- Joined
- Mar 4, 2015
- Messages
- 337
- Reaction score
- 88
- Location
- Rhode Island, USA
- VCDS Serial number
- C?ID=240768
OK, We had one COLD morning yesterday @ around 1 Degree, it was so cold the radio button was so hard it wouldn't move.
I went out and started my wife's Q7 and it started but every light you can imaging was lite up like a X-Mas tree. I tried first to clear all the codes but was running late for work so took off. When I applied the gas it would not go like it was in neutral. I pulled over and turned the car off let it sit for a moment then the car would not start again. I walked home and grabbed my Audi A8 to give it a jump because it was saying the battery was to low to run a scan. This was confusing because everything else worked perfect no dimmed headlights or anything. At this point I called a tow truck and I left to work in my car, My wife called me and said that after the tow guy dropped the car off in our driveway it started fine and drove fine but all the lights were still lite up. I told her to let the car run for about an hour so it got to normal temp and let the battery charge. I then came home last night and started the car right up without an issue. This AM is when I went out and car started right up again and I ran a scan, below is the scan from this AM. I then cleared all codes but now I have component protection active on the radio, Thanks god it still works so I don't take a trip to the STEALER. Any thoughts on what may have happen? Please shine some light if you may know thanks.
Thursday,28,December,2017,09:44:59:14758
VCDS Version: 17.8.1.0 (x64)
VIN: WA1BY74L27D066562 License Plate: Q7
Mileage: 243120km-151067mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 15 16 17 19 36 37 3C 42 46 47 4F
52 55 56 61 62 6D 6F 72 77
VIN: WA1BY74L27D066562 Mileage: 243120km-151067miles
02-Auto Trans -- Status: Malfunction 1010
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 1010
Address 01: Engine Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 BG HW: 03H 906 032 G
Component: Q7 3.6-FSI-LEV2 G00 0447
Revision: 5CH05--- Serial number:
Coding: 0001175
Shop #: WSC 31414 790 00001
VCID: 68DF86995B4A7D0639-803C
8 Faults Found:
049441 - No Communication with ABS Brake Control Module
U0121 - 008 - - Intermittent
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:48
RPM: 667 /min
Load: 22.0 %
Temperature: 70.0°C
Temperature: 7.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.732 V
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:48
RPM: 667 /min
Load: 22.0 %
Temperature: 70.0°C
Temperature: 7.0°C
Voltage: 14.732 V
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:48
RPM: 667 /min
Load: 22.0 %
Temperature: 70.0°C
Temperature: 7.0°C
Voltage: 14.732 V
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:48
RPM: 667 /min
Load: 22.0 %
Temperature: 70.0°C
Temperature: 7.0°C
Voltage: 14.732 V
Fault Frequency: 12
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:48
RPM: 667 /min
Load: 22.0 %
Temperature: 70.0°C
Temperature: 7.0°C
Voltage: 14.732 V
049409 - No Communication with Transmission Control Module
U0101 - 008 - - Intermittent
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:48
Temperature: 41.0°C
Temperature: 18.0°C
Voltage: 11.430 V
049489 - No Communications with Airbag Control Module
U0151 - 008 - - Intermittent
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:48
RPM: 667 /min
Load: 22.0 %
Temperature: 70.0°C
Temperature: 7.0°C
Voltage: 14.732 V
005668 - MIL Request Signal Active (Check TCM for errors too!)
P1624 - 008 -
Mileage: 243119 km
Date: 2017.12.27
Time: 10:15:05
RPM: 1155 /min
Load: 69.4 %
Temperature: 18.0°C
Temperature: 3.0°C
Voltage: 13.970 V
Readiness: 0010 0101
Part No SW: 4L0 910 156 C HW: 0AT 927 156
Component: AG6 0AT 3,6 FSI USA 0010
Revision: --H01--- Serial number: 4012101
VCID: 2959C39D80C0840EE6-807C
6 Faults Found:
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 000 - - Intermittent
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:31
RPM: 800 /min
RPM: 704 /min
(no units): 30.0
(no units): 25.0
Temperature: -3.0°C
T.B. Angle: 60.0°
050177 - Implausible Data Received from Engine Control Module
U0401 - 000 - - Intermittent
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:31
006273 - Powertrain Data Bus: Missing Message
P1881 - 000 - Acceleration Request - Intermittent
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:31
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:31
049493 - No Communication with Instrument Cluster
U0155 - 000 - - Intermittent
Fault Frequency: 20
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:31
049478 - No Communication with Diagnostic Gateway
U0146 - 000 - - Intermittent
Fault Frequency: 19
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:31
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0033809
VCID: 285FC6999BCABD06F9-807C
Reset counter: 0
Count: 128
Count: 8449
Count: 8211
Count: 49664
Reset counter: 48
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:31
Count: 128
Count: 12545
Count: 8194
Count: 52480
Reset counter: 48
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:31
Count: 12545
Count: 8208
Count: 52480
Reset counter: 48
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:31
Count: 128
Count: 12545
Count: 8207
Count: 52480
Reset counter: 48
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:31
Count: 12289
Count: 166
Count: 52224
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H31 0220
Revision: 31050601 Serial number: 10601100600299
Coding: 0000139
VCID: 63C591B5A26C1E5EEC-8036
Subsystem 1 - Part No: 4F0 910 131 J
Component: FBSAUDIC6 EZS H45 0080
Subsystem 2 - Part No: 4F0 910 220 A
Component: FBSAUDIC6 IDG H01 0040
00263 - Transmission
Reset counter: 89
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:43
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 731 E HW: 4E0 035 729
Component: Interfacebox H43 3360
Revision: 00000000 Serial number: 308KR067513371
Coding: 0002003
VCID: 2A5B3C9185C68F16EF-807E
Subsystem 2 - Serial number: 00000001836152
Subsystem 3 - Serial number: 0106.05.110000000100010535ÿ
Subsystem 4 - Serial number: 010535ÿ
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Revision: 00---012 Serial number: 00000030014698
Coding: 0524326
VCID: 61C99BBDB8700C4EFE-8034
Reset counter: 89
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:21
Part No SW: 4F0 910 279 K HW: 4F0 907 279
Component: ILM Fahrer H17 0240
Coding: 0014123
VCID: 31692BFDA810FCCE2E-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Part No SW: 4L0 910 110 HW: 4L0 035 110
Component: MP3-Changer H43 0270
Revision: 00043000 Serial number: AUZ5ZBF1018131
VCID: 5CB7AA499F1221A6AD-8008
Reset counter: 48
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:56
02084 - Component Protection
Fault Status: 01100101
Reset counter: 0
02261 - Data Medium
Fault Status: 00101110
Reset counter: 89
Mileage: 243119 km
Date: 2017.12.27
Time: 08:58:46
Text: 00000000
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0014598
VCID: 2C573A898F3291261D-8078
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD044DH2
Coding: 0014131
VCID: 2B5539958A3C961E14-807E
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME192204373
Subsystem 3 - Serial number: 6342QSME1A433C19J
Subsystem 4 - Serial number: 6352QSME18774667N
Subsystem 5 - Serial number: 6362QSME1829185BN
Subsystem 6 - Serial number: 63734SME183B4173$
Subsystem 7 - Serial number: 63834SME1874497FE
000 - - - Intermittent - MIL ON
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Revision: 00H08000 Serial number: 90026063140279
Coding: 0002042
VCID: 66C388A1515E6B760B-8032
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 H
Component: KOMBIINSTR. M73 H17 0170
Revision: 00700000 Serial number: 5HH538PC6
Coding: 2641268
Shop #: WSC 01126 444 104924
VCID: 2345D1B5E2EC5E5EAC-8076
Fault Frequency: 12
Reset counter: 89
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:22
Fault Frequency: 11
Reset counter: 89
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:22
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06B0880B3
Coding: E5D3BE77343A02
Shop #: WSC 01110 444 83876
VCID: 6CD7FA894FB251265D-8038
Reset counter: 89
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:14
Reset counter: 89
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:14
Reset counter: 89
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:14
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082946
Part No SW: 4E0 910 888 D HW: 4E0 919 887 L
Component: MNS US H48 0970
Revision: 00000000 Serial number: 313KU067511848
VCID: 2F6D2D85BE24EA3E38-807A
Fault Frequency: 7
Reset counter: 89
Mileage: 243119 km
Date: 2017.12.27
Time: 08:58:11
Bin. Bits: 1100
Part No SW: 4L0 910 566 A HW: 4L0 907 566 A
Component: J0769_SWA_MasterH06 0060
Revision: 00H06000 Serial number: 6PZ 009 014-00
Subsystem 1 - Part No: 4L0 910 568 A
Component: J0770_SWA_Slave_H05 0060
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F09.11.0600H0500000010167ÿ
Subsystem 4 - Serial number: 010167ÿ
Fault Frequency: 11
Reset counter: 89
Mileage: 243116 km
Date: 2017.12.27
Time: 08:57:33
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0035531
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01025322370000
Coding: 7698581
Fault Frequency: 14
Reset counter: 89
Mileage: 243119 km
Date: 2017.12.27
Time: 08:14:32
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000125648
Coding: 0000016
Shop #: WSC 01126 444 100627
00447 - Function Limitation due to Over-Voltage
Fault Status: 00100001
Fault Frequency: 0
Time Indication: 15
Voltage: 25.50 V
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000055733
Coding: 0012001
VCID: 5EB3A041890E33B6C3-800A
Fault Frequency: 12
Reset counter: 89
Mileage: 243116 km
Date: 2017.12.27
Time: 08:57:00
Voltage: 11.300 V
Temperature: -3.0°C
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0035531
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000021
Fault Frequency: 12
Reset counter: 89
Mileage: 243112 km
Date: 2017.12.27
Time: 08:57:25
Part No SW: 4E0 910 541 M HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 388K$067571722
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000062542
Shop #: WSC 01814 444 69312
VCID: 64C792A9A762196615-8030
Component: von VA0 2611171029
Coding: 344630393135313035442056413032363131313731303239
Fault Frequency: 10
Mileage: 243119 km
Date: 2017.12.27
Time: 08:58:03
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0035338
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 3 - Serial number: RD15.11.06--H21001000A0274ÿ
Subsystem 4 - Serial number: 0A0274ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002197615-----
Coding: 0003595
VCID: 2643C8A191DEAB76CB-8072
Component: J_245_EE15_SKB09H10 0180
Component: J_394_EE15_SKB09H10 0180
Component: J_392_EE15_SKB09H10 0180
02961 - Lamp in Bumper; Rear Right
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 48
Mileage: 243119 km
Date: 2017.12.27
Time: 08:57:45
Bin. Bits: 000 100
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0035338
Part No SW: 4F0 910 336 D HW: 4E0 062 335
Component: Handyvorb2 H16 0700
Revision: 00000000 Serial number: 00000007556136
Coding: 0010900
VCID: 2447D2A9E7E25966D5-8070
End-------------------------(Elapsed Time: 03:00)--------------------------
