Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: 0BH DQ500 DSG Basic settings
    Feb 2017
    Any more follow up to this? We just got done with a set of clutches on an RS3 would like to adapt.
  2. #12
    Tartu, Estonia
    Quote Originally Posted by ChrisG View Post
    From me unfortunately no at moment. Transporter went to dealer to get a new gearbox with goodwill.
    I am a VW Freak - Le WV Freaks OR Come visit me at my work with ODIS concerns - FORSS ODIS GeKo/FaZit access for VW/AUDI/koda
    The world is my oyster...
  3. #13
    Oct 2014
    Kenya
    Hello @dana . We have loads of these DQ500 gearboxes equipped on the 2011 onwards Tiguans. What would you need to help you guys ?? Let me know and ill get on it.
  4. #14
    United States
    Hi Naushad,
    Please try NEtech's procedure in post #9.
    Detailed feedback including scans, logs, screen shots, video or similar would be very helpful. Testing on a vehicle that does not have a malfunctioning transmission would be ideal.
    If you are using a HEX-NET or HEX-V2 interface it couldn't hurt to run a complete measuring block function map on address 02 with the engine running at idle and trans in Park before the procedure -and- then again after the procedure. Doing so would allow us to compare the before and after conditions. Maps are explained here: http://www.ross-tech.com/vcds/tour/c...annels-map.php
  5. #15
    Jan 2016
    Botswana
    Confirmed, we don't have a procedure for that unit and the only DQ500 NAR market scan I located in our files was a Canadian TTRS Coupe Quattro 2.5 gasser. I haven't seen any in person but I speculate that's the 2018 US market 7-Speed facelifted Golf R's transmission as well.
    This is NOT the correct procedure but after looking at the ROD files I believe this is worth a shot: http://forums.ross-tech.com/showthre...ll=1#post76381
    Hi all.
    I would like to confirm that this procedure worked for my DQ500 - 0BH transmission. I followed it as suggested and it works great! My 2011 Tiguan transmission was jerky on 1st and 3rd gear. All the other gears were smooth. I might add that immediately after the completion of the basic setting procedure, the car wouldn't move in any gear! I switched the ignition off then on and lo and behold, my Tiguan was back to normal!
    Chassis Type: 5N-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 22 25 42 44 46 52 53 56 62 72
    VIN: WVGZZZ5NZBW079185   Mileage: 111720km-69419miles
    Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
       Part No SW: 06J 906 026 FK    HW: 06J 906 026 DA
       Component: MED17.5             7329
       Revision: AAH18---    Serial number:
       Coding: 0423000C240F0060
       Shop #: WSC 26807 001 1048576
       VCID: 78F909890B3CAC8AE5-802C
    000257 - Mass Air Flow Sensor (G70)
                   P0101 - 000 - Implausible Signal
                        Mileage: 111725 km
                        Date: 2013.10.09
                        Time: 16:14:45
                        RPM: 798 /min
                        Load: 31.8 %
                        Temperature: 98.0°C
                        Temperature: 44.0°C
                        Absolute Pres.: 900.0 mbar
                        Voltage: 13.462 V
    Readiness: 1110 0101
       Part No SW: 0BH 300 011 T    HW: 0BH 927 711 G
       Component: DSG DQ500-7A  H11 1818
       Revision: 00H11V01
       ROD: EV_TCMDQ500021.rod
       VCID: 3363FEA59ADA8FD210-8066
    Address 03: ABS Brakes        Labels: 5N0-614-109-C4.clb
       Part No SW: 5N0 614 109 P    HW: 5N0 614 109 P
       Component: J104    C4 450 V102 0006
       Revision: --H28---    Serial number: 00000003541764
       Coding: 0006468
       Shop #: WSC 01324 020 00200
       VCID: 3879C9894BBC6C8A25-806C
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 2
                        Mileage: 111725 km
                        Date: 2013.10.09
                        Time: 16:14:45
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 13.25 V
                        Bin. Bits: 00011111
                        Count: 237
                        Hex Value: 0x0000
       Part No SW: 5K0 907 044 DT    HW: 5K0 907 044 DT
       Component: Climatronic   H17 1010
       Revision: 00003001
       Coding: 0000001002
       VCID: 000961699BECE44ADD-8054
       Part No SW: 5K0 937 086 J    HW: 5K0 937 086 J
       Component: BCM PQ35 M    011 0046
       Revision: BC011001
       Coding: 40180A3BC82518C000080080B40003A443713088536D89605C8000000040
       VCID: 3B73D685BA8A4792C8-806E
       Subsystem 1 - Part No SW: 5N2 955 119     HW:              Labels: 1KX-955-119.CLB
       Component: Wischer 14121  012 0203
       Serial number: N2955119   °203!
       Coding: 009795
       Component: RLS 161210 05  54  0403
       Coding: 07304D
       Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
       Component: J234__201 VW10 HI   1918
       Revision: 22014000    Serial number: 003K0PRCHAZK
       Coding: 0012337
       VCID: 4C9185592F24F02A71-8018
       Subsystem 1 - Serial number: 6332MTS605713330
       Subsystem 2 - Serial number: 6342MTS616593340
       Subsystem 3 - Serial number: 6351HTS6P6AKI9KJ
       Subsystem 4 - Serial number: 6361HTS61P9KI9KR
       Part No SW: 5K0 953 521 AR    HW: 5K0 953 569 A
       Component: LENKS.MODUL   009 0136
       Revision: FF010039    Serial number: 20101215200934
       Coding: 1882040000
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 7CF11599F70480AA81-8028
       Component: E221__MFL-TAS  H07 0013
       Coding: 820000
       Part No SW: 5N0 920 872     HW: 5N0 920 872
       Component: KOMBI         H20 0420
       Coding: 110F00
       VCID: 6FEB32D5B672EB3234-803A
       Part No SW: 7N0 907 530 C    HW: 1K0 907 951
       Component: J533  Gateway H37 0614
       Revision:   H37       Serial number: 141210F1002571
       Coding: 356003
       VCID: 3069F1A963CCB4CA6D-8064
       Part No SW: 0AY 907 554 D    HW: 0AY 907 554 D
       Component: Haldex 4Motion      0042
       Coding: 0000005
       Component: IMMO          H20 0420
       VCID: 6ADD23C18D900E1A63-803E
       Part No SW: 5N0 959 701 E    HW: 5N0 959 701 E
       Component: Tuer-SG         009 2112
       Coding: 0004790
       VCID: 377BCAB546A263F22C-8062
       Part No: 5N0 909 144 M
       Component: EPS_ZFLS Kl. 202    3201
       Revision: 00H20000
       Shop #: WSC 01324 785 00200
       VCID: 3B73D6857A8A4792C8-806E
       Part No SW: 5N0 959 702 E    HW: 5N0 959 702 E
       Coding: 0005046
       Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
       Component: J540 EPB4  VW-55183 0007
       Revision:   H18       Serial number: 00000000093209
       Coding: 0023057
       VCID: 3363FEA552DA8FD210-8066
       Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 01000000    Serial number: VWZ1Z2K8576115
       Coding: 0500040004
       VCID: 6BD326C58A6A171218-803E
       Part No SW: 5N0 959 703 D    HW: 5N0 959 703 D
       Component: Tuer-SG         007 2102
       Coding: 0000144
       Shop #: WSC 01324 020 1012552
       Part No SW: 5N0 959 704 D    HW: 5N0 959 704 D
       Coding: 0000144
       VCID: 397FCC8D70B67582DA-806C
    End-------------------------(Elapsed Time: 02:46)--------------------------
