- Joined
- Mar 9, 2015
- Messages
- 475
- Reaction score
- 336
- Location
- Australia
- VCDS Serial number
- C?ID=241363
Hi All,
For whatever perverse marketing reasons, VW (at least here in Australia, not sure about other markets) offers the Tiguan in 3 trim levels all with front assist and city emergency brake.
Not too sure how this is done across the rest of the model range yet.
Therefor they are equipped with an A5 camera module and 13 auto distance radar as well as the appropriate ABS module.
However ACC is part of an additional package known as the Driver Assistance Package that also includes side assist.
So whilst all the requisite hardware is there for ACC, it cannot be enabled by simply coding the modules correctly.
VW have chosen to lock the feature using Feature Enable Codes, and will not offer to enable ACC as a SoftWare as A Product upgrade.
Thankfully Don Wang from this forum has been able to assist me.
Yesterday we activated ACC on 2 Tiguans, one a Comfortline TSI and another an RLine TDI.
What is required in order to perform the retrofit is a brand new ("virgin") Canbus gateway module and front radar module.
In our case we used the exact same ADR part number, but used a newer 5Q0 gateway in place of his original 3Q0 gateway.
You can't just add the FEC to the existing factory modules.
Also need to replace the steering wheel button set with the new ACC version.
Don is then able to add the brand new modules one at a time using that VW online software which shall not be mentioned, clear CP and perform the coding required.
Perform G85 and 13 ADR calibrations and away you go.
Thank you Don!!!
Here is an autoscan of the Rline after ACC has been activated and everything is calibrated and working:
Thank you Don!!!
Friday,19,January,2018,00:38:34:58930
VCDS Version: 17.12.0.1 (x64) HEX-V2 CB: 0.4411.4
Data version: 20171213 DS285.1
VIN: WVGZZZ5NZHW3 License Plate:
Mileage: 6348km-3944mi Repair Order:
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 29 2B 36 39 42 44
4B 52 5F 6C 6D A5 BB BC CA D6 D7
VIN: WVGZZZ5NZHW3 Mileage: 6348km-3944miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-DFHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 EJ HW: 04L 907 309 P
Component: R4 2.0l TDI H24 3661
Revision: B4H24---
Coding: 0125003204671D083000
Shop #: WSC 52104 002 1048576
ASAM Dataset: EV_ECM20TDI01104L906026EJ 004003
ROD: EV_ECM20TDI01104L906026EJ_004.rod
VCID: 76B51813C8495E91B55E-8022
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0DL 300 011 N HW: 0GC 927 711 G
Component: GSG DQ500 H06 2001
Revision: 00H06V07
VCID: 3333E1079BBB0BB952C0-8066
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CG HW: 5Q0 614 517 AG
Component: ESC H62 0643
Revision: 00000000 Serial number: 63216000002448
Coding: 0AEE939A54270B704779070462C34950C92AD0E2E046927D386250B8C22A4200002F641A1B13111435351919323200
ROD: EV_Brake1UDSContiMK100IPB_036.rod
VCID: 78A9162BC25D28E1A772-802C
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0422762018
Coding: 032C2C070F
ROD: EV_KessyHellaMQBAB.rod
VCID: 3C21CA3BB6E5C4C1839A-8068
Subsystem 1 - Part No SW: 3G0 962 243 A HW: 3G0 962 243 A
Component: GEB.F.Heckoef H17 0903
Serial number: 98100182
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 5NA 907 044 G HW: 5NA 907 044 G
Component: AC Automat H35 4101
Revision: 20K08000 Serial number: 00000B00307409
Coding: 0012012420010000110510001210142A
ASAM Dataset: EV_ACClimaPrehVW37X 002019
ROD: EV_ACClimaPrehVW37X_002_VW37.rod
VCID: 43D3B1C7CB1BBB39C260-8016
Subsystem 2 - Part No SW: 3G0 907 049 D HW: 3G0 907 049 D
Component: E265KlimaHeck H02 0201
Serial number: 04031501850571
Part No SW: 5Q0 937 084 CG HW: 5Q0 937 084 CG
Component: BCM MQBAB H H34 0236
Serial number: 02001632000959
ROD: EV_BCMBOSCH_017.rod
VCID: 7F5BFD37E7731FD9E638-802A
Subsystem 1 - Part No SW: 5NC 955 119 HW: 5NC 955 119 Labels: 1KX-955-119.CLB
Component: 326 RL 160922 033 0372
Serial number: 00000001609200301956
Subsystem 2 - Part No SW: 5Q0 955 547 B HW: 5Q0 955 547 B Labels: 5Q0-955-547.CLB
Component: RLHS 042 0105
Serial number: S5Y16M11D22H08M10S38
Coding: 06A8DD
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 3Q0 919 298 A HW: 3Q0 919 298
Component: PLA 3.0 12K H09 0021
Serial number: 001907167478000
Coding: 0331563051
ASAM Dataset: EV_EPHBO2CVW3260000 010016
ROD: EV_EPHBO2CVW3260000.rod
VCID: 3B23C927B3EBC3F98A90-806E
Address 13: Auto Dist. Reg (J428) Labels:| 2Q0-907-572.clb
Part No SW: 2Q0 907 572 H HW: 2Q0 907 572 B
Component: ACCCONTIMQB H01 0155
Coding: 320147C15CFF8428749C8065303087
Shop #: WSC 00070 123 104857
ASAM Dataset: EV_ACCMRRCONTIVW376 001010
ROD: EV_ACCMRRCONTIVW376_001.rod
VCID: 392FD32FB9D7F1E998FC-806C
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 19101641350033
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 3829D62B82DDE8E167F2-806C
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR2C2AX2
Coding: 98CCC0C00C0000005C540000008800000065
VCID: 10794E8BCAED10A10F62-8044
Subsystem 1 - Part No SW: ----------- HW: 480 001 711 16
Serial number: 357000000002A37CEF1-
Subsystem 2 - Part No SW: ----------- HW: 480 001 711 16
Serial number: 35800000000F737CEF14
Subsystem 3 - Part No SW: ----------- HW: 480 401 811 16
Serial number: 3510001BB2303C81F2C4
Subsystem 4 - Part No SW: ----------- HW: 480 401 811 16
Serial number: 3520001BB2303C84F453
Subsystem 5 - Part No SW: ----------- HW: 480 401 411 16
Component: FrontSensor_D 000 6149
Serial number: 3550001C523B3B51C3C8
Pedestrian Protection Driver:
Subsystem 6 - Part No SW: ----------- HW: 480 402 111 16
Component: PedP_Sensor_D 000 6149
Serial number: 2280001C522F9761C334
Subsystem 7 - Part No SW: ----------- HW: 480 402 111 16
Component: PedP_Sensor_P 000 6149
Serial number: 2290001A922F9765C2FM
Pedestrian Protection Center:
Subsystem 8 - Part No SW: ----------- HW: 480 402 111 16
Component: PedP_Sensor_C 000 6149
Serial number: 2300001C522F976125C+
Subsystem 9 - Part No SW: ----------- HW: 480 001 411 16
Component: PedPSensor_D2 001 0887
Serial number: I0M0000000024B094F10
Subsystem 10 - Part No SW: ----------- HW: 480 001 411 16
Component: PedPSensor_P2 001 0887
Serial number: I0N00000000FE2716F1G
Address 16: Steering wheel (J524) Labels:| 5Q0-953-549.clb
Part No SW: 3Q0 953 521 DM HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20161122200788
Coding: 0C10
ASAM Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 7EA50033E07916D1ED2E-802A
Part No SW: 5NA 920 751 A HW: 5NA 920 751 A
Component: KOMBI 309 8311
Coding: 27A500187F84000801886B031401000000000000
VCID: 3D27C73FADFFCDC9B4A4-8068
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 02081610000651
Coding: 030500047F085900FB07225E1E0F00010001050100000000000000000000
Shop #: WSC 19460 666 12345
ROD: EV_GatewConti_013_VW37.rod
VCID: 7CA10A3BF66504C1C31A-8028
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29160000260380076054
Coding: 2C0000
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 7226062104
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00026.10.16
Coding: 0101
VCID: 4ACD9CE3EC316A710126-801E
Address 29: Left Light (J1018) Labels: 8V0-907-399.clb
Part No SW: 8V0 907 399 B HW: 8V0 907 399 B
Component: LCM_MLBevoH07 0014
VCID: 45D7AFDFC52F8509EC74-8010
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000255273007
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BF2B0FA12779A960AC-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0020
Serial number: Y0006PJS16792
Coding: 0014000000000500018281808181000000008181000000F400
ROD: EV_SeatMemorDriveSide_002_VW48.rod
Address 39: Right Light (J1023) Labels: 8V0-907-399.clb
Component: TSG FS 020 0041
Serial number: 041116EK418066
Coding: 003F1B20D201040000000000
Part No SW: 5QF 909 144 HW: 5QF 909 144 _
Component: EPS_MQB_ZFLS 506 5572
Coding: 9307
ROD: EV_SteerAssisMQB_013.rod
VCID: 074B65D7BFA35719DE88-8052
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 001 0285
Serial number: 09111610801415
Coding: 000000050100085607000F010A0000000000000000000000000000000000
VCID: 72BD2403A42142B199B6-8026
Component: TSG BFS 020 0041
Serial number: 251016EJP11281
Coding: 003F1120DE01040000000000
VCID: 42DDB4C3D401B231C956-8016
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 045 D HW: 3G0 035 045
Component: MU-H-N-RW H51 0814
Serial number: A688K0G2509427
Coding: 02730608FF00000051510001000808001F0106C601200100DF
VCID: 1F1B1DB70733BFD986F8-804A
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL05350
Subsystem 2 - Part No SW: V03 959 801 EC HW: -----------
Component: ROW 2017 --- 0062
Subsystem 3 - Part No SW: V03 959 800 EG HW: -----------
Component: Gracenote2--- --- 4009
Address 6C: Back-up Cam. (J772) Labels:| 5Q0-980-556.clb
Part No SW: 5Q0 980 556 B HW: 5Q0 980 556 B
Component: RVC Compact H12 0231
Coding: 0123060122002017000040
ROD: EV_CamSysRVRVCPANAMQBAB.rod
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 M HW: 5Q0 959 107 C
Component: HDSG-Modul H12 0261
Revision: -------- Serial number: 30963136400000
Coding: 0A28
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H06 0271
Serial number: 22111611P20670
Coding: 000307060000010100022344C150A90094000E230020
Shop #: WSC 40543 002 104857
ROD: EV_MFKBoschMQBB_VW27.rod
Part No SW: 5Q0 959 595 E HW: 5Q0 959 595 B
Component: TSG HFS 020 0041
Serial number: 081116EK711655
Coding: 002A11200100040000000000
Component: TSG HBFS 020 0041
Serial number: 081116EK714274
Address CA: Sunroof (J245) Labels:| 4M0-907-594.clb
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Coding: 108040732602
ROD: EV_SunRoofCONTIAU736.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7PP-941-572.clb
Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A
Component: LED1L H09 0003
VCID: 16753893E809FE91551E-8042
Address D7: Light Ctrl Right 2 (A27) Labels: 7PP-941-572.clb
Component: LED1R H09 0003
ROD: EV_LEDModLeftMELCOAU736_VW48.rod
End----------(Elapsed Time: 02:10, VBatt start/end: 12.4V/12.4V)-----------
