Page 3 of 3 FirstFirst 123
Results 21 to 21 of 21
Thread: 2017 Tiguan Limited (Old Mk6 body style) 2.0T CCTA
  1. #21
    Apr 2017
    Dana,
    Sorry to hear about your the water leaking Alltrack - seems it is inevitable that new models/body styles always come with unexpected issues. Hopefully, the next year model will be better.
    Not sure if you upgraded to a 2018/2019 Alltrack yet, but I too ended up getting a 2017 Tiguan Limited for my wife - ours is a 2WD version though.
    Anyway, as soon as we got the Tig, I went to work with my VCDS and got a few nice features activated.
    One of the most recent mods I attempted, was to add doors puddle lights and door ambient lights. I have a 2-door 2013 GTI and did that without a problem. I also did that mod on my brother's 4-door 2014 GTI - took a while to figure out the rear doors ambient lighting, but thanks to a fellow Ross-Tech member we got that figured out.
    So, I thought it would be easy-peasy to do this mod to my wife's new Tig... I installed all the parts (puddle lights and ambient LED's), and then tried to activate these features in VCDS. The front doors were not a problem (mirror puddle lights, door panel puddle lights and ambient lights). However, the rear door modules are not accessible via VCDS (even though they seem to show up and all door functions seem to work just fine.
    A many few forums searches later (and visit to Ross-tech website), it turns out this is all normal with Gen4 door modules (which our Tig comes with). However, for the life of me I can't seem to find directions on how to adjust coding for the "slave" rear door modules. Even on your site, I saw a note that says there should be more explanations for this on the Gen4 site, but can't seem to find it.
    Anyway, could you please help with this?
    Below is a scan from the Tig, after all the various mods made, but before I activated the various lighting features for the front doors. I'm out of town at the moment, and can't run a new scan right this moment, but I can provide that if needed. I'm hoping is just a manner of adding a certain decimal value to the front door modules to enable the rear doors puddle + ambient lighting, but not sure...
    One more item I would love to do is activate (though not as big a deal as the rear doors lighting features), is the amber rear turn signals (instead of the red blinking). The lens are there, the bulbs are there, and I'm hoping the wiring harness is there, and it is a matter of coding only - not afraid of wiring things up, but can't imagine VW developed a whole new wiring harness just for NAR vehicles (to eliminate the amber blinkers), yet didn't spend the time/money to revise the rear lens themselves....
    I tried different suggestions from forums and almost screwed up my lights functionality (I got it fixed thanks to one of Uwe's post), so I dropped the pursuit for changing the blinkers. However, if you have a tip on how to do this, I'd love to try it out.
    Anyway, here is the scan and details of the mods made (just in case):
    • XDS – Enabled
    • Automatic Transmission – Change from Tiguan NAR(00000483) to Tiguan RoW (0000) – to add gear position in MFD
    • Comfort Opening For Sliding Roof – inactive
    • Comfort Closing For Sliding Roof – inactive
    • Comfort Operation via Remote
    • Comfort Operation via Lock/Unlock Button independent of Term 15/Ignition
    • Horn Lock Confirmation – disabled
    • Rear Fog Lights Inactive while Trailer Attached – deactivated
    • DRL Active/Inactive Enabled
    • Coming Home Enabled
    • Coming Home Mode – Manual
    • DRL Inactive with Turn Signal
    • DRL via separate Lights – inactive
    • DRL via Parking Lights - active
    • DRL Adaptation (MFA+) - active
    • Parking Lights Off with Term S Off and Light Switch at Low Beam
    • Emergency Brake Flashing via Turn Signal Lights Active
    • License Plate Light w/o PWM – LED Light
    • Central Electronics - Byte 18 / Bit 00 to Bit AD (2014 Tig SE - Uwe) – To reset lights to NAR Std
    • Interior Light via Rear Lid Hatch – Deactivated
    • Tear Drop Wiping for Rear
    • Instrumentation Celebration – active
    • Instrumentation Country – Canada (instead of USA) – activate different chimes for seatbelt, door ajar, etc.
    With Error Codes Cleared:
    With Some Error Codes after trip to Toronto – Parking Brake Error Light Came On in MFD and car had to be restarted to go back to normal
    Saturday,14,July,2018,16:22:24:39032
    VCDS Version: 18.2.1.2 (x64)
    VIN: WVGAV7AX2HK051280   License Plate:
    Chassis Type: AX-VW36 (7N0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4C 52 53 5F 62 72
    VIN: WVGAV7AX2HK051280   Mileage: 4340km-2696miles
    Address 01: Engine (CCT)       Labels: None
       Part No SW: 06J 906 027 KA    HW: 06J 907 309 A
       Component: MED17.5.2 TFSI 2 07 3230
       Revision: P3H08---    Serial number:
       Coding: 0423010A19070060
       Shop #: WSC 00040 028 00001
       VCID: 74C9073E172357E433-8020
       Part No SW: 09G 927 750 PP    HW: 09G 927 750 PP
       Component: AQ 250 6F           3435
       Revision: 00H97000    Serial number:
       Coding: 0000328
       VCID: 0E3D75D619CF1D34A5-805A
    Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
       Part No SW: 5N0 614 109 CN    HW: 5N0 614 109 CN
       Component: J104   C6 450M VD30 0023
       Revision: --H07---    Serial number: 00000009304224
       Coding: 0005158
       VCID: 79D7360A30412A8C60-802C
                        Fault Frequency: 7
                        Reset counter: 48
                        Mileage: 3518 km
                        Date: 2018.07.13
                        Time: 17:36:52
                        Speed: 111.0 km/h
                        Hex Value: 0x0100
                        Bin. Bits: 00000000 00000000
                        Voltage: 13.75 V
                        Bin. Bits: 00011111
                        Count: 251
                        Hex Value: 0x0008
       Part No SW: 561 907 426 F    HW: 561 907 426 F
       Component: AC Manuell    H03 0506
       Revision: 00001K03
       Coding: 0010001002
       Shop #: WSC 00040 028 00009
       ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
       ROD: EV_ACManuaElectGen2BHTC_VW36.rod
       VCID: 1E1D0596012FADB435-804A
       Part No SW: 5K0 937 084 N    HW: 5K0 937 084 N
       Component: BCM PQ35 B    122 0186
       Revision: BG122001
       Coding: EF1A0AB880212EC4000800C1150000E84C81AD86505D8960648020000040
       VCID: 3D5FE21AA4E9D6AC0C-8068
       Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
       Component: WWS316 260717  24  0664
       Coding: 009795
                000 -  -  - Intermittent
                        Reset counter: 64
                        Mileage: 657 km
                        Date: 2018.06.27
                        Time: 22:52:27
                        Voltage: 14.25 V
       Part No SW: 5N0 959 655 AB    HW: 5N0 959 655 AB
       Component: J234__005 VW10 HI   5418
       Revision: 36023000    Serial number: 003MAPHK528Q
       Coding: 0012341
       VCID: 7DDF221A246916AC4C-8028
       Subsystem 1 - Part No: 5N0 959 339 B
       Subsystem 2 - Serial number: 0000000000V9T8
       Subsystem 3 - Serial number: 0020.04.170000300000650005˙† 63
       Subsystem 4 - Serial number: 650005˙† 6332MTS607022157.˙† 63
       Subsystem 5 - Serial number: 22157.˙† 6342MTS610372157/˙† 63
       Subsystem 6 - Serial number: 72157/˙† 6351HTS6IPG1OEKRP˙† 63
       Subsystem 7 - Serial number: 1OEKRP˙† 6361HTS6G602OEKJP˙† 63
       Subsystem 8 - Serial number: 2OEKJP˙† 63727TS6S26LPEKJ8˙† 63
       Subsystem 9 - Serial number: LPEKJ8˙† 63827TS6QA0LPEKRH˙
       Subsystem 10 - Serial number: LPEKRH˙
       Part No SW: 5K0 953 501 CL    HW: 5K0 953 569 AJ
       Revision: FF010042    Serial number: 20170831300672
       Coding: 5980040000
       VCID: 76CD3D36C95F45F40D-8022
       Part No SW: 5N0 920 973 M    HW: 5N0 920 973 M
       Component: KOMBI         H02 1104
       Coding: 321F010000
       Shop #: WSC 00040 028 00058
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
       VCID: 3E5DE516A1EFCDB415-806A
       Part No SW: 7N0 907 530 BH    HW: 7N0 907 530 AK
       Component: J533  Gateway H57 1682
       Revision:   H57       Serial number: 170817F1000283
       Coding: 356022
       VCID: 77D33032C6553CFC16-8022
       Component: IMMO          H02 1104
       VCID: 6AF519468DE7911499-803E
       Part No SW: 5N0 959 701 H    HW: 3C0 959 793 H
       Component: TUER-SG FT    002 0601
       Revision: 13100010    Serial number: 0011018423
       Coding: 0004B4
       ASAM Dataset: EV_TSGFPQ35BRFVW46X A04004
       VCID: 3A55E906BDC7E19429-806E
       Slave Driver:
       Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  010 1505
       Serial number: 00000009900480
       Coding: 000490
       Part No SW: 5N1 909 144 S    HW: 5N1 909 148 K
       Component: J500__APA-BS KL.285 1501
       Revision: 1BH04843    Serial number: 00172010031301
       Coding: 0000258
       VCID: 42A591E61D17A95471-8016
       Part No SW: 5N0 959 702 H    HW: 3C0 959 792 H
       Component: TUER-SG BT    002 0601
       Revision: 15100010    Serial number: 0011018901
       Coding: 0004B4
       ASAM Dataset: EV_TSGBPQ35BRFVW46X A04004
       VCID: 3B5BEC02B2FDD89C32-806E
       Slave Passenger:
       Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  010 1505
       Serial number: 00000009902269
       Coding: 000490
       Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
       Component: J540 EPB4  VW-63206 0012
       Revision:   H21       Serial number: 00000000038914
       Coding: 0026156
       VCID: 3851F30E4BCBF384DF-806C
                        Fault Status: 00110001
                        Reset counter: 88
                        Mileage: 3403 km
                        Date: 2018.07.13
                        Time: 14:28:45
                        Voltage: 13.90 V
                        Count: 38
                        Speed: 118.0 km/h
                        Hex Value: 0x1260
                        Hex Value: 0x0004
                        Hex Value: 0x0101
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-ENT2.clb
       Part No SW: 561 035 150 B    HW: 561 035 150 B
       Component: MU-E--ER      056 7227
       Serial number: 10071700010291
       Coding: 02130600FF00000041220001001000009F0000140000010000
       ASAM Dataset: EV_MUEnt4CGen2LGE 001032
       ROD: EV_MUEnt4CGen2LGE_VW12.rod
       VCID: 0C397FDEA7D32F244B-8058
    End-------------------------(Elapsed Time: 01:50)--------------------------
    Edit by Dana: We moved the discussion to this thread: https://forums.ross-tech.com/showthr...uddle-Lighting
    Last edited by Dana; 04-08-2019 at 05:00 PM. Reason: CODE tags and new thread link
