How to enable Drive select on an A4 B9 2017?
Molemans
C?ID=215708
Hi all
how to enable drive select, It worked before coding the comfort module and now it shows not available on the MMI.
Thank you.
rlarsen
Copenhagen, Denmark
C?ID=78998
Look in the logs folder under your VCDS installation, and post what you have changed - Codings and/or Adaptation Channels from and to
Molemans
C?ID=215708
Tuesday,09,January,2018,20:23:52:49819
VCDS Version: 17.12.0.1 (x64)  HEX-V2 CB: 0.4411.4
Data version: 20171213 DS285.1
VIN:    License Plate:
Mileage: 32922km-20456mi   Repair Order:
Chassis Type: F4-AU49 (8W6)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 3C 42 44 46 47 52 5F 6C
          81 A5 BB BC CA CF D6 D7
VIN: Mileage: 32922km-20456miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CYMC)       Labels: None
   Part No SW: 8W0 906 259 C    HW: 06L 907 425
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 0A2500322326010E34280000000000000000000000000000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TFS0208W0906259C 001005
   ROD: EV_ECM20TFS0208W0906259C.rod
   VCID: 41DFB8440105E3B9D04C-8014
Readiness: 1010 0101
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 8W1 927 155 B    HW: 0CK 927 156 S
   Component: 0CL 20TFSINAR H06 0003
   Revision: --H06---    Serial number: 0000000100
   ASAM Dataset: EV_TCMDL382021 002023
   ROD: EV_TCMDL382021_AU48.rod
   VCID: 3FDBBEBC77F19549A6B8-806A
   Manual Transmission Fluid Pump:
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  HB1 0572
   Serial number: 75117051150334000996
Address 03: ABS Brakes (J104)       Labels:. 8W0-907-379-PLU-V1.clb
   Part No SW: 8W0 907 379 E    HW: 8W0 907 379 J
   Component: ESP9 Plus     H06 0593
   Coding: 18AA409928A20A9815A4489900855292E6259A18021450A812004A4967A459
   Shop #: WSC 61656 001 1048576
   ASAM Dataset: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X_012.rod
   VCID: 47CBA65C2F21DD891E08-8012
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
   Component: Klima Zone 3  H32 0052
   Coding: 140805085548000D10000100800000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 372BD69C5FC1AD096EE8-8062
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000687399
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: 15E84AD7000000000001
   Subsystem 3 - Part No SW: 8W0 919 158 A    HW: 8W0 919 158 A
   Component: Klima Heck  H34 0050
   Part No SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0228
   Coding: 07500363E0081CCD0115871518AC98BB11033D00000000000000000020001A010A690122025505
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 00597D404A8F2AB19FC2-8054
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 151009  043 0813
   Serial number: 894353?0401528203101
   Coding: 5BC7F7
   Serial number: 60995248
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 N    HW: 4M0 941 531 N
   Component: E1 - LDS  H06 0008
   Serial number: 30 08 2015  00082828
   Subsystem 4 - Part No SW: 4M0 907 410 A    HW: 4M0 907 410 A
   Component: USHL5  H04 0040
   Serial number: 0000009600335Z08SV02
   Coding: 350000
   Garage Door Opener Operating Unit:
   Subsystem 5 - Part No SW: 4M0 959 719 A    HW: 4M0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20151118105834 00239
   Subsystem 6 - Part No SW: 8W0 857 511 B    HW: 8W0 857 511 B
   Component: Y7_Innenspieg  H01 0002
   Serial number: GX1CE130101511910378
   Interior Light Module:
   Subsystem 7 - Part No SW: 8W0 947 135 AN    HW: 8W0 947 135
   Component: J528-Dachele  H13 0080
   Serial number: Q00026115
   Subsystem 8 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H15 0010
   Serial number: 2615000118889002
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 A    HW: 8W0 959 655 A
   Component: Airbag10.44   H64 0086
   Serial number: 003N8000E016
   Coding: BFCCF0C000800000A0000033C24C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
   Component: BeltPretRevFL  306 2033
   Serial number: 8W0857705C0218Q00881
   Coding: 80000D
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
   Component: BeltPretRevFR  306 2033
   Serial number: 8W0857706C0327P01475
   Coding: 80000D
   Occupant Detection:
   Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
   Component: BF-Gewichtss.  H10 0021
   Serial number: IBH0000J150003RHDD0F
   Subsystem 4 - Part No SW: -----------    HW: 442 060 611 15
   Component: SideSensor_Df  1E2 0887
   Serial number: 3577Y00A31AF3CF4740B
   Subsystem 5 - Part No SW: -----------    HW: 442 060 611 15
   Component: SideSensor_Pf  1E2 0887
   Serial number: 3587Y00AD1AF3CF1E2F$
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 411 15
   Component: SideSensor_Dr  1C7 0148
   Serial number: 3517700B11E0EE95636L
   Subsystem 7 - Part No SW: -----------    HW: 442 0B0 411 15
   Component: SideSensor_Pr  1C7 0148
   Serial number: 3527700AF1E0EE95608Y
   Subsystem 8 - Part No SW: -----------    HW: 442 0C2 611 15
   Component: FrontSensor_D  1C5 014A
   Serial number: 3557500A51DEC3E253DY
   Front Sensor Passenger:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C2 611 15
   Component: FrontSensor_P  1C5 014A
   Serial number: 3567500A31DEC3E3145N
   Part No SW: 4M0 907 129 GK    HW: 4M0 907 129 GK
   Component: Lenks.Modul   H11 0008
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 7F5BFEBC37715549E638-802A
   Part No SW: 8W5 920 890 B    HW: 8W5 920 890 B
   Component: FBenUSA       H11 0275
   Coding: 08E751C1288CD705022B79601800000000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   ROD: EV_DashBoardAU736_AU49.rod
   VCID: 42DDB7480403F8A1C956-8016
   Part No SW: 8W6 907 468     HW: 8W6 907 468
   Component: Gateway       H11 2079
   Revision: 3R050039    Serial number: 3983R007716219
   Coding: 0301000100000F4029000000005900104C100007000000000175070E00000000
   ASAM Dataset: EV_CGateCONTIAU491 002040
   ROD: EV_CGateCONTIAU491_002_AU49.rod
   VCID: 074B665C6FA11D89DE88-8052
   Subsystem 1 - Part No SW: 8W0 951 523 H    HW: 8W0 951 523 H
   Component: J453 MFL  H04 0002
   Serial number: 20151110052535 RD118
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 5467628403
Address 29: Left Light (J1018)       Labels: 4M0-907-397.clb
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0022
   ASAM Dataset: EV_LCMLeftHELLAAU736 001011
   ROD: EV_LCMLeftHELLAAU736_VW48.rod
   VCID: 78A915A0125F6271A772-802C
   Part No SW: 4M0 959 760     HW: 4M0 959 760
   Component: MEM-FS        008 0015
   Serial number: 00000187089918
   Coding: 005C1B000000B0010000210101010000000000000000000000000000000000
   ASAM Dataset: EV_SCMDriveSideCONTIAU736 006007
   ROD: EV_SCMDriveSideCONTIAU736.rod
   VCID: 75B71C94054D1F19BC54-8020
9655892 - Motor for Seat Backrest Adjustment
          B1356 54 [041] - Missing Calibration / Basic Setting
                    Reset counter: 169
                    Mileage: 32922 km
                    Date: 2018.01.09
                    Time: 16:00:03
9655380 - Motor for seat height adjustment
          B1354 54 [041] - Missing Calibration / Basic Setting
                    Reset counter: 169
                    Mileage: 32922 km
                    Date: 2018.01.09
                    Time: 16:00:03
Address 39: Right Light (J1023)       Labels: 4M0-907-397.clb
   ASAM Dataset: EV_LCMRightHELLAAU736 001011
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 3431E1904EB746114BCA-8060
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000176050505
   Coding: 005F1B205E001080000100B2
   ROD: EV_DCU2DriveSideMAXHCONT.rod
   Part No SW: 8W0 909 144 D    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0405
   Coding: 09000080008000
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X_002.rod
   VCID: 3E25C3B870FB9C41ADAE-806A
   Part No SW: 8W0 907 064 AC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   016 0307
   Coding: 013400004F100080659FA0002E01000233024000000023502F0400000B04803F001E0001000000
   Shop #: WSC 00008 444 12345
   ASAM Dataset: EV_BCM2HellaAU736 010010
   ROD: EV_BCM2HellaAU736_010_AU49.rod
   VCID: 7DA704B43D7D4759F424-8028
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   Serial number: 000000000ZY1529308BA
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000064209862
   Subsystem 3 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94036540
   Part No SW: 8W0 035 223 B    HW: 8W0 035 223
   Component: MIB2_amp_P_B9 H06 0250
   Revision: 00000001    Serial number: AUZ8ZAFH6004V1U
   Coding: 0194010800AFAAAFAA0000010000
   ASAM Dataset: EV_AMPMst16C2Gen2ALPI 001012
   ROD: EV_AMPMst16C2Gen2ALPI.rod
   VCID: 3039ED80BAAF7A312F22-8064
   Part No SW: 4M0 959 792 D    HW: 4M0 959 792 C
   Component: TSG BFS       009 0039
   Serial number: 0000174366789
   Coding: 005F1B205E001080000100B0
   ROD: EV_DCU2PasseSideMAXHCONT.rod
Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGH2.clb
   Part No SW: 8W0 035 880     HW: 8W0 035 880
   Component: MU-P-LNS-US   051 0377
   Serial number: A400K0FB001179
   Coding: 019401020000000053220002041A00102F0002E501700104FE
   ROD: EV_MUHig6C3Gen2HBAS_AU49.rod
   VCID: 77AB169C1F416D09AE68-8022
   Subsystem 1 - Part No SW: V03 959 801 PS    HW: -----------
   Component: NAR 2018  --- 0063
   Subsystem 2 - Part No SW: 8W0 919 605     HW: 8W0 919 605
   Component: AU49x_DU_HIGH  H40 0008
   Serial number: AUZ8Z9FBJ00703
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 P    HW: 8W0 919 614 P
   Component: ControlUnit_H  H22 0139
   Serial number: C1000022101500020225
   Component: Gracenote2  --- 3007
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 169
                    Mileage: 32922 km
                    Date: 2018.01.09
                    Time: 16:00:08
                    Voltage terminal 30: 15.1 V
                    BAP-BAP_Function_ID: 02
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 4M0 980 556     HW: 4M0 980 556
   Component: RVC Compact   H08 0130
   Coding: 0294010102002001000040
   ASAM Dataset: EV_CamSysRVRVCPANAMLBEv 004008
   ROD: EV_CamSysRVRVCPANAMLBEv_004.rod
   VCID: 72BD27887423082199B6-8026
   Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20151111000657
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736_VW53.rod
   VCID: 3537DC9445CD5F197CD4-8060
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
   Part No SW: 8W0 907 217 A    HW: 8W0 907 217
   Component: BVS           H13 0030
   Coding: 0404090100000201022023A2A50000FC00F0C020C000
   ASAM Dataset: EV_BVSMLBevKOSTAAU736 002022
   ROD: EV_BVSMLBevKOSTAAU736.rod
   VCID: 3A2DCFA86CD3B0619186-806E
   Part No SW: 4M0 959 795 D    HW: 4M0 959 795 C
   Component: TSG HFS       009 0039
   Serial number: 0000175896822
   Coding: 004F1B2000001080400000A0
   ROD: EV_DCU2RearDriveMAXHCONT.rod
   Component: TSG HBFS      009 0039
   Serial number: 0000176256939
   ROD: EV_DCU2RearPasseMAXHCONT.rod
   Part No SW: 4M0 907 594 A    HW: 4M0 907 594
   Component: SAD_STG_1     011 0003
   Coding: 208000049100
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 0E8002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
   ROD: EV_RearRadarS2BoschAU736.rod
   VCID: 313FE884B1A57339202C-8064
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 16753B18380BB401551E-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:04, VBatt start/end: 15.1V/15.0V)-----------
Porto91
Unverified
Romania
LP/IP
Hi Molemans. I know it's been a while, but did you ever succed to activate back the Audi Drive Select? I want to retrofit it on my A4 B9, I installed the buttons, now I need the right coding . Can you help me? Thank you!
Are you 100% sure that Drive Select can be enabled and that it is NOT SwAP that requires a FeC code?
Porto91
Unverified
Romania
LP/IP
No, I'm not sure, but on A4 B8 it can be done, there are several videos on youtube so i'm thinking it can be done on A4 B9 as well. I've asked about this on my dealer and they don't want to code modules that are not from factory, based on VIN. I already made the Auto Hold retrofit and I want to retrofit ADS as well.
diskoboy
C?ID=50403
Audi A4 B8 is ooooooooold... totally different car than A4 B9. Best guess it does require SWAP codes
downtime
C?ID=280813
^ diskoboy is correct. SWAP function so you need to buy the official aftermarket kit for the car (if available).
Porto91
Unverified
Romania
LP/IP
Interesting, my Audi Dealer said they don't do that. If it's not from factory on the car, they have nothing to do. Maybe they don't know how to do it either ..
downtime
C?ID=280813
Audi most likely does not sell the drive select as aftermarket kit like VW does for Golf and some other models. So no official way to get drive select then I'm afraid :(
