MMI lost car settings after battery swap
dildildil
Pirate
Walking the Plank
Hi guys I have a 2004 audi a8l I recently changed my battery in my car and now I lost car height option in the mmi, if im correct I need to connect the car with vagcom and re enable it
Thank you
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
This person is local to me. He's not an interface owner, but I'll be helping him. I asked him to post here because I don't know what might be necessary to fix the Audi MMI after a power loss. I don't yet have an Auto-Scan; I was hoping to fix him up in one trip.
Jason
jakematic
NC USA
C?ID=129085
First thing I would do is recode BMM so that it knows a new battery has been installed.
If it's not a serialized battery, choose one of similar spec and increase the existing serial # by 1.
Then enable hidden menu if not already:
[07 - Control Head]
[Adaptation - 10] -> Channel 8
change 0 to 1
Use this hidden menu at your own risk.
Caution: Keep away from the "Bootloader"
Reboot MMI with Tel+Center Dial+Upper right
Press and hold Car and Setup simultaneously to access hidden menu.
Make sure Charisma is enabled and reboot MMI.
More details in this thread.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Excellent point. This is why I wanted to consult with Audi gurus first. :)
Okay, we should be able to get that done.
Is this something that commonly happens on battery disconnect? It's certainly common to lose adaptations like window/seat position, but I've not known of cars in the past that lose installed-equipment data. I'm curious if this is normal or abnormal for this car, so I know what I'm getting into.
Jason
jakematic
NC USA
C?ID=129085
It's not something that happens every time, but has been known to happen.
Usually if the battery is not in great shape to begin with things like this occur more often.
Anything flaky on a D3 is almost always battery, which is why I'm so fervent about checking the freeze frames.
It's also surprising how many are running around with original batteries still !
I think the tractor sized battery used in A8 and Phaeton hide issue due to sheer capability.
Good point on the windows - one touch up/down may need to be relearned.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Okay, just wanted to make sure I was probably dealing with a known scenario instead of a possibly defective MMI or suspension.
In the case of the Phaeton dual-battery setup, the battery controller can hide a multitude of sins, but it doesn't TELL ANYONE that it's doing so. Things just start acting more and more strangely over time, until one day your car won't start because both batteries are toast and it's out of workarounds. If there is one thing on the Phaeton that I think was designed badly, that's it. It has all the intelligence and hard relay controls needed to temporarily help you out of a jam, but doesn't tell the driver OR the dealer if it's having to do so frequently.
Jason
jakematic
NC USA
C?ID=129085
Assuming nothing was horribly wrong to begin with you should be OK ;)
Clear all DTCs, run suspension through it's paces including jack mode, and if nothing shows up after a couple DCYs you're good.
Based on the age you likely will get a telematics battery DTC unless the OnStar has been removed.
Also don't be surprised by an SDARS DTC about not being activated - ignore that.
If anything does come up.... you know where to find me :cool:
jakematic
NC USA
C?ID=129085
Sorry Jake, DCYs? Driving CYcles??
I'm trying to keep up :)
Correct.
Blame Jack... I'm using more of the acronyms he does from hanging around here :p
Dana
Western PA, USA
Hi Jason,
In addition to the great suggestions so far you may want to use the LCH to check the additive value of channel # 001 to see if +00064 = Adaptive Air Suspension installed (PR-1BK) is still present. I don't think 4E0-910-7xx-07.lbl is encrypted so you can check that out ahead of time.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Excellent tip, thank you. I checked and that label file is indeed readable.
Jason
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Got a look at the car today. It showed up with all zeros coding, but correctly equipped in adaptation 001/002. It also had DTCs for incorrect coding and component protection. I was able to correct the coding value to 00003, and that allowed us to clear the incorrect coding DTC. However, the component protection DTC is stuck, which I understand is typical.
The owner also has a 2006 A8L and says he swapped the MMI modules between the two at some point for troubleshooting an unrelated issue. He says they're back in the correct original cars now. This would account for CP going off, but it's interesting that it stays on even when restored to its original home.
We can't get into the hidden service menu at all. It's turned on with VCDS, indeed, it was turned on already and the owner had used it in the past. I tried several different things including reboots, turned it off and on, etc. I can't help but think component protection is hurting us here, but the owner asserts it worked after the swap back. He had the key sequences memorized so I tend to believe him.
Any thoughts?
Jason
jakematic
NC USA
C?ID=129085
Sounds like progress....
If you need any coding help, which I doubt due to your level of understanding of VCDS, let me know.
It could be CP, but I'm not certain.
You pressed CAR+SETUP right ?
Theory: CP negates hidden menu to avoid someone running bootloader to flash the module
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
The label file had excellent descriptions and I believe it's right now. I'd post the scan but I'm away from a computer for the next day or so.
Yes, and that was my exact theory when you told me about the boot loader menu.
Jason
jakematic
NC USA
C?ID=129085
And well proven too.
No rush on the scan, be good for posterity though.
Great minds, or overthinking engineers hard at work :p
I can't think of a single time when I heard of someone trying to get in diag menu with CP activated.
He/she is going to need to get it removed anyway for the vehicle(s) to function properly.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Here is the Auto-Scan from the OP's car, as it was upon arrival:
Saturday,27,September,2014,11:23:27:21122
VCDS Version: 14.8.1.0 (x64)
Data version: 20140905
Dealer/Shop Name: SW Ohio B5 Rescue
Workshop Code: 444 03207 084420
VIN: WAUML44EX4N017951   License Plate: 2004A8L
Mileage: 296790km-184416mi   Repair Order: BETA1481-HNIF
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
          47 4F 52 53 55 56 61 62 65 72 75
VIN: WAUML44EX4N017951   Mileage: 296790km-184416miles
Address 01: Engine        Labels: 077-910-560-BFM.lbl
   Part No SW: 4E0 910 560 A    HW: 4E0 907 560
   Component: 4.2L V8/5V      G   0070
   Revision: 00000000    Serial number: AUX3Z0CD531420
   Coding: 0007773
   Shop #: WSC 02313 785 00200
   VCID: 9F0EA2144EEFDEC240-80CA
   Part No SW: 4E0 910 156 E    HW: 09E 927 156 A
   Component: AG6 09E 4,2L5V USA  0110
   Revision: 00000001    Serial number:        0028316
   VCID: A404ADF86789FD1A1D-80F1
Address 03: ABS Brakes        Labels: 4E0-910-517.lbl
   Part No SW: 4E0 910 517 B    HW: 4E0 614 517 N
   Component: ESP 5.7 allrad  H44 0500
   Coding: 0007597
   Shop #: WSC 02313 000 00000
   VCID: A208ABE07D9DF32A6F-80F7
Address 05: Acc/Start Auth.        Labels: 4E0-910-131.lbl
   Part No SW: 4E0 910 131     HW: 4E0 909 131 A
   Component:     FBS AUDID3  H03 0140
   Revision: 01403903    Serial number: AUX3Z0CD531420
   Coding: 0263168
   Shop #: WSC 02311 785 00200
   VCID: D8FCC9086B4169FA41-808D
01176 - Key
                    Fault Frequency: 0
                    Mileage: 296672 km
                    Date: 2014.09.27
                    Time: 10:09:44
   Part No SW: 4E0 910 760 C    HW: 4E0 959 760
   Component: Sitzmemory BFS H07  0060
   Revision: 00000000    Serial number: 5DS 008 795-03
   Coding: 3940448
   VCID: A306AEE46287FA2264-80F6
Address 07: Control Head        Labels: 4E0-910-7xx-07.lbl
   Part No SW: 4E0 910 729 J    HW: 4E0 035 729
   Component: Interfacebox    H43 0600
   Revision: 00000000    Serial number: 346AP047508951
   Coding: 0000000
   VCID: AF2E52D43E4F4E42F0-80FA
   Subsystem 1 - Part No: 4E0 910 609 A
   Component: Bedienteil MMI  H42 0020
   Subsystem 2 - Serial number: 301AE047530891
   Subsystem 3 - Serial number: 7409.01.040000000000010050ÿ
   Subsystem 4 - Serial number: 010050ÿ
02084 - Component Protection
                    Fault Status: 01100101
                    Reset counter: 84
                    Mileage: 294013 km
                    Date: 2014.03.13
                    Time: 17:32:47
                    Reset counter: 84
                    Mileage: 294013 km
                    Date: 2014.03.13
                    Time: 17:32:47
   Part No SW: 4E0 910 043     HW: 4E0 820 043 B
   Component: KLIMAAUTOMAT    016 0240
   Revision: 00000022    Serial number: 00000000033974
   Coding: 1085889
   VCID: DAF8D300154D7BEA77-808F
   Subsystem 1 - Part No: 4E0 910 772 A
   Component: Sitzluefter  FS H02  010
   Subsystem 2 - Part No: 4E0 910 772 A
   Component: Sitzluefter BFS H02  010
   Subsystem 3 - Serial number: 898053000
   Subsystem 4 - Serial number: HO07012004065A000000000046ÿ†89
   Subsystem 5 - Serial number: 000046ÿ†898053000      000-SHO
   Subsystem 6 - Serial number:     000-SHO07012004065A00000000
   Subsystem 7 - Serial number: 65A000000000021ÿ
01273 - Fresh Air Blower (V2)
                    Fault Status: 00100011
                    Reset counter: 210
                    Mileage: 296615 km
                    Date: 2014.09.27
                    Time: 09:05:05
                    Temperature: 16.0°C
                    (no units): 189.0
                    (no units): 80.0
Address 09: Cent. Elect.        Labels: 4E0-910-279.lbl
   Part No SW: 4E0 910 279 E    HW: 4E0 907 279 E
   Component: ILM Fahrer      H11 0100
   Coding: 0111113
   VCID: AA1843C005AD2B6A27-80FF
   Subsystem 1 - Part No: 4E1 910 113 B
   Component: Wischer WWS D3  H40 0380
   Coding: 00000036
   Shop #: WSC 02313
   Part No SW: 4E0 910 111 C    HW: 4E0 035 111
   Component: CD-Changer      H43 0340
   Revision: 00000501    Serial number: AUZ5ZBC1030094
   VCID: 997A8C0C50CBB0F2BE-80CC
Address 15: Airbags        Labels: 4E0-910-655-84.lbl
   Part No SW: 4E0 910 655 A    HW: 4E0 959 655 E
   Component: Airbag 8.4E+    H10 0920
   Coding: 0530707
No Faults Found
Address 16: Steering wheel        Labels: 4E0-910-549.lbl
   Part No SW: 4E0 910 549     HW: 4E0 953 549 A
   Coding: 0012241
   VCID: E582F0FC2C33C412CA-80B0
   Component: Lenkradmodul    H04 0080
Address 17: Instruments        Labels: 4E0-910-xxx-17.lbl
   Part No SW: 4E0 910 900     HW: 4E0 920 950 B
   Component: KOMBIINSTR. VDO H44 0090
   Revision: D15         Serial number: AUDID3D0006074
   Coding: 0016203
   Shop #: WSC 03164 444 101329
   VCID: DCF4D5181F7985DA65-8089
Address 19: CAN Gateway        Labels: 4E0-910-468.lbl
   Part No SW: 4E0 910 468 A    HW: 4E0 907 468 C
   Component: Gateway         H07 0030
   Revision: 07          Serial number: 0200503C0211DD
   Coding: 7CFE7BDD1B2304
   VCID: A600B7F011B50F0A03-80F3
Address 25: Immobilizer        Labels: 4E0-910-131.lbl
   Coding: 0263168
   XXXXXXXXXXX ELV                 XXXX
01176 - Key
                    Fault Frequency: 0
                    Mileage: 296672 km
                    Date: 2014.09.27
                    Time: 10:09:44
Address 34: Level Control        Labels: 4E0-910-553.lbl
   Part No SW: 4E0 910 553 E    HW: 4E0 907 553 E
   Component: LUFTFDR.-CDC    H05 4290
   Coding: 0015510
   VCID: A502B0FC6CB304120A-80F0
   Component: Sitzmemory FS  H07  0060
   Coding: 4071522
   Part No SW: 4E0 910 887 K    HW: 4E0 919 887 C
   Component: MNS US          H42 0570
   Revision: 00000000    Serial number: 355AL047514491
   VCID: B52260BCDC137492BA-80E0
Address 38: Roof Electronics        Labels: 4E0-910-135.lbl
   Part No SW: 4E0 910 135 A    HW: 4E0 907 135
   Component: Dachknoten D3   H01 0090
   Serial number: 00000333900223
   Coding: 0003991
   VCID: 9D72981C44E3CCD252-80C8
Address 42: Door Elect, Driver        Labels: 4E1-910-802-42.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 801
   Component: Türsteuer.FS BRM005 0110
   Coding: 0028196
   VCID: DEF0DF10096597CA0B-808B
Address 46: Central Conv.        Labels: 4E0-910-289.lbl
   Part No SW: 4E0 910 289 A    HW: 4E0 907 289
   Component: Komfortgeraet   H03 0030
   Revision: 00300003    Serial number:  W040312110092
   Coding: 0065150
   VCID: A71EBAF416BF160238-80F2
   Component: Heckdeckel   P14H06 0070
   Component: Neigungssensor  H02 0020
Address 47: Sound System        Labels: 4E0-910-223.lbl
   Part No SW: 4E0 910 223 H    HW: 4E0 035 223 B
   Component: DSP-High D3/AUX H13 0370
   Revision: Dev_D01     Serial number: 00000000674975
   Coding: 0000016
Address 4F: Centr. Electr. II        Labels: None
   Part No SW: 4E0 910 280 A    HW: 4E0 907 280 A
   Component: ILM Beifahrer   H08 0020
   Revision:             Serial number: 00000000030215
   Coding: 0010111
   VCID: 9E709F1049E5D7CA4B-80CB
                    Reset counter: 211
                    Date: 2023.06.06
                    Time: 00:00:00
02258 - Door Opener Transmitter
                    Fault Frequency: 9
                    Reset counter: 172
                    Mileage: 262136 km
                    Date: 2014.09.22
                    Time: 14:03:00
Address 52: Door Elect, Pass.        Labels: 4E1-910-802-52.lbl
   Part No SW: 4E1 910 802     HW: 4E1 959 802
   Component: Türsteuer.BF BRM007 0110
   Coding: 0028196
Address 53: Parking Brake        Labels: 4E0-910-801.clb
   Part No SW: 4E0 910 801 C    HW: 4E0 907 801 A
   Component: EPB  A32C0220   H02 0220
   Revision: A32C0220
   Coding: 0000532
   Shop #: WSC 03164 444 101294
02443 - Control Head
                    Fault Status: 00111100
                    Reset counter: 211
                    Mileage: 296584 km
                    Date: 2003.10.12
                    Time: 00:40:49
                    Voltage: 5.38 V
                    Count: 40
Address 55: Headlight Range        Labels: 4E0-910-357.lbl
   Part No SW: 4E0 910 357     HW: 4E0 907 357
   Component: Pre-AFS         H01 0040
   VCID: E288EBE03D1DB32A2F-80B7
   Part No SW: 4E0 910 541 C    HW: 4E0 035 541
   Component: TUNER EU/US/RDW H41 0290
   Revision: 00000000    Serial number: 304AC047557220
   VCID: A00CA1E87391E13A79-80F5
Address 61: Battery Regul.        Labels: 4E0-910-181.lbl
   Part No SW: 4E0 910 181 B    HW: 4E0 915 181
   Component: ENERGIEMANAGER  H02 0240
   Revision: 00000000    Serial number: 00000006291475
   Shop #: WSC 08278 444 00440
   Subsystem 1 - Part No: 000 915 105 AK
   Component: von VA0  1401010590
   Coding: 303030393135313035414B56413031343031303130353930
   Shop #: WSC 00000 128 00289
                    Mileage: 296584 km
                    Date: 2003.10.08
                    Time: 00:32:14
                    Fault Frequency: 7
                    Mileage: 296588 km
                    Date: 2014.09.22
                    Time: 14:05:28
02276 - Quiescent Current Stage 5
                    Fault Frequency: 7
                    Mileage: 296588 km
                    Date: 2014.09.22
                    Time: 14:05:38
02274 - Quiescent Current Stage 3
                    Mileage: 296593 km
                    Date: 2014.09.22
                    Time: 14:22:45
Address 62: Door, Rear Left        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 801 A
   Component: Türsteuer.HL BRM005 0110
   Coding: 0028196
   VCID: DDF2D81C04638CD212-8088
                    Reset counter: 172
                    Mileage: 296784 km
                    Date: 2014.09.27
                    Time: 11:15:24
Address 65: Tire Pressure        Labels: 4E0-910-273.lbl
   Part No SW: 4E0 910 273     HW: 4E0 907 273
   Component: Reifendruck 2   H01 0210
   Coding: 0212127
   VCID: DF8EE2140E6F9EC200-808A
00532 - Supply Voltage B+
                    Fault Status: 10100010
                    Reset counter: 210
                    Mileage: 296584 km
                    Date: 2003.10.08
                    Time: 00:30:55
                    Speed: 255.0 km/h
                    Voltage: 7.30 V
                    (no units): 42.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
01477 - System Switched Off
                    Fault Frequency: 21
                    Reset counter: 172
                    Mileage: 296584 km
                    Date: 2003.10.12
                    Time: 00:40:31
                    Speed: 255.0 km/h
                    Temperature: 16.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                    Fault Status: 11100100
                    Reset counter: 171
                    Mileage: 296610 km
                    Date: 2014.09.22
                    Time: 16:31:52
                    Speed: 18.0 km/h
                    Temperature: 18.0°C
                    Error Code: 0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 72: Door, Rear Right        Labels: 4E0-910-802.lbl
   Part No SW: 4E0 910 802     HW: 4E0 959 802 A
   Component: Türsteuer.HR BRM005 0110
   Coding: 0028196
Address 75: Telematics        Labels: None
   Part No SW: 4E0 910 616     HW: 4E0 035 616 A
   Component: Telematik USA1      0070
   Revision: 00000004    Serial number: 0000ATD3007617
   Coding: 0000005
   Shop #: WSC 08219 444 53946
   VCID: E08CE1E83211A13A39-5184
01531 - Emergency Battery
End-------------------------(Elapsed Time: 02:59)--------------------------
This is how the MMI looks after re-coding:
   Coding: 0000003
   Shop #: WSC 03207 444 84420
   VCID: 2F6768FCBE09EC4270-807A
                    Reset counter: 84
                    Mileage: 294013 km
                    Date: 2014.03.13
                    Time: 17:32:47
jakematic
NC USA
C?ID=129085
Voltage: 5.38 V
Might need a new battery LOL.
I'd loop out and code out module 75 or it will keep setting MIL.
