I was trying to change the set up of lights. In my beetle 2012 I have DRL on while driving. Tail lights are off. I woul like to have tail lights on.
I went to 09 central electronics. I choosed long coding helper. There was row 3 active and I was looking something like "DRL s via tail lets active.
I don*t find anything like that.
From where those tail lights are possible to "click" on= how I change the coding?
VCDS Version: Release 12.12.3 (x64)
Data version: 20140905
Wednesday,24,September,2014,20:00:14:33791
Chassis Type: 16 (6R0)
Scan: 01 03 08 09 15 17 19 25 44 55 56
VIN: WVWZZZ16ZCM638147
Address 01: Engine (J623-CBZB) Labels: 03F-906-070-CBZ.clb
Part No SW: 03F 906 070 JD HW: 03F 907 309 R
Component: SIMOS10.12AH10 2663
Revision: --H10--- Serial number: 00000000000000
Coding: 001900D6232400080000
Shop #: WSC 00066 000 00070
ASAM Dataset: EV_ECM12TFS02103F906070JD 004004
ROD: EV_ECM12TFS02103F906070AB.rod
VCID: 6DDAC3AFBC12017640B-8038
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 5C0 907 379 C HW: 5C0 907 379 C
Component: ESP MK60EC1 H31 0156
Revision: 00H31001
Coding: E13B20F809250002870C04E890200040211000
VCID: 2E5804A37994BA6E391-807B
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AL HW: 5C0 820 047 AL
Component: J301 Klimaanlage 0203
Revision: 2001109S Serial number: 00000000812805
VCID: 6AD0C8B345FC164E259-803F
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 6R0 937 088 F HW: 6R0 937 088
Component: BCM PQ25 Re4 H50 0352
Revision: BU050001 Serial number: 04571066120150
Coding: 6CB869380801080001A809912E0F86C4F8C2672F60011841B20004010000
VCID: 41824F1FD80A3516D43-8014
Subsystem 1 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 020212 05 54 0403
Coding: 02300A
Subsystem 2 - Part No SW: 5C5 959 801 D HW: 5C5 959 801 D
Component: J386__TSG_FT C08 9430
Coding: 080000
Subsystem 3 - Part No SW: 5C5 959 802 F HW: 5C5 959 802 F
Component: J387__TSG_BT C08 9430
Coding: 080000
Subsystem 4 - Part No SW: 5C0 959 442 HW: 5C0 959 442
Component: E221__MFL-TK6 H02 0103
Coding: E20000
Part No SW: 5C0 959 655 F HW: 5C0 959 655 F
Component: AirbagVW10 013 0613
Serial number: 003JQM0096CB
Coding: 0000424B
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 356A2BCF94C289B678B-8060
Subsystem 1 - Part No SW: 5K0 959 354 HW: 5K0 959 354
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME6446526AZZZ-
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME5972526AZZZ/
Part No SW: 5C5 920 870 HW: 5C5 920 870
Component: KOMBI H13 0016
Revision: X0013004 Serial number:
Coding: 150B00
Shop #: WSC 00066 000 00126
ASAM Dataset: EV_KombiUDSMM9RM10 A04305
ROD: EV_KombiUDSMM9RM10_SE12.rod
VCID: E7D631871EEEAB26BA7-80B2
Address 19: CAN Gateway (J533) Labels: 6R0-907-530-V2.clb
Part No SW: 6R0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H38 0035
Revision: H38 Serial number: 12031201300366
Coding: 254080
VCID: 346C16CB97B890BE4F5-8061
Part No SW: 5K0 953 234 HW: 5C5 920 870
Component: IMMO H13 0016
ASAM Dataset: EV_ImmoUDSMM9RM10 A01301
ROD: EV_ImmoUDSMM9RM10_SE36.rod
VCID: EAD048B30DFC964EA59-80BF
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 68 3305
Revision: 00H22000
VCID: 377621C746CE7BA66A7-8062
Address 55: Xenon Range (J431) Labels: 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Coding: 0312000001000000
ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
ROD: EV_HeadlRegulVWLWRPt.rod
VCID: F7F661C74E4E3BA62A7-80A2
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 042 0082
Revision: 01000001 Serial number: VWZ1Z2M4247262
Coding: 05000400040002
VCID: 72E0D0D3AD2CDE8E9D9-8027
End ---------------------------------------------------------------------
