Results 21 to 30 of 39
Thread: "No ROD file found"
  1. #21
    Mar 2015
    Quote Originally Posted by Sebastian View Post
    Problem found, the fix was accidentally removed during a related change. Fixed permanently now, I'll make a revised version/update available next week.
    When will you publish a new version? It's over 7 weeks since you wrote it and there is still no release. I am facing this problem every time with MIB STD2 PQ units 5L0035200 / 5L0035680 installed in Superb Mk2.
  2. #22
    Jun 2017
    Doesn't the latest beta help with its new feature to select partially matching ROD data??
    http://www.ross-tech.com/vcds/download/beta/current.php
  3. #23
    Mar 2015
    Beta doesn't work with previous generation interfaces... and I am not willing to spend another bucket of dollars replacing my interface
  4. #24
    Mar 2015
    Any update? Another 7 weeks passed by and still no support for legacy interfaces.
  5. #25
    Magdeburg, Germany
    Download and install the following update for Release 18.2.1:
    https://ross-tech.de/downloads/upd
    That should take care of it.
  6. #26
    Stoke on Trent, England
    I've just download 18.2.1 update but when I try to install it says VCDS found on your computer does NOT match Requirements. Update aborted (VCDS version found 18.2.1.2). Would I like to download the latest version, which I have.
    These ROD - Unknown Error Code have been showing for years.
    29-12-2017 Not finding a ROD file is not unusual when modules that don't belong in a particular car get retrofit. I'm confident we can make a work-around for this once we're back in the office next week.
    New User Keith
  7. #27
    Quote Originally Posted by Keithuk View Post
    No, apparently you don't. The current version on the download page is 18.2.1.5.
  8. Likes Sebastian liked this post
  9. #28
    Magdeburg, Germany
    I'll make sure to offer opening the download page, when a lower version is found (next time I touch that updater...).
  10. Likes Uwe, PetrolDave liked this post
  11. #29
    Ok I had 18.2.1 but I didn't check the version number. I downloaded and installed the current online download and installed it. Then I ran Sebastian's update and it installed.
    I think you should change the number shown to 18.2.1A, B, C with updates so its obvious which version your using.
    New User Keith
  12. #30
    Magdeburg, Germany
    Since the subversion isn't changed that often and it's industry standard to use numbers (not necessarily letters), it's not really necessary to change anything here. That said, as I mentioned before - I'll make sure the error message is more clear with the next builds.
