Page 3 of 9 FirstFirst 12345 ... LastLast
Results 21 to 30 of 84
Thread: 2008 GTI (Canadian) - TPMS import to USA
  1. #21
    Dec 2017
    San Diego, USA
    And when I took it to a VW dealer to have them run a scan on it... I got a lot of errors including VAG01330 (no signal/comm) and VAG01044 (incorrect programming).
  2. #22
    Dec 2017
    San Diego, USA
    Does anybody know what the two letter designation at the end of the CCM part number mean? I have seen the following... Are the geographic designations?
    1K0 959 433 CA (the one the GTI had original from Canada)
    1K0 959 433 CT (the one I bought from ebay, but from a USA Jetta, 99% sure)
    1K0 959 433 AS
    1K0 959 433 CD
    1K0 959 433 DA
  3. #23
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by Duck dive View Post
    1K0 959 433 AS
    1K0 959 433 CD
    1K0 959 433 DA
    Variants or revisions of the same basic part. Can mean anything. Here's what it means in your case:
    Your car came with the -CA version. It's the only one that isn't grayed out, when querying VW's parts database using your VIN. Those PR codes are factory production codes that tell you when/why a particular variant would be fitted to your vehicle. You can look them up here: http://prsearch.planetvag.com/.
    The only one with a PR code mentioning TPMS support is the -CT variant, the one you already bought. It also mentions some odd Mexico-only stuff, but that may just be because it was manufactured in Mexico. I pulled up a random USA 2008 GTI for sale on eBay:
    https://www.ebay.com/itm/Volkswagen-...Fbb2Ow&vxp=mtr
    And it looks like that vehicle indeed came with the -CT variant:
    So you've bought the right thing. As for the sensors, here you go:
    As for any programming/coding necessary, VCDS should be able to accomplish that. Not having VCDS available is going to be an issue. We're not going to be able to guide you through that blind, if you can't produce Auto-Scan data for us and let us see what changes are needed and then put those back in. May I suggest a trip to the Ross-Tech store for a HEX-V2 Enthusiast? It appears you've already spent more than half of that cost, or more, getting a dealer to just throw their hands up in confusion.
    Silence gives consent.
  4. Likes Uwe liked this post
  5. #24
    Dec 2017
    San Diego, USA
    Great information. Thank you. Luckily, the dealer performed the scan at no charge.
    My friend and I both have 1993 Eurovans, and we get together once a year to scan them. I think he bought the 2x2 adapter to do that.
    I'm still waiting for him to get back to me... but I guess it is time for me to pickup my own.
    Just ordered from Ross Tech. Will report back once I can Autoscan and post results.
    I will perform one with the original. Then I will install the CT version and perform another Autoscan.
    Stay tuned.
  6. Likes jyoung8607, Uwe, Fredrick Awuor liked this post
  7. #25
    Dec 2017
    San Diego, USA
    Rcvd my HEX-V2 to scan this GTI (and a 2x2 for my 1993 Eurovan too)
    Here are the Autoscan results with the original (Canadian) CCM
    This is my first ever, so please bear with me.
    I notice something about the ignition switch... it has hesitated when started sometimes (we already replaced original battery).
    The headlight one... guess I need to research.
    The cooling one is probably the thermostat (I have a cheap bluetooth OBD2). But $500 to swap (called two places). Not sure I want to try it myself. Why do they put a part that will fail so deep in there?
    Then there is the 1330 no signal/intermittent with the CCM. Not sure about that???
    Anyway, the goal is to swap the CCM to the USA version ending in -CT. Now that I have done the Autoscan, is there a way to copy the settings so they can be input in the the USA CCM?
    Friday,31,August,2018,14:50:39:15635
    VCDS Version: 18.2.1.5 (x64)  HEX-V2 CB: 0.4411.4
    VIN: WVWEV71K88W168445   License Plate:
    Mileage: 111750km-69438mi   Repair Order:
    Gateway Installation List:  1K0 907 530 L
    46-Central Conv. -- Status: Malfunction 1010
    Friday,31,August,2018,14:52:13:15635
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56
    VIN: WVWEV71K88W168445   Mileage: 111750km-69438miles
       Part No SW: 1K0 907 115 S    HW: 8P0 907 115 B
       Revision: 5BH16---    Serial number: VWX7Z0GN3N67YR
       Coding: 0403010A18070160
       Shop #: WSC 01279 785 00200
       VCID: 363525885444AC879B8-8062
    008577 - Performance Malfunction in Cooling System
                   P2181 - 008 -  - Intermittent - MIL ON
                        Fault Status: 10101000
                        Mileage: 106103 km
                        Time: 02:03:52
                        RPM: 3077 /min
                        Load: 31.4 %
                        Speed: 61.0 km/h
                        Temperature: 75.0°C
                        Temperature: 35.0°C
                        Absolute Pres.: 1000.0 mbar
                        Voltage: 14.224 V
       Revision: 00H11001
       Coding: 0004738
       VCID: 73B3DC9C07B6F9AF7C6-8026
       Part No SW: 1K0 907 044 CQ    HW: 1K0 907 044 CQ
       Component: ClimatronicPQ35 130 1212
       Revision: 00130022    Serial number: 00000000000000
       VCID: 78A9EBB01ED09AF7494-802C
       Revision: 00H54000    Serial number: 01000007715840
       Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
       Shop #: WSC 91511 999 72883
       VCID: 71BFD6947DAACBBF8EA-8024
       Component: Wischer 071107 021  0501
       Coding: 00038805
       Shop #: WSC 91511
                010 - Open or Short to Plus
                        Fault Status: 01111010
                        Reset counter: 214
                        Mileage: 110630 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 14.30 V
                        Reset counter: 247
                        Mileage: 111563 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.30 V
       Part No SW: 8E0 035 593 H    HW: 8E0 035 593 H
       Component: SDAR SIRIUS     H06 0080
       Revision: 00000000    Serial number: AUZ4Z7G0179201
       VCID: 2E050DE8AC149447D38-807A
                        Fault Frequency: 21
                        Reset counter: 190
                        Mileage: 111272 km
                        Time: 18:27:15
       Component: 6L AIRBAG VW8R  034 8000
       Revision: 05034000    Serial number: 003B6D09VZWB
       Coding: 0013900
       Shop #: WSC 01269 785 00200
       VCID: 6C81C7E05A882657BDC-8038
       Subsystem 1 - Serial number: 6332MSME315748627
       Subsystem 2 - Serial number: 6342MSME31530F087
       Subsystem 3 - Serial number: 6352QSME42232131
       Subsystem 4 - Serial number: 6362QSME446E0A0FV
       Subsystem 5 - Serial number: 63727SME107C4807%
       Subsystem 6 - Serial number: 63827SME0F1F2E61F
       Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
       Component: J0527           036 0070
       Coding: 0002022
       VCID: 75B7E28409C2E79F522-8020
       Part No SW: 1K6 920 874 A    HW: 1K6 920 874 A
       Component: KOMBIINSTRUMENT VDD 1216
       Revision: V0002000    Serial number: VWX7Z0GN3N67YR
       Coding: 0007303
       Shop #: WSC 19410 444 98964
       VCID: 313F1694BD2A8BBFCEA-8064
                        Reset counter: 247
                        Mileage: 111563 km
                        Time: 13:22:22
       Component: J533__Gateway   H15 0180
       Revision:   H15       Serial number: 1400K07A27014F
       Coding: E9811F060013020000
       VCID: 30391390B62082B7C14-8064
                        Reset counter: 247
                        Mileage: 111563 km
                        Time: 13:22:23
                000 -  -  - Intermittent
                        Reset counter: 247
                        Mileage: 111563 km
                        Time: 13:26:04
       Part No SW: 1K6 919 879     HW: 1K6 919 879
       Component: Kompass         001 0003
       Revision: 00001000    Serial number: 1225223T28PM03
       VCID: 7DA7FAA431F2BFDF1A2-8028
       Component: IMMO            VDD 1216
    01176 - Key
       Component: Tuer-SG         006 1207
       Coding: 0001077
       VCID: 38292BB05E505AF7894-806C
       Part No: 1K1 909 144 M
       Component: EPS_ZFLS Kl.074 H08 1901
       Shop #: WSC 00000 028 00001
       VCID: 353722844942A79F922-8060
       Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
       Coding: 939006885103281B0904058FB0080A0488BC00
       Shop #: WSC 00000 785 00200
                        Fault Frequency: 13
                        Reset counter: 247
                        Mileage: 111563 km
                        Time: 18:03:16
       Coding: 0001076
       VCID: 392F2EB4655A43FF76A-806C
       Part No: 1T0 907 357
       Coding: 0000003
       VCID: 74B1DF8002B8FE9765C-8020
       Component: Radio PM6       130 0037
       Revision: 00130000    Serial number: VWZ5Z7I2297042
       Coding: 0040401
       Shop #: WSC 39612 828 149130
       VCID: 290FFEF495FAF37F06A-807C
                        Fault Status: 01111011
                        Reset counter: 141
                        Mileage: 107460 km
                        Time: 11:44:21
    End----------(Elapsed Time: 01:06, VBatt start/end: 12.4V/12.4V)-----------
  8. Likes Uwe, jyoung8607 liked this post
  9. #26
    Rcvd my HEX-V2
    Got you Verified. Moving this to Retrofits now.
    Well, we have the coding there. But it's not entirely clear to me whether the coding will transfer directly.
    The other thing I would do, just to have it, is to make an Adaptation Channel Map from your CCM.
    [Applications]
    [Controller Channel Map]
    Controller Address = 46
    Login or Security Access Code: leave blank
    Function: Adaptation
    Output: CSV File
    [Go]
    Once that's done, I would physically swap the modules and run another scan so we can see what you've got. Don't change anything in the new module yet.
  10. Likes jyoung8607 liked this post
  11. #27
    Dec 2017
    San Diego, USA
    Here is the Adaptation Channel Map from the original CCM -CA (Canada)
    I will swap to -CT CCM and run Autoscan and Adaptation and post later today.
    ;SW:1K0-959-433-CA HW:1K0-959-433-CA --- Central Conv.
    ;Component: KSG PQ35 G2 020 0204, Coding:939006885103281B0904058FB0080A0488BC00
    ;Saturday,01,September,2018,09:45:59:15635
    ;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.2
    ;VCID: 71BFD6947DAACBBF8EA-8024
    Channel,,Field 1,Field 2,Field 3,Field 4,
    01,1,Key,learn (adapt),1, - ,
    02,,ERROR:,Channel 02,Not,Available,
    03,1,OPEN,Single Door,ON, - ,
    04,1,Auto Lock /, ,ON, - ,
    05,0,Auto Unlock, ,OFF, - ,
    06,,ERROR:,Channel 06,Not,Available,
    07,1,Unlocked,Remote Ctrl.,Blink, - ,
    08,1,Unlocked,Key,Blink, - ,
    09,,ERROR:,Channel 09,Not,Available,
  12. Likes Uwe liked this post
  13. #28
    Dec 2017
    San Diego, USA
    Is it recommended (or required) to disconnect battery for swapping CCM?
  14. #29
    Võru, Estonia
    Not really.
    The world is my oyster...
  15. #30
    Dec 2017
    San Diego, USA
    Here is the Autoscan and Adaptation Channel Map from the CCM -CT (USA)
    Saturday,01,September,2018,14:53:21:15635
    Mileage: 111750km-69438mi   Repair Order: CCM-CT
    Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
    65-Tire Pressure -- Status: Not registered 0011
                        Mileage: 106103 km
                        Time: 02:03:52
                        RPM: 3077 /min
                        Load: 31.4 %
                        Speed: 61.0 km/h
                        Temperature: 75.0∞C
                        Temperature: 35.0∞C
                        Voltage: 14.224 V
       Revision: 00H11001
       Coding: 0004738
       Coding: 00038805
       Shop #: WSC 91511
                        Fault Status: 01101010
                        Reset counter: 214
                        Mileage: 110630 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 14.30 V
                        Reset counter: 254
                        Mileage: 111563 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.30 V
                        Fault Frequency: 21
                        Reset counter: 190
                        Mileage: 111272 km
                        Time: 18:27:15
       Coding: 0013900
       Coding: 0002022
       Coding: 0007303
                        Fault Frequency: 10
                        Reset counter: 254
                        Mileage: 111563 km
                        Time: 13:22:22
                        Reset counter: 254
                        Mileage: 111563 km
                        Time: 13:22:23
                        Reset counter: 214
                        Mileage: 111563 km
                        Time: 13:26:04
    01176 - Key
       Coding: 0001077
       Component:    KSG PQ35 RDK 052 0218
       Coding: 13900F880186281B0904058FB0880F0488DCA0
       VCID: 04518F405218CE1755C-8050
                        Reset counter: 247
    00830 - Convertible Top Control Module (J256)
                        Reset counter: 203
                        Fault Status: 00110100
                        Reset counter: 247
                        Reset counter: 203
                        Reset counter: 247
       Coding: 0001076
       Coding: 0000003
       Coding: 0040401
                        Reset counter: 141
                        Mileage: 107460 km
                        Time: 11:44:21
       Component:    RDK              0440
       Coding: 0100101
                        Reset counter: 254
                        Mileage: 111578 km
                        Time: 12:23:37
    End----------(Elapsed Time: 01:09, VBatt start/end: 12.1V/12.2V)-----------
    ;SW:1K0-959-433-CT HW:1K0-959-433-CT --- Central Conv.
    ;Component: KSG PQ35 RDK 052 0218, Coding:13900F880186281B0904058FB0880F0488DCA0
    ;Saturday,01,September,2018,14:53:56:15635
    ;VCID: 04518F405218CE1755C-8050
    10,3,Locked,Remote Ctrl.,Beep + Blink, - ,
    11,3,Locked,Key,Beep + Blink, - ,
    12,2,safe, ,Beep, - ,
    13,,ERROR:,Channel 13,Not,Available,
    14,,ERROR:,Channel 14,Not,Available,
    15,,ERROR:,Channel 15,Not,Available,
    16,,ERROR:,Channel 16,Not,Available,
    17,0,Comfort,Remote Ctrl.,OFF, - ,
    18,1,Alarm delay,Driver,ON, - ,
    19,0,Locked,Inactive,OFF, - ,
    20,,ERROR:,Channel 20,Not,Available,
    21,,ERROR:,Channel 21,Not,Available,
    22,,ERROR:,Channel 22,Not,Available,
    23,,ERROR:,Channel 23,Not,Available,
    24,,ERROR:,Channel 24,Not,Available,
    25,,ERROR:,Channel 25,Not,Available,
    ****** Continues
