Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 42
Thread: Retrofit from Discover pro MIB1 to MIB2 on GOLF MK7
  1. #21
    Oct 2017
    Italy
    Thanks guys ... tomorrow I'll post everything.
  2. #22
    Dec 2016
    Amsterdam
    Well, inn the meantime while we're waiting for that; as far as 5F goes:
    IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,No ,3 >>> Set to 'Yes'
    Normally 5F slaves to the gateway regarding installation changes and sets this ^^^ channel to 'Yes' automatically when the Amplifier is registered in the gateway. Could be yet another sign you need to do something with that gateway.
    Two other channels i've found to be different:
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64 >>> Leave it like this
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64 >>> Set to 'Databus Infotainment'
    Current:
  3. Likes Riddick20 liked this post
  4. #23
    Oct 2017
    Italy
    here I am!!!
    19 GATEWAY'S ADAPTATION
    ;SW:5Q0-907-530-AM   HW:5Q0-907-530-F ---  CAN Gateway
    ;Component:GW MQB High   128 1265, Coding:030100042B085900EF00066B080F00010001000000000000000000000000
    ;EV_GatewLear,013020,EV_GatewLear_013_VW37.rod
    ;Saturday,17,February,2018,09:17:45:49498
    ;VCDS Version: Release 18.2.0  Data version: 20180212 DS287.0
    ;VCID: 7CF06CC3F72A3DA444-8028
    IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating ,3
    IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating ,3
    IDE00002-Transport mode,not active ,1
    IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V,2
    IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V,2
    IDE01211-Static current measuring mode,not activated ,1
    IDE01457-Energy management deactivation stage,Mode not active ,1
    IDE01459-Energy management heat output control status,Mode not active ,1
    IDE01844-Increase idle speed request,Mode not active ,1
    IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,-- ,3
    IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active ,3
    IDE01860-Generator specified voltage value variable,10.6 V,1
    IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded ,32
    IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,Not coded ,32
    IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded ,32
    IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded ,32
    IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded ,32
    IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded ,32
    IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded ,32
    IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded ,32
    IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded ,32
    IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded ,32
    IDE01996-SFT00021-Installation list: specified installations-Airbag,coded ,32
    IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded ,32
    IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded ,32
    IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded ,32
    IDE01996-SFT00025-Installation list: specified installations-Gateway,1 ,32
    IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded ,32
    IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded ,32
    IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded ,32
    IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded ,32
    IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded ,32
    IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded ,32
    IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded ,32
    IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,coded ,32
    IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded ,32
    IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded ,32
    IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded ,32
    IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded ,32
    IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded ,32
    IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded ,32
    IDE01996-SFT00071-Installation list: specified installations-Sound System,coded ,32
    IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded ,32
    IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded ,32
    IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded ,32
    IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,coded ,32
    IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded ,32
    IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded ,32
    IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded ,32
    IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded ,32
    IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded ,32
    IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded ,32
    IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,Not coded ,32
    IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded ,32
    IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded ,32
    IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,Not coded ,32
    IDE01996-SFT00128-Installation list: specified installations-Battery Regulation Auxiliary Accumulator 1,Not coded ,32
    IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded ,32
    IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded ,32
    IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded ,32
    IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded ,32
    IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,coded ,32
    IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded ,32
    IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded ,32
    IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded ,32
    IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded ,32
    IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded ,32
    IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded ,32
    IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded ,32
    IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded ,32
    IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded ,32
    IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded ,32
    IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded ,32
    IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded ,32
    IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded ,32
    IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded ,32
    IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded ,32
    IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded ,32
    IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded ,32
    IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded ,32
    IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded ,32
    IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded ,32
    IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded ,32
    IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded ,32
    IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded ,32
    IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded ,32
    IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded ,32
    IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded ,32
    IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded ,32
    IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded ,32
    IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded ,32
    IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded ,32
    IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded ,32
    IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded ,32
    IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded ,32
    IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded ,32
    IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded ,32
    IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded ,32
    IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded ,32
    IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded ,32
    IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded ,32
    IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded ,32
    IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded ,32
    IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded ,32
    IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded ,32
    IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded ,32
    IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded ,32
    IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded ,32
    IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded ,32
    IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded ,32
    IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded ,32
    IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded ,32
    IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded ,32
    IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded ,32
    IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded ,32
    IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded ,32
    IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded ,32
    IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded ,32
    IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded ,32
    IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded ,32
    IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded ,32
    IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded ,32
    IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded ,32
    IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded ,32
    IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded ,32
    IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded ,32
    IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded ,32
    IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded ,32
    IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded ,32
    IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded ,32
    IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded ,32
    IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded ,32
    IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded ,32
    IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded ,32
    IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded ,32
    IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded ,32
    IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded ,32
    IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded ,32
    IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded ,32
    IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded ,32
    IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded ,32
    IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded ,32
    IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded ,32
    IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded ,32
    IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded ,32
    IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded ,32
    IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded ,32
    IDE01996-ENG118302-Installation list: specified installations-Node_0x85,Not coded ,32
    IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded ,32
    IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded ,32
    IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded ,32
    IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded ,32
    IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded ,32
    IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded ,32
    IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded ,32
    IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded ,32
    IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded ,32
    IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded ,32
    IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded ,32
    IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded ,32
    IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded ,32
    IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded ,32
    IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded ,32
    IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded ,32
    IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded ,32
    IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded ,32
    IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded ,32
    IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded ,32
    IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded ,32
    IDE01996-ENG118324-Installation list: specified installations-Node_0x9C,Not coded ,32
    IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded ,32
    IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded ,32
    IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded ,32
    IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded ,32
    IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded ,32
    IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded ,32
    IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded ,32
    IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded ,32
    IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded ,32
    IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded ,32
    IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded ,32
    IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded ,32
    IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded ,32
    IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded ,32
    IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded ,32
    IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded ,32
    IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded ,32
    IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded ,32
    IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded ,32
    IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded ,32
    IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded ,32
    IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded ,32
    IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded ,32
    IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded ,32
    IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded ,32
    IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded ,32
    IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded ,32
    IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded ,32
    IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded ,32
    IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded ,32
    IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded ,32
    IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded ,32
    IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded ,32
    IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded ,32
    IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded ,32
    IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded ,32
    IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded ,32
    IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded ,32
    IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded ,32
    IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded ,32
    IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded ,32
    IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded ,32
    IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded ,32
    IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded ,32
    IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded ,32
    IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded ,32
    IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded ,32
    IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded ,32
    IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded ,32
    IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded ,32
    IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded ,32
    IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded ,32
    IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded ,32
    IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded ,32
    IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded ,32
    IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded ,32
    IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded ,32
    IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded ,32
    IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded ,32
    IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded ,32
    IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded ,32
    IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded ,32
    IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded ,32
    IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded ,32
    IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded ,32
    IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded ,32
    IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded ,32
    IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded ,32
    IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded ,32
    IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded ,32
    IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded ,32
    IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded ,32
    IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded ,32
    IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded ,32
    IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded ,32
    IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded ,32
    IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded ,32
    IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded ,32
    IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded ,32
    IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded ,32
    IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded ,32
    IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded ,32
    IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded ,32
    IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded ,32
    IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded ,32
    IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded ,32
    IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded ,32
    IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded ,32
    IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded ,32
    IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded ,32
    IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded ,32
    IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded ,32
    IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded ,32
    IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded ,32
    IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded ,32
    IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded ,32
    IDE02200-Component protection showroom mode,not active ,1
    IDE03256-MAS06105-Battery adaptation-Rated battery capacity,69 Ah,15
    IDE03256-MAS06106-Battery adaptation-Battery technology,EFB ,15
    IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB ,15
    IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111 ,15
    IDE03903-Production process data 1,01 E0 ,2
    IDE04159-Deactivation of start-stop function,Mode not active ,1
    IDE04186-Battery terminal recognition,connected ,1
    IDE04330-Transfer of release code for a SWaP function,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,384
    IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated ,1
    IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error ,1
    IDE06530-Distance left for deactivation of static current measuring mode,2 ,1
    IDE06541-Distance left for deactivation of transport mode,50 ,1
    IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated ,4
    IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated ,4
    IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated ,4
    IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated ,4
    IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated ,4
    IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated ,4
    IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated ,4
    IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated ,4
    IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated ,4
    IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated ,4
    IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated ,4
    IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated ,4
    IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated ,4
    IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated ,4
    IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated ,4
    IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated ,4
    IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated ,4
    IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated ,4
    IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,activated ,4
    IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated ,4
    IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated ,4
    IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated ,4
    IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated ,4
    IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,activated ,4
    IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated ,4
    IDE06753-MAS14430-Efficiency program display-Dependence of ECO tips on driver profile selection,ECO tips independent of driver profile selection ,4
    IDE06753-MAS19094-Efficiency program display-Convenience_consumption_air_condition_ventilation_rear,activated ,4
    IDE06753-MAS19095-Efficiency program display-Convenience_consumption_mirror_heating_dependency,Until_temperature_threshold_with_after-run_with_switch ,4
    IDE07838-Counter for inconsistent states,0 ,2
    IDE08348-Start/stop start voltage limit,7.6 V,1
    IDE08624-MKE Check box,activated ,1
    IDE10736-Cyclization limitation request battery service,0 ,1
    IDE10748-MAS11262-Range gain-Range gain AC system,activated ,3
    IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated ,3
    IDE10748-MAS11264-Range gain-Range gain window defogger,activated ,3
    IDE10748-MAS11265-Range gain-Range gain seat heater front,activated ,3
    IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated ,3
    IDE10748-MAS11267-Range gain-Range gain rear heater,activated ,3
    IDE10748-MAS11268-Range gain-Range gain fog light,activated ,3
    IDE10748-MAS11269-Range gain-Range gain rear fog light,activated ,3
    IDE10748-MAS11270-Range gain-Range gain windshield heating,activated ,3
    IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated ,3
    IDE10748-MAS11272-Range gain-Range gain mirror heater,activated ,3
    IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated ,3
    IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated ,3
    IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,activated ,3
    IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,activated ,3
    IDE10748-MAS11277-Range gain-PTC(low voltage) consumption,activated ,3
    IDE10748-MAS11278-Range gain-PTC(low voltage) range gain,activated ,3
    IDE10748-MAS11279-Range gain-List at engine still stand,activated ,3
    IDE10748-MAS12689-Range gain-Catalogue range display,activated ,3
    IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated ,3
    IDE10748-MAS13161-Range gain-List display absolute values ??with weighting,activated ,3
    IDE10748-MAS19099-Range gain-Convenience_consumption_means_plug,activated ,3
    IDE10748-MAS19100-Range gain-Convenience_consumption_air_condition_ventilation_manually,activated ,3
    IDE10748-MAS19132-Range gain-Consumption_mirror_heating_in_heated_rear_window,activated ,3
    ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %,10
    ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold,100 ,10
    ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In,0 ms,10
    ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms,10
    ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out,0 ms,10
    ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms,10
    ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay,0 ms,10
    ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence,0 ms,10
    ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness,active ,3
    ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active ,3
    ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active ,3
    ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active ,12
    ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100 ,12
    ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms,12
    ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms,12
    ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,0 ms,12
    ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms,12
    ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms,12
    ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms,12
    ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,200 ms,12
    ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,125000 ms,12
    ENG137060-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active ,4
    ENG137060-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active ,4
    ENG137060-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active ,4
    ENG137060-ENG118686-EM_energy_management_warning_displays-MMI Vorwarnungen,Mode not active ,4
    ENG137075-EM_heating_power_quota_adjustment,1000 W,1
    ENG137061-EM_nominal_voltage_limitation_low_beams,12.1 V,1
    ENG137064-EM_requirement_cyclic_time_voltage_measurement,0 s,1
    ENG137063-EM_requirement_reduction_air_blowers,Mode not active ,1
    ENG137062-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C,2
    ENG137062-ENG137099-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C,2
    ENG137058-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled ,32
    ENG137058-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled ,32
    ENG137058-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled ,32
    ENG137058-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled ,32
    ENG137058-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled ,32
    ENG137058-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled ,32
    ENG137058-SFT00011-GW_Enable_CAN_Timeout_DTC-Auxiliary Air Heater,Enabled ,32
    ENG137058-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled ,32
    ENG137058-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled ,32
    ENG137058-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled ,32
    ENG137058-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled ,32
    ENG137058-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled ,32
    ENG137058-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled ,32
    ENG137058-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled ,32
    ENG137058-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled ,32
    ENG137058-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled ,32
    ENG137058-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled ,32
    ENG137058-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled ,32
    ENG137058-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled ,32
    ENG137058-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled ,32
    ENG137058-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled ,32
    ENG137058-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled ,32
    ENG137058-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled ,32
    ENG137058-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled ,32
    ENG137058-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled ,32
    ENG137058-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled ,32
    ENG137058-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled ,32
    ENG137058-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled ,32
    ENG137058-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled ,32
    ENG137058-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled ,32
    ENG137058-SFT00075-GW_Enable_CAN_Timeout_DTC-Multifunction module,Enabled ,32
    ENG137058-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled ,32
    ENG137058-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled ,32
    ENG137058-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled ,32
    ENG137058-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled ,32
    ENG137058-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled ,32
    ENG137058-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled ,32
    ENG137058-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled ,32
    ENG137058-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled ,32
    ENG137058-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled ,32
    ENG137058-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled ,32
    ENG137058-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled ,32
    ENG137058-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled ,32
    ENG137058-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled ,32
    ENG137058-SFT00128-GW_Enable_CAN_Timeout_DTC-Battery Regulation Auxiliary Accumulator 1,Enabled ,32
    ENG137058-SFT00130-GW_Enable_CAN_Timeout_DTC-Head Up Display,Enabled ,32
    ENG137058-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled ,32
    ENG137058-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled ,32
    ENG137058-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled ,32
    ENG137058-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled ,32
    ENG137058-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled ,32
    ENG137058-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled ,32
    ENG137058-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled ,32
    ENG137058-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled ,32
    ENG137058-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled ,32
    ENG137058-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled ,32
    ENG137058-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled ,32
    ENG137058-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled ,32
    ENG137058-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled ,32
    ENG137058-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled ,32
    ENG137058-SFT00207-GW_Enable_CAN_Timeout_DTC-Control Unit Lane Change Assistant 2,Enabled ,32
    ENG137058-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled ,32
    ENG137058-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled ,32
    ENG137058-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled ,32
    ENG137058-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled ,32
    ENG137058-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled ,32
    ENG137058-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled ,32
    ENG137058-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled ,32
    ENG137058-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled ,32
    ENG137058-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled ,32
    ENG137058-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled ,32
    ENG137058-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled ,32
    ENG137058-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled ,32
    ENG137058-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled ,32
    ENG137058-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled ,32
    ENG137058-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled ,32
    ENG137058-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled ,32
    ENG137058-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled ,32
    ENG137058-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled ,32
    ENG137058-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled ,32
    ENG137058-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled ,32
    ENG137058-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled ,32
    ENG137058-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled ,32
    ENG137058-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled ,32
    ENG137058-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled ,32
    ENG137058-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled ,32
    ENG137058-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled ,32
    ENG137058-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled ,32
    ENG137058-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled ,32
    ENG137058-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled ,32
    ENG137058-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled ,32
    ENG137058-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled ,32
    ENG137058-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled ,32
    ENG137058-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled ,32
    ENG137058-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled ,32
    ENG137058-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled ,32
    ENG137058-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled ,32
    ENG137058-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled ,32
    ENG137058-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled ,32
    ENG137058-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled ,32
    ENG137058-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled ,32
    ENG137058-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled ,32
    ENG137058-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled ,32
    ENG137058-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled ,32
    ENG137058-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled ,32
    ENG137058-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled ,32
    ENG137058-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled ,32
    ENG137058-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled ,32
    ENG137058-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled ,32
    ENG137058-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled ,32
    ENG137058-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled ,32
    ENG137058-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled ,32
    ENG137058-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled ,32
    ENG137058-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled ,32
    ENG137058-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled ,32
    ENG137058-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled ,32
    ENG137058-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled ,32
    ENG137058-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled ,32
    ENG137058-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled ,32
    ENG137058-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled ,32
    ENG137058-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled ,32
    ENG137058-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled ,32
    ENG137058-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled ,32
    ENG137058-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled ,32
    ENG137058-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled ,32
    ENG137058-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled ,32
    ENG137058-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled ,32
    ENG137058-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled ,32
    ENG137058-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled ,32
    ENG137058-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled ,32
    ENG137058-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled ,32
    ENG137058-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled ,32
    ENG137058-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled ,32
    ENG137058-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled ,32
    ENG137058-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled ,32
    ENG137058-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled ,32
    ENG137058-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled ,32
    ENG137058-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled ,32
    ENG137058-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled ,32
    ENG137058-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled ,32
    ENG137058-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled ,32
    ENG137058-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled ,32
    ENG137058-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled ,32
    ENG137058-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled ,32
    ENG137058-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled ,32
    ENG137058-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled ,32
    ENG137058-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled ,32
    ENG137058-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled ,32
    ENG137058-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled ,32
    ENG137058-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled ,32
    ENG137058-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled ,32
    ENG137058-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled ,32
    ENG137058-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled ,32
    ENG137058-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled ,32
    ENG137058-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled ,32
    ENG137058-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled ,32
    ENG137058-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled ,32
    ENG137058-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled ,32
    ENG137058-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled ,32
    ENG137058-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled ,32
    ENG137058-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled ,32
    ENG137058-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled ,32
    ENG137058-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled ,32
    ENG137058-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled ,32
    ENG137058-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled ,32
    ENG137058-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled ,32
    ENG137058-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled ,32
    ENG137058-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled ,32
    ENG137058-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled ,32
    ENG137058-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled ,32
    ENG137058-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled ,32
    ENG137058-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled ,32
    ENG137058-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled ,32
    ENG137058-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled ,32
    ENG137058-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled ,32
    ENG137058-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled ,32
    ENG137058-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled ,32
    ENG137058-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled ,32
    ENG137058-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled ,32
    ENG137058-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled ,32
    ENG137058-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled ,32
    ENG137058-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled ,32
    ENG137058-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled ,32
    ENG137058-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled ,32
    ENG137058-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled ,32
    ENG137058-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled ,32
    ENG137058-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled ,32
    ENG137058-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled ,32
    ENG137058-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled ,32
    ENG137058-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled ,32
    ENG137058-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled ,32
    ENG137058-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled ,32
    ENG137058-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled ,32
    ENG137058-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled ,32
    ENG137058-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled ,32
    ENG137058-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled ,32
    ENG137058-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled ,32
    ENG137058-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled ,32
    ENG137058-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled ,32
    ENG137058-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled ,32
    ENG137058-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled ,32
    ENG137058-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled ,32
    ENG137058-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled ,32
    ENG137058-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled ,32
    ENG137058-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled ,32
    ENG137058-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled ,32
    ENG137058-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled ,32
    ENG137058-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled ,32
    ENG137058-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled ,32
    ENG137058-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled ,32
    ENG137058-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled ,32
    ENG137058-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled ,32
    ENG137058-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled ,32
    ENG137058-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled ,32
    ENG137058-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled ,32
    ENG137058-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled ,32
    ENG137058-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled ,32
    ENG137058-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled ,32
    ENG137058-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled ,32
    ENG137058-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled ,32
    ENG137058-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled ,32
    ENG137058-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled ,32
    ENG137058-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled ,32
    ENG137058-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled ,32
    ENG137058-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled ,32
    ENG137058-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled ,32
    ENG137058-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled ,32
    ENG137058-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled ,32
    ENG137058-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled ,32
    ENG137058-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled ,32
    ENG137058-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled ,32
    ENG137058-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled ,32
    ENG137058-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled ,32
    ENG137058-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled ,32
    ENG137058-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled ,32
    ENG137058-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled ,32
    ENG137058-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled ,32
    ENG137058-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled ,32
    ENG137058-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled ,32
    ENG137058-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled ,32
    ENG137058-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled ,32
    ENG137058-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled ,32
    ENG137058-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled ,32
    ENG137058-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled ,32
    ENG137058-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled ,32
    ENG137058-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled ,32
    ENG137058-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled ,32
    ENG137058-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled ,32
    ENG137058-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled ,32
    ENG137058-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled ,32
    ENG137058-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled ,32
    ENG137058-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled ,32
    ENG137058-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled ,32
    ENG137058-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled ,32
    ENG137058-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled ,32
    ENG137058-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled ,32
    ENG137059-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain ,2
    ENG137059-ENG118465-GW_mirror_mode-mirror_mode_typ,not active ,2
    ENG137065-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    ENG137066-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    ENG137067-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    ENG137068-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    ENG137069-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    ENG137070-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    ENG137071-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    ENG137072-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    ENG137073-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    ENG137074-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00 ,12
    ENG118779-IDE02583-Multi_function_steering_wheel_control_module Coding Value-Steering wheel Tiptronic switch,not installed ,3
    ENG118779-MAS06614-Multi_function_steering_wheel_control_module Coding Value-Version,CCS ,3
    ENG118779-MAS09758-Multi_function_steering_wheel_control_module Coding Value-Temperature sensor,installed ,3
    ENG118779-ENG118724-Multi_function_steering_wheel_control_module Coding Value-development_1,active ,3
    ENG118779-ENG118725-Multi_function_steering_wheel_control_module Coding Value-development_2,not active ,3
    ENG118774-ENG98345-WakeUpMonitor_Activation-Activation,activated ,1
    ENG118774-ENG152567-WakeUpMonitor_Activation-Open_Filter_Activate,not activated ,1
    ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100 ,5
    ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s,5
    ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s,5
    LAST SCAN
    Sunday,18,March,2018,14:59:29:49498
    VCDS Version: 18.2.0.3 (x64)
    Workshop Code: 011 01357 000200
    VIN: WVWZZZAUZEW144891   License Plate:
    Mileage: 17548km-10903mi   Repair Order:
    Chassis Type: AU-VW37 (5Q0)
    Scan: 01 03 08 09 15 16 17 19 32 42 44 47 52 55 5F A9
    VIN: WVWZZZAUZEW144891   Mileage: 17548km-10903miles
    47-Sound System -- Status: Cannot be reached 0100
    Address 01: Engine (J623-CHHA)       Labels:. 06K-907-425-V1.clb
       Part No SW: 5G0 906 259     HW: 06K 907 425 B
       Component: 2.0l R4 TFSI  H13 0007
       Revision: --H13---
       Coding: 091900122424050B2000
       ASAM Dataset: EV_ECM20TFS0215G0906259 001011
       ROD: EV_ECM20TFS0215G0906259.rod
       VCID: 6BD25F9F8244AA1CDD-803E
    Readiness: 1010 0001
       Part No SW: 5Q0 907 379 CK    HW: 5Q0 907 379 G
       Component: ESC           H31 0472
       Revision: 00000000    Serial number: 626830000007B8
       Coding: 01FA6BA154242970037F060941C46980D62A94C0608296F700400079C009
       VCID: 071A032FBEEC6E7C59-8052
       Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
       Component: Climatronic   080 Z052
       Revision: 00001K07
       Coding: 00020004200100011005004000101000
       VCID: 73E247FFDA7472DC15-8026
       Serial number: 01061703800247
       Coding: 00000A46C24122FB4BE4400000080708100A000000000000000000000000
       ROD: EV_BCMBOSCH_015.rod
       VCID: 040014238FDA45643C-8050
       Component: WWS    130926  042 0551
       Serial number:         130927225315
       Component: RLFS  024 0042
       Serial number: Y13M09D28H19M20S59S1
       Coding: 06A8DD
    558100 - Databus
                        Reset counter: 29
                        Mileage: 17548 km
                        Date: 2018.03.18
                        Time: 14:30:55
       Component: AirbagVW20    014 0385
       Serial number: 003F6R00ZNE.
       VCID: 418EDD37D048904C57-8014
       Subsystem 1 - Part No SW: -----------    HW: 480 001 109 13
       Serial number: 35767000000A1A759D0/
       Subsystem 2 - Part No SW: -----------    HW: 480 001 009 13
       Serial number: 35867000000ED8409D04
       Subsystem 3 - Part No SW: -----------    HW: 480 402 709 13
       Serial number: 3516502AD1118A543091
       Subsystem 4 - Part No SW: -----------    HW: 480 402 709 13
       Serial number: 3526502AD1118A557255
       Subsystem 5 - Part No SW: -----------    HW: 480 402 509 13
       Serial number: 3556502C31142C83511-
    9447189 - Seat Occupied Sensor; Passenger's Side
              B1027 15 [137] - Open or Short to Plus
                        Mileage: 17548 km
                        Date: 2018.03.18
                        Time: 14:30:57
       Part No SW: 5Q0 953 507 AA    HW: 5Q0 953 549
       Revision: --------    Serial number: 24091304220220
       Coding: 0400
       ROD: EV_SMLSKLOMQB_013_AU37.rod
       VCID: 75E679E7D4006CEC3B-8020
       Part No SW: 5G6 920 870     HW: 5G6 920 870
       Component: KOMBI         314 2210
       Coding: 03AD09002B80000C04087E00040000
       VCID: 6CD05C83874AAD24D4-8038
       Revision: --------    Serial number: 0005526889
       Coding: 030100042B085900EF00066B080F00010001000000000000000000000000
       VCID: 7CF06CC3F72A3DA444-8028
       Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H06 0101
       Serial number: 27130002010240093502
       Coding: 2A0000
       Serial number: 7070981403
    131695 - Digital sound System control module
              U106A 00 [009] - No Communication
                        Reset counter: 29
                        Mileage: 17548 km
                        Date: 2018.03.18
                        Time: 14:30:56
                        Supply voltage: Terminal 30: 14.6 V
                        Terminal 15: On
    1029 - invalid data record
              B2005 00 [009] -  -
                        Reset counter: 29
                        Mileage: 17548 km
                        Date: 2018.03.18
                        Time: 14:30:56
                        Terminal 15: On
    Address 32: Differential Locks (J492)       Labels:* 0CQ-907-554.clb
       Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
       Component: Quersperre    H52 8038
       Serial number: HA1-00013.09.13
       Coding: 0001
       ASAM Dataset: EV_LockElectHA1VW37X 001001
       ROD: EV_LockElectHA1VW37X.rod
       VCID: 479AC32FFE6CAE7C99-8012
       Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
       Serial number: 050215BB301568
       Coding: 001F0320D000040000001000
       VCID: 428CD23BD54E8B544E-8016
       Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000002846731
       Part No SW: 3Q0 909 144 D    HW: 3Q0 909 144 E
       Component: EPS_MQB_ZFLS  502 5011
       Coding: 0101
       ASAM Dataset: EV_SteerAssisMQB 009026
       ROD: EV_SteerAssisMQB_009_VW37.rod
       VCID: 336287FF9AF432DCD5-8066
    Address 47: Sound System (J525)       Labels:| 5Q0-035-456.clb
       Part No SW: 5Q0 035 456     HW: 5Q0 035 456
       Component: MIB2_lite_amp H30 0150
       Revision: 00000001    Serial number: VWZ8Z1GBA02UBX/
       Coding: 12000000008AAA8A000000000000
       ASAM Dataset: EV_AMPMst11CGen2ALPI 001002
       ROD: EV_AMPMst11CGen2ALPI.rod
       VCID: 6DD65187BC50A42CC3-8038
       Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
       Serial number: 29081406070299
       Coding: 001F0120DE00040000801000
       Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A  Labels: 5QX-959-81X-V1.CLB
       Serial number: 00000000000002832675
       Coding: 090000
       Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
       Coding: 029A01000B010200
       VCID: 3D76A1C7ACB0F4AC33-8068
       Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo links  H05 0012
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
       Component: LeiMo rechts  H05 0012
       Coding: 2E0000
    Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
       Part No SW: 5NA 035 043 A    HW: 5NA 035 043
       Component: MU-H-N-EU     H41 1161
       Serial number: A599E0F7520138
       Coding: 027310010000000011110002000800031F0003B401000100DF
       VCID: 346084E39FFA35E4CC-8060
       Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
       Component: ABT_High-2  H40 9074
       Serial number: VWZ6ZFT0341456
       Subsystem 2 - Part No SW: V03 959 800 QS    HW: -----------
       Component: ECE 2018  --- 0166
       Component: Gracenote2  --- 1013
       Component: SAS-GEN 2     H06 0011
       Serial number: 130725200355
    End-------------------------(Elapsed Time: 04:21)--------------------------
  5. #24
    Oct 2017
    Italy
    Quote Originally Posted by MasterTommy View Post
    Well, inn the meantime while we're waiting for that; as far as 5F goes:
    IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,No ,3 >>> Set to 'Yes'
    Normally 5F slaves to the gateway regarding installation changes and sets this ^^^ channel to 'Yes' automatically when the Amplifier is registered in the gateway. Could be yet another sign you need to do something with that gateway.
    Two other channels i've found to be different:
    ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64 >>> Leave it like this
    ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64 >>> Set to 'Databus Infotainment'
    Hello guys,
    I changed the settings like these above but nothing has changed ...
    The errors remain!
  6. #25
    Sep 2015
    Hey guys,
    Basically brand new to the forums here. I'm trying to upgrade my Fender MIB1 to MIB2. I have got everything installed including the MIB2 amplifier. My buddy that works for VW was able to remove component protection from the 5F module but we were unable to get the 47 module to be readable. I have double checked the part number on the amp and have also tried a different MIB2 amplifier with no luck of 47 being recognized. Hoping this thread is a good place to look for help. Not sure how to get these adaptation scans. Any help for this noob is appreciated.
  7. #26
    Quote Originally Posted by BJAsayHEY View Post
    Please post an Auto-Scan so people can see what state your car is currently in.
  8. #27
    Sep 2015
    Ok, so I actually got the amp working! It was something in the 5F coding, but I seem to be having some of the same codes as Riddick remaining. Below is my autoscan. I will have component protection removed tomorrow for the amp. Was there any resolution to Riddick's codes?
    Monday,21,May,2018,21:23:45:30166
    VCDS Version: 18.2.1.2 (x64)
    VIN: WVWLF7AU6FW214275   License Plate:
    Mileage: 15738km-9779mi   Repair Order: MIBswapautoscan
    Scan: 01 02 03 05 08 09 10 14 15 16 17 19 22 2B 42 44 47 52 55 5F
              75 A9
    VIN: WVWLF7AU6FW214275   Mileage: 15738km-9779miles
    Address 01: Engine (J623-CYFB)       Labels:. 06K-907-425-V1.clb
       Part No SW: 8V0 906 259 H    HW: 06K 907 425 E
       Component: 2.0l R4 TFSI  H13 7010
       Revision: --H13---
       Coding: 091D00322426000E3000
       ASAM Dataset: EV_ECM20TFS0208V0906259H 001003
       ROD: EV_ECM20TFS0208V0906259H.rod
       VCID: 4580D782C4D4306C54-8010
    Readiness: 1110 0101
       Part No SW: 0D9 300 012 L    HW: 02E 927 770 AQ
       Component: DQ250-UM 977e H53 4523
       Revision: 03253104    Serial number: TFK01412091268
       ROD: EV_TCMDQ250021.rod
       VCID: 1F4C65EA06C80ABC3E-804A
       Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
       Component: ESC           H42 0610
       Revision: 00000000    Serial number: 63234000000893
       Coding: 01FA6BA1542109700579030741C86980D62A90A0C08296B7004000D8C208
       ROD: EV_Brake1UDSContiMK100IPB_034.rod
       VCID: 489EDEB6F3C62D04AF-801C
       Revision: 00021000    Serial number: 0355577311
       Coding: 030C0C
       VCID: 3A7AB47EBD2A4F9429-806E
       Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
       Revision: 00001K08
       Coding: 00020004200100000005000012111400
       VCID: 6ADA443E8D0A3F1499-803E
       Part No SW: 5Q0 937 085 AC    HW: 5Q0 937 085 AC
       Component: BCM MQBAB HNA H18 0137
       Serial number: 01011434201141
       Coding: 00011A46C041A2E169E44000091C07201800000000000000000000000000
       ROD: EV_BCMBOSCH_013.rod
       VCID: 7AFA747EFDAA8F9469-802E
       Component: WWS    141127  043 0551
       Serial number:         141204072741
       Component: RLHS  037 0059
       Serial number: S5Y14M12D18H18M42S18
       Coding: 06A8DD
       Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
       Component: PARKHILFE 8K  H03 0048
       Revision: --------    Serial number: 39391433803468
       Coding: 0031151011
       ROD: EV_EPHVA18AU3700000_002_VW27.rod
       VCID: 3D70BF62AC0478AC0C-8068
       Part No SW: 5Q0 907 376     HW: 5Q0 907 376
       Component: DAEMPFUNGS-SG H16 0115
       Serial number: 03121441350166
       ROD: EV_DRCONTITEMIC_VW27.rod
       VCID: 76E2604EC9B2EBF40D-8022
       Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
       Serial number: 003MHM00XGRB
       VCID: 51A8F3D2009CECCCF8-8004
       Occupant Detection:
       Component: BF-Gewichtss.  H10 0021
       Serial number: IBH0000J14000203JL0T
       Coding: 303058
       Subsystem 2 - Part No SW: -----------    HW: 480 000 412 14
       Serial number: 35700000000F8BD0321P
       Subsystem 3 - Part No SW: -----------    HW: 480 000 412 14
       Serial number: 35800000000EFC9C121$
       Subsystem 4 - Part No SW: -----------    HW: 480 400 512 14
       Serial number: 35100029918B3AB1034
       Subsystem 5 - Part No SW: -----------    HW: 480 400 412 14
       Serial number: 3520002C51811B95209X
       Subsystem 6 - Part No SW: -----------    HW: 480 400 512 14
       Serial number: 3550002C318B3AB283DE
       Front Sensor Passenger:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 412 14
       Serial number: 3560002A518B3AB572DG
       Part No SW: 5Q0 953 507 EA    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 05121404220499
       Coding: 0410
       VCID: 79F86B72F8AC848C60-802C
       Part No SW: 5G1 920 858     HW: 5G1 920 858
       Component: KOMBI         304 4270
       Coding: 0BAD081A3B80CF0502086A001400000000000000
       VCID: 6DD04F22BCE4282CFC-8038
       Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1204
       Revision: --------    Serial number: 0002850996
       Coding: 0101000820085900EF00022A9C0F00000001050000000000000000000000
       ASAM Dataset: EV_GatewLear 011020
       ROD: EV_GatewLear_011_VW37.rod
       VCID: 72EA5C5EA5DAF7D421-8026
       Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
       Component: E221__MFL-DC1  H10 0101
       Serial number: 29140002591150104482
       Coding: 31FFFF
                        Reset counter: 107
                        Mileage: 15738 km
                        Date: 2018.05.21
                        Time: 21:17:26
                        Supply voltage: Terminal 30: 12.0 V
                        Terminal 15: On
              U1101 00 [009] - Active
                        Reset counter: 107
                        Mileage: 15738 km
                        Date: 2018.05.21
                        Time: 21:17:26
                        Terminal 15: On
       Serial number: HA1-00005.11.14
       Coding: 0001
       VCID: 4682D08EF9D23B745D-8012
       Revision: 00000000    Serial number: 14000345258005
       Coding: 5D00000000000000
       ROD: EV_ELVMarquMQB.rod
       VCID: 34669A469F4EB9E4F3-8060
       Serial number: 031214BL305446
       Coding: 003E13208000040000000000
       VCID: 428ACC9ED5FA075471-8016
       Serial number: 00000000000004762904
       Coding: 111000
       Coding: 8102
       VCID: 377CAD4A8E3852FCD6-8062
       Component: MIB2_lite_amp H20 0130
       Revision: 00000001    Serial number: VWZ8Z1FBA013LPD
       Coding: 2200000000AAAAAA000000000000
       ASAM Dataset: EV_AMPMst12C1Gen2ALPI 001003
       ROD: EV_AMPMst12C1Gen2ALPI.rod
    15360768 - Component Protection
                        Reset counter: 107
                        Mileage: 15738 km
                        Date: 2018.05.21
                        Time: 21:17:25
                        Voltage terminal 30: 12.2 V
       Serial number: 111214BLB05998
       Coding: 003E13208000040000800000
       VCID: 4188C392D0FC1C4C68-8014
       Serial number: 00000000000004758278
       Coding: 091000
       Coding: 022202000B000400
       VCID: 408EC696DBF6154467-8014
       Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
       Coding: 2E0000
       Part No SW: 3Q0 035 844     HW: 3Q0 035 844
       Component: MU-S-S-US     620 0613
       Coding: 027300000000000051220002001808001F0107F40120010002
       ROD: EV_MUStd4CDELP_VW27.rod
       VCID: 6CD6422687FE2124EB-8038
       Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
       Component: ABT_Std-2  H52 1028
       Serial number: VWZ8Z9RES003F9
              B201A 00 [009] -  -
                        Reset counter: 107
                        Mileage: 15738 km
                        Date: 2018.05.21
                        Time: 21:17:25
                        Voltage terminal 30: 12.1 V
                        Status_Software_Version_Management-module_name: C
              B11CF 53 [009] - Deactivated
                        Reset counter: 107
                        Mileage: 15738 km
                        Date: 2018.05.21
                        Time: 21:18:17
                        SDARS_tuner_status_2-Antenna current: 143 mA
                        SDARS_tuner_status_2-Reception quality: No_signal
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation status: 05
                        SDARS_tuner_status_2-Satellite radio tuner: pre-activation value: 05
       Component: OCULowMQBUS   007 0564
       Coding: 02730202C2821A017F1E06020000
       ROD: EV_OCULowMQB.rod
       VCID: 4384C99ACAE00E5C7A-8016
       Part No SW: 5G0 907 159 B    HW: 4H0 907 159 A
       Component: SAS-GEN 2     H07 0006
       Serial number: 141028202096
       VCID: 2D508F227C64E82CBC-8078
    End-------------------------(Elapsed Time: 04:53)--------------------------
  9. Likes Uwe liked this post
  10. #28
    May 2017
    I don't think your 5F coding is still correct.
    Byte 4 - 8 is sound system installed and in your case it's set to 00 00 00 00. Sound system coding is AA 00 00 00. These 4 bytes tells the 5F which outputs and frequency ranges to enable. HT and/or TT and from which output.
    Also byte 11 should be 03 which means external sound system => AMP.
    So based on this my proposal for coding is :
    02730000AA00000051220003001808001F0107F40120010002
    For the SVM error, google that and you'll find lot's of guides how to get rid of that. The tuner, it is disabled in coding but not sure if it really is. Check the adaptations, most likely still enabled there.
  11. Likes Uwe liked this post
  12. #29
    Sep 2015
    Well gentlemen. I have sorted the error in the CAN Gateway for:
    After a lot of tinkering and searching other forums for users with issues after a MIB1>2 swap, I fixed the issue by simply deselecting 47 from the Gateway installation list. If I understood correctly it is something along the lines of 47 being a subsystem of 5F detected through the MOST network. After unchecking 47 from the installation list the error went away and my autoscan no longer says:
    I am happy to have resolved this and hope this helps Riddick if he is still having this issue. However I cannot for the life of me figure out why I am getting the code:
    Any further help or advice on this code would be greatly appreciated. Cheers!
    Edit for latest autoscan:
    Monday,28,May,2018,15:47:21:30166
    Mileage: 16002km-9943mi   Repair Order:
              75 A9
    VIN: WVWLF7AU6FW214275   Mileage: 16002km-9943miles
       Revision: --H13---
    Readiness: 1010 0101
       Coding: 030C0C
       Revision: 00001K08
       Coding: 06A8DD
    204290 - Remote key 1
              B1479 18 [009] - Current Too Low
                        Reset counter: 114
                        Mileage: 16002 km
                        Date: 2018.05.28
                        Time: 15:26:21
       Coding: 0031151011
       Occupant Detection:
       Coding: 303058
       Coding: 0410
       Coding: 31FFFF
       Coding: 0001
       Coding: 111000
       Coding: 8102
       Coding: 091000
       Coding: 2E0000
       Coding: 2E0000
       Coding: 027300000000000051220002001808001F0107F40120010502
              B201A 00 [009] -  -
                        Reset counter: 114
                        Mileage: 16002 km
                        Date: 2018.05.28
                        Time: 15:21:53
                        Voltage terminal 30: 14.2 V
                        Reset counter: 114
                        Mileage: 16002 km
                        Date: 2018.05.28
                        Time: 15:22:02
                        Voltage terminal 30: 14.3 V
    End-------------------------(Elapsed Time: 04:55)--------------------------
  13. Likes Riddick20 liked this post
  14. #30
    Well, that's uhm, different....
    I believe the error "Tuner for Satelite Radio - Deactivated" just indicates that you do not have an active Sirius/XM subscription.
  15. Likes BJAsayHEY liked this post
