Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: VCDS Beta 14.9.0 out of date
    Stoke on Trent, England
    Hi guys.
    I've just plugged it in to do my normal scan VCDS Release 14.10.0 after it finished I thought I would give the VCDS Beta 14.9.0 ago. All buttons were disabled and a message at the top said it out of date. I went online the http://www.ross-tech.com/vcds/downlo...a/current.html and its showing the VCDS Beta 14.9.0 I have installed. If you click the download it goes to the normal download page VCDS Release 14.10.0 which I have installed.
    As the Beta version finished or is it a bad link on the download button?
    Just another quick point while I'm posting. After every scan I've done and saved the log file. Out of 24 scans done on my GTD 14 of them have the mileage added to the filename, Mileage: isn't shown in the files without it. Why doesn't it save or show the mileage every time?
    Only one error code showed which I will have to look into.
    Data version: 20141022
    Dealer/Shop Name: Keith Stanier
    VIN: WVWZZZ1KZAW267666   License Plate: GTD U
    Mileage: 42950km-26687mi   Repair Order:
    Chassis Type: 1K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
    VIN: WVWZZZ1KZAW267666   Mileage: 42950km-26687miles
    Address 01: Engine (CBB)       Labels: 03L-906-022-CBA.clb
       Part No SW: 03L 906 022 LC    HW: 03L 906 022 G
       Component: R4 2,0L EDC 0000SG  6655
       Revision: 13H03---    Serial number:
       Coding: 0001072
       Shop #: WSC 00256 210 88209
       VCID: 71EC587868FBDAA9905-8024
       Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
       Revision: 00H30001
       Coding: 163B600D09280001681106EA901F0082340800
       VCID: 78FA655CCB818BE157B-802D
       Part No SW: 5K0 907 044 BS    HW: 5K0 907 044 BS
       Component: Climatronic   H15 0709
       Revision: 00003001
       Coding: 0000000002
       ROD: EV_ClimaAutoBasis_SE36.rod
       VCID: 7DF47448ECA3AEC904D-8028
       Part No SW: 1K0 937 086 C    HW: 1K0 937 086 C
       Component: BCM PQ35  M   103 0575
       Revision: 00103 AG
       Coding: 48180A3A9025F1C044080080340001E443510088536D8160648000200000
       VCID: 306A9D7C637193A1DFB-8065
       Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
       Component: Wischer 16120  21  0512
       Coding: 009795
       Component: RLS 211209 05  54  0402
       Coding: 0330AD
       Subsystem 4 - Part No: 1K8 951 605
       Component: LIN BACKUP HO  H10 9003
    00532 - Supply Voltage B+
                        Reset counter: 159
                        Mileage: 42853 km
                        Date: 2014.11.10
                        Time: 15:28:21
                            Term 15 On
                        Voltage: 14.30 V
                            Term 50 Off
                        Fault Status: 00100001
                        Reset counter: 162
                        Mileage: 42932 km
                            Term 15 Off
                        Voltage: 15.05 V
                            Term 50 Off
       Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
       Component: AirbagVW10    037 0606
       Serial number: 003FKRA26LAS
       Coding: 00003133
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01011
       ROD: EV_AirbaVW10SMEVW360_SK35.rod
       VCID: 3B70BA50B23760F97A9-806E
       Serial number: 3572MSME7741744EZZZ+
       Serial number: 3582MSME5961654EZZZ1
       Serial number: 3512QSME2E1E455EZZZ7
       Serial number: 3522QSME2C524572ZZZV
       Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
       Coding: 0000502
       VCID: 78FA655C0B818BE157B-802D
       Subsystem 1 - Part No: 5K0 959 542   Labels: 3C8-959-537.CLB
       Component: E221__MFL-TAS   H05 0010
       Coding: 00000130
       Part No SW: 5K6 920 970 E    HW: 5K6 920 970 E
       Component: KOMBI         H03 0305
       Coding: 470900
       ROD: EV_Kombi_UDS_VDD_RM09_SE25.rod
       VCID: 3666AB648915BD91857-8063
    Address 19: CAN Gateway        Labels: 1K0-907-530-V4.clb
       Component: J533  Gateway   H16 0233
       Revision:   H16       Serial number: 4520K09C11031B
       Coding: E9807F06000212000003
       VCID: 69DC3018402B2269D85-803C
       Component: IMMO          H03 0305
       VCID: 6ADE4F148D2D2971D1F-803F
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
       Revision: A1001003    Serial number: 7667727711
       VCID: 26467B2451B5CD11357-8073
       Component: Tuer-SG         009 2114
       Coding: 0000692
       VCID: 316C9878A87B9AA9D05-8064
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Component: Tuer-SG         009 2140
       Coding: 0000692
       VCID: 3462916C5769AF81BB3-8061
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
       Component: Radio RCD310  016 0049
       Revision: 00000000    Serial number: VWZ1Z2I7269487
       Coding: 0100040004
       VCID: 65C43C286C330609FCD-8030
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Coding: 0000144
       Shop #: WSC 01357 011 1012552
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0000144
       VCID: 3564AC685C13B6898CD-8060
    End-------------------------(Elapsed Time: 01:59)--------------------------
    VAG Error Code: 00532
    EOBD II Error Code: P1750
    Fault Location:
    Supply Voltage B+ - Open Circuit/Signal too Low/Signal too High/Lower Limit Exceeded/Upper Limit Exceeded - Intermittent
    Possible Cause:
    Malfunction Indicator Lamp (MIL)(K83) active.
    Fuse(s).
    Wiring/Connectors from/to ABS Control Module (J104)/Brake Electronics Control Module (J104).
    This Diagnostic Trouble Code (DTC) is only stored, if it occurs the first time the vehicle exceeds 6 km/h.
    As soon as the supply voltage is again within the valid voltage range, the system is switched back on and the warning lights turn off.
    Open circuit or resistance too high between voltage supply of terminal 15 and ABS Control Module (J104)/Brake Electronics Control Module (J104) (terminal 1).
    Open circuit or resistance too high in earth supply to ABS Control Module (J104)/Brake Electronics Control Module (J104) terminals 28 & 29.
    Voltage jumps in vehicle.
    Power Supply (Battery/Generator) faulty.
    Possible Solutions:
    Check/Replace Fuse(s).
    Check/Replace all faulty Wiring/Connectors from/to Control Module.
    Check Power Supply (Battery/Generator).
    Read Measuring Value Blocks (MVB).
    Special Notes:
    When found in an individual control module, it's most likely a local source (e.g. wiring/connectors).
    When found in multiple control modules at the same time, it's most likely a common source (e.g. ground spot, battery, generator).
    Intermittent codes are often stored during low outside temperature when the battery capacity goes down and may be ignored.
    Common with 16946/P0562/001378 - System Voltage: Too Low stored in other control modules.
    New User Keith
    Lansdale, PA
    We felt the beta was good enough for a release, so beta 14.9 was replaced with release 14.10.
  3. Likes Sebastian, jyoung8607 liked this post
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Quote Originally Posted by Keithuk View Post
    Release 14.10.0 is the "next version" after Beta 14.9.0. There is no current Beta. You can go ahead and uninstall Beta 14.9.0 if you haven't already.
    Were they all complete Auto-Scans, or perhaps were you only saving codes from one module? Gathering of VIN and mileage is opportunistic. If it happened to see them in 17-Instruments, it should save them, if not it won't.
    Jason
    Ok so you may as well uninstall the VCDS Beta as you can't use it.
    Anything on why it does show the mileage in the filename or in the log file?
    New User Keith
    Magdeburg, Germany
    The mileage in the Auto-Scan for newer models was a feature added during the 14.X Beta cycle. So the older scans which don't show that are likely done with older versions like Release 12.12
  7. Likes jyoung8607, Uwe liked this post
    Well its strange that some of the earlier log files show mileage but later ones don't.
    VCDS Version: Release 10.6.3 Some shows mileage some don't.
    VCDS Version: Release 10.6.4 Some shows mileage some don't.
    VCDS Version: Release 10.6.5 Don't show mileage.
    VCDS Version: Release 11.11.0 Some shows mileage some don't.
    VCDS Version: Release Beta 11.11.2 Doesn't show mileage.
    VCDS Version: Release 11.11.3 Does show mileage.
    VCDS Version: Release 11.11.4 Does show mileage.
    VCDS Version: Release 11.11.5 Some shows mileage some don't.
    VCDS Version: Release 11.11.6 Does show mileage.
    VCDS Version: Release 12.12.0 (x64) Some shows mileage some don't.
    VCDS Version: Release 12.12.2 Does show mileage.
    VCDS Version: Release 12.12.3 Some shows mileage some don't.
    VCDS Version: 14.10.0.0 Does show mileage.
    VCDS Version Beta: 14.5.1.0 Does show mileage.
    VCDS Version Beta: 14.7.2.0 Does show mileage.
    VCDS Version Beta: 14.8.1.0 Does show mileage.
    I've downloaded and installed all 33 versions released 10.63-14.10.0 but I may have not used them all.
    New User Keith
    Much depends on the cluster, and specifically whether the cluster in the car uses UDS or one of the older protocols.
  10. Likes Sebastian liked this post
  11. #8
    Well the cluster is the same on all scans of my 2010 Golf GTD (170) CBBB.
    New User Keith
  12. #9
    And all the scans in question were full Auto-Scans?
    Magdeburg, Germany
    Any chance you may have entered the mileages manually on all scans/versions up to and including 12.12?
