Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Need help with ABS code for vcds (MK60EC1)
    New User
    Jan 2018
    Dartmouth, MA
    ABS showing no codes in vcds, took a picture of the sticker in trunk but don't know how to read the label
    Have you got your powetrain databus issues sorted yet?
    New User
    Jan 2018
    Dartmouth, MA
    Removed ecu and reconnected and was able to communicate to clear codes, car shifts into gear and works just have the abs, brake lights on. Will have to autoscan again
    New User
    Jan 2018
    Dartmouth, MA
    Sunday,28,January,2018,15:09:31:34138
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
    VCDS Version: 18.1.0.2
    VIN: WVWDM7AJ1CW114712   License Plate:
    Mileage: 96220km-59788mi   Repair Order: 1
    Chassis Type: AJ-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
    VIN: WVWDM7AJ1CW114712   Mileage: 96220km-59788miles
    Address 01: Engine (CJA)       Labels: None
       Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
       Component: R4 2.0l TDI G000AG  9983
       Revision: 12H14---    Serial number:
       Coding: 0050078
       Shop #: WSC 27770 001 1048576
       VCID: 306F3EB8A3A609C505-8064
    Readiness: 0 0 0 1 1
       Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 9334
       Revision: 05351113    Serial number: 00001107090991
       VCID: 173DE5242608FEFD64-8042
       Revision: 00H31001
       VCID: 7BF5D994FA603A9DE0-802E
                        Reset counter: 101
                        Mileage: 96227 km
                        Date: 2018.01.28
                        Time: 02:03:15
                        Count: 7
                        Count: 12
                        Count: 20480
                        Count: 195
                        Count: 39936
                        Count: 512
                        Fault Status: 01100101
                        Reset counter: 101
                        Mileage: 96227 km
                        Date: 2018.01.28
                        Time: 02:03:14
                        Count: 2
                        Count: 12
                        Count: 20480
                        Count: 279
                        Count: 39936
                        Count: 512
                        Reset counter: 101
                        Mileage: 96227 km
                        Date: 2018.01.28
                        Time: 02:03:15
                        Count: 7
                        Count: 12
                        Count: 20480
                        Count: 295
                        Count: 39936
                        Count: 512
                        Reset counter: 101
                        Mileage: 96227 km
                        Date: 2018.01.28
                        Time: 02:03:14
                        Count: 2
                        Count: 12
                        Count: 20480
                        Count: 270
                        Count: 39936
                        Count: 512
       Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
       Component: AC Manuell    H19 0304
       Revision: 00001016
       Coding: 0000001002
       VCID: 000FAE789B865945B5-8054
       Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
       Component: BCM PQ35  M   110 0657
       Revision: 00110 AC
       Coding: 6F180A3A90272AC4008800C17000854448010386534D8560648020200040
       VCID: 3D71178CA4F4F4AD9E-8068
       Component: Wischer 04091  26  0512
       Coding: 009795
                        Reset counter: 101
                        Mileage: 96227 km
                        Date: 2018.01.28
                        Time: 02:03:14
                        Voltage: 11.20 V
                            Term 50 Off
       Serial number: 003GVRA0KE80
       Coding: 00003131
       ROD: EV_AirbaVW10SMEVW360.rod
       VCID: 3F8D6D84A6F8E6BD8C-806A
       Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
       Component: BF-Gewichtss.  007 0002
       Serial number: ---0000R--00060VXT00
       Serial number: 3572MSME7B580163ZZZY
       Serial number: 3582MSME49706562ZZZX
       Serial number: 3512QSME64415B20ZZZO
       Serial number: 3522QSME5A015C48ZZZ.
       Serial number: 35527SME462C6628ZZZM
       Serial number: 35627SME6A1C6628ZZZS
       Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
       Revision: --------    Serial number:  90422KHV001C0
       Coding: 189A140000
       ROD: EV_SMLSNGKUDS_A05.rod
       VCID: 76E3C8A0C94267F59F-8022
       Serial number: 50000000000000484913
       Coding: E30000
       Part No SW: 5K0 920 972 C    HW: 5K0 920 972 C
       Coding: 270D00
       Shop #: WSC 00066 000 00119
       VCID: 306F3EB86BA609C505-8064
       Revision:   H42       Serial number: 020911F2001202
       Coding: 350002
       VCID: 35610FAC9CC42CED56-8060
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1225223REJ6M06
       VCID: 7EF3D08029722FB5C7-802A
       Component: IMMO          H03 0607
       VCID: 6ADBECD08DFAB3150B-803E
       Revision: A1001003    Serial number: 7660798010
       VCID: 2959D3DC407C780DC2-807C
       Coding: 0001204
       VCID: 31693BBCA8AC00CD0A-8064
       Part No: 1K0 909 144 M
       Component: EPS_ZFLS Kl. 70     3201
       Revision: 00H20000
       VCID: 346732A857BE35E561-8060
                        Fault Status: 11100101
                        Mileage: 96227 km
                        Date: 2018.01.28
                        Time: 02:03:13
                        Battery Volts: 11.2 V
                            DD
                        Temperature: 14.0∞C
                        Count: 3
                        Steering Angle: 0.00∞
                            SteerAng n.Init
       Coding: 0001204
       VCID: 326B34B0ADAA3BD573-8066
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7L1133704
       Coding: 01000400040005
       VCID: 63C581F462D0E25DC8-8036
                        Reset counter: 101
                        Mileage: 96227 km
                        Date: 2018.01.28
                        Time: 02:03:13
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 35610FAC5CC42CED56-8060
       Coding: 0001168
       VCID: 366308A041C227F55F-8062
       Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
       Component: TELEFON       H09 2902
       Revision: 1B001001    Serial number: 00007660754145
       Coding: 0A10040000010100
       ASAM Dataset: EV_UHVNA A01719
       ROD: UHVNA.rod
       VCID: 275DD5E45E684E7DD4-8072
    End-------------------------(Elapsed Time: 02:48)--------------------------
  5. Likes Uwe liked this post
    Aug 2016
    The Hague, NL
    Hmm... is it a Jetta?
    00000000000000000000000000000000000000 empty code
    B14B6051092300FE8D1206E5901B0042050C00 iichel 1 byte 0 B1
    B14B4051492300FE8D1202E5921B0042A71000 iichel 2 byte 0 B1
    A14B6051092300FE851206E5901B0042050C00 iichel 3 byte 0 A1
    A14B4051492300FE851202E5921B0042A71000 iichel 4 byte 0 A1
    A14B400C49220001850E02E892190042A51400 iichel 5 byte 0 A1
    B14B400C492200018D0E02E892190042A51400 iichel 6 byte 0 B1
    New User
    Jan 2018
    Dartmouth, MA
    Golf tdi 2012
    Aug 2016
    The Hague, NL
    OK, clear, you VIN holds AJ as chassis so that's why i'm a bit curious.
  9. #8
    The US standard for VINs requires model year encoding to b unambiguous for a 60-year span, not the 30 year span that is inherent in the 10th digit. Take a look here at the paragraphs below the table. As of 2010, this has forced VWAG to use different 7th and 8th digits in the NAR market as opposed to RDW..
  10. #9
    New User
    Jan 2018
    Dartmouth, MA
    Are those codes you gave for a jetta
  11. #10
    Aug 2016
    The Hague, NL
    For AJ chassis yes
