Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: Audi A6 Allroad 2010 Flash To Pass lights on with Xenon high beam
    May 2015
    Lithuania
    Looks like there is no coding option to address this problem, but the solution exists:
    https://www.youtube.com/watch?v=K-WquvY0ptk
  2. #12
    Verified VCDS User Gremling's Avatar
    Dec 2017
    Norway, Nordland
    Nah, have my own solution now.
    Extender chord between OEM headlight cable and headlight, cut cable for Xenon curtain function, and this circuit/current/voltage is feed via a small low control signal effect relay (control signal plus selectable 2 In and 1 Out) and then into headlight. The controlled circuit in relay has: Control circuit 2 pins, and the controlled circuit 3pins has #1 in is from OEM Flash to pass circuit, #2 in is new wire from spare fuse in engine compartment fusebox and the #1 Out is connected to the "Flash to pass" wiring to headlamp. This way the auto dimming function takes care of "both High beams in either headlamps"
    Regards
    Gremling
  3. Likes Uwe liked this post
