AdBlue Adaptation
   #41
barbarmi
C?ID=217814
Another way to find out is to unplug and see if you get a DTC for short to open.
Thanks, I did check for DTCs with the motor unplugged, no DTCs showed. So I agree the transfer pump is likely not monitored.
You may in fact be experiencing the tanks completing a gravity feed only to the one tank and is why you get the warning.
I agree I am experiencing the gravity feed to the Aux/Reserve tank, (hence it being full). Also, when I get the warning I can only add about 1 gal of AdBlue to the main tank. Which would also seem to confirm only the main tank fluid is ever available (the 3000mi between warnings).
Digging into the measuring blocks the Channel 105 shows " 0 (no units) 3 (no units) 17 (no units) 88.0 l Tank Cont" which seems to be an implausible reading for the main fluid level (88.0 l Tank Cont), which has me concerned the level sensor in the main tank may also be a problem.
Trying to figure out if the transfer pump is triggered by Main Tank level or some other event (every time the vehicle is started etc). If it is triggered off of the tank level this may also be the problem.
Any help is appreciated.
   #42
Well you could trick the level sender and than measure for transfer voltages at the pump.
This way you can verify the conditions needed.
I would also pull the WD and or tone generate the tracks to track all related devices.
   #43
barbarmi
C?ID=217814
I did trace the WD for the transfer pump, problem is the transfer pump is connected directly to the control module (like everything else). So without knowing which specific signals the control module is using to turn the transfer pump on and off I am into checking every device connected to the control module.
The fact the main tank level indicator is showing such a high value (88.0 l) makes me suspicious of the sensor, but that could be associated with not being able to perform the adaptation.
At this point in time I am planning on putting everything back together with the new pump and see what happens. At least I'll know the transfer pump is good, if the problem persists I know to start tearing into the main tank and the sensors.
Thanks for all the suggestions and help. I'll post updates as I learn.
   #44
Does the module support outputs to be pulsed for the transfer pump or does it commence when Outputs are queried?
I would check.........
   #45
Sprocket
Detroit
C?ID=162267
Well, approx 10,500 miles later the codes & the countdown came back on for the AdBlue.
Sunday,15,February,2015,21:43:38:03916
VCDS Version: Release 14.10.1 (x64)
                Address 01: Engine       Labels: 059-907-401-CAT1.clb
Control Module Part Number: 7L0 907 401 T    HW: 7L0 907 401 K
  Component and/or Version: 3.0TDI EDC17G004AG  0100
           Software Coding: 0421002A590F0D68
            Work Shop Code: WSC 40662 001 1048576
                      VCID: 3C778E167C64EBC1728-5124
008430 - SCR NOx Catalyst Bank 1
               P20EE - 001 - Efficiency too Low - Intermittent
                    Fault Status: 00100001
                    Mileage: 158857 km
                    Date: 2015.01.28
                    Time: 14:47:38
                    RPM: 2331 /min
                    Speed: 117.6 km/h
                    Voltage: 14.59 V
                    Temperature: 288.0*C
                    (no units): 0.52
                    (no units): 0.63
                    (no units): 1.20
008251 - Reductant Level Sensor
               P203B - 001 - Implausible Signal - Intermittent
                    Fault Frequency: 13
                    Mileage: 160573 km
                    Date: 2015.02.12
                    Time: 14:42:24
                    RPM: 777 /min
                    Voltage: 13.98 V
                    Load: 12.2 %
                    Temperature: -5.4*C
                        4.9 bar
                    Temperature: 7.2*C
008319 - Reductant Quality Performance
               P207F - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 160755 km
                    Date: 2015.02.15
                    Time: 21:26:16
                    RPM: 2205 /min
                    Speed: 112.0 km/h
                    Voltage: 13.98 V
                    Temperature: 264.0*C
                    (no units): 0.00
                    (no units): 0.29
                    (no units): 1.47
Readiness: 1 1 0 0 0
I tried a couple of things last night to resolve the above issues, but the 008319 Reductant Quality Performance keeps coming back on along with a warning that I have 450 miles until no restart.
Here's what I did:
I pulled the AdBlue injector out of the exhaust system and noticed that the port the nozzle sits in was approx 90% blocked with crystallized AdBlue.
I also checked the nozzle itself and it wasn't that dirty, but cleaned it off as best I could. Here is a picture before cleaning.
Please note that the part # has now been superseded to suffix "C".
Here is the port the nozzle sits in after cleaning and sucking out the debris.
I thought this would surely solve my issue, but after doing a hard reset via pulling the fuse, the low AdBlue light & 450 mile warning came back on. Only 1 fault code showed up this time though.
Monday,16,February,2015,18:26:53:03916
                    Mileage: 160820 km
                    Date: 2015.02.16
                    Time: 17:56:23
                    RPM: 2310 /min
                    Speed: 40.3 km/h
                    Voltage: 14.14 V
                    Temperature: 246.0*C
                    (no units): 0.00
                    (no units): 0.22
                    (no units): 1.47
I tried to remove the rear Nox sensor to clean it like Jack suggested, but I couldn't get it to budge. I put some PB blaster on it and am letting it soak in and will try again tonight.
I'm open to thoughts or suggestions on what else to check. I'm wondering if the low temp here in Michigan the last few days is playing a part on the 008251 Reductant level sensor. I know the AdBlue will freeze at approx 12F and we've been in the -10 to +10 range these last few days. Granted there is a AdBlue heater, but not sure how quickly / effectively it works in these temps.
Sprocket
Detroit
C?ID=162267
Heat with torch at thread points and than loosen it up.
Yeah it could freeze with these temps.
Success! Removed the rear Nox sensor and heated it up like you suggested and so far so good. The 008319 code for reductant quality and low AdBlue warning went off immediately after re-installing the sensor and restarting the vehicle.
I also checked my rear Nox sensor control module to see what version it is. Part# 059-907-807-D is what I have installed, but that has also been superseded to 059-907-807-G. Not sure what the difference between the two is though.
I'll keep an eye on everything and update this thread if anything changes down the road.
Thanks for all the help so far!
   #48
Sprocket
Detroit
C?ID=162267
Update, the saga continues. I ended up purchasing the heater repair kit for inside the AdBlue tank which fixed the low fluid level & temp sensor related issues I was having. However, now I'm getting the P2OEE code again:
VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
Sunday,17,May,2015,12:13:31:03916
Chassis Type: A9 (6N0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2E 34 37 46 47 55 56 65 68
          69 6C 6D 6E 76 77
VIN: WVGAK7A94AD002442   Mileage: 171320km-106453miles
68-Wiper Electr. -- Status: OK 0000
6E-Ctrl Head Roof -- Status: OK 0000
Address 01: Engine (CAT)       Labels: 059-907-401-CAT1.clb
   Part No SW: 7L0 907 401 T    HW: 7L0 907 401 K
   Component: 3.0TDI EDC17G004AG  0100
   Revision: 33H02---    Serial number: VWX3Z0I6903246
   Shop #: WSC 40662 001 1048576
   VCID: 3C778E167C64EBC1727-5124
               P20EE - 001 - Efficiency too Low - MIL ON
                    Fault Status: 11100001
                    Mileage: 169561 km
                    Date: 2015.05.07
                    Time: 18:05:04
                    RPM: 2184 /min
                    Speed: 110.9 km/h
                    Voltage: 14.14 V
                    Temperature: 258.0°C
                    (no units): 0.00
                    (no units): 0.55
                    (no units): 1.37
   #50
DrPeter
16.4905° S, 151.7375° W
P20EE - SCR NOx Catalyst Efficiency Below Threshold; Bank 1
The above sets when:
"Difference between simulated efficiency of a non defective system under the current operating conditions and the measured actual efficiency > 40%"
- In other words, the ECM does not think your NOx reduction system is working the way it should, too much NOx is being detected.
- How far was the vehicle driven?
Please have a look at the MVB-183, field 1 and tell us what you see.
- Also, is the AdBlue strong enough? Check the concentration, it can be tested with a refractometer.
ASTM D7821 Standard
Thanks,
drpeter
   #51
Sprocket
Detroit
C?ID=162267
ASTM D7821 Standard
Thanks,
drpeter
Hello Dr. Peter,
MVB-183 shows 1.32. What does this tell us?
Old AdBlue was removed & fresh / new AdBlue added when I replaced the heater repair kit in the AdBlue tank. PEAK Blue DEF has been used as well as the AdBlue from the VW dealer. Tank has been emptied and refilled 2x since I've owned the vehicle from Oct, 2014. I've also consistently topped off the tank every 10k miles.
As for how far the vehicle has been driven. It's a sporadic fault that seems to come and go as it pleases since I purchased the vehicle with approx 89k miles on it. It now has 107,931 miles. Presently, not showing any faults, but I know that will change again in a day or two.
Just trying to figure out if it's the NOx sensor itself, the AdBlue injector not injecting sufficient quantity, or something else.
This seems to be a common problem with Audi & VW's with AdBlue treatment systems. Some dealers are just replacing the entire AdBlue components, which I wouldn't have a problem with if VW was footing the bill, but I'm way out of warranty and don't want to just throw parts at it and drain my wallet in the process.
   #52
You could have a bad CAT or the CAT is restricted with contaminates.
Remove it and clean it.........just as you would clean a DPF.
I have found that chemical removal works well for all three.
CAT/DPF, NOX and OXS.
I have been developing a system to as a matter of speech " ass rape the tail pipe enema ".
I take magical chemicals...... then blow them up to the DPF/turbo with the scrubbing bubbles + water and air PSI adding a blockage plate to turbo and bubbling it for 30 minutes........ then back flush and run it HOT Farting the car!
So far it's showing promise with the bore camera.........proctologist's look out.
   #53
DrPeter
Sorry for the delay. . . .
Measuring Value Block Group [183] field 1 = SCR Learned Adaptation value
1.01 = Baseline (center) (not 1.00)
Acceptable Range = 0.90 to 1.10
A value greater than 1.00 = adding more reducing agent (example 1.20 = clogged injector, High DPF content, etc...)
A value less than 1.00 = taking away reducing agent (example 0.80 = leaking injector, etc. . )
Hope this helps,
drpeter
   #54
Sprocket
Detroit
C?ID=162267
So are there more tests or measuring value blocks that can help to pin point exactly what part(s) needs to be replaced to solve the DTC I keep getting?
I'd really like to fix the issue below myself if at all possible vs having to take it to the dealer.
Thanks to everyone who has tried to help me so far.
   #55
pincusa
C?ID=97500
The process in posting #17 was a great help and was the only way to resetting the mileage countdown on my 2009 T'egg. In hoping it might help someone else, I created a youtube video running through the process.
Thanks again for posting this Sprocket!
jocker01
Steinbach, MB, Canada
C?ID=194603
Hi
So today I was called by a local mechanic which is struggling with removing adblue warning message. Unfortunately I was unsuccessful too :(
Wednesday,16,June,2021,18:11:01:03250
VCDS Version: 21.3.0.0 (x64)  HEX-NET2 CB: 0.4544.4
Data version: 20210226 DS325.0
VIN: WVGFK6A90AD002910   License Plate: BLUE
Scan: 01 02 03 05 08 09 0F 15 16 17 19 1C 22 46 56 68 69 6E 77
VIN: WVGFK6A90AD002910   Mileage: 184200km-114456miles
6E-Ctrl Head Roof -- Status: Malfunction 0010
Address 01: Engine (CAT)       Labels:. 059-907-401-CAT1.clb
   Component: 3.0TDI FSA  G004AG  0140
   Revision: 33H02---    Serial number: VWX3Z0J2905254
   Coding: 0421002A590F0968
   VCID: 3C2A5F387A7B6CCB93B-5184
   Part No SW: 09D 927 750 LD    HW: 09D 927 750 LD
   Component: AL 750 6A           3405
   Revision: 00H75000    Serial number:
   Coding: 0004984
   Shop #: WSC 57150 003 1048576
   VCID: 7BA89C243FF5ABF3DA1-5160
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25E1.clb
   Part No SW: 7L0 907 379 P    HW: 7L0 614 517 C
   Component: ESP ALLRAD MK25E1   0304
   Revision: 00H53001
   Coding: 0004354
   Shop #: WSC 31414 790 00001
   VCID: 46DE3DD034B7261BF5F-5184
                    Fault Frequency: 12
                    Reset counter: 199
                    Mileage: 184207 km
                    Date: 2021.05.04
                    Time: 16:32:12
                    Count: 64
                    Count: 6145
                    Count: 128
                    Count: 255
                    Fault Frequency: 65
                    Reset counter: 199
                    Mileage: 184207 km
                    Date: 2021.06.01
                    Time: 16:13:21
                    Count: 128
                    Count: 4353
                    Count: 294
                    Count: 1
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 135 C    HW: 7L0 909 135 C
   Component:    Kessy            6850
   Revision: 00H22072    Serial number: VWX3Z0J2905254
   Coding: 0000232
   VCID: 31347E0CAD6991A330D-8064
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 AL
   Component: CLIMAtronic R/L     4537
   Coding: 0003020
   VCID: 7AA69920309F92FBC17-802E
00003 - Control Module
            014 - Defective
                    (no units): 2.0
                    Temperature: 31.0°C
                    Temperature: 51.0°C
00532 - Supply Voltage B+
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V2.clb
   Part No SW: 7L6 937 049 AF    HW: 7L6 937 049 AF
   Component: J519                2004
   Revision: -0004---    Serial number: --------------
   Coding: 030002002C00BC000000000000000000
   VCID: 0052EBC85643C82B8F3-8054
00576 - Terminal 15
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7J0567221
   Coding: 0000102
   VCID: 363E4D104447B69B65F-8062
                    Reset counter: 199
                    Mileage: 184206 km
                    Date: 2021.06.07
                    Time: 01:46:17
Address 15: Airbags        Labels: 7L0-959-655.lbl
   Part No SW: 7L0 959 655 A    HW: 7L0 959 655 A
   Component: J234__0B VW8T       0270
   Revision: 92013027    Serial number: 003C6001BRCT
   Coding: 0012354
   VCID: 3B285C247F256BF39A1-806E
   Part No: 7L6 953 549 F
   Component: J527                3601
   Coding: 0010011
   VCID: 42D621C018CF1A3BD97-8016
Address 17: Instruments        Labels: 7L6-920-xxx-7L6.lbl
   Part No SW: 7L6 920 876 B    HW: 7L6 920 876 B
   Component: J285 KOMBI-INST.    9833
   Revision: KHH05V44
   Coding: 0007301
   VCID: 3B285C247F656BF39A1-806E
                    Reset counter: 199
                    Mileage: 184206 km
                    Date: 2021.06.07
                    Time: 01:44:50
00447 - Function Limitation due to Over-Voltage
                    Reset counter: 239
                    Mileage: 184206 km
                    Date: 2021.06.08
                    Time: 06:18:36
Address 19: CAN Gateway        Labels:. 6N0-909-901-7L.clb
   Part No SW: 6N0 909 901     HW: 7L6 920 876 B
   Component: J533  GW-K-CAN TP20 9833
   Coding: 57E2678BE1066002
   VCID: 70B2BB0866A3D8AB7F3-8024
                    Reset counter: 199
                    Mileage: 184206 km
                    Date: 2021.06.07
                    Time: 01:44:50
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No SW: 7L6 919 879 B    HW: 7L6 919 879 B
   Component: Kompass         001 0001
   Revision: 00001000    Serial number: 1439802T1GPS02
   VCID: 46DE3DD034A7261BF5F-8012
   Part No: 0AD 927 755 BG
   Component: TRANSFERCASE        0126
   VCID: 0154EECC5D19C12380D-5184
   Part No: 7L6 959 933 A
   Component: 4M HSG              0601
   Coding: 0000085
   VCID: 40D22BC81693082BCF3-4B3C
   Subsystem 1 - Part No: 7L0 959 701 M
   Component: Tuersteuergeraet FS 6304
   Subsystem 2 - Part No: 7L0 959 702 M
   Component: Tuersteuergeraet BF 6304
   Subsystem 3 - Part No: 7L0 959 703 C
   Subsystem 4 - Part No: 7L0 959 704 C
6 Faults Found:
Address 56: Radio        Labels: 7L6-035-180-56.lbl
   Part No SW: 7L6 035 180 C    HW: 7L6 035 180 C
   Component: Radio DE2           0008
   Revision: 00006000    Serial number: VWZ4Z4K7326978
   Coding: 0003400
   VCID: 2D0C627CB111F543145-8078
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L6 955 119 B
   Component: J400__ Front Wiper  5301
   Coding: 0001392
   VCID: 3924462C755959E388D-806C
   Component: RLS nicht vorhanden
   Coding: 00000000
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 N    HW: 7L0 907 383 N
   Component: J345  Anhaenger     0080
   Revision: 4A008002    Serial number: 00000124767927
   Coding: 0016386
   VCID: 3FD028346B3D77D3B69-806A
                    Reset counter: 239
                    Mileage: 184207 km
                    Date: 2021.06.01
                    Time: 09:23:46
Address 6E: Ctrl Head Roof        Labels: None
   Part No SW: 7L6 919 044 AD    HW: 7L6 919 044 AD
   Component: J702  Dachdisplay   0401
   Revision: 1030006S    Serial number: 00000000147426
   VCID: 79A4862C35D999E3C8D-802C
                    Reset counter: 239
                    Mileage: 184206 km
                    Date: 2021.06.07
                    Time: 01:51:31
                    Reset counter: 239
                    Mileage: 184206 km
                    Date: 2021.06.08
                    Time: 06:18:37
Address 77: Telephone        Labels: 5P0-862-335.lbl
   Part No SW: 1Z0 035 729 E    HW: 1Z0 035 729 E
   Component: FSE_2P8x        H40 0190
   Revision: 00000000    Serial number: 00000005169319
   Coding: 0002077
   VCID: 3A265920705F52FB817-806E
End----------(Elapsed Time: 02:09, VBatt start/end: 12.7V/12.8V)-----------
I decided to return tomorrow and attempt to flash ECU with newer software, does anyone know what software number shall I flash, please?
Thank you
   #58
0140 (which is what you have) appears to be the latest for 7L0-907-401-T.
However, I would suppose that there is a diselgate update for that ECU with a different part number. Personally, I'm not at all sure I'd go there.
jocker01
C?ID=194603
That's what I figured... I might try to flash the same version, hopefully it will unlock adblue warning message.
Or maybe someone will know what software ver they change too, please?
A car doesn't start anymore so there is no other option but flash or abandon the repair altogerher. I used to work on Skoda with similar issue and new software did the trick, and it was software with different part number as you suggested ;)
Thank you
   #60
Is it safe to assume you have tried the Adaptation Channel 080 reset?
- Save "001" to that channel.
Also try disconnecting the fuse for the AdBlue system. Cycle the ignition to set a fault code for that system. Then re-install the fuse and try the Adaptation Channel 080 reset again.
