Page 4 of 4 FirstFirst ... 234
Results 31 to 36 of 36
Thread: Need help with ABS code for vcds (MK60EC1)
  1. #31
    Are you in process of getting verified?
    http://forums.ross-tech.com/showthre...ut-0x01-08-000
    Please explain in detail what the immobilizer issue was or is having?
    Is this ECU also tuned with IMMO defeat?
  2. #32
    New User
    Jan 2018
    Dartmouth, MA
    Car would sometimes start and just stall but happens rarely, got the delete so would not chance getting abandoned somewhere, ecu is stock with the delete
  3. #33
    New User
    Jan 2018
    Dartmouth, MA
    So i restarted my laptop and then cleared codes in each controller, used 114B600C492300FE881206E5921B0042310400, and for some reason it worked. Thanks for the help, jack thanks for taking time answering my questions, will verify soon just little low on dough, again thanks
  4. #34
    Aug 2016
    Eindhoven, NB, NL
    great that it worked. did you do all the diagnostics, like system function test and steering angle calibration
    http://wiki.ross-tech.com/wiki/index..._Function_Test
  5. #35
    I updated the post to identify the code that functioned..........
    Reboots will now be a consideration.
    http://forums.ross-tech.com/showthre...l=1#post119462
  6. #36
    "Sweetdang" please get verified.......
    Thank you
