2008 GTI (Canadian) - TPMS import to USA
Duck dive
San Diego, USA
C?ID=345556
My new wife (Canadian) and I are in the middle of a few stressful issues.
K1 (marriage) immigration to USA for her, 9 month old boy, and trying to import her 2008 Canadian GTI only to find out that TPMS is required.
From what I gather, her GTI has ABS and ESP. A VIN search at https://vpic.nhtsa.dot.gov/ show that "Active TPMS" is null.
We are really hoping that the indirect TPMS can be turned on with VCDS, but I'm unsure how to confirm whether it is possible :confused:.
I have an 05 Golf TDI and 93 Eurovan so I have a shop that might be able to help with the VCDS to turn on the TPMS. But I want to be informed and know what I'm talking about, at least slightly.
Is there a particular model/part number of ABS that would verify that TPMS can be turned on? Or would a full AutoScan and post here allow some benevolent dictator to confirm?
This car TPMS issue is really stressing my wife out (and me too)... her GTI is in great condition with ridiculously low miles... plus I love driving it too.
Any advice greatly appreciated!
Duck dive
San Diego, USA
C?ID=345556
My little boy is not and issue... haha. Whoops. That sounded wrong. I'll blame that on lack of sleep. :facepalm:
Although some ABS modules were capable of supporting TPMS back then, the algorithms in them weren't sophisticated enough to meet all the US regulatory requirements, most likely the requirement that it detect a condition where all the tires are under-inflated equally. So all the US cars that had TPMS back then used a direct system....
golfi_vend
Tartu, Estonia
C?ID=195131
I would say adding tpms to mk5 is too simple to stress about it.
Change CCM and add sensors. Do the coding and should be enough.
Autoscan would be helpful.
Duck dive
San Diego, USA
C?ID=345556
Ughh. Well, I’ve got an appt to get an Autoscan and find out more about the ABS tomorrow. I’ll post back what I find.
Duck dive
San Diego, USA
C?ID=345556
I wish I felt unstressed about it. From what you are saying, it sounds easy. But I see that there are many different CCMs for MK5s. And is there any concern that a USA spec CCM might cause an issue with a Canadian spec vehicle?
If you know what part number for the correct CCM or can advise me where/who to ask to spec it, I would be very grateful.
As for sensors, I see some like this that would presumably work with the CCM. https://www.amazon.com/dp/B009YWG2RA
I will post Autoscan results tomorrow.
Duck dive
San Diego, USA
C?ID=345556
A bit more info. We used the change noted by BlakH00 in this thread
Following the change, the TPMS indicator shows on the dash when turning the key before starting.
Yet, I took the GTI to the dealer, and he said that their scanner isn't picking up on it. I don't know what scanner he is using, and he didn't want to be advising code changes to a customer. Does anybody know if VW dealers typically use an inhouse scan tool and what it is? He did state that in CAN Gateway, Coding/Long, #19, that a checkbox for TPMS should be checked in order for his scanner to see TPMS as active.
Maybe the procedure (above) I used doesn't check that box. I will investigate, but I thought I'd share.
Any advise or input greatly appreciated...
The Scan after change.
Friday,29,December,2017,11:36:49:49819
VCDS Version: 17.8.1.0
VIN: WVWEV71K88W168445   License Plate:
Mileage: 107460km-66772mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56
VIN: WVWEV71K88W168445   Mileage: 107460km-66772miles
   Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0GN3N67YR
   Coding: 0403010A18070160
   Shop #: WSC 01279 785 00200
   VCID: 366302674185E6F67B-8062
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -  - Intermittent
                    Mileage: 106103 km
                    Time: 02:03:52
                    RPM: 3159 /min
                    Load: 39.6 %
                    Speed: 108.0 km/h
                    Temperature: 75.0°C
                    Temperature: 24.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.351 V
   Revision: 00H11001
   Coding: 0004738
   VCID: 73E5FB731277B3DE9C-8026
   Part No SW: 1K0 907 044 CQ    HW: 1K0 907 044 CQ
   Component: ClimatronicPQ35 130 1212
   Revision: 00130022    Serial number: 00000000000000
   VCID: 78FFCC5F0B11D086A9-802C
   Revision: 00H54000    Serial number: 01000007715840
   Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
   Shop #: WSC 91511 999 72883
   VCID: 71E9F17B686B81CE6E-8024
   Component: Wischer 071107 021  0501
   Coding: 00038805
   Shop #: WSC 91511
   Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
   Component: SDAR SIRIUS     H06 0080
   Revision: 00000000    Serial number: AUZ4Z7G0179201
   VCID: 2E532A07B9D5DE3633-807A
                    Fault Frequency: 20
                    Reset counter: 182
                    Mileage: 104495 km
                    Time: 13:35:22
   Component: 6L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D09VZWB
   Coding: 0013900
   Shop #: WSC 01269 785 00200
   VCID: 6CD7E00F4F496C265D-8038
   Subsystem 1 - Serial number: 6332MSME315748627
   Subsystem 2 - Serial number: 6342MSME31530F087
   Subsystem 3 - Serial number: 6352QSME42232131
   Subsystem 4 - Serial number: 6362QSME446E0A0FV
   Subsystem 5 - Serial number: 63727SME107C4807%
   Subsystem 6 - Serial number: 63827SME0F1F2E61F
   Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
   Component: J0527           036 0070
   Coding: 0002022
   VCID: 75E1C56B1C03ADEEB2-8020
   Part No SW: 1K6 920 874 A    HW: 1K6 920 874 A
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0GN3N67YR
   Coding: 0007303
   Shop #: WSC 19410 444 98964
   VCID: 3169317BA8EBC1CE2E-8064
   Component: J533__Gateway   H15 0180
   Revision:   H15       Serial number: 1400K07A27014F
   Coding: E9811F060013020000
   VCID: 306F347FA3E1C8C621-8064
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T28PM03
   VCID: 7DF1DD4B2433F5AEFA-8028
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 1207
   Coding: 0001077
   VCID: 387F0C5F4B91108669-806C
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.074 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: 3561056B5C83EDEE72-8060
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 939006885103281B0904058FB0080A0488BC00
   Shop #: WSC 00000 785 00200
   Coding: 0001076
   VCID: 3979095B709B098E96-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74E7F86F1779B4E685-8020
   Component: Radio PM6       130 0037
   Revision: 00130000    Serial number: VWZ5Z7I2297042
   Coding: 0040401
   Shop #: WSC 39612 828 149130
   VCID: 2959D91B803BB90EE6-807C
                    Reset counter: 33
                    Mileage: 107460 km
                    Time: 11:44:21
End-------------------------(Elapsed Time: 02:02)--------------------------
Duck dive
San Diego, USA
C?ID=345556
Bump... time has passed. We have kept the Canada plates on (renewed another year), and now it is time to deal with this again. Why the delay? raising a 17 month old.
Anyway, the Indirect TPMS is definitely working. I checked it again today. The indicator on the dash came on when one tire was about 20% less PSI.
Does anybody have a 2008 US based GTI that can post a scan that would show that TPMS is installed/enabled? so I can compare...
MVB_
C?ID=164610
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: RDK 0450
Revision: 00052000 Serial number: 00000000000000
Coding: 0100101
VCID: 040DAB3F470D1D66B5-8050
Here is a 2008 US GTI that belonged to one of our guys for a time:
Wednesday,07,January,2015,11:15:19:35435
VCDS Version: 14.10.0.0
Data version: 20141022
VIN: WVWED71K58W330910   License Plate:
Mileage: 140450km-87271mi   Repair Order:
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWED71K58W330910   Mileage: 140450km-87271miles
Address 01: Engine (CBF)       Labels: 06J-907-115-CBF.clb
   Part No SW: 1K0 907 115 AD    HW: 1K0 907 115 AD
   Component: 2.0l R4/4V TFSI     0060
   Revision: E3H12---    Serial number: VWX7Z0H33NP7VV
   Coding: 0403010818070160
   VCID: E89CF9EFDBF9306147B-80BD
Readiness: 0010 1000
   Revision: 00H11001
   Coding: 0021122
   VCID: F3A69E83923FC3B9E29-80A6
   Part No SW: 1K0 820 047 HS    HW: 1K0 820 047 HS
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: FCB4B5BFBF618CC1B33-80A9
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 00000008311308
   Coding: 078D8F014004150047140000001400008019770B5C000100000000000000
   Shop #: WSC 06485 444 10329
   VCID: F1AA948BE823F1A9105-80A4
   Component: Wischer 210408 021  0501
   Coding: 00038805
   Shop #: WSC 06485
   Revision: 00000000    Serial number: AUZ4Z7H0303069
   Coding: 0000000
   VCID: B3265E83D2BF83B9229-80E6
                    Reset counter: 58
                    Mileage: 138547 km
                    Time: 19:05:37
01304 - Radio
                    Reset counter: 193
                    Mileage: 140233 km
                    Time: 12:54:49
   Component: 6K AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0B39V1
   Coding: 0013899
   VCID: EC9485FFCF011C41233-80B9
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 6332MSME3B6110351
   Subsystem 3 - Serial number: 6342MSME28144F7ER
   Subsystem 4 - Serial number: 6352QSME5D777927Y
   Subsystem 5 - Serial number: 6362QSME6033445DG
   Subsystem 6 - Serial number: 63727SME15590326Y
   Subsystem 7 - Serial number: 63827SME15584D625
   Part No SW: 1K0 953 549 BP    HW: 1K0 953 549 BP
   Component: J0527           752 0101
   Coding: 0002022
   VCID: 814AC44BD883E129E05-80D4
   Part No SW: 1K6 920 974 A    HW: 1K6 920 974 A
   Component: KOMBIINSTRUMENT VDD 2216
   Revision: V0002000    Serial number: VWX7Z0H33NP7VV
   Coding: 0005403
   Shop #: WSC 06417 444 54452
   VCID: B2285B872DA58AB129F-80E7
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 180408F1008767
   Coding: E9811F070013020000
   VCID: B02C518F23A9B8A15FB-80E5
   Revision: 00001000    Serial number: 1225223T34K403
   VCID: FDB2B8BBA47B85C984D-80A8
   Component: IMMO            VDD 2216
   Coding: 0001077
   VCID: B83C69AFCBD960E117B-80ED
   VCID: B522609BDCCB9D890CD-80E0
   Coding: 1B9006885103083F7D04058FB0080A04889C00
   Shop #: WSC 12345 785 00200
   VCID: 8444CD5FC791F401CB3-80D1
   Coding: 0001076
   VCID: B93A6CABF0D379E9E85-80EC
   Coding: 0000003
   VCID: F4A49D9F9731C481FB3-80A1
Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3AD 035 190 A    HW: 3AD 035 190 A
   Component: RCD510USBRVC  003 0003
   Revision: -----001    Serial number: VWZ4Z3N8141478
   Coding: 01000424040010
   Shop #: WSC 00079 790 00000
   VCID: AB1646E3CA8FDB796A9-80FE
                    Reset counter: 159
                    Mileage: 140310 km
                    Time: 10:28:42
   Coding: 0100101
End-------------------------(Elapsed Time: 02:53)--------------------------
As you can see toward the end of the scan, it has a separately addressable TPMS module ("Address 65: Tire Pressure"), but that module is actually incorporated into the CCM ("Address 46: Central Conv.") as evidenced by the fact that both have the same Hardware ID ("HW: 1K0 959 433 CT").
Your HW: 1K0 959 433 CA does not have direct TPMS capability, as evidenced by the "G2" in the Component field in place of the "RDK" on this one. "RDK" stands for "Reifen Druck Kontrolle" (Tire Pressure Monitoring in German).
Duck dive
San Diego, USA
C?ID=345556
Thanks Uwe. That is very helpful. I somewhat understood that there was some kind of hardware difference, and the Comfort Control Module being a part of that (and the tire pressure sensors).
Now I see that those CCMs are for sale online. And it looks like a simple plug/change out. I'm sure I can find the location and also by the tire pressure sensors.
We've contacted all of the Registered Importers and many dealers (as well as VW of America). Nobody is able to assist or even give us a quote to retrofit. It looks pretty simple. I might just buy a used CCM off ebay and see if the Autoscan picks up on Address 65. If it does, then I can probably take it to VW to have them scan it and provide a letter of conformity.
Can you think of any reason that I shouldn't try this? Like is there a strong chance that something else would get messed up?
Duck dive
San Diego, USA
C?ID=345556
I have received the new CCM 1K0 959 433 CT.
I will attempt to install it via these instructions - https://www.youtube.com/watch?v=PLd9TUGa5Hw
If somebody has happened to had there glove compartment off with a view of their CCM (same model, USA MK5 GTI), can you post a photo? I'm curious to know how many wire sets you have plugged into your CCM.
Duck dive
San Diego, USA
C?ID=345556
Bump. Wondering if there is any reason that I shouldn't swap the CA (Canada) CCM for the CT (USA) CCM.
Will I harm anything?
Can't think of any reason why that would be a problem.
golfi_vend
Tartu, Estonia
C?ID=195131
Why are You stressing?
Duck dive
San Diego, USA
C?ID=345556
Stressing because VWofA is no help. I have to have a letter of compliance in order to import with Customs and Border Patrol. I do not think I'll even be able to get the letter of compliance because when I ask them where I can get CCM and sensors installed so that they can authenticate and provide letter of conformity, they have no answer.
So at this point, I'm desperate and about to do this myself. It doesn't seem that difficult, but there is no guarantee that CBP will allow the import without something official from VW.
Indirect TPMS is working and confirmed. But according to NHSTA import rules, the TPMS must be the same as OEM. We already tried to import, but were unsuccessful when we showed them the Indirect.
So the next question... I don't have VCDS myself. A friend has helped me. I forgot that the Indirect TPMS is still coded ON. If I add the CCM (USA with Direct TPMS), what do you think will happen?
Duck dive
San Diego, USA
C?ID=345556
So next question (CCM swap is fine)... with the new CCM (1K0 959 433 CT) that I installed, I'd also like to use the exact OEM tire pressure sensors. I reviewed the Autoscan posted by UWE to see if the OEM tire pressure sensor part number was listed, but I don't see anything. I will have to research (on ebay, I'm seeing many that state they are for GTI MK5), but if anybody knows the tire pressure sensor PN off a USA based GTI 2008 MK5... please let me know.
More info...
Well, the installation of the CCM went well. It is installed. Now just have to meet with anybody in San Diego that has VCDS to get an Autoscan (I'm trying to coordinate with my friend)... so if there is anybody in North County San Diego that is willing to help... please contact me.
The cables are the exact same (just two). The CCMs are slightly different (see photo).
The TPMS indicator on dash is illuminated... likely error condition because no sensors at tires. Gonna get scan first to be sure module 65 Direct TPMS is there in Autoscan (assuming it is but want to confirm).
Then I will source some OEM sensors and take to DTire to install/mount/balance.
About $25/tire is what they charge.
https://photos.google.com/share/AF1...?key=eW0tSllPaUFIZThRRzZ0RE52WGhGVHNGRG43cTJ3
Duck dive
San Diego, USA
C?ID=345556
I may have spoken too soon. After swapping the CCM, the truck and fuel door/gas cap control seem to be swapped. Using the key FOB for trunk unlock actually opens the fuel door/gas cap. Using the drivers door buttons to open fuel door/gas cap unlocks the trunk and trunk opens fuel door.
When trying to open the trunk with VW emblem/handle, it doesn't open trunk but instead opens fuel door.
Hmm. Ideas?
golfi_vend
Tartu, Estonia
C?ID=195131
I have no real idea about US laws, but clearly to have any letter You must have this system up and running.
But for Your problems, I think perhaps this CCM came from Jetta and is coded for it. You need a VCDS to code Your old coding to CCM and enable bits for TPMS.
Duck dive
San Diego, USA
C?ID=345556
Hmm. So would it be easy to re-code the CCM? I have no idea how to do it. Is it kind of like updating firmware on a computer? Where would I find the 2008 USA GTI MK5 VCDS code for the CCM?
Or am I just better off finding a CCM that I know came off of a MK5 GTI USA? Seems like it.
I guess I should have known that there could be a part used on multiple models of VWs and that the programming could be different. My mistake.
