UDS - Re-adapt Adaptive Suspension to default position -
DrPeter
16.4905° S, 151.7375° W
Hello....
Revised 7/1/2020
- Streamlined [The Procedure] below, again, thank you ALL for your feedback!
This procedure is not for the 'older' non UDS vehicles, this procedure can be found here, 'Suspension Level Calibration'
How can you tell if you have a 'UDS' Level Controller? Click here UDS vs. Non-UDS
This is an example of a UDS Level controller when found in the Auto-Scan results:
Address 34: Level Control (J197) Labels: 3Y0-907-533-V1.clb​
Part No SW: 3Y0 907 553 HW: 3Y0 907 553​
Component: LUFE-DAEMPFER H16 1095​
Coding: 008000​
Shop #: WSC 00083 790 00174​
ASAM Dataset: EV_AirSuspe 003017​
ROD: EV_AirSuspe_AU64.rod
This procedure is applicable for follow vehicles.
Audi A6 (4G2) 2011 -->
Audi A7 (4GA) 2012 -->
Audi Q7 2011* -->
Audi A8/A8L (4H2/4H8) 2011 -->
Bentley Mulsanne (3Y2) 2011 -->
Standard Ride Height in millimeter as per repair manual, use the correct PR-Code
Brand Model:
(PR Code) Suspension type
Front axleRear axle
Audi A6/A7 (C7 Coupe/Sportback):
(1BK) standard running gear
384mm382mm
(1BS) Heavy duty running gear
391mm389mm
Audi A6/A7 (C7 Coupe/Sportback S):
(2MB) Sport running gear
386mm384mm
Audi A6/A7 (C7 Coupe/Sportback RS):
(2MA) RS running gear
386mm382mm
Audi A6 (C7 Saloon/Avant):
384mm382mm
389mm387mm
Audi A6 (C7 Saloon/Avant S):
(2MB) sports running gear
384mm382mm
Audi A6 (C7 Saloon/Avant RS):
(2MA) sports running gear
384mm384mm
Audi A6 (C7 Allroad):
(1BY) heavy-duty running gear:
393mm390mm
Audi A6 (C7 Coupe):
(1BK) standard running gear:
386mm384mm
Audi A6 (C7 Coupe S):
384mm382mm
Audi Q7:*
442mm454mm
Audi Q7:*
(2MA) Sports running gear:
427mm439mm
Audi A4/S4|A5/S5:*
(1BL) Suspension / Damping controlled:
384mm383mm
Audi A4/S4|A5/S5:*
384mm383mm
Audi A4/S4|A5/S5:*
(2MN) Suspension / Damping controlled:
410mm408mm
Audi A8/S8 (4H2/4H8) 2011
(1BK) Standard running gear:
410mm405mm
(2MA/2MB) Sports running gear:
400mm395mm
(1By) Heavy-duty running gear:
418mm413mm
Bentley Mulsanne 2011]
424mm 429mm
414mm419mm
Brand Model:
Front axleRear axle
(* Certain vehicles with UDS Level controllers)
(A4/A5 vehicles are unconfirmed at this time
Table revised January_2020
Note:
1BA/1BH = Standard running gear
1BE = Sports running gear
1BB/1BR = Heavy-duty running gear
1BK = Standard running gear, air suspension
1BS = Heavy-duty running gear, air suspension
1BV = Sports running gear (S line)
1BY = allroad
2MA = RS running gear, air suspension
2MB = Sports running gear, air suspension
2MC = RS running gear
[Coding]
- If there is an 'incorrectly coded' fault in the [34-Level Control], the controller will need to be coded first, before 'The Procedure' below can be completed!
- If you have saved an [Auto-Scan] of the vehicle prior to the coding being lost, you can search the scan and copy/paste the coding into the controller.
- In the unlikely event you have lost coding, create a new Ross-Tech forum thread in the Car Repair Support section and let's see if we can help.
Special Notes, warnings, etc
- Do not at any point in time select Basic Settings [*IDE01475*] [Resetting of all adaptations]. If you choose to do so, DTC B2013 will be stored and you will need to make an appointment with your local dealer! B2013: No End-of-Line Programming will prevent a successful calibration.
- Make sure you perform and save an [Auto-Scan] before beginning any work
- If you are attempting to alter the ride height use this procedure at your own risk!
- If you copy or post this procedure and/or any of its contents anywhere else, please be respectful and give credit where credit is due
[The Procedure]
Prerequisites
- Ignition [ON], Use a Battery maintainer
- Vehicle on level surface
- No persons or gear in Vehicle
- Fuel Tank 60% or more
- Nothing under vehicle
- Door are to remain shut during the entire procedure
- No faults in the [34-Level Control] controller other than "No or incorrect Basic Settings"
Using the MMI (under [Car]/[Service] ) the following needs to be set-
- Audi Drive Select (under Car menu) set to [Auto]
or
- Automatic Drive Program set to [Auto] (Bentley)
1) Select - [34-Level Control]
Press [Security Access-16] enter - [20103], [Do it!]
2) Select - [Basic Settings - 04]
- Choose - [*IDE03804*] Deactivating loading mode- Press [Go!]
- Wait for basic Settings to end, [Finished correctly/Not Running], then press [Stop]
3) Select - [Basic Settings - 04]
- Choose - [*IDE03751*] [Activate level control]- Press [Go!]
4) Choose - [*IDE03761*] [Delete calibration for level control] - Press [Go!]
5) Choose - [*IDE03802*] [Set reference level]- Press [Go!]
- Note, basic Settings [*IDE03939*] [Start up to reference level (production)] should NOT be used.
- Wait for basic Settings to end, [Finished correctly/Not Running], then press [Stop], [Go Back] (vehicle should level it's self wait till it stops)
6) Measure the ride height, in millimeters, from the center of the wheel to the edge of fender, do this for all four wheels and record the values, this will set the ride height to the factory level.
- Modification to ride height may be possible, for example adding to the measured value would lower the suspension because the level control system thinks the ride height it too high. DO THIS AT YOUR OWN RISK!​
- We do not suggest anyone to make changes to the standard ride heights!​
- Users may post their 'tweaking ride height' questions here, in the Ross-Tech forum, Tweaks section.​
Select [Adaptation - 10]
Choose from the drop down menu and enter the [New value] recorded value for each of the wheels below, then press [Do it!]
[*IDE02001*] [Body height left front wheel house edge]
[*IDE02002*] [Body height right front wheel house edge]
[*IDE02003*] [Body height left rear wheel house edge]
[*IDE02004*] [Body height right rear wheel house edge]
See the above table for standard values
7) Select - [Basic Settings - 04]
- Choose - [*IDE03762*] [Calibrate level control] - Press [Go!]
(Vehicle may lower/raise)
8) Select - [Basic Settings - 04]
- Choose - [*IDE03751*] [Activate level control] - Press [Go!]
- Wait for basic Settings to end, [Finished correctly/Not Running], then press [Stop], [Go Back], [Close Controller]
Quality check and house keeping:
A.) Measure the ride height again and verify the values are within 3mm of the displayed values in Advanced Measuring Value Blocks.
B.) Using the MMI verify the following setting -
- Air Spring Wheel Change = [off]
C.) Ignition Key On/Off Cycle must be completed.
D.) Clear ALL fault codes and re-check for fault codes, road test vehicle.
Reference:
- You may have one or more of the fault codes listed below...
403201 - Function Shut-Off Active
C10C8 00 [009] - -
C10C8 00 [008] - -
367877 - Ride Height Not Learned
C1044 00 [009] - -
266752 - Control module not coded
U1013 00 [009] - -
Tech Tips:
- If you notice one (or more) of the Air Spring Strut(s) is taking longer to fill or bleed and/or the compressor appears to be working harder, it is possible the "Residual pressure valve" on the Air Spring Strut is restricted/stuck closed or partially closed.
The "Connection piece for air pipe with residual pressure valve" is Not available separately from the manufacture and they say the Air Spring Strut must be replaced as a complete assembly. (However... Some customers report it is possible to drill our the valve, we of course do not recommend to do this.) ;)
Again, feedback is welcome and you are encouraged to post your experiences here in the Ross-Tech forum.
Thank you and as always, hope this helps,
drpeter
1st rev.20/12/2017
22/12/2017-Updated chart, missing info
DMS 01/08/2018-added additional B2013 warnings
drp_16/1/2020-Updated chart, missing info
drp 12/05/2023-Added no faults to prerequisites
drp 08/12/2023-Added Tech tips
NEtech
C?ID=56995
Small item, there is a redirect file, so label file should probably be 4G0-907-553
Are you sure odis use that many logins?
DrPeter
Hi...
- The last time we received positive feedback, I had a caller on the phone and we did run through the rough draft of the procedure, it appeared that before each of the Basic Settings functions would complete successfully only if the Security Access was used.
That is a good question though, is ODIS actually doing it the same way with the SA codes?? We have not tested that, ..yet. ;)
Thanks,
drpeter
http://forums.ross-tech.com/showthread.php?13450-Screwed-up-lowering-of-2018-S6-Need-help-pleeeease-)
Yeah well this locked thread linked above is a great example of what not to do or how to act.
The process above from Dr. Peter for me works very well in this thread.
FYI: When I have tested it and I can confirm that sometimes sessions get dropped, further requiring a login again due to bad connectivity, otherwise it streamed right through.
ADVANCED USERS!
MANUAL RESETS........
When after readings were in fact erased.
I was able each time to input them by setting the sensors to full high in service position. I do this by disconnecting on lift and reinitiating the test path to do a final save.
I find in some cases it is needed to have a second tech in the car to switch the ignition terminal 15 fast & between saving settings to eeprom in some controllers in steps or using a hand trigger wired if by yourself because there is limited time to lower car and get to the tester or switch!
While some controllers will allow for function tests, adjustment or a first adaption to commence, you will find that after you have the EOLE or coding DTC's; that if you don't bypass an alarm zone or verify all the zones & battery voltage is at least 13.25 Volts at all times under load or you may get blocked in a routine.
The main reason I disconnect ride sensors and lift the car, is to save the pump and not stress out the controller to get it done quick.
If people marked the sensor positions front and back with timing marks, simply readjusting the position you can change height this way too much faster.
In some cases I take the sensor rods off and make them adjustable with a double jam nuts for on the car mechanical connected calibrations for off road track use only!
In this case a good FOD or test path for tweaked cars to obtain the specification.
elp_jc
El Paso, TX USA
C?ID=323850
Don't know about ODIS, but with VCDS, you only need to key security code once (on step #1 of post #1). Everything else is spot on. And I'd put to set suspension on AUTO in bold, especially when your intention is to lower the car, and you left it in 'dynamic'. That's what I did, and had to get the module reflashed by dealer. Mastec tech said programming was corrupted when suspension bottomed out during calibration, aborting the procedure. Nothing can fix that other than reflashing the module. By the way, I'm the one that Jack linked above, and I see he said I'm the example how not to act? He was the one who behaved like a jacka$$ first (judge by yourselves), and I just followed suit. I apologized to Uwe, and asked him to remove the thread, since nobody knew how to fix my issue... plus it couldn't be fixed by VCDS anyway.
dean001
Australia
C?ID=277309
Anyone tried this on a 7P Touareg? I had this plugged in to attempt and none of the basic settings existed on the module, it does hhve the UDS on the module in vcds. here is the code for that module
Address 34: Level Control (J197)       Labels:. 7P0-907-553.clb
   Part No SW: 7P0 907 553 N    HW: 7P0 907 553 N
   Component: PASM          H01 1550
   Revision: 00000000    Serial number: 00000121680815
   Coding: 14210000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_PASMConti 001004
   ROD: EV_PASMConti.rod
   VCID: 428B3FFFD531EE544E-8016
Solo
Nigeria
C?ID=157225
Hi, i replaced the front Shock Absorbers and the lower arms on Audi A8 2013, after finishing the job i did the re-adaptation and everything went well but i have the right side higher than the left side, any suggestions please.
T00fast
Omaha, NE, USA
C?ID=403866
Anyone know where I can find the default values for a c7.5 (2016) s6 ?
cryptrade
C?ID=425004
Is it possible to activate level controls again after they have permanently disabled with VCDS? Last option from the adaptations menu says permanently disable level controls. I can’t get the compressor to work after I’ve done that.
Yves
Belgium
Guys,
I need urgent help with this as I may have done something wrong. This is for a 2014 Audi A6 allroad 4G.
In my menu I couldn't find the function 'start up to reference level' only the one with production leven which was said not to use it, so I used 'start up to normal level and permanently deactivate control' and then went on to do the rest but I couldn't enter the values so now level control is not working and having faults with headlights etc.
Yves
Belgium
All,
After discussing with Uwe I redid it and this time when entering each value for the height I waited a little while and then went back with the 'go back' option. It then retained the entered value and now it works again. Thanks.
Smiley32
Romania
C?ID=303818
Hi, for a Lamborghini URUS 2019 you not have a procedure for calibration? Login code?
Component: Fahrwerk-SG
ASAM/OX File ID:EV_ChassContrContiAU651
ASAM/ODX File Version:001011
Vw/Audi Part Number:4M8907777N
Software Version:2031
Hardware Version:H51
Hardware Part Number: 4M8907777
Serial Number:0503190592
System Description:Fahrwerk-SG
System Abbreviation:J775
FAZIT Identification:TSR-K7405.03.1900000592
boostboy
I'm assuming this coding applies c7 S6 as well? my car is lowered by vcds and its pretty low, if I can change it I would probably just make it lower in sport mode and standard height in the other modes. I'll probably look into that
