Results 1 to 5 of 5
Thread: Error 31: Request out of range - Coding Rejected
    Jan 2018
    Hello, I'm would like te recode a ecu from manual to automatic gearbox. When I do vcds gives error Error 31: Request out of range - Coding Rejected.
    Any help would be appreciated.
    auto-scan:
    Friday,12,January,2018,13:35:37:40204
    VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4411.4
    Workshop Code: 790 02757 050316
    VIN: WV2ZZZ7HZFH036785   License Plate: DQ500
    Chassis Type: 7H-VN75 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72
    02-Auto Trans -- Status: Not registered 0011
    03-ABS Brakes -- Status: Cannot be reached 1100
    04-Steering Angle -- Status: Cannot be reached 1100
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    44-Steering Assist -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
       Part No SW: 03L 906 019 GQ    HW: 03L 907 309 L
       Component: R4 2,0L EDC   H38 6305
       Revision: 22H38---    Serial number: 00000000000000
       Coding: 0119401A233401080000
       Shop #: WSC 02757 790 50316
       ASAM Dataset: EV_ECM20TDI01103L906019GQ 003004
       ROD: EV_ECM20TDI01103L906019FH_003.rod
       VCID: 0058712AAA8AD3C75A1-8054
    33 Faults Found:
    4527 - Coolant Fan Control Circuit 1
              P0480 00 [035] - Electrical Malfunction
    16703 - Gear Reconition Sensor
              P181C 00 [035] - Implausbile Signal
    5270 - Output for Starter Relay
              P0615 00 [035] - Open Circuit
    5457 - Control Circuit for Starter Relay 2
              P3049 00 [035] - Open Circuit
    4871 - Exhaust Gas Recirculation Cooling Valve Control
              P2425 00 [039] - Open Circuit
                        Vehicle speed: 255 km/h
                        Coolant temperature: -12 C
                        Intake air temperature: -40 C
                        Voltage terminal 30: 13.820 V
                        Coolant temperature at radiator outlet: actual value: 70.5 C
                        Bypass valve for EGR cooler: status-Bit 0: 1
                        exh.gas recirc.: shut-off conditions-Bit 0: 0
                        exh.gas recirc.: shut-off conditions-Bit 16: 0
                        exh.gas recirc.: shut-off conditions-Bit 24: 0
                        exh.gas recirc.: shut-off conditions-Bit 8: 5
                        EGR cooling function: status-Bit 0: 3
                        exh.gas recirc. (EGR) cooler pump: specified value: 0.00 %
                        Exh.gas temp.sen 1: 314.0 C
    4875 - Coolant Pump 2
              P261A 00 [167] - Open circuit
                        Time: 00:00:00
                        EGR cooling function: status-Bit 0: 4
                        exh.gas recirc. (EGR) cooler pump: specified value: 80.00 %
    5568 - Sensor for Ambient Air Temperature (G17)
              P0073 00 [039] - Signal too High
                        Time: 00:00:00
                        Exh.gas temp.sen 2: -0.0 C
                        Exh.gas temp.sen 3: 349.0 C
                        Exh.gas temp.sen 4: 343.2 C
                        Shut-off timer: last engine shut-off time: 5 s
    4978 - Glow Plug Module 1; Glow Plug Circuit
              P0670 00 [035] - Electrical Malfunction
    5111 - Oxygen (Lambda) Sensor B1 S1; Heating Circuit
              P0135 00 [039] - Malfunction
                        Time: 00:00:00
    5132 - Valve for Fuel Metering (N290)
              P0090 00 [167] - Open Circuit
                        Coolant temperature: -13 C
                        Voltage terminal 30: 13.840 V
                        Engine status: COENG_READY
    13828 - Relay for Aux Coolant Pump (J496)
              P1927 00 [039] - Open Circuit
                        Voltage terminal 30: 13.800 V
                        Electric auxiliary heater: shut-off conditions-Bit 0: 0
                        Electric auxiliary heater: shut-off conditions-Bit 8: 0
                        Electric auxiliary heater: relay activation-Bit 0: 0
                        Preheat time: 2500 ms
                        Glow status-Bit 0: 0
                        Glow status-Bit 8: 0
                        Glow cycles above temperature threshold-Bit 0: 0
                        Glow cycles above temperature threshold-Bit 8: 0
                        Glow cycles below temperature threshold-Bit 0: 0
                        Glow cycles below temperature threshold-Bit 8: 0
                        Outside air temperature: -3549.9 C
    10065 - Mass Air Flow Sensor (G70)
              P0104 00 [167] - Intermittent
                        Air mass: actual value (mg/stroke): 0.0 mg/stroke
                        Standardized airflow ratio: filtered: 3.9999
                        EGR Solen.val.: actual value: 100.00 %
                        Throttle valve adapter: actual value: 100.00 %
                        Charge air pressure specified value: 1050 hPa
                        Charge air pressure: actual value: 3000.0 hPa
                        Mean injection quantity: 0.00 mg/stroke
    4881 - EGR Valve (N18)
              P1440 00 [039] - Open Circuit
                        Time: 00:00:00
                        EGR Vacuum Regulator Solen.val.: activation: 100.00 %
                        EGR valve: offset closed: 1.11 %
                        Actuator for high pressure EGR: status-Bit 0: 0
                        Actuator for high pressure EGR: status-Bit 16: 3
                        Actuator for high pressure EGR: status-Bit 24: 55
                        Actuator for high pressure EGR: status-Bit 8: 2
                        High press EGR actuator: actual unconditioned volt val: 3.8 mV
    4900 - EGR Sensor 1
              P0405 00 [039] - Signal too Low
                        Actuator for high pressure EGR: status-Bit 16: 0
                        High press EGR actuator: actual unconditioned volt val: 9.6 mV
    9531 - Manifold / Barometric Pressure Sensor (G71) / (F96)
              P0105 00 [039] - Malfunction
                        Intake air pressure sensor after air cleaner: raw value: 1150 hPa
    5169 - Manifold Pressure / Boost Sensor (G31)
              P0238 00 [167] - Signal too High
    5253 - Diesel Particle Filter; Differential Pressure Sensor
              P2452 00 [039] - Elect. Malfunction
                        Sensor for particle filter differential press: raw value: 1057 hPa
                        Particle filter: difference pressure: -3 hPa
                        Particle filter: offset for differential press.: 1 hPa
                        Particle filter: differential pressure: dynamic offset: 3 hPa
                        Particle filter: soot mass measured: 1.39 g
                        Particle filter: soot mass calculated: 10.49 g
    12006 - Indicator Lamp for Start-Stop Operation
              P167A 00 [039] - Electrical Malfunction
    4667 - Accelerator Position Sensors (G79) / (G185)
              P2138 00 [167] - Implausible Correlation
                        Accelerator pedal: sensor voltage 1: 1371.2 mV
                        Accelerator pedal: sensor voltage 2: 1380.0 mV
                        Accelerator pedal: switch positions-Bit 0: 0
                        Starter control: Interlock- or P/N-signal-Bit 0: 81
                        Limitation: torque: 0.0 Nm
                        Control Module temperature: 34.0 C
    5282 - Intake Air Temp. Sensor (G42)
              P0113 00 [039] - Signal too High
                        Exh.gas temp.sen 4: 346.1 C
    5290 - Throttle Actuator Control Circuit
              P2100 00 [167] - Open Circuit
                        Time: 00:00:00
                        Throttle valve adapter: specified value: 100.00 %
                        Throttle valve adapter: offset closed: -0.07 %
                        Throttle valve adapter: status-Bit 0: 0
                        Throttle valve adapter: status-Bit 16: 11
                        Throttle valve adapter: status-Bit 24: 50
                        Throttle valve adapter: status-Bit 8: 2
                        Throttle valve adapter: uncond voltage actual value: 4988.0 mV
    5305 - Throttle Position Sensor (G69)
              P0123 00 [167] - Signal too High
                        Throttle valve adapter: status-Bit 16: 8
                        Throttle valve adapter: uncond voltage actual value: 4993.8 mV
    5325 - Boost Pressure Control Valve/Solenoid (Bank 1)
              P0045 00 [167] - Open Circuit
                        Charge Pressure Actuator: activation: 10.00 %
                        Charge Pressure Actuator: acknowledgment: 10.88 %
                        Turbocharger boost control: offset closed: 5.60 %
                        High press turbocharger actuator: status-Bit 0: 0
                        High press turbocharger actuator: status-Bit 16: 0
                        High press turbocharger actuator: status-Bit 24: 7
                        High press turbocharger actuator: status-Bit 8: 0
                        High press turbocharger actuator: actual uncond volt value: 994.4 mV
                        Accelerator pedal travel: 5.64 %
    5557 - Body Control Module (Central Electric)
              U0140 00 [035] - No Communications
    11060 - Body Control Module (Central Electric)
    5615 - Door Control Module - Driver's Door
              U0199 00 [035] - No Communications
    10092 - Neutral Gear Sensor
              P15A0 00 [035] - Electrical Malfunction
    7027 - Software Incompatibility with Transmission Control Module
              U0302 00 [167] - -
                        Neutral position sensor: current transmission angle: 20.00
                        Neutral position sensor: adapted transmission angle: 0.00
                        Transmission neutral position sensor voltage: 0 mV
                        selected gear-Bit 0: 0
    4708 - No Communications with HVAC Control Module (J301)
              U0164 00 [035] - -
    4710 - No Communications with Airbag Control Module
              U0151 00 [035] - -
    4713 - No Communication with ABS Brake Control Module
              U0121 00 [167] - -
                        Limitation: accelerator pedal: 92.4 Nm
                        CAN status - engine control module-Bit 0: 0
                        Cruise Control System (CCS): status-Bit 0: 206
                        CAN status - transmission control module-Bit 0: 0
                        CAN status - brake control module 1-Bit 0: 0
                        CAN status - brake control module 2-Bit 0: 0
    4717 - Body Control Module (Central Electric)
    4729 - Steering Effort Control Module
              U0130 00 [035] - No Communications
       Part No SW: 0BT 300 045 P    HW: 0BH 927 711 C
       Component: DSG DQ500-7F  H07 1803
       Revision: 00H07V01
       VCID: 42DCBB22E40601D70C5-8016
    12 Faults Found:
    10632 - No Communication with Gear Selector Module
              U0103 00 [047] - -
                        Time: 00:00:00
                        Coolant temperature: -40 C
                        Clutch: primary stat: New
                        selected gear: GANG N
                        Driving position: P
                        Engine torque: 0 Nm
                        Control Module temperature: -12 C
                        Accelerator position: 27.6 %
                        DTC memory status: 255
    10633 - Selector Lever
              P0914 00 [040] - Electrical Malfunction
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
    10645 - Selector Lever
              P0919 00 [044] - Malfunction
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
    10647 - Selector Lever
              P0919 00 [040] - Malfunction
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
    10650 - Selector Lever
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
    10676 - Powertrain Databus
              U0001 00 [040] - Unspecified Malfunction
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
    10680 - Databus
              U1121 00 [047] - Missing Message
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
    10684 - Databus
              U1121 00 [044] - Missing Message
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
    10686 - Databus
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
    10730 - Databus
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
    17994 - Powertrain Databus
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
              P1734 00 [047] - -
                        Mileage: 46739 km
                        Time: 00:00:00
                        Driving position: P
                        Engine torque: 0 Nm
    Address 03: ABS Brakes
    Address 08: Auto HVAC
    Address 09: Cent. Elect.
    Address 10: Park/Steer Assist
    Address 15: Airbags
    Address 16: Steering wheel
    Address 17: Instruments
       Part No SW: 7N0 907 530 S    HW: 7N0 907 530 J
       Component: J533  Gateway H43 1632
       Revision:   H43       Serial number: 020612F1000268
       Coding: 356303
       Shop #: WSC 33361 790 00075
       VCID: 40D8B12AEA8A13C71A1-8014
    7 Faults Found:
                        Reset counter: 208
                        Reset counter: 208
                        Reset counter: 208
                        Reset counter: 208
                        Reset counter: 208
    03075 - Parallel Parking Assistance Control Module (J791)
                        Reset counter: 208
    Address 25: Immobilizer
    Address 44: Steering Assist
    Address 46: Central Conv.
    Address 52: Door Elect, Pass.
    Address 56: Radio
       Part No SW: 7N0 907 534     HW: 7N0 907 530 J
       Component: Batt.regelung H43 1632
       Coding: 030B185A
       VCID: 71BE24EE91A0CA4FA5F-8024
    00458 - Control Module for Battery Monitoring (J367)
                        Fault Status: 01110100
                        Reset counter: 208
    02252 - Generator
                        Fault Status: 00100011
                        Fault Frequency: 7
                        Reset counter: 248
                        Mileage: 33518 km
                        Date: 2027.14.00
                        Time: 08:40:57
    02252 - Generator
                        Reset counter: 208
    02252 - Generator
                        Fault Status: 00101100
                        Fault Frequency: 7
                        Reset counter: 248
                        Mileage: 33518 km
                        Date: 2027.14.00
                        Time: 08:40:57
    Address 62: Door, Rear Left
    Address 72: Door, Rear Right
    End----(Elapsed Time: 00:40, VBatt start/end: 13.9V/13.9V. VIgn 0.0V)------
    Many modern ECUs have transmission-specific software; i.e. the software part number will be different for an ECU that's meant to be used on a manual vs. an ECU that's meant to be used on an automatic. While these ECUs may have coding information that implies it's possible to change transmission types, if they have transmission-specific software, that software will reject a coding that it cannot accommodate with a "Request out of Range" error.
    Jan 2018
    OK, so it has nothing to do with wsc and imp number etc?
    In this case, I do not think so.
    Oct 2017
    Northwest UK
    UWE is most probably correct, although some modules are the same on both manual and auto models.
    What is the part number of the module you are referring to. What model vehicle are you fitting this to? We can check the current part number and see if it is different for an auto. If it's an engine ECU then VCDS cannot code it as these are flashed with certain variables specific to the car. Contact a chipping tuner who may be able to help.
