017, the DRL's would extinguish when the headlights are turned on. This one doesn't. How would I change it so the DRL's turn off when the headlights are on? Also, the LED's are really bright. Is there a way to turn down the intensity when the DRL's are on?
How can you turn off the motion lockout for the radio/NAV unit? We would like to be able to enter addresses in the NAV when the car is in motion. Someone posted that you need to raise the speed limit but I can't find it anywhere.
Wednesday,31,January,2018,09:36:04:55654
VCDS Version: 18.1.0.2 (x64)
VIN: 3VW5T7AJ0HM408436   License Plate:
Mileage: 860km-534mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 03 05 08 09 10 15 16 17 19 25 2B 3C 42 44 46 47 4F 52 5F
          62 72 75
VIN: 3VW5T7AJ0HM408436   Mileage: 860km-534miles
Address 01: Engine (J623-CPPA)       Labels:. 06K-907-425-V2.clb
   Part No SW: 06K 906 071 BL    HW: 06K 907 425 C
   Component: R4 2.0l TFS   H13 3686
   Revision: --H13---
   Coding: 00190012242400171000
   Shop #: WSC 00066 790 00184
   ASAM Dataset: EV_ECM20TFS02006K906071BL 001005
   ROD: EV_ECM20TFS02006K906071BL.rod
   VCID: 76E9ECE6C91E5BF59F-8022
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Coding: A14B600C49220002850F06E7921F00412118F02A
   VCID: 75EBEBEADC1850ED96-8020
   Part No SW: 5K0 959 434 G    HW: 5K0 959 434
   Component: VWKESSYPQ35GP 092 1305
   Revision: 00092000    Serial number: 0439074147
   Coding: 032C0C
   Shop #: WSC 00066 000 00295
   VCID: 397327DAB880F48DB2-806C
   Part No SW: 1K8 907 044 CN    HW: 1K8 907 044 CN
   Component: Climatronic   H08 0405
   Revision: 00001K05
   Coding: 0050019002
   Shop #: WSC 00066 790 00319
   VCID: 7DFBF3CAEC2808ADDE-8028
   Part No SW: 5K0 937 087 AJ    HW: 5K0 937 087 AJ
   Component: BCM PQ35 H+   122 0184
   Revision: BL122001
   Coding: EF200A1A902F06D4018800812400054C0070000845A08DB2E4802000A040
   VCID: 7DFBF3CAE42808ADDE-8028
   Subsystem 1 - Part No: 5K7 955 559 C  Labels: 5K7-955-559.CLB
   Component: RLS 240417 04  42  0106
   Coding: 0228DD
   Part No SW: 1K8 919 472 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0480
   Revision: --------    Serial number: 39331712804710
   Coding: 0071155001
   ASAM Dataset: EV_EPHVA18VW364GP00 001007
   VCID: 377721E28E94E2FD44-8062
Address 15: Airbags (J234)       Labels:* 561-959-655.clb
   Part No SW: 561 959 655     HW: 561 959 655
   Component: AirbagVW11    008 0210
   Serial number: 003RXM0D8HLF
   Coding: 8CCCF000000000005000001AC20800000065
   ASAM Dataset: EV_AirbaVW11SMEVW411 001002
   ROD: EV_AirbaVW11SMEVW411.rod
   VCID: 63CFA5B26A8CDE5DC8-8036
   Serial number: IBH000000000007AOBCO
   Coding: 30314C
   Subsystem 2 - Part No SW: -----------    HW: 480 000 304 17
   Serial number: 3570000000072C35B22G
   Subsystem 3 - Part No SW: -----------    HW: 480 000 304 17
   Serial number: 3580000000042C35B22E
   Subsystem 4 - Part No SW: -----------    HW: 480 020 104 17
   Component: SideSensor_Dr  000 0148
   Serial number: 3510001AD257C44606A3
   Subsystem 5 - Part No SW: -----------    HW: 480 020 104 17
   Component: SideSensor_Pr  000 0148
   Serial number: 3520001B9257C42245C0
   Subsystem 6 - Part No SW: -----------    HW: 480 020 505 17
   Component: FrontSensor_D  000 0189
   Serial number: 35500019B249E3C3E7AQ
   Subsystem 7 - Part No SW: -----------    HW: 480 020 505 17
   Component: FrontSensor_P  000 0189
   Serial number: 35600019B249E3C5178E
   Part No SW: 1K5 953 521 CR    HW: 5K0 953 569 BF
   Component: LENKS.MODUL   018 0230
   Revision: FF010042    Serial number: 20170401300568
   Coding: 0002440008
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 7F0709C2E6241ABDCC-802A
   Subsystem 1 - Part No SW: 6C0 959 442 C    HW: 6C0 959 442 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H04 0103
   Serial number: 29170000473340087083
   Coding: B0FFFF
   Part No SW: 5C6 920 986 C    HW: 5C6 920 986 C
   Component: KOMBI         H02 1104
   Coding: 221E010000
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
   VCID: 336F15F29AEC0EDD78-8066
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 31051703010322
   Coding: 351032
   VCID: 7BFFFDD2FA3C069DE0-802E
   Component: IMMO          H02 1104
   Coding: 000007
   VCID: 6AD1C8968DA68F150B-803E
Address 2B: Steer. Col. Lock (J764)       Labels:| 5K0-905-861.clb
   Part No SW: 5K0 905 861 D    HW: 5K0 905 861 D
   Component: ELV-PQ35      H22 0240
   Revision: 00000000    Serial number: 17000106780007
   Coding: 4100000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 31631FFA60F03CCD0A-8064
   Component: HRE_Master    H12 0071
   Serial number: 0436794636
   Coding: 02011102
   Shop #: WSC 00066 790 00295
   ROD: EV_HREntryHella_VW27.rod
   VCID: 3C7D3ECEB7B2C1A5A9-8068
   Lane Change Assistant 2:
   Component: HRE_Slave  H12 0071
   Serial number: 0436174965
   Coding: 020111
   Part No SW: 561 959 701 B    HW: 3C0 959 793 H
   Component: TUER-SG FT    002 0631
   Revision: 13100010    Serial number: 0010960375
   Coding: 0404BD
   Shop #: WSC 00066 790 00192
   ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
   VCID: 1D3BD34A0C68A8ADBE-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 6R0 959 811 T    HW: 6R0 959 811 T
   Component: J388__TSG_HL  022 1467
   Serial number: 14102745170512195423
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 306    3501
   Revision: 00H22000
   VCID: 397327DA7080F48DB2-806C
   Part No SW: 5C6 035 456 C    HW: 5C6 035 456 C
   Component: KonzernAmp10K H09 6831
   Revision: --------    Serial number: EAA098C0133866
   VCID: 2855F29E532A7D05DD-807C
   Component: EZE_2         H56 1682
   Coding: 01030100
   VCID: 6FE7D982BE446A3D5C-803A
   Subsystem 1 - Part No SW: 5K0 959 591 A    HW: 6R0 959 591 D
   Component: J245 PS41.402  H03 0004
   Serial number: 0000FST001KBJAP00000
   Coding: 180000
   Part No SW: 561 959 702 B    HW: 3C0 959 792 H
   Component: TUER-SG BT    002 0631
   Revision: 15100010    Serial number: 0010958771
   Coding: 0404BC
   ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
   VCID: 1E39D446016EB3B5A7-804A
   Slave Passenger:
   Subsystem 1 - Part No SW: 6R0 959 812 T    HW: 6R0 959 812 T
   Component: J389__TSG_HR  022 1467
   Serial number: 14102744170506193420
   Part No SW: 5C0 035 684 B    HW: 5C0 035 684 B
   Component: MU-S-NS-US    H31 0363
   Serial number: VWZAZ2T1318091
   Coding: 02630102AA00000051220003001808009F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW27.rod
   VCID: 244DE6AE2F029965F1-8070
   Subsystem 1 - Part No SW: 3G0 919 866 BB    HW: -----------
   Component: NAR 2017  --- 0525
   Part No SW: 561 035 285 A    HW: 561 035 285 A
   Component: OCULowUSA     020 0160
   Serial number: 000003554140565
   Coding: 02630102C24232107F1606000000
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_OCULow 002010
   ROD: EV_OCULow_002.rod
   VCID: 142DB66EFFA2E9E501-8040
End-------------------------(Elapsed Time: 03:20)--------------------------
