Results 1 to 2 of 2
Thread: Audi A4 B8 Errors after Telephone Module Retrofit
    Feb 2017
    After retrofitting an 8T0 862 335 telephone module I have got a 01043 - Control Module; Incorrect Software Version error from my Concert 3 unit. Does anyone have any idea why this error is occurring? The Bluetooth hands-free is working fine. (The is an energy management active error that is due to the battery running a bit low).
    Thanks.
    Friday,22,December,2017,15:23:08:04200
    VCDS Version: 17.8.1.0 (x64)
    VIN: WAUZZZ8K99A17XXXX   License Plate:
    Chassis Type: 8K-AU48 (8T0)
    Scan: 01 03 05 08 09 15 16 17 19 42 46 47 52 53 55 56 62 72 77
    VIN: WAUZZZ8K99A175181   Mileage: 166490km-103452miles
    Address 01: Engine (J623-CCWA)       Labels:| 059-907-401-V1.clb
       Part No SW: 8K2 907 401 A    HW: 8K1 907 401 A
       Component: 3.0TDI EDC17  H01 0006
       Revision: 15H01---
       Coding: 0104002C180F0118
       Shop #: WSC 06325 000 00000
       ASAM Dataset: EV_ECM30TDI0118K2907401A 001006
       ROD: EV_ECM30TDI0118K2907401A.rod
       VCID: 2B55328C4215581E14-807E
       Part No SW: 8K0 907 379 AF    HW: 8K0 907 379 AF
       Component: ESP8 quattro  H04 0210
       Coding: 1B0500
       VCID: 7DF1CCD4E4E106AEFA-8028
       Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
       Component: BCM2 1.1      H80 0145
       Coding: 031100
       VCID: 306F25E063333BC621-8064
       Subsystem 1 - Part No SW: 8T0 959 754 K    HW: 8T0 959 754 K
       Component: FBSAUDIB8 IDG  H60 0072
       Serial number: 0811000031275014
       Serial number: 0208000096256014
       Part No SW: 8T2 820 043 S    HW: 8T2 820 043 S
       Component: KLIMA 3 ZONEN H06 0150
       Revision: D0000000    Serial number: 01311020080306
       Coding: 36140000
       Shop #: WSC 06325 123 12345
       VCID: 428B7F28DD9FB956C7-8016
       Part No SW: 8K0 907 063 C    HW: 8K0 907 063 C
       Revision: 04022001    Serial number: 00000000165534
       Coding: 260050914034AF010001000000001D0D001D030800010141000000
       VCID: 2F6D269C7E0D243E38-807A
       Subsystem 1 - Part No SW: 8K2 955 119 A    HW: 8T2 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 041108  H05 0070
       Serial number: SWF08110040356
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10319558
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 AA    HW: 8K0 941 531 AA
       Component: E1 - LDS  H07 0080
       Serial number: 00000000001911080066
       Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
       Serial number: 0038JD1CMMR+
       Coding: 30363435363030303030554A3052384B3053
       VCID: 3C7701D0B77BCFA68D-8068
       Serial number: 6334MSME432545141
       Serial number: 6344MSME4224756BF
       Serial number: 6352QSME64133C1EL
       Serial number: 6362QSME35123F32C
       Serial number: 63732SME1E141410P
       Serial number: 63832SME52121614M
       Component: Lenks.Modul   H13 0013
       Revision: --------    Serial number: 90304HKD000ON
       Coding: 000016
       VCID: 3D710CD4A461C6AEBA-8068
       Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
       Component: KOMBIINSTR.   H17 0224
       Revision: 00100000    Serial number: 9E358J2C8
       Coding: 2F44090002002600010000
       VCID: 316920E4683932CE2E-8064
       Part No SW: 8T0 907 468 M    HW: 8T0 907 468 H
       Component: GW-BEM 5CAN   H06 0095
       Revision: GB300043    Serial number: 4300G08A289005
       Coding: 000303
       VCID: 4B95520CEAD5781E34-801E
       Component: J367-BDM  H04 0150
       Serial number: 180548DA061108
                000 -  -
                        Reset counter: 30
                        Mileage: 166494 km
                        Date: 2017.12.22
                        Time: 15:14:00
       Part No SW: 8K0 959 793 E    HW: 8K0 959 793 E
       Revision:             Serial number: 0000008152982
       Coding: 011002204001410001
       Revision: 00002001    Serial number: 0116037973
       Coding: 011B062200390440002001
       Shop #: WSC 06342 000 00000
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
       Part No SW: 8T0 035 223 S    HW: 8T0 035 223 B
       Component: DSP Prem      H13 0210
       Revision: 00013001    Serial number: 34833002327405
       Coding: 0203010201
       VCID: 3E730BD8A967DDB6A3-806A
                000 -  -
                        Reset counter: 30
                        Mileage: 166494 km
                        Date: 2017.12.22
                        Time: 10:16:01
                        Voltage: 11.60 V
                        Temperature: 14.0°C
                        Temperature: 25.0°C
                        Bin. Bits: 00000001
       Part No SW: 8K0 959 792 E    HW: 8K0 959 792 E
       Revision:             Serial number: 0000008160240
       VCID: 41897024D899A24EDE-8014
       Part No SW: 8K0 907 801 F    HW: 8K0 907 801 F
       Component: EPB Audi B8   H06 0070
       Revision: 00000003    Serial number: 10000000138705
       VCID: 326B2FE86D3F09D657-8066
       Part No: 8K5 907 357
       Coding: 0000004
       Shop #: WSC 06324 000 00000
       VCID: 77FDDEFC06DD2CFEA0-8022
       Part No SW: 8T2 035 186 C    HW: 8T2 035 186 C
       Component: Concert3      H02 0230
       Revision: 00000005    Serial number: AUZ5Z6H1145386
       Coding: 050300820101CD020359870900
       VCID: 387F1DC08B43E38669-806C
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
                000 -  -
                        Reset counter: 30
                        Mileage: 166494 km
                        Date: 2017.12.22
                        Time: 10:16:01
                        Bin. Bits: 00000010
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                000 -  -  - Intermittent
                        Reset counter: 70
                        Mileage: 166494 km
                        Date: 2017.12.22
                        Time: 10:16:04
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
                        Bin. Bits: 10000000
                        Bin. Bits: 00000000
                        Bin. Bits: 00000000
       Part No SW: 4F0 959 795 N    HW: 8K0 959 795 C
       Revision:             Serial number: 0000008117340
       Coding: 010002204001210001
       VCID: 44877930C78BB766F5-8010
       Revision:             Serial number: 0000008116823
       Part No SW: 8T0 862 335 F    HW: 8T0 862 335 E
       Component: FSE_256x BT     H45 0660
       Revision: 00000000    Serial number: 00000005460893
       Coding: 0010320
       Shop #: WSC 02335 785 00200
       VCID: 3D710CD46461C6AEBA-8068
    End-------------------------(Elapsed Time: 03:17)--------------------------
    Oct 2017
    Northwest UK
    Hi Ibis
    Is it working correctly? If it is then ignore this. SVM (Software Version Management) is a VAG system they use to update modules and coding. In retrofitting this is a common error to see.
    VW use their own system called ODIS with SVM coding to update the module's software. You only need to be concerned about SVM if it's not functioning correctly. As the good old saying goes 'if if ain't broken, don't try fixing it!'.
