Results 1 to 10 of 10
Thread: DSG gearbox retrofitted. Manual to DSG swap. Help ABS coding.
    Mar 2014
    Romania
    Dear All,
    I have retrofitted DSG gearbox on a 2013 Passat B7. It was initially fitted with manual gearbox.
    I have some issues coding a few of the modules installed. ABS and EPB. Please see below an auto scan from the car. Can you please advise for proper coding?
    Also the software incompatibility will be resolved with a new EDC SW number 03L 906 018 BM. Can you also confirm that this SW number is ok? Found that should be for CFFB, Bluemotion with AD Blue, DSG 6 speed.
    Thank you in advance,
    Best regards
    Friday,12,January,2018,15:36:47:28047
    VCDS Version: 17.12.0.1 (x64)
    Data version: 20171213 DS285.1
    VIN: WVWZZZ3CZDE050120   License Plate: BV27RDX
    Mileage: 207790km-129114mi   Repair Order:
    Chassis Type: 3C-VW46 (7N0)
    Scan: 01 02 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56
              61 62 72
    VIN: WVWZZZ3CZDE050120   Mileage: 207790km-129114miles
       Part No SW: 03L 906 018 BL    HW: 03L 907 309 Q
       Component: R4 2,0L EDC   H28 9910
       Revision: 44H28---    Serial number: 00000000000000
       Coding: 00190012042401080000
       Shop #: WSC 00015 115 00000
       ASAM Dataset: EV_ECM20TDI01103L906018BL 003014
       ROD: EV_ECM20TDI01103L906018BL.rod
       VCID: 75E128D8D4ACB982EC4-8020
    10092 - Neutral Gear Sensor
              P15A0 00 [039] - Electrical Malfunction
                        Mileage: 207795 km
                        Date: 2018.01.12
                        Time: 00:14:41
                        Engine speed: 832.50 /min
                        Normed load value: 27.5 %
                        Coolant temperature: 50 C
                        Intake air temperature: 20 C
                        Ambient air pressure: 950 mbar
                        Voltage terminal 30: 12.580 V
                        Neutral position sensor: current transmission angle: 20.00
                        Neutral position sensor: adapted transmission angle: 0.00
                        Adaptation status for transmission neutral position sensor-Bits 0-7: 4
                        Transmission neutral position sensor voltage: 0 mV
                        Neutral position sensor: upper adaptation value: 0 mV
                        Neutral position sensor: lower adaptation value: 0 mV
    7027 - Software Incompatibility with Transmission Control Module
              U0302 00 [167] - -
                        Mileage: 207795 km
                        Date: 2018.01.12
                        Time: 00:14:41
                        Engine speed: 839.50 /min
                        Normed load value: 27.1 %
                        Voltage terminal 30: 12.660 V
                        selected gear-Bits 0-7: 0
       Part No SW: 02E 300 054 J    HW: 02E 927 770 AL
       Component: GSG DSG AG6     511 2604
       Revision: 05351112    Serial number: 00001011130860
       Shop #: WSC 44551 111 44551
       VCID: 1D311078C4DC41C2C44-8048
       Part No SW: 3AA 614 109 BK    HW: 3AA 614 109 BK
       Component: J104   C2 450M VD9F 0024
       Revision: --H07---    Serial number: 00000006136993
       Coding: 0003504
       Shop #: WSC 05311 000 00000
       VCID: 77FD22D006A0CB92FE8-8022
    02757 - Learning Tire Pressures
                000 -  -
                        Reset counter: 159
                        Mileage: 207795 km
                        Date: 2018.01.12
                        Time: 00:14:41
                        Hex Value: 0x0000
                        Bin. Bits: 00000000 00000000
                        Voltage: 12.50 V
                        Bin. Bits: 00011111
                        Count: 194
                        Hex Value: 0x0000
                008 - Implausible Signal
                        Fault Status: 01101000
                        Reset counter: 159
                        Mileage: 207795 km
                        Date: 2018.01.12
                        Time: 00:14:42
                        Hex Value: 0x0000
                        Voltage: 12.50 V
                        Bin. Bits: 00011111
                        Count: 223
                        Hex Value: 0x0000
                000 -  -
                        Reset counter: 159
                        Mileage: 207795 km
                        Date: 2018.01.12
                        Time: 00:14:42
                        Hex Value: 0x0000
                        Voltage: 12.25 V
                        Bin. Bits: 00011111
                        Count: 215
                        Hex Value: 0x0000
       Part No SW: 3AA 907 044 AG    HW: 3AA 907 044 AG
       Component: Climatronic   H03 0303
       Revision: 00001K02
       Coding: 0014004803
    Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
       Part No SW: 3AA 937 087 F    HW: 3AA 937 087 F
       Component: BCM PQ47 M    421 0465
       Revision: BA421001
       Coding: 0008000000000000009800805400006403510088426D85606480C7200041
       VCID: 3D71F0F8A41C21C2E44-8068
       Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
       Component: Wischer 06071  10  0603
       Coding: 00B795
       Component: RLS 010912 05  54  0403
       Coding: 02302A
    Address 10: Park/Steer Assist (J446)       Labels:| 3AE-919-475.clb
       Part No SW: 3AE 919 475 B    HW: 7N0 919 475
       Component: PARKHILFE 8K  H06 0016
       Revision: --------    Serial number: 28261223601020
       Coding: 108002
       ASAM Dataset: EV_EPHVA18VW47X0000 001005
       ROD: EV_EPHVA18VW47X0000.rod
       VCID: 3E73F7F4A11A3ADAFDE-806A
       Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
       Component: J234__107 VW10 HI   2118
       Revision: 24017000    Serial number: 003L7PHLF7PC
       Coding: 0012343
       VCID: 7CF73DFC3F86E8CA93A-8028
       Subsystem 1 - Serial number: 6332MTS659172342
       Subsystem 2 - Serial number: 6342MTS609032352
       Subsystem 3 - Serial number: 6351HTS6UVQCABKJ
       Subsystem 4 - Serial number: 6361HTS68UVDABKR
    Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
       Part No SW: 3C9 953 501 BN    HW: 5K0 953 569 AB
       Revision: FF010041    Serial number: 20120822201141
       Coding: 118A250000
       VCID: 76E32FD4C9AAB29AE5E-8022
       Component: E221__MFL-TK6  H07 0022
       Coding: E20000
       Part No SW: 3AA 920 870 J    HW: 3AA 920 870 J
       Component: KOMBI         H05 0705
       Coding: 161F01
       Shop #: WSC 05314 115 00000
       VCID: 3979E4E8B8341DE2C8C-806C
       Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
       Component: J533  Gateway H40 1632
       Revision:   H40       Serial number: 260812F1003385
       Coding: 352006
       Shop #: WSC 05314 123 12345
       VCID: 41898C08D8E4452280C-8014
                000 -  -  - Intermittent
                        Mileage: 207795 km
                        Date: 2018.01.12
                        Time: 00:14:42
       Part No SW: 3AA 959 433     HW: 3AA 959 433
       Component:    IMMO         045 0400
       Revision: 00045000    Serial number: VWZCZ000000000
       VCID: 76E32FD401AAB29AE5E-8022
       Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
       Component: SG EXT.PLAYER H18 0546
       Revision: A1001003    Serial number: 7663357196
       Coding: 020100
       Shop #: WSC 05314 000 00000
       VCID: 2A5BCBA44592A67AB16-807E
       Part No SW: 3C0 035 279 N    HW: 3C0 035 279 N
       Component: RNS315-EU   H52 0319
       Serial number: VWZAZ2M5986726
       Coding: 040004110400110000011301
       ASAM Dataset: EV_RNS315EUV2UDS 001705
       ROD: EV_RNS315EUV2UDS.rod
       VCID: 2E53C7B4717ACA5A6DE-807A
       Component: EUR_W_0038  0038
       Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
       Component: TUER-SG FT    002 0533
       Revision: 12110009    Serial number: 0005589283
       Coding: 0210B7
       Shop #: WSC 05311 115 00000
       VCID: 3561E8D8942CF9822C4-8060
       Slave Driver:
       Subsystem 1 - Part No SW: 3AA 959 703 A    HW: 3AA 959 795   Labels: 1K0-959-70X-GEN4.CLB
       Component: J388__TSG-HL  004 0503
       Serial number: 00000003092305
       Coding: 010090
              B11EC 54 [009] - Missing Calibration / Basic Setting
                        Reset counter: 159
                        Mileage: 207795 km
                        Date: 2018.01.12
                        Time: 00:14:41
       Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
       Component: J500__APA-BS KL.309 1101
       Revision: 1AH03735    Serial number: 00122310071401
       Coding: 0000258
       VCID: 3D71F0F8641C21C2E44-8068
       Component:    KSG PQ47 ELV 045 0634
       Coding: 0091020052830E76340494157C084F0B605801
       Shop #: WSC 05311 123 12345
       Part No SW: 7N0 907 532     HW: 7N0 907 530 K
       Component: EZE_2         H40 1632
       Coding: 00000008
       VCID: 6FED1AB0BEF08352268-803A
       Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
       Component: Analoguhr  004 0004
       Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
       Component: TUER-SG BT    002 0533
       Revision: 14110009    Serial number: 0005603463
       Coding: 0210B6
       VCID: 3663EFD4892AF29A25E-8062
       Slave Passenger:
       Subsystem 1 - Part No SW: 3AA 959 704 A    HW: 3AA 959 794   Labels: 1K0-959-70X-GEN4.CLB
       Component: J389__TSG-HR  004 0503
       Serial number: 00000003098155
       Coding: 010090
       Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
       Component: J540 EPB4  VW-86594 0010
       Revision:   H19       Serial number: 00000000407604
       Coding: 0022167
       VCID: 3663EFD4412AF29A25E-8062
    03182 - Clutch Position Sensor (G476)
                010 - Open or Short to Plus
                        Fault Status: 01111010
                        Reset counter: 159
                        Mileage: 207795 km
                        Date: 2018.01.12
                        Time: 00:14:41
                        Voltage: 12.40 V
                        Count: 55
                        Hex Value: 0x1260
                        Hex Value: 0x0001
                        Hex Value: 0x0101
       Part No SW: 7N0 907 534     HW: 7N0 907 530 K
       Component: Batt.regelung H40 1632
       Coding: 030F1859
       VCID: 71E91CC8A8C495A230C-8024
       Component: J367-BDM  H07 0180
       Serial number: 00000000008900058286
    End-------------------------(Elapsed Time: 03:07)--------------------------
    Nov 2014
    New Zealand
    Once you have the correct Engine ECU (EDC) suited to a DSG equiped car, then the other faults may disappear.
    The DSG TCU is broadcasting that it is online, but the EDC is reporting the car is manual transmission.
    I had this issue on my Touran when swapping auto to manual - a Manual Engine ECU fixed the issue instantly with no coding changes.
    I'm not sure on the EPB, but it would be easier to fix after the EDC is changed.
  3. Likes Uwe, PetrolDave, Boki Ar liked this post
    Mar 2014
    Romania
    All sorted out like you said. Updated EDC software with BM version, coded the ECU for automatic transmission and all set up
    perfect. Warning lights off and good to go.
    Thanks!
    All i need is a steering wheel module that locks the smart key in when lever not in park and new steering with padles 😛.
    Jan 2018
    Looks like you could do with updating your VCDS.
    2006 EOS 3.2 V6.
    Mar 2014
    Romania
    Hi, updating vcds has nothing to do with updating ECU software. This was made with CMD flash tool and the original factory file. Is this what are you refering at?
    Aug 2016
    Switzerland
    03L906018BM
    (1)
    control unit for diesel engine
    D >> - 07.11.2011
    Model data: CFFB + PR-
    7ME --> 7ME AGM Emission standard EU6 Diesel
    G1A --> G1A GSP 6-speed automatic transmission
    looks ok to me
    Mar 2014
    Romania
    It sure is as the car is running flawless. The retrofit is a success 😬. Checked the PR codes myself before writing the new software on the ECU.
    Just a heads up for anyone trying, be sure to make a full back-up on BDM for the ecu in boot mode before writing the new file.
  9. #8
    Jan 2018
    Quote Originally Posted by mirceaciuciuc View Post
    I was referring to the fact your VCDS is an older version, and wasn't sure you knew there is a newer version.
    2006 EOS 3.2 V6.
  10. #9
    Apr 2018
    Australia
    HI
    did you have to change any wiring inside the vehicle, i want to convert a mk5 manual to dsg
  11. #10
    Mar 2014
    Romania
    Yes, there are a few wires that needs connection from the mechatronic to CAN- BUS inside the vehicle to the can bus module. The gear selection electronics needs connections too. Also the mechatronics needs power from the main relay box in the engine compartment. Best is if you have from the donor car all the wiring necesary that you must disconect yourself and remember its connections. Otherwise electrics diagrams. Writing the engine ecu with the file suitable for your configuration is a must.
    Have fun!
    I know I did... )
