Results 1 to 8 of 8
Thread: First Post - 2010 VW Touareg TDI Bluetooth issues
    Oct 2017
    Canada
    Angry First Post - 2010 VW Touareg TDI Bluetooth issues
    ok I am going to try to put as much information as possible
    I purchased a 2010 VW Touareg Canadian version tdi..it came with Bluetooth (9w3 unit with the delta radio (no nav)) and was working fine...i decided to have a buddy install the aftermarket nav android radio
    He had this great idea of using the stock mic, so he pulled my stock radio out, pulled the 2 mic wires from the green harness and connected them to a mini plug to us with the android unit..this did not work
    I decided I did not like the android unit after using it and went back to stock...now my Bluetooth works except they cannot hear me from the speakers and voice control no longer works
    Here is what I have done
    1) checked the coding on the radio and Bluetooth unit (which I didn't need to)
    2) disconnected the Bluetooth unit from under the passenger seat to reset it
    3) disconnected the amp in the trunk to reset it
    4) I have reset the main battery to reset everything
    5) I replaced the mic with a brand new oem one
    6) I have purchased a new 9w7 unit and tried that
    7) Took it to VW and their testing (after ($118 CDN)) is that the Bluetooth unit is bad and a 9w7 will not work in my car (I have full red cluster) so another 9w3 will be needed
    8) I have purchased a used working 9w3 out of the same year and tried that
    9) tried different phones to see if it was my samsung s7
    All these did not work, no voice controls and no audio(call sound) from the speakers but they can hear me and everything else is working...radio work fine, its only the Bluetooth call sound
    I checked the coding on the new 9w3 and its 4077
    no errors on the Bluetooth unit, sound system or radio
    running out of options on what to check and fix
    any help is greatly appreciated.
    i have purchased VCDS and can provide scans and whatever else is needed
    not sure what else to look at now
    thank you
    Let's start with an Auto-Scan.
    Oct 2017
    Canada
    Chassis Type: A9 (6N0)
    Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 36 46 47 55 56 68 69
              6D 6E 76 77
    68-Wiper Electr. -- Status: OK 0000
    6E-Ctrl Head Roof -- Status: OK 0000
    Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
       Part No SW: 7L0 907 401 T    HW: 7L0 907 401 K
       Component: 3.0TDI EDC17G004AG  0090
       Revision: 33H02---    Serial number:
       Coding: 0421002A590F0968
       Shop #: WSC 31414 790 00001
       VCID: 3C21CA5ADA7FA437472-5160
       Part No SW: 09D 927 750 LD    HW: 09D 927 750 LD
       Component: AL 750 6A           1667
       Revision: 00H89000    Serial number:
       Coding: 0004984
       VCID: 7BA309469FF1630F0E8-5160
    Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
       Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
       Component: ESP ALLRAD MK25E1   0304
       Revision: 00H53001
       Coding: 0004354
       VCID: 46D5A8B294E3EEE7216-8012
    Address 05: Acc/Start Auth.        Labels: None
       Part No SW: 7L0 909 135 C    HW: 7L0 909 135 C
       Component:    Kessy            6850
       Revision: 00H22072    Serial number: VWX3Z0J2911891
       Coding: 0000232
       VCID: 313FEB6E0D6D595FE44-8064
    Address 08: Auto HVAC        Labels: 7L6-907-040.clb
       Part No: 7L6 907 040 AL
       Component: CLIMAtronic R/L     4537
       Coding: 0003030
       VCID: 7AAD0C42909B5A0715E-802E
    Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
       Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
       Component: J519                2004
       Revision: -0004---    Serial number: --------------
       Coding: 230008002F00BC000000000000000000
       VCID: 00597EAAF64700D75BA-8054
       Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
       Component: SDAR SIRIUS     H07 0160
       Revision: 00000000    Serial number: AUZ4Z7K0572097
       Coding: 0000102
       VCID: 3635D872E4437E67B16-8062
                        Reset counter: 24
                        Mileage: 164800 km
                        Date: 2018.01.06
                        Time: 12:09:19
    Address 15: Airbags        Labels: 7L0-959-655.lbl
       Part No SW: 7L0 959 655 A    HW: 7L0 959 655 A
       Component: J234__0B VW8T       0270
       Revision: 92013027    Serial number: 003C6001FTK0
       Coding: 0012354
       VCID: 3B23C946DF21A30F4E8-806E
       Part No: 7L6 953 549 G
       Component: J527                3601
       Coding: 0010211
       VCID: 43D3B1A6A7D1DBCF068-8016
    Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
       Part No SW: 7L6 920 876 B    HW: 7L6 920 876 B
       Component: J285 KOMBI-INST.    9833
       Revision: KHH05V44
       Coding: 0007301
       Shop #: WSC 39254 002 104857
       VCID: 3B23C946DF61A30F4E8-806E
                        Reset counter: 67
                        Mileage: 165666 km
                        Date: 2018.01.17
                        Time: 21:11:23
    Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
       Part No SW: 6N0 909 901     HW: 7L6 920 876 B
       Component: J533  GW-K-CAN TP20 9833
       Coding: 77E2EF9BE3066002
       VCID: 70B92E6AC6A71057ABA-8024
                        Reset counter: 67
                        Mileage: 165666 km
                        Date: 2018.01.17
                        Time: 21:11:23
    Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
       Part No SW: 7L6 919 879 B    HW: 7L6 919 879 B
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1439802T1EHZ02
       VCID: 46D5A8B294A3EEE7216-8012
       Part No: 0AD 927 755 BG
       Component: TRANSFERCASE        0126
       VCID: 015F7BAEFD1D09DF544-5160
       Part No: 7L0 959 760
       Component: Sitzverstellung     0702
       VCID: 77AB1576A389476F6A0-8022
       Part No: 7L6 959 933 A
       Component: 4M HSG              0601
       Coding: 0000085
       VCID: 40D9BEAAB697C0D71BA-4B1E
       Subsystem 1 - Part No: 7L0 959 701 N
       Component: Tuersteuergeraet FS 6304
       Subsystem 2 - Part No: 7L0 959 702 N
       Component: Tuersteuergeraet BF 6304
       Subsystem 3 - Part No: 7L0 959 703 C
       Subsystem 4 - Part No: 7L0 959 704 C
    Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
       Part No SW: 7L6 035 456 B    HW: 7L6 035 456 B
       Component: 08K Audioverst.     0008
       Revision: 00006000    Serial number: 00000008156215
       VCID: 323DE462082B62479DE-8066
    Address 55: Headlight Range        Labels: 7L6-907-357-A.lbl
       Part No SW: 7L6 907 357 C    HW: 7L6 907 357 C
       Component: AFS-Steuergeraet    0143
       Coding: 1290435
       Coding: 00000019
       Coding: 00000019
    Address 56: Radio        Labels: 7L6-035-180-56.lbl
       Part No SW: 7L6 035 180 C    HW: 7L6 035 180 C
       Component: Radio DE2           0008
       Revision: 00007000    Serial number: VWZ4Z4K7330545
       Coding: 0003000
       VCID: 2D07F71E11153DBFC0C-8078
    Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
       Part No: 7L6 955 119 B
       Component: J400__ Front Wiper  5301
       Coding: 0001397
       VCID: 392FD34ED55D911F5C4-806C
       Component: RLS     130210 054  0403
       Coding: 00208941
       Shop #: WSC 31414
    Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
       Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
       Component: J345  Anhaenger     0080
       Revision: 4A008002    Serial number: 00000126144967
       Coding: 0016386
       VCID: 3FDBBD56CB39BF2F620-806A
    Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
       Part No SW: 7L6 959 107 B    HW: 7L6 959 107 B
       Component: J605  HECKKLAPPE    1310
       Revision: --H05---    Serial number: --------051983
       Coding: 0122110
       VCID: 3A2DCC42D01B9A0755E-806E
    Address 6E: Ctrl Head Roof        Labels: None
       Part No SW: 7L6 919 044 AD    HW: 7L6 919 044 AD
       Component: J702  Dachdisplay   0401
       Revision: 1030006S    Serial number: 00000000155342
       VCID: 79AF134E95DD511F1C4-802C
       Part No: 7L0 919 283 F
       Component: 0L Einparkhilfe     1108
       VCID: 392FD34ED51D911F5C4-806C
    Address 77: Telephone        Labels: 5P0-862-335.lbl
       Part No SW: 1Z0 035 729 E    HW: 1Z0 035 729 E
       Component: FSE_2P8x        H40 0190
       Revision: 00000000    Serial number: 00000005243983
       Coding: 0004077
       Shop #: WSC 05311 000 00000
       VCID: 3A2DCC42D05B9A0755E-806E
    End----(Elapsed Time: 02:09, VBatt start/end: 12.3V/11.8V. VIgn 11.8V)-----
    Oct 2017
    Canada
    the delta radio is coded at 3000 and the 9w3 is coded at 4077
    thank you
    Oct 2017
    Canada
    also if anyone has a wiring diagram of the radio and bluetooth module I can check the wires, that would help
    thank you in advance
    Oct 2017
    Canada
    any one have a possible solution or something for me to try?
  7. #7
    Oct 2017
    Canada
    anyone have an idea?
  8. #8
    Oct 2017
    Canada
    This can be closed, I was able to spend sometime and find out the issue
    the dealer told me the unit was gone, so I bought a used one and it did the same thing
    I traced all the cables and under the passenger seat (at the harness) there was one wire that was slightly cut where it attaches to the pin..hardly noticeable as I had to trace the cables with a trace tool to find out, fixed and now everything works.
  9. Likes Uwe liked this post
