Need help with ABS code for vcds (MK60EC1)
sweetdang
Dartmouth, MA
DS285.1
ABS showing no codes in vcds, took a picture of the sticker in trunk but don't know how to read the label
sweetdang
Dartmouth, MA
DS285.1
Removed ecu and reconnected and was able to communicate to clear codes, car shifts into gear and works just have the abs, brake lights on. Will have to autoscan again
sweetdang
Dartmouth, MA
DS285.1
Sunday,28,January,2018,15:09:31:34138
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 18.1.0.2
VIN: WVWDM7AJ1CW114712   License Plate:
Mileage: 96220km-59788mi   Repair Order: 1
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 2E 42 44 46 52 56 62 72 77
VIN: WVWDM7AJ1CW114712   Mileage: 96220km-59788miles
Address 01: Engine (CJA)       Labels: None
   Part No SW: 03L 997 030 E    HW: 03L 907 309 AA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H14---    Serial number:
   Coding: 0050078
   Shop #: WSC 27770 001 1048576
   VCID: 306F3EB8A3A609C505-8064
Readiness: 0 0 0 1 1
   Part No SW: 02E 300 057 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 9334
   Revision: 05351113    Serial number: 00001107090991
   VCID: 173DE5242608FEFD64-8042
   Revision: 00H31001
   VCID: 7BF5D994FA603A9DE0-802E
            000 -  -
                    Reset counter: 101
                    Mileage: 96227 km
                    Date: 2018.01.28
                    Time: 02:03:15
                    Count: 7
                    Count: 12
                    Count: 20480
                    Count: 195
                    Count: 39936
                    Count: 512
                    Fault Status: 01100101
                    Reset counter: 101
                    Mileage: 96227 km
                    Date: 2018.01.28
                    Time: 02:03:14
                    Count: 2
                    Count: 12
                    Count: 20480
                    Count: 279
                    Count: 39936
                    Count: 512
                    Reset counter: 101
                    Mileage: 96227 km
                    Date: 2018.01.28
                    Time: 02:03:15
                    Count: 7
                    Count: 12
                    Count: 20480
                    Count: 295
                    Count: 39936
                    Count: 512
                    Reset counter: 101
                    Mileage: 96227 km
                    Date: 2018.01.28
                    Time: 02:03:14
                    Count: 2
                    Count: 12
                    Count: 20480
                    Count: 270
                    Count: 39936
                    Count: 512
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0304
   Revision: 00001016
   Coding: 0000001002
   VCID: 000FAE789B865945B5-8054
   Part No SW: 1K0 937 086 P    HW: 1K0 937 086 P
   Component: BCM PQ35  M   110 0657
   Revision: 00110 AC
   Coding: 6F180A3A90272AC4008800C17000854448010386534D8560648020200040
   VCID: 3D71178CA4F4F4AD9E-8068
   Component: Wischer 04091  26  0512
   Coding: 009795
            000 -  -
                    Reset counter: 101
                    Mileage: 96227 km
                    Date: 2018.01.28
                    Time: 02:03:14
                        Term 15 On
                    Voltage: 11.20 V
                        Term 50 Off
   Part No SW: 5K0 959 655 H    HW: 5K0 959 655 H
   Component: AirbagVW10G   013 0724
   Serial number: 003GVRA0KE80
   Coding: 00003131
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3F8D6D84A6F8E6BD8C-806A
   Subsystem 1 - Part No SW: 5K0 959 339     HW: 5K0 959 339
   Component: BF-Gewichtss.  007 0002
   Serial number: ---0000R--00060VXT00
   Serial number: 3572MSME7B580163ZZZY
   Serial number: 3582MSME49706562ZZZX
   Serial number: 3512QSME64415B20ZZZO
   Serial number: 3522QSME5A015C48ZZZ.
   Serial number: 35527SME462C6628ZZZM
   Serial number: 35627SME6A1C6628ZZZS
   Part No SW: 5K0 953 507 AH    HW: 5K0 953 549 B
   Revision: --------    Serial number:  90422KHV001C0
   Coding: 189A140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 76E3C8A0C94267F59F-8022
   Serial number: 50000000000000484913
   Coding: E30000
   Part No SW: 5K0 920 972 C    HW: 5K0 920 972 C
   Coding: 270D00
   Shop #: WSC 00066 000 00119
   VCID: 306F3EB86BA609C505-8064
   Part No SW: 7N0 907 530 H    HW: 1K0 907 951
   Component: J533  Gateway H42 1620
   Revision:   H42       Serial number: 020911F2001202
   Coding: 350002
   VCID: 35610FAC9CC42CED56-8060
   Revision: 00001000    Serial number: 1225223REJ6M06
   VCID: 7EF3D08029722FB5C7-802A
   Component: IMMO          H03 0607
   VCID: 6ADBECD08DFAB3150B-803E
   Revision: A1001003    Serial number: 7660798010
   VCID: 2959D3DC407C780DC2-807C
   Coding: 0001204
   VCID: 31693BBCA8AC00CD0A-8064
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 70     3201
   Revision: 00H20000
   VCID: 346732A857BE35E561-8060
                    Fault Status: 11100101
                    Mileage: 96227 km
                    Date: 2018.01.28
                    Time: 02:03:13
                    Battery Volts: 11.2 V
                        DD
                    Temperature: 14.0∞C
                    Count: 3
                    Steering Angle: 0.00∞
                        SteerAng n.Init
   Coding: 0001204
   VCID: 326B34B0ADAA3BD573-8066
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L1133704
   Coding: 01000400040005
   VCID: 63C581F462D0E25DC8-8036
            000 -  -
                    Reset counter: 101
                    Mileage: 96227 km
                    Date: 2018.01.28
                    Time: 02:03:13
   Coding: 0001168
   Shop #: WSC 01357 011 1012552
   VCID: 35610FAC5CC42CED56-8060
   Coding: 0001168
   VCID: 366308A041C227F55F-8062
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007660754145
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 275DD5E45E684E7DD4-8072
End-------------------------(Elapsed Time: 02:48)--------------------------
iichel
Netherlands, eastern part
C?ID=284912
Hmm... is it a Jetta?
00000000000000000000000000000000000000 empty code
B14B6051092300FE8D1206E5901B0042050C00 iichel 1 byte 0 B1
B14B4051492300FE8D1202E5921B0042A71000 iichel 2 byte 0 B1
A14B6051092300FE851206E5901B0042050C00 iichel 3 byte 0 A1
A14B4051492300FE851202E5921B0042A71000 iichel 4 byte 0 A1
A14B400C49220001850E02E892190042A51400 iichel 5 byte 0 A1
B14B400C492200018D0E02E892190042A51400 iichel 6 byte 0 B1
iichel
C?ID=284912
OK, clear, you VIN holds AJ as chassis so that's why i'm a bit curious.
The US standard for VINs requires model year encoding to b unambiguous for a 60-year span, not the 30 year span that is inherent in the 10th digit. Take a look here at the paragraphs below the table. As of 2010, this has forced VWAG to use different 7th and 8th digits in the NAR market as opposed to RDW.. :mad:
iichel
C?ID=284912
that doesn't make sense, my codes are equal in length to the empty code?
edit: just caught myself trying to reason with a german electronic module. bad idea. :facepalm:
sweetdang
Dartmouth, MA
DS285.1
yea is there a way to find out the code by looking at the abs unit
IvanADE
New Member
2.0 tdi ,LHD, no start/stop, TPMS installed
Disc diameter front 288, back 253 = 00004000092300FE001202E5901B0042040000
Disc diameter front 312, back 253 = 00006000092300FE001206E5901B0042040000
Disc diameter front 345, back 310 = 00008000092300FE001201E5901B0042040000
Disc diameter front 312, back 272 = 0000C000092300FE001203E5901B0042040000
Try
Regards
Ivan
sweetdang
Dartmouth, MA
DS285.1
tried all four codes, "codes rejected, error 31"
