Results 1 to 3 of 3
Thread: Battery Monitoring Control Module Fault
    Nov 2017
    An Auto Scan identified a fault in my Battery Monitoring Control Module. Full scan attached
    Sunday,31,December,2017,15:26:27:45944
    VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4407.4
    VIN: WAUZZZ4G8CN165114   License Plate: SM12 EKX
    Mileage: 89513km-55620mi   Repair Order:
    Chassis Type: 4G-AU57 (4G5)
    Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 56 5F 62 69
              72
    VIN: WAUZZZ4G8CN165114   Mileage: 89513km-55620miles
    69-Trailer -- Status: Not registered 0001
    Address 01: Engine (J623-CLAB)       Labels:. 059-907-401-V2.clb
       Part No SW: 4G0 907 311 D    HW: 4G0 907 401
       Component: 3.0TDI EDC17  H37 0003
       Revision: 53H37---
       Coding: 12194012052401020000
       Shop #: WSC 02391 785 00200
       ASAM Dataset: EV_ECM30TDI0114G0907311D 001007
       ROD: EV_ECM30TDI0114G0907311D.rod
       VCID: 2412E429EE50C8A71E9-8070
       Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
       Component: ESP PREMIUM   H09 0361
       Coding: 07A08701E005E1808B00
       VCID: 36362E6148CC4A37B0D-8062
       Part No SW: 4H0 907 064 BG    HW: 4H0 907 064 BG
       Component: BCM2 2.0      H31 0333
       Coding: 03B93006000000000000
       VCID: 6FB8DB0577963BFFB3B-803A
       Serial number: 2312000061223016
    Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
       Part No SW: 4G0 820 043 H    HW: 4G0 820 043 H
       Component: KLIMA 2 ZONEN H10 0064
       Serial number: 16041200040477
       Coding: 3622000820
       ASAM Dataset: EV_AirCondiBasisUDS 002040
    0027 - Motor for Defroster Flap
              B1090 07 [008] - Mechanical Failure
                        Reset counter: 124
                        Mileage: 86791 km
                        Date: 2017.11.24
                        Time: 07:20:53
                        Voltage terminal 30: 14.23 V
                        Outside air temperature: 0.5 °C
                        Interior temperature: 4.45 °C
                        Defroster flap motor-Act.val.: 9996
                        Defroster flap motor-Specified value: 11581
                        Defroster flap motor-Stop open: 11280
                        Defroster flap motor-Stop closed: 10000
       Part No SW: 4H0 907 063 BJ    HW: 4H0 907 063 B
       Component: BCM1 2.0      H12 0111
       Revision: 13012002    Serial number: 00000001278715
       Coding: 690000108034A7600405008300005F5F0F9D860827080101000004402000
       VCID: 71BCDD7D61A22D0FA5F-8024
       Component: WWS57X 120309  H35 0080
       Serial number:         120317110303
       Coding: 0045F7
       Component: RLS  H04 0003
       Serial number: 20136956
       Coding: 02512B
       Subsystem 3 - Part No SW: 4G0 941 531     HW: 4G0 941 531
       Component: E1 - LDS  H07 0044
       Serial number: 04 04 2012  00000709
       Serial number: 43788226000000000001
       Part No SW: 4H0 919 475 Q    HW: 4H0 919 475 C
       Component: PARKHILFE ACC H07 0060
       Revision: 11001001    Serial number: 55901209300226
       Coding: 090207
       Shop #: WSC 12345 123 12345
       ASAM Dataset: EV_EPHVA18AU57X0000 004005
       ROD: EV_EPHVA18AU57X0000_003.rod
       VCID: 40DA48B91A08F4871A1-8014
       Revision: --------    Serial number: 003JG007Y8JK
       Coding: 30323436313330303537554A305234473053
       Serial number: 3575HRB406718NQOG0N+
       Serial number: 3585HRB406918NQO39EV
       Serial number: 3515JRB40104UHL8E9OV
       Serial number: 3525JRB405H184CO3GD7
       Serial number: 3554VRB400M4UHPKGP5$
       Serial number: 3564VRB400M4UHPKIHA$
       Revision: 00000000    Serial number: 20120413001477
       Coding: 000015
       VCID: 303A1879AA286407EA1-8064
       Subsystem 1 - Part No SW: 4G0 951 528 D    HW: 4G0 951 528 D
       Component: E221 - MFL  H09 0009
    Address 17: Instruments (J285)       Labels:| 4H0-920-xxx-17.clb
       Part No SW: 4G8 920 982 K    HW: 4G8 920 982 K
       Component: TDieGb        H79 0416
       Revision: 28460177    Serial number: 658030412596020
       Coding: 33A4100003012600010000
       ASAM Dataset: EV_RBD4K 004045
       ROD: EV_RBD4K.rod
       VCID: 3C223C4976E09067469-8068
       Part No SW: 4G5 907 468 A    HW: 4G5 907 468
       Component: J533--Gateway H10 0028
       Revision: --------    Serial number: 00000000457606
       Coding: 00CD077D00
       ASAM Dataset: EV_GatewPkoUDS 001013
       ROD: EV_GatewPkoUDS_001.rod
       VCID: 333017755BBE5F1F973-8066
       Component: J367-BDM  H07 0141
       Serial number: 00000000003790807976
       Voltage stabilizer:
    0021 - Control Module Incorrectly Coded
              U1014 00 [009] - -
                        Reset counter: 118
                        Mileage: 89513 km
                        Date: 2017.12.31
                        Time: 15:23:17
                        Voltage terminal 30: 11.4 V
                        Voltage terminal 15: 11.6 V
                        Control Module temperature: 8 °C
                        System status: Terminal 15 on
                        Engine running: OFF
                        IN ZAS_Te_X: On
                        Terminal 15 status: On
                        Datenfeld: 0
       Part No SW: 4G0 907 637     HW: 4G0 907 637
       Component: SARA 3D       H02 0009
       Revision: --------    Serial number: EJ1BPA32021L0N0
       ASAM Dataset: EV_SARA 009017
       ROD: EV_SARA_009.rod
       VCID: 6B80CF15430EC7DF9F3-803E
       Part No SW: 4G8 959 793 E    HW: 4G8 959 793 A
       Component: TSG FA        H05 0212
       Coding: 011C16204001620002080002
       VCID: 42DE42B11484E6970C5-8016
       Component: RCEPS         H35 0010
       Revision: 00001000    Serial number: 0026467717
       Coding: 101000010000
       ASAM Dataset: EV_RCEPS 009008
       ROD: EV_RCEPS_009.rod
       VCID: 323E1271A4A456179C5-8066
       Revision: 00002001    Serial number: 0174000125
       Coding: 013B062220B9044083200904000104000000000000000000000000000000
       Part No SW: 4G8 959 792 E    HW: 4G8 959 792 A
       Component: TSG BF        H05 0212
       VCID: 41DC4DBD1182FD8F15F-8014
       Revision: --------    Serial number: 00000000316200
       ROD: EV_ParkiBrake_AU57.rod
       VCID: 2A0E0A118C741ED7245-807E
       Part No SW: 4G0 035 056 E    HW: 4G0 035 056
       Component: Radio U STD   H60 0093
       Revision: AB001007    Serial number: 230DQ0C7556510
       Coding: 010003020100000001
       VCID: 2310E735EBDECF9F673-8076
       Part No SW: 4G0 035 670 H    HW: 4G0 035 670 H
       Component: H-BNT-EU      H49 0526
       Revision: --------    Serial number: 190DM0C7501016
       Coding: 050101010003A1ED05008B3E00000003000001000000000000
       VCID: 280AF01992F82CC7321-807C
       Subsystem 1 - Part No: 8R0 060 884 DF
       Component: EUR 2016  2204
       Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
       Component: DU8 C7 SV  H42 0021
       Serial number: AUZ8ZDC94017AAC
       Subsystem 3 - Part No SW: 4G2 919 710 C    HW: 4G2 919 710 C
       Serial number: 90349LD500108
       Subsystem 4 - Part No: 8R0 060 961 C
       Component: CD-Database  3638
       Part No SW: 4G8 959 795 E    HW: 4G8 959 795 A
       Component: TSG HL        H04 0212
       Coding: 010814204001620002080002
       VCID: 44D244A90E90E8A73E9-8010
    Address 69: Trailer (J345)       Labels:. 4G8-907-383-V1.clb
       Part No SW: 4G8 907 383     HW: 4G8 907 383
       Component: Towbar module H07 0100
       Coding: 0100000100000000
       Component: TSG HR        H04 0212
    End----(Elapsed Time: 01:58, VBatt start/end: 11.7V/11.9V. VIgn 11.9V)-----
    The timing of it coincided with when I installed an aftermarket trailer module. I thought perhaps it was because I'd had the battery disconnected and had read on the Ross-Tech Wiki paghe about programming the battery details. When I checked there were no battery details in my module so I entered them as per the instructions, cleared all codes, re-ran the auto-scan and still have the same fault, so Iguess I was barking up the wrong tree. Any advice on what this fault actually is and how I can rectify it would be appreciated.
    Many thanks
    Adam
    The fault is is from the Gateway, not the Battery Monitoring module. The latter is a sub-system of the former, and subs-systems don't have their own faults.
    You might want to tell the Gateway that you've installed a trailer module. I suspect that will make it happy again.
    Nov 2017
    Thank you very much Uwe, you were spot on.
  5. Likes Uwe liked this post
