Results 1 to 10 of 20
Thread: Intermittent issues with DSG
    Feb 2016
    Jamaica
    Greetings,
    I have developed an issue with my DSG since yesterday where it just did what I'd call a "neutral dump" where it somehow falls out of "gear". In other words, I was cruising along and it was as though the transmission went from Drive to Neutral where the engine RPM shot straight up. I brought the car to a stop and placed the shifter in Park, but couldn't get it out of Park. I switched the engine off, but couldn't restart as though the interlock was preventing me from being able to do so. I did a combination of locking and unlocking the car with the key-fob and clearing the error codes using a third party tool that I had on-hand at the time. The car started and I was able to complete my journey problem free. One of the errors I saw on the dashboard at the point the issue occured was something about the brakes overheating (which was impossible on the basis that I was previously driving up a slight incline after sitting in traffic).
    Fast forwarding to today: I drove my car to work issue free. I did the VCDS clutch adaptation (group 60) since both the engine and DSG was at operating temperature in the parking lot. I did not do a test drive.
    Later this evening (going home time) when I drove out the parking lot, I noticed the car was stuck in first gear and the PRNDS lights were blinking to alert me to a DSG error. The DSG does not select a gear when I place it in Reverse. I pulled out the VCDS to do a scan on the car below. I checked all fuses and those were good. I haven't tested the relays as yet.
    Thursday,28,December,2017,18:19:42:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 17.12.0.1 (x64)
    Data version: 20171213 DS285.1
    Dealer/Shop Name: Matthew Taylor
    VIN: WVWZZZ1KZ8W111078   License Plate: 3395 GY
    Mileage: 173240km-107646mi   Repair Order: Matthew Taylor3
    Chassis Type: 1K (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 77
    VIN: WVWZZZ1KZ8W111078   Mileage: 173240km-107646miles
    77-Telephone -- Status: Not registered 0001
       Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
       Coding: 040300101C070160
       Shop #: WSC 66565 257 00032
       VCID: 354FD8585CDD5E822C4-8060
    000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
                   P0036 - 004 - Malfunction / Open Circuit
                        Mileage: 173234 km
                        Time: 08:14:31
                        RPM: 1410 /min
                        Load: 11.0 %
                        Speed: 38.0 km/h
                        Temperature: 63.0C
                        Temperature: 26.0C
                        Absolute Pres.: 990.0 mbar
                        Voltage: 14.224 V
    001089 - EVAP Emission Control Sys
                   P0441 - 002 - Incorrect Flow
                        Fault Status: 01100010
                        Mileage: 173239 km
                        Time: 08:23:54
                        RPM: 752 /min
                        Load: 14.9 %
                        Temperature: 85.0C
                        Temperature: 30.0C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.097 V
    005668 - MIL Request Signal Active (Check TCM for errors too!)
                   P1624 - 008 -
                        Mileage: 173241 km
                        Time: 18:04:11
                        RPM: 1143 /min
                        Load: 25.9 %
                        Temperature: 36.0C
                        Temperature: 31.0C
                        Voltage: 14.097 V
    Readiness: 0110 0101
       Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
       Component: GSG DSG         082 1407
       Revision: 04808020    Serial number: 00000907050136
       Shop #: WSC 09537 809 89632
       VCID: 1C192DFCDF37EFCA33A-8048
                        Fault Frequency: 255
                        Reset counter: 60
                        Mileage: 173241 km
    19143 - Unexpected / Implausible Mechanical Gear Disengagement
                P2711 - 005 -  - MIL ON
                        Fault Status: 11100101
                        Reset counter: 40
                        Mileage: 173241 km
       Revision: 00H11001
       Coding: 0004738
       VCID: 73CB2640122900B2C20-8026
       Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
       Component: ClimatronicPQ35 120 1111
       Revision: 00120021    Serial number: 00000000000000
       VCID: 79D7146830457AE288C-802C
    00229 - Refrigerant Pressure
                002 - Lower Limit Exceeded
       Revision: 00H54000    Serial number: 01000007456322
       Coding: F70E8F2F000415000F140AFF1400FFE48019FD07FF10010C000000000000
       Shop #: WSC 11111 111 45725
       VCID: 71C72C48683532A230C-8024
       Component: Wischer 300807 021  0501
       Coding: 00038837
       Shop #: WSC 11111
       Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
       Component: RLS     130907 046  0204
       Coding: 00208933
       Shop #: WSC 11111
                        Reset counter: 127
                        Mileage: 173234 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 13.70 V
       Component: 3A AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PD1FKU0T
       Coding: 0013121
       Shop #: WSC 01269 785 00200
       VCID: 3D5FC07864ED86C2E44-8068
       Subsystem 1 - Serial number: 6332MSME2C406B29H
       Subsystem 2 - Serial number: 6342MSME2C42223ED
       Subsystem 3 - Serial number: 6352QSME3D213635D
       Subsystem 4 - Serial number: 6362QSME3C0B0C41L
    7 Faults Found:
    00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
                007 - Short to Ground - Intermittent - MIL ON
    00589 - Airbag Igniter 1; Passenger Side (N131)
    01228 - Airbag Cut-Off Switch for Passenger Side (E224)
    02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
    00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
                001 - Upper Limit Exceeded - Intermittent - MIL ON
       Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
       Component: J0527           036 0070
       Coding: 0012122
       VCID: 01277C8858952222C0C-8054
       Part No SW: 1K6 920 974     HW: 1K6 920 974
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0G83NA8OV
       Coding: 0006103
       Component: J533  Gateway   H07 0052
       Revision:   H07 01    Serial number: 040907F1000254
       Coding: ED811F060002020001
       Shop #: WSC 11111 123 12345
       VCID: 3041E94CA3BF7BAA7F2-8064
                        Fault Frequency: 9
                        Mileage: 173214 km
                        Time: 20:00:39
       Component: IMMO            VDD 1216
       Component: Tuer-SG         006 120B
       Coding: 0000564
       Shop #: WSC 11111 111 45799
       VCID: 3851D16C4BCFA3EA372-806C
    00109 - Left Mirror Turn Signal Lamp (L131)
       Part No: 1K0 909 144 H
       Component: EPS_ZFLS Kl. 69     2901
       Revision: 00H15000
       VCID: 2F43EA30BE816452668-807A
       Coding: 9890020851030C7F42CC0F0FF0085A2670B840
       VCID: 032B768042893032D20-8056
    01134 - Alarm Horn (H12)
                        Reset counter: 126
                        Mileage: 173234 km
                        Time: 08:10:58
       Coding: 0000596
       VCID: 3957D46870C5BAE2C8C-806C
    00121 - Outside Warning Light/Door exit Light Passenger Side
       Part No: 1T0 907 357
       Coding: 0000003
       Shop #: WSC 00000 785 00200
       VCID: 74C9255C1727078ADBA-8020
       Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
       Component: Radio Prem-8  H02 0016
       Revision: -----16S    Serial number: VWZ4Z7L3180243
       Coding: 01000401000000
       VCID: 63EB560062C99032B20-8036
                        Reset counter: 125
                        Mileage: 173214 km
                        Time: 20:00:44
    02633 - Antenna for Satellite Tuner
                        Reset counter: 125
                        Mileage: 173214 km
                        Time: 20:03:13
                        Reset counter: 125
                        Mileage: 173214 km
                        Time: 20:03:18
    Address 77: Telephone
    End-------------------------(Elapsed Time: 01:12)--------------------------
    Address 01: DTCs cleared
    Address 02: DTCs cleared
    Feb 2016
    Jamaica
    It is important for me to declare that the DSG transmission fluid is due for a change now and as such I'll have to get it done this weekend.
    I'm just trying to avoid the thought of a mechatronic failure as that would be a repair bill that would be difficult to swallow. It just seemed weird that the car took me to work quite fine (changing gears and everything). Now it just only goes into Reverse briefly when I clear ALL the error codes from all the modules (before flashing the PRNDS lights again then getting stuck in neutral). In Drive, the car stays in first gear so I can't even complete the documented test drive procedure. There needs to be an easier method of draining the DSG fluid other than pulling the bung underneath the DSG. I'm wondering if there is a way for the majority of it to be siphoned out of the filter hole up top underneath the battery. I don't have the fancy dealer tool to drain the "inner" reservoir.
  3. Likes Vasco Ferraz liked this post
    Every time I see this it results in..........drum roll please!
    Time for a DSG don't even bother with the fluid........ it won't help & is waste of money..........
  5. Likes NitrousOxide liked this post
  6. #4
    Oct 2016
    Stockholm Sweden
    I totally agree.
    +1
    Feb 2016
    Jamaica
    I'm in Jamaica, so ordering and importing one is an arm and a leg. The car have an error message about "brakes overheating, check service manual", even though the car has been parked for hours. I suspect that it is an electrical issue. Which component other than fuses and relays should I be checking first? Where is the brake temperature being measured exactly?
    Nov 2016
    Is the battery OK? I ask because I had an early (2004) A3, 3.2 DSG and I had the 'neutral dump' 3 times in the time that I owned it, and every time it happened it was shortly after start-up when the battery had been on the low side.
    It had a battery drain problem that got worse as it got older, never did work out why but (car's gone now so doesn't matter). It was OK if used every day or two but if left a week or so the battery would be low on charge, usually it would still start but then it, it would (sometimes) cycle through multiple errors; steering, ABS, coolant etc. they would all clear after maybe a minute and it would be OK but on the 3 occasions where the gearbox messed up it happened shortly after such an event.
    Each time after I switched off and restarted it was fine.
    I looked into mechatronic unit replacement at the time but fortunately mine never needed it (maybe would have later?) expensive new but can be repaired by some specialists for a fraction of the price.
    2014 Audi S4 Avant, 'black edition'.
    2019 Audi Q2 Sport 30 tdi.
    2011 VW Golf 'Match' 1.4 tsi.
    2004 VW Polo 1.2.
  9. Likes NitrousOxide liked this post
  10. #7
    Feb 2016
    Jamaica
    Quote Originally Posted by Dukedesmo View Post
    I've suspected my battery for months. Sometimes the car will do a very slow start randomly once every month. My battery goes through batteries quite frequently (completely dead and can't crank).
    I got a random TPMS low light as though it was reset, and one Xenon headlight will sometimes go out and be re-lit quickly as though the ballast was failing. Swapping the ballasts for testing does not rectify the issue (the bulbs are new). Some errors that I do get using a third party tool (OBDeleven) insufficient voltage for some modules, but the situation doesn't stay long enough when I scan with VCDS. In Jamaica, we don't have specialists who "repair" mechatronic units. The dealer (ATL Jamaica) will only do custom orders for new mechatronic units from Germany. Before I buy a brand new battery for testing, I just want to have an idea which relays control the distribution of power to the rest of the car. I'm willing to bet that it is a relay issue that is causing all this. I had a battery test done on the existing battery where a 500-Amp load was applied to it and the voltage did drop to 11.xx volts. It starts the car, but I don't know if it is enough to get everything else going once the alternator kicks in. I have done no testing whatsoever of the alternator, however my third party app claims that my terminal voltage is 14.1 with the engine running (where it used to be between 13.5-13.8 volts before).
  11. #8
    Hmmm lets see....... what's the icon say? Oh yeah RTFB and JPPSG.
    Trace for bad grounds & fuses using WD and read SSP too, for design and function & if in oppositional order to question.
    By all means........... take all apart and inspect everything, further using RTFB and don't forget to purchase all the precision testing measuring devices and other tools to fix the DSG, versus changing the entire DSG unit like a dealer does.
    Not going to be a battery on this unless it is shorted but I don't see a whiff of codes for low voltage unless you are supplying FOD scans
  12. Likes NitrousOxide liked this post
  13. #9
    Nov 2016
    Quote Originally Posted by NitrousOxide View Post
    If you are certain it is the mechatronic and can manage without the car for whatever the turn-around time is then there are places here (UK) that can repair for significantly less than the new price, may not be practical though due to leaving the car hanging around with the gearbox apart plus the shipping costs?
    Wouldn't hurt to fit a new battery if yours is suspect. My A3 got through 3 batteries in the time I had it and when I got rid of it, the battery was definitely on the way out again.
    2004 VW Polo 1.2.
  14. Likes NitrousOxide liked this post
  15. #10
    Feb 2016
    Jamaica
    When you say shorted, do you mean an internally bad cell, or are you suggesting a wiring fault. I'll try a doing a jump-start with another battery to see if the issues are the same. The scans I've submitted are for my car which was previously flashed but restored to stock DSG and ECU settings months ago.
