Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: Intermittent issues with DSG
    Feb 2016
    Jamaica
    Quote Originally Posted by Dukedesmo View Post
    My A3 got through 3 batteries in the time I had it.
    My car has been through 4 batteries now (same brand) and I've only had the car for 2 years (daily driven). I'll try doing a jump-start (just to ensure that the current is good) then do the auto scan again.
  2. #12
    Quote Originally Posted by NitrousOxide View Post
    Then something is taking far too much current when the ignition is off.
    My previous Audi RS4 was only driven once a week and the battery on that lasted 7 years, so 4 batteries in 2 years is very wrong.
  3. #13
    Feb 2016
    Jamaica
    Yesterday, I thought I had a "breakthrough" when I used the circuit tester to find fuses in my car un-blown, yet un-powered (no 12 volts). I then realised that these were just spare fuses sitting in the lot. I no have to do some basic testing of the relays, but first need to learn how each of them work (by relay number).
  4. #14
    Feb 2016
    Jamaica
    My car's symptoms are different now where I was able to drive the car home in limp mode (stuck in first gear with no reverse gear).
    The codes I get now are:
    VIN: WVWZZZ1KZ8W111078   License Plate:
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56
    VIN: WVWZZZ1KZ8W111078   Mileage: 145950km-90689miles
    Address 01: Engine        Labels: 06F-907-115-AXX.clb
       Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
       Coding: 040300101C070060
       Shop #: WSC 80182 411 444102
       VCID: 354FD8585CDD5E9692-8060
    000256 - Mass Air Flow Sensor (G70)
                   P0100 - 004 - Supply Voltage
                        Mileage: 145809 km
                        Time: 21:23:26
                        RPM: 752 /min
                        Load: 28.6 %
                        Temperature: 85.0C
                        Temperature: 35.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 13.589 V
    000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
                   P0036 - 004 - Malfunction / Open Circuit
                        Mileage: 145809 km
                        Time: 21:23:37
                        RPM: 764 /min
                        Load: 27.8 %
                        Temperature: 85.0C
                        Temperature: 35.0C
                        Voltage: 13.843 V
    Readiness: 0110 0101
    Address 02: Auto Trans        Labels: 02E-927-770.lbl
       Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
       Component: GSG DSG         082 1407
       Revision: 04808020    Serial number: 00000907050136
       Shop #: WSC 09537 809 89632
       VCID: 1C192DFCDF37EFDE8D-8048
    18149 - Clutch Pressure Adaptation
                P1741 - 002 - Limit Reached
                        Fault Status: 01100010
                        Fault Frequency: 255
                        Reset counter: 2
                        Mileage: 145809 km
       Revision: 00H11001
       Coding: 0004738
       Shop #: WSC 00000 785 00200
       VCID: 73CB2640122900A67C-8026
    01487 - System Function Test
                000 -  -  - Intermittent
                000 -  -
                013 - Check DTC Memory
       Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
       Component: ClimatronicPQ35 120 1111
       Revision: 00120021    Serial number: 00000000000000
       VCID: 79D7146830457AF636-802C
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
    Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
       Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
       Revision: 00H54000    Serial number: 01000007456322
       Coding: E78C8B2F00041500471400041400000000097D075C100100000000000000
       Shop #: WSC 11111 111 45725
       VCID: 71C72C48683532B68E-8024
       Component: Wischer 300807 021  0501
       Coding: 00038805
       Shop #: WSC 11111
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     130907 046  0204
       Coding: 00221517
       Shop #: WSC 11111
    02498 - Left Low Beam Reflector Motor (V294)
                        Fault Status: 01111100
                        Reset counter: 232
                        Mileage: 145811 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.85 V
    02499 - Right Low Beam Reflector Motor (V295)
                        Reset counter: 232
                        Mileage: 145811 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.85 V
    01335 - Drivers Seat/Mirror Position Control Module (J543)
                        Fault Status: 01110100
                        Reset counter: 232
                        Mileage: 145809 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.50 V
                        Reset counter: 232
                        Mileage: 145809 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.55 V
       Component: 3A AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1FKU0T
       Coding: 0013121
       Shop #: WSC 01269 785 00200
       VCID: 3D5FC07864ED86D65A-8068
       Subsystem 1 - Serial number: 6332MSME2C406B29H
       Subsystem 2 - Serial number: 6342MSME2C42223ED
       Subsystem 3 - Serial number: 6352QSME3D213635D
       Subsystem 4 - Serial number: 6362QSME3C0B0C41L
    7 Faults Found:
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                007 - Short to Ground - Intermittent - MIL ON
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Coding: 0012102
       VCID: 01277C88589522367E-8054
    01748 - Switch for Tiptronic in Steering Wheel (E438); Up
       Part No SW: 1K6 920 974     HW: 1K6 920 974
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0G83NA8OV
       Coding: 0004103
       Shop #: WSC 12345 111 45725
    Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
       Part No SW: 1K0 907 530 L    HW: 1K0 907 951
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 040907F1000254
       Coding: ED811F060002020001
       Shop #: WSC 12345 785 00200
       VCID: 3041E94CA3BF7BBEC1-8064
       Component: IMMO            VDD 1216
       Component: Tuer-SG         006 120B
       Coding: 0000564
       VCID: 3851D16C4BCFA3FE89-806C
    00109 - Left Mirror Turn Signal Lamp (L131)
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 69     2901
       Revision: 00H15000
       VCID: 2F43EA30BE816446D8-807A
    Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
       Coding: 9890020851030C7F02CC0F0FF0085A2690BC00
       VCID: 032B7680428930266C-8056
       Subsystem 1 - Component:   Sounder No Answer
    01134 - Alarm Horn (H12)
                        Reset counter: 225
                        Mileage: 145809 km
                        Time: 21:23:41
       Coding: 0000564
       VCID: 3957D46870C5BAF676-806C
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74C9255C1727079E65-8020
    01539 - Headlights Not Adjusted
       Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
       Component: Radio PM6       018 0035
       Revision: 00018000    Serial number: VWZ5Z7G2174742
       Coding: 0040400
       VCID: 2A75FB248563016E0F-807E
    End-------------------------(Elapsed Time: 01:03)--------------------------
    Monday,15,February,2016,20:05:44:39976
    VCDS Version: 15.7.3.0 (x64)
    Data version: 20151216
    Adaptation Channel 009:
    Stored value
    Saturday,30,December,2017,18:43:19:39976
    VCDS Version: 17.10.0.2 (x64)
    Data version: 20171026 DS283.3
    Dealer/Shop Name: Matthew Taylor
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
    VIN: WVWZZZ1KZ8W111078   Mileage: 173240km-107646miles
    77-Telephone -- Status: Not registered 0001
       Coding: 040300101C070160
       Shop #: WSC 66565 257 00032
       VCID: 354FD8585CDD5E825FF-8060
    Readiness: 0110 0001
       VCID: 1C192DFCDF37EFCA401-8048
       Revision: 00H11001
       Coding: 0004738
       Shop #: WSC 12345 123 12345
       VCID: 73CB2640122900B2B1B-8026
       VCID: 79D7146830457AE2FB7-802C
       Coding: F70E8F2F000415000F140AFF1400FFE48019FD07FF10010C000000000000
       VCID: 71C72C48683532A2437-8024
       Coding: 00038837
       Shop #: WSC 11111
       Coding: 00208933
       Shop #: WSC 11111
       Coding: 0013121
       VCID: 3D5FC07864ED86C297F-8068
                007 - Short to Ground - MIL ON
       Coding: 0012122
       VCID: 01277C8858952222B37-8054
    00002 - Transmission Control Unit
       Coding: 0006103
       Shop #: WSC 11111 123 12345
       VCID: 3041E94CA3BF7BAA0C9-8064
                000 -  -
       Coding: 0000564
       Shop #: WSC 11111 111 45799
       VCID: 3851D16C4BCFA3EA449-806C
       Revision: 00H15000
       VCID: 2F43EA30BE816452153-807A
       Coding: 9890020851030C7F42CC0F0FF0085A2670B840
       VCID: 032B768042893032A1B-8056
       Coding: 0000596
       VCID: 3957D46870C5BAE2BB7-806C
       Coding: 0000003
       VCID: 74C9255C1727078AA81-8020
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7L3180243
       Coding: 01000401000000
       VCID: 63EB560062C99032C1B-8036
    02633 - Antenna for Satellite Tuner
                000 -  -
    Address 77: Telephone
    End-------------------------(Elapsed Time: 01:08)--------------------------
    If I select reverse, then I get the error code about an implausible disengagement. I can't seem to get to group 60 or 61 to do the adaptation again.
  5. #15
    Jul 2014
    fix your engine faults first
  6. #16
    Feb 2016
    Jamaica
    Those harmless engine faults existed long before the issue occurred.
    My priority is in fixing the transmission issue at the moment
  7. #17
    Jul 2014
    Ok see you
  8. #18
    Feb 2016
    Jamaica
    The odd thing I've noticed is that I can only access Group 60 and 61 in the transmission control module when the engine is off, but not when the engine is running.
    If I start the engine while accessing group 60 or 61, then I'm kicked out with the error code saying something to the effect that this is unavailable.
    By Thursday this week, I should have the funds to order a new clutch kit and mechatronics unit.
  9. #19
    Let me see in this short break if I can ask the right question in run on sentence question okay?
    Did you know that some basic settings tests in VCDS are restricted & because they are not supposed to be done while the vehicle is running or without a login & that may reflect it in the stack of the controller or in some cases even when they are not, someone at RT figured it out that someone would do this and not follow directions of the RTFB and try anyway so they disabled certain requests in program?
  10. Likes NitrousOxide liked this post
  11. #20
    Feb 2016
    Jamaica
    I was unaware of this at the time. I thought it was something possibly relay related under the dashboard or engine bay. It wasn't after I had replaced the complete DSG (then did some reading) I understood this.
    I forgot to close this thread years later by admitting as you stated, new dual-clutch kit, mechatronic unit, and fluid with filter change, didn't fix the issue (but allowed me to drive the car normally for an additional day).
    I had ended up having to order a complete DSG (which included all above mentioned components) to resolve the issue.
    However, I disagree with group 60 and 61 being made unavailable with a running engine as it would be impossible to do the adaptation although I entered the security code.
    Thanks for reminding me that I need to post up the new clutch-kit and mechatronic unit somewhere online as they have been only used for under 24 hours to drive about 9 kilometers from the dealer to my house.
