hello forum member i need your help
As i ve just change this passat cc t from 1.8 tsi engine to 2.5 engine , the ABS light is on and the brake light is permanently on ,so i need the ABS coding thanks in advance
HERE IS THE FULL SCAN
Chassis Type: 1K (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 4F 52 53 56 61 62
72
VIN: 3VWHM71K99M130348 Mileage: 79440km-49361miles
Address 01: Engine (CBT) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 P HW: 07K 906 055 M
Component: 2,5l R5/4V G 9970
Revision: G6H02--- Serial number: VWX7Z0I024I0JX
Coding: 0000075
Shop #: WSC 08087 444 12151
VCID: 3B7EC0847AAB369AA9-806E
9 Faults Found:
001384 - Cruise Control Switch (E45)
P0568 - 000 - Implausible Signal
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:58
Load: 0.0 %
Temperature: 27.0°C
Temperature: -40.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.811 V
008581 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:58
Load: 0.0 %
Temperature: 27.0°C
Voltage: 11.811 V
049409 - No Communication with Transmission Control Module
U0101 - 000 -
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:58
Load: 0.0 %
Temperature: 27.0°C
Voltage: 11.811 V
009266 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
P2432 - 000 - Short to Ground
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:58
Load: 0.0 %
Temperature: 27.0°C
Voltage: 11.811 V
001152 - Coolant Fan Control Circuit 1
P0480 - 000 - Electrical Malfunction
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:59
Load: 0.0 %
Temperature: 27.0°C
Voltage: 11.811 V
000112 - Sensor for Ambient Air Temperature (G17)
P0070 - 000 - Malfunction
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:59
Load: 0.0 %
Temperature: 27.0°C
Voltage: 11.811 V
001575 - Fuel Pump Relay Control Circuit
P0627 - 000 - Open Circuit
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:59
Load: 0.0 %
Temperature: 27.0°C
Voltage: 11.811 V
000275 - Intake Air Temp. Sensor (G42)
P0113 - 000 - Signal too High
Mileage: 79449 km
Date: 2018.01.25
Time: 00:02:03
Load: 0.0 %
Temperature: 27.0°C
Voltage: 11.811 V
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 000 -
Mileage: 79449 km
Date: 2018.01.25
Time: 00:06:11
Load: 0.0 %
Temperature: 27.0°C
Voltage: 11.811 V
Readiness: 0110 1101
Part No SW: 02E 300 050 J HW: 02E 927 770 AD
Component: GSG DSG 082 1407
Revision: 05108020 Serial number: 00001003150750
Shop #: WSC 04940 001 00001
VCID: 19323A0CD057248A5B-804C
18250 - Please check DTC Memory of Instrument Cluster
P1842 - 000 -
Fault Frequency: 255
Reset counter: 1
Mileage: 79449 km
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 N HW: 3AA 614 109 N
Component: J104 C2 450M VDCA 0005
Revision: --H07--- Serial number: 00000003555145
Coding: 0001402
Shop #: WSC 05311 000 00000
VCID: 3874DF884B9D1D8244-806C
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:07:27
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 212
Hex Value: 0x0000
00283 - ABS Wheel Speed Sensor; Front Left (G47)
Fault Status: 01101100
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:06:10
Hex Value: 0x0000
Voltage: 11.75 V
Bin. Bits: 00011111
Count: 12
Hex Value: 0x0000
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:06:10
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 EA HW: 5K0 907 044 EA
Component: Climatronic H17 1010
Revision: 00003001
Coding: 0000001002
Shop #: WSC 00015 115 00000
VCID: 6ED839D0B15993325E-803A
13701376 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 6
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:18:21
13701888 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Fault Frequency: 38
Reset counter: 242
Mileage: 79429 km
Date: 2018.01.25
Time: 01:49:10
13701392 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:09
13701968 - Function Restriction due to Faults in Other Modules
U1113 00 [009] - -
Fault Frequency: 55
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:22
13635840 - Supply voltage
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:33
Address 09: Cent. Elect. (J519) Labels: 3AA-937-087.clb
Part No SW: 3AA 937 087 B HW: 3AA 937 087 B
Component: BCM PQ47 H+ 413 0452
Revision: BC413001
Coding: 00000000000000000098022094008024435176884060CD60008046200041
Shop #: WSC 05311 123 12345
VCID: 3972DA8CB097048ABB-806C
Subsystem 1 - Part No SW: 3C8 955 119 D HW: 3C8 955 119 D Labels: 1KX-955-119.CLB
Component: Wischer 11111 10 0603
Coding: 00B795
Component: RLS 091210 05 54 0403
Coding: 0330ED
7 Faults Found:
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:08:15
Term 15 On
Voltage: 7.70 V
00532 - Supply Voltage B+
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:08:15
Term 15 On
Voltage: 7.70 V
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:25
Term 15 On
Voltage: 11.80 V
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:24
Term 15 On
Voltage: 11.85 V
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:24
Term 15 On
Voltage: 11.80 V
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:24
Term 15 On
Voltage: 11.80 V
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:24
Term 15 On
Voltage: 11.80 V
Address 10: Park/Steer Assist (J446) Labels: 3AE-919-475.clb
Part No SW: 3AE 919 475 HW: 7N0 919 475
Component: PARKHILFE 8K H04 0009
Revision: -------- Serial number: 77631034200470
Coding: 108103
ASAM Dataset: EV_EPHVA18VW47X0000 001003
ROD: EV_EPHVA18VW4280000.rod
VCID: 7CFC0398F725F1A2E0-8028
Reset counter: 242
U1400 00 [008] - -
Reset counter: 242
12583168 - Powertrain Databus
U0001 00 [008] - Unspecified Malfunction
Fault Frequency: 17
Reset counter: 242
12658720 - Databus
Reset counter: 242
12648736 - Databus
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.27
Time: 00:38:45
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__305 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PQZT76M
Coding: 0012341
VCID: 4C9C93582F05812210-8018
Subsystem 1 - Serial number: 6332MTS631203200
Subsystem 2 - Serial number: 6342MTS672983190
Subsystem 3 - Serial number: 6351HTS6FVUKH9KJ
Subsystem 4 - Serial number: 6361HTS6NVURH9KJ
01312 - Powertrain Data Bus
Fault Status: 00101110
Fault Frequency: 6
Reset counter: 242
Fault Frequency: 11
Reset counter: 242
Mileage: 78820 km
Date: 2018.11.06
Time: 01:13:11
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BG HW: 5K0 953 569 T
Component: LENKS.MODUL 009 0136
Revision: FF010039 Serial number: 20101212100866
Coding: 0982270000
VCID: 6BDE30C4824B661A79-803E
Component: E221__MFL-TK6 H06 0022
Coding: E20000
7 Faults Found:
0516 - Databus
Fault Frequency: 9
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.27
Time: 00:38:45
114178 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:38
136194 - Supply voltage
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:21
147464 - Terminal 15
B1148 29 [008] - Signal Implausible
Reset counter: 242
Date: 2000.01.01
Time: 00:00:00
335876 - Powertrain Databus
U0002 00 [008] - No Communications
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:09
335886 - Powertrain Databus
Fault Frequency: 9
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:08
365060 - Controls in Steering Wheel
U108E 00 [008] - No Communications
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:02
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3C8 920 870 H HW: 3C8 920 870 H
Component: KOMBI H20 0420
Coding: 140F01
Shop #: WSC 05314 115 00000
VCID: 3064E7A86BEDC5C20C-8064
11 Faults Found:
9453074 - Fuel Level Sensor 1
B103E 1B [008] - Resistance Too High
Fault Frequency: 6
Reset counter: 242
9453330 - Outside temperature sensor
B103F 1B [009] - Resistance Too High
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.27
Time: 00:00:01
9453842 - Oil Level Thermal Sensor
B1041 35 [009] - Signal high time > maximum
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:09:02
12648448 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:18:20
12648704 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 01:04:59
12656896 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:08
12669184 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:08
13638912 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:08
12658688 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Fault Frequency: 16
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:08
12671232 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:09
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:43
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 051210F6000232
Coding: 469006
Shop #: WSC 05314 123 12345
VCID: 3162E2AC68E7CCCA03-8064
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:06:26
03406 - Control Module for Battery Monitoring
Reset counter: 202
Mileage: 79449 km
Date: 2018.01.25
Time: 00:10:53
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0399
Revision: 00043000 Serial number: VWZCZ000000000
VCID: 76E811B00109ABF296-8022
Component: ELV 029 0380
3C0905861J ELV 029 0380
02827 - Wake-Up request via ESP
Fault Status: 00111000
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:52
02812 - Supply Voltage (Terminal 30) for Electronic Steering Column Lock
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:03
Part No SW: 3C8 959 701 HW: 3C0 959 793 C
Component: TUER-SG FT 002 0501
Revision: 12110009 Serial number: 0001883032
Coding: 0010B7
Shop #: WSC 05311 115 00000
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 6DDA3EDCBC5F682A67-8038
Slave Driver:
Subsystem 1 - Part No SW: 3C8 959 703 C HW: 3C0 959 795 B Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0401
Serial number: 00000001786808
Coding: 000090
B11EC 54 [009] - Missing Calibration / Basic Setting
Reset counter: 202
68100 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:18:57
68107 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:09
65793 - Supply voltage
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:13
131329 - Rear Door Control Module
B11ED F0 [008] - Supply Voltage too Low
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:00:41
B11EE 54 [008] - Missing Calibration / Basic Setting
Reset counter: 242
Part No SW: 5N1 909 144 L HW: 5N1 909 148 G
Component: J500__APA-BS KL.303 0802
Revision: 1AH03729 Serial number: 00103400113901
Coding: 0000258
10 Faults Found:
Reset counter: 242
Term 15 On
RPM: 1500 /min
Speed: 50.0 km/h
(no units): 6.0
Voltage: 11.90 V
Reset counter: 232
Mileage: 79292 km
Date: 2018.01.25
Time: 00:04:48
Voltage: 3.80 V
Voltage: 7.80 V
Voltage: 7.80 V
Not Occup.
Not Occup.
01316 - ABS Control Module
Fault Status: 11101101
Fault Frequency: 191
Reset counter: 202
Mileage: 79007 km
Date: 2018.11.06
Time: 00:00:53
Term 15 On
RPM: 910 /min
(no units): 7.0
Voltage: 14.40 V
Reset counter: 232
Mileage: 79292 km
Date: 2018.01.25
Time: 00:04:49
Voltage: 2.00 V
Voltage: 5.40 V
Voltage: 5.40 V
Not Occup.
Not Occup.
Fault Frequency: 6
Reset counter: 242
Mileage: 79427 km
Date: 2018.01.25
Time: 01:01:31
Voltage: 17.90 V
Voltage: 10.40 V
Voltage: 17.90 V
Not Occup.
Not Occup.
Reset counter: 242
Term 15 Off
Speed: 50.0 km/h
(no units): 7.0
Voltage: 12.00 V
Reset counter: 242
Term 15 Off
Speed: 50.0 km/h
(no units): 7.0
Voltage: 12.00 V
Reset counter: 242
(no units): 115
(no units): 115
(no units): 115
(no units): 115
(no units): 115
00576 - Terminal 15
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:10:00
Term 15 On
(no units): 4.0
Voltage: 11.80 V
Fault Status: 00101101
Fault Frequency: 36
Reset counter: 242
Mileage: 79429 km
Date: 2018.01.25
Time: 00:04:32
Term 15 On
RPM: 466 /min
(no units): 7.0
Voltage: 10.70 V
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 043 0631
Coding: 00910A0001860E763604941570084F0B607801
Fault Frequency: 7
Reset counter: 242
Mileage: 79267 km
Date: 2018.01.26
Time: 18:55:08
Fault Status: 00110000
Fault Frequency: 20
Reset counter: 240
Mileage: 79267 km
Date: 2018.01.26
Time: 19:03:21
00625 - Vehicle Speed Signal
Fault Frequency: 7
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:06
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:01:07
Reset counter: 242
Mileage: 79449 km
Date: 2018.01.25
Time: 00:45:57
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H35 0614
Coding: 00000008
VCID: 6FE624D4BE539A3A55-803A
Subsystem 1 - Part No SW: 3AA 919 204 HW: 3AA 919 204
Component: Analoguhr 003 0003
Part No SW: 3C8 959 702 HW: 3C0 959 792 C
Component: TUER-SG BT 002 0501
Revision: 14110009 Serial number: 0001864062
Coding: 0010B6
ROD: EV_TSGBPQ35BRFVW46X.rod
Slave Passenger:
Subsystem 1 - Part No SW: 3C8 959 704 C HW: 3C0 959 794 B Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0401
Serial number: 00000001774906
Coding: 000090
7 Faults Found:
