Bentley Mulsanne CKB 2011 Steering Angle Reset
FioranoCars
C?ID=68608
Hi
Just had a quick search for codes to check and see how we can reset the steering angle sensors for this vehicle, and found this FAQ:
http://wiki.ross-tech.com/wiki/index.php/Bentley_Continental_(3W)_Brake_Electronics_(Bosch_5.7)
but it does not list any codes for the Mulsanne, and clearly don't want to incorrectly attempt this and block or corrupt the ECU in error.
Background for this job, in case it's relevant or sets alarm bells for anyone:
We've had to have the steering rack rebuilt (leaking, but appeared to have some historic physical damage too which has been rectified), BUT the returned unit has the column shaft input when centered now offset from the original, so the shaft/steering wheel/angle sensor is no longer central or at Zero position. (a real pain and annoyed it's not back in the same place but can't change that right now).
The locking bolt is keyed to only 1 position in 360deg. The rack is fitted and centered with even adjustment etc etc and was checked using the steering angle sensor readings to get it precisely central within it's 1200 odd deg of movement.
The Steering wheel needed to be removed and repositioned to achieve the correct placement, which is done, but the steering angle sensor needs to be reset from it's 190deg reading when it's dead ahead! It was a choice of either the 190 or -170, but matters little as both equally out, and the 190 was where we refitted it, so that's what we're stuck with!
Anyway, enough of the "how we got here", sadly our other Bentley capable tool will only reset the Mulsanne ABS ECU's "all adaptive values", which again needs "codes", and we'd rather just reset the Steering Angle sensor if we can.
So HELP !!!
Is the Mulsanne the same codes as one of the Continentals, or does it require a completely different set ... or is the procedure totally different ?
If you need any ECU information or other data about the CAR or ECU ... please shout
Thanks in advance
Richard
Please post an Auto-Scan so people can see what control modules this car has.
Dana
Western PA, USA
FioranoCars
C?ID=68608
From a few other pointers, and the realisation that the angle sensor is in fact inside the Steering wheel unit (so rotating it to normal level position moves the zero point to the correct position), however it did need a reset.
Just for others, our final process to reset was:
ECU 3 ABS
1. Clear Error Codes with Wheel Dead ahead
2. reset "all adaptive values" within basic settings (after using security access code)
Then ECU 14 Steering Wheel
3. Use security access to then undertake Basic settings routine 001 and run it, with sucessful result
Checked advanced Values and both Steering readiness codes show as "OK" (calibration was showing as "NOT OK" prior)
All appears good. This car does not have an ECU 44. If you need any further data for improvement or analysis please let me know.
thanks
Data enclosed below, first the gateway scan with historical errors:
Monday,18,December,2017,15:57:13:48085
VCDS Version: 17.8.1.0 (x64)  HEX-NET CB: 0.4401.4
Dealer/Shop Name: FioranoCars
VIN: SCBBA63Y4BC015423   License Plate:
Chassis Type: 3Y-BY83 (4H0)
Scan: 01 02 03 05 06 08 09 0E 10 13 15 16 17 19 28 30 34 36 3B 42
          46 47 48 52 53 56 5B 5F 62 65 6C 6D 72 81 88 89 8A 8B 8D
47-Sound System -- Status: Cannot be reached 0100
48-Seat, Rear, DS -- Status: Malfunction 0010
5B-Seat,Rear,PS -- Status: Malfunction 0010
8A-Multicont. Seat Rear,DS -- Status: OK 0000
8B-Adaptive Cruise 2 -- Status: Malfunction 0010
8D-Multicont. Seat Rear,PS -- Status: OK 0000
Address 01: Engine (J623-CKBB)       Labels: None
   Part No SW: 07V 906 018 F    HW: 07V 907 018
   Component: ME17.1.1      H05 1307
   Revision: Q4H05---
   Coding: 0D2A0032436C00001800
   Shop #: WSC 29297 001 1048576
   ASAM Dataset: EV_ECM68TMP01107V906018F 001036
   ROD: EV_ECM68TMP01107V906018F_BY83.rod
   VCID: 3B36E164B2DE759E84-806E
Readiness: 1010 0001
   Part No SW: 3Y0 927 158 A    HW: 0BL 927 156 B
   Component: 0BL 67 BiTRdW H08 0003
   Revision: --H08---
   Coding: 001001
   ASAM Dataset: EV_TCMALX51011 001012
   ROD: EV_TCMALX51011_001.rod
   VCID: 3D32EF7CACCA7BAEBA-8068
Address 03: ABS Brakes (J104)       Labels:. 3Y0-614-517.clb
   Part No SW: 3Y0 614 517 A    HW: 3Y0 614 517 A
   Component: ESP PREMIUM   H09 0150
   Coding: 22E1820044874100D300
   Shop #: WSC 00083 790 00165
   ASAM Dataset: EV_ESPPremi 004018
   ROD: EV_ESPPremi_004_BY73.rod
   VCID: 3522F75C94FAA3EE72-8060
0378 - Steering angle sensor
          B1168 29 [008] - Signal Implausible
                    Reset counter: 120
                    Mileage: 69931 km
                    Date: 2017.12.15
                    Time: 18:48:34
                    VzRef: 00
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 82
                    Bit Info 4: 00
                    F-Path: 1C
                    F-Type: 2F
                    Uz: B7
   Part No SW: 4H0 907 064 P    HW: 4H0 907 064 P
   Component: BCM2 2.0      H13 0096
   Coding: 059B0001000000000000
   Shop #: WSC 00083 790 00174
   VCID: 3620F05081FCA8F67B-8062
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 0210000104429012
03285 - Sensor for Contact with Door Handle; Front Left
                    Fault Frequency: 13
                    Reset counter: 82
                    Mileage: 67601 km
                    Date: 2017.07.27
                    Time: 12:31:13
                    Raw, Index/Key Err.: 190 034 010
                    Raw, Index/Key Err.: 252 034 043
                    Raw, Index/Key Err.: 217 157 118
                    Angle: 8816.640°
                    Raw, Index/Key Err.: 237 146 236
                    Raw, Index/Key Err.: 254 024 128
                    Segment Corr.: 36.779°KW
                    Raw, Index/Key Err.: 195 191 174
                    Pressure: -25 mbar
                    Inj. Quantity: 40.7 mg/str
00956 - Key 2
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 81
                    Mileage: 69931 km
                    Date: 2017.12.06
                    Time: 10:32:23
   Part No SW: 4H0 959 760 E    HW: 4H0 959 760 E
   Revision: AA000000    Serial number: 00001002112600
   Coding: C028360085060301290001010101002100212323000000
   VCID: 3522F75C9CFAA3EE72-8060
03324 - Switch for Backrest Angle Adjustment: Forward
                    Reset counter: 114
                    Mileage: 67643 km
                    Date: 2017.07.28
                    Time: 09:26:10
Address 08: Auto HVAC (J255)       Labels:| 4H0-820-043.clb
   Part No SW: 3Y0 907 040 B    HW: 3Y0 907 040 B
   Component: Klima 4 Zonen H07 0030
   Coding: 282100F680
   ROD: EV_AirCondiFront_BY73.rod
   VCID: 3228CC406594B4D657-8066
   Part No SW: 4H0 907 063 C    HW: 4H0 907 063 C
   Component: BCM1 2.0      H11 0083
   Revision: 14011002    Serial number: 00000000606877
   Coding: 46CA201000369F210A81000480001B00CF9DD348B3010161800008000000
   VCID: 281C2E285B48CE06F9-807C
   Subsystem 1 - Part No SW: 3Y2 955 119     HW: 3Y2 955 119
   Component: WWS83x 090312  H32 0040
   Serial number:         090508102604
   Coding: 0045F7
   Component: RLS  H04 0003
   Serial number: 10643139
   Coding: 025729
   Subsystem 3 - Part No SW: 3Y0 941 531     HW: 3Y0 941 531
   Component: E1 - LDS  H03 0044
   Serial number: 26 08 2010  00000048
   Subsystem 4 - Part No SW: 4H0 907 410     HW: 4H0 907 410
   Component: EHL2 V07.03  H30 0020
   Serial number: 0000001805568R05VW05
   Subsystem 5 - Part No SW: 4H0 907 705 H    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0275
   Serial number: WA100296000000049228
   Coding: 020300
   Serial number: AE188625000000000001
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4F0 035 110 A    HW: 4F0 035 110
   Component: CDC-MP3-Alp   H44 0140
   Revision: AA001001
   VCID: 156217DCFC3A43EE52-8040
Address 10: Park/Steer Assist (J446)       Labels:* None
   Part No SW: 3Y0 919 465     HW: 3Y0 919 465
   Component: PARKHILFE ACC H02 0101
   Revision: 11001001    Serial number: 01431014801549
   Coding: 300901
   ASAM Dataset: EV_BY83XParkiAssis2 001001
   ROD: EV_BY83XParkiAssis2.rod
   VCID: 7EB02870E14CA0B6E3-802A
   Part No SW: 3Y0 907 561 A    HW: 3Y0 907 561 A
   Component: ACC3          H13 0120
   Coding: 2404010201
   Shop #: WSC 29655 000 1048576
   ASAM Dataset: EV_AdaptCruisContrBY83X 001004
   ROD: EV_AdaptCruisContrBY83X_BY83.rod
   VCID: 393AFB6CB8E2478E96-806C
98304 - Door Contact Switch
          C1076 29 [008] - Signal Implausible
                    Reset counter: 123
                    Mileage: 68784 km
                    Date: 2017.09.06
                    Time: 16:23:10
                    Control Module temperature: 39 °C
                    Voltage terminal 15: 13.917 V
99072 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Reset counter: 123
                    Mileage: 69476 km
                    Date: 2017.10.22
                    Time: 14:41:01
                    Control Module temperature: 42 °C
                    Voltage terminal 15: 14.655 V
105472 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Fault Frequency: 7
                    Reset counter: 123
                    Mileage: 67598 km
                    Date: 2017.07.27
                    Time: 12:26:06
                    Control Module temperature: 25 °C
                    Voltage terminal 15: 13.880 V
                    Velocity_vehicle_reference: 16.53 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.16 m/s²
Address 15: Airbags (J234)       Labels:| 4H0-959-655.clb
   Part No SW: 4H0 959 655 B    HW: 4H0 959 655 B
   Component: Airbag10.43   H24 0028
   Revision: --------    Serial number: 003G100173K8
   Coding: 30323331303230303033554A304C34483053
   ROD: EV_AirbaAU10BPAAU64X_BY83.rod
   Serial number: 3575HRB405F6O2OUEHCD
   Serial number: 3585HRB405F6O2OUC9C4
   Serial number: 3515JRB40556094I68IP
   Serial number: 3525JRB40576094IBPB0
   Serial number: 3554VRB405070PNCMOTM
   Serial number: 3564VRB405070PNCAHP0
   Part No SW: 4H0 953 568 A    HW: 4H0 953 568 A
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815JID0000U
   Coding: 00003C
   Shop #: WSC 00083 790 00170
   VCID: 312AC34C68928FCE2E-8064
   Subsystem 1 - Part No SW: 3Y0 959 442 B    HW: 3Y0 959 442 B
   Component: E221 - MFL  H05 0003
   Serial number: 07 10 2010  46000548
Address 17: Instruments (J285)       Labels:* None
   Part No SW: 3Y0 920 840 P    HW: 3Y0 920 840 P
   Component: Kombi         H50 0284
   Revision: 13140038    Serial number: 658050810593019
   Coding: 3F16080117002600010000
   ASAM Dataset: EV_DashBoardBY83XMMO 004033
   ROD: EV_DashBoardBY83XMMO.rod
   VCID: 43C69984CA2E0D5ECC-8016
   Analog_clock:
   Subsystem 1 - Part No SW: 3Y0 919 527 K    HW: 3Y0 919 527 K
   Component: Bentley C F T  H05 0010
   Serial number: 20100929000000000521
   Part No SW: 4H0 907 468 C    HW: 4H0 907 468 C
   Component: J533--Gateway H07 0175
   Revision: --------    Serial number: 00000000027306
   Coding: 000103FF00
   ASAM Dataset: EV_GatewUDS 001021
   ROD: EV_GatewUDS_AU57.rod
   VCID: 312AC34C60928FCE2E-8064
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0125
   Serial number: 00000000002799169085
12290 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 120
                    Mileage: 69931 km
                    Date: 2017.12.15
                    Time: 21:31:38
                    Voltage terminal 30: 11.9 V
                    Voltage terminal 15: 0.0 V
                    Control Module temperature: 8 °C
                    System status: LIN_active
                    Engine running: OFF
                    IN ZAS_Te_X: OFF
                    Terminal 15 status: OFF
                    Datenfeld: 0
          U140B 00 [008] - -
                    Reset counter: 123
                    Mileage: 69931 km
                    Date: 2017.12.15
                    Time: 19:07:44
                    Voltage terminal 30: 11.7 V
                    Voltage terminal 15: 0.2 V
                    Engine running: On
                    IN ZAS_Te_X: OFF
                    Datenfeld: 1
Address 28: HVAC, Rear (E265)       Labels:* None
   Part No SW: 3Y0 907 049 B    HW: 3Y0 907 049 B
   Component: Klima Fond    H07 0030
   Coding: 0E00000000
   ASAM Dataset: EV_AirCondiHeck 001038
   ROD: EV_AirCondiHeck_BY73.rod
Address 30: Special Function II (J843)       Labels: None
   Part No SW: 3Y0 907 440     HW: 3Y0 907 440
   Component: DBMC          H06 0001
   Revision: S0H06000    Serial number: 00000000004927
   Coding: 01000000000000000000000000
   VCID: 74A40A58D700FAE685-8020
   Part No SW: 3Y0 907 553     HW: 3Y0 907 553
   Component: LUFE-DAEMPFER H16 1095
   Coding: 008002
   ASAM Dataset: EV_AirSuspe 003017
   ROD: EV_AirSuspe_003_BY83.rod
   VCID: 79BA3B6CF862878ED6-802C
455690 - Sensor for Ride-Height
          C1048 07 [008] - Mechanical Failure
                    Reset counter: 121
                    Time: 00:00:00
455691 - Sensor for Ride-Height
                    Reset counter: 100
                    Mileage: 68754 km
                    Date: 2017.09.06
                    Time: 07:56:52
          C10C8 00 [008] -  -
                    Fault Frequency: 15
                    Reset counter: 120
                    Mileage: 67597 km
                    Date: 2017.07.24
                    Time: 15:49:39
0648 - Function Restriction due to Implausible Message(s)
          U1112 00 [008] - -
                    Reset counter: 120
                    Mileage: 69931 km
                    Date: 2017.12.15
                    Time: 16:27:51
   Revision: AA000000    Serial number: 00001002112554
   Coding: C028BF8085870301090001010101002100212323000000
   Part No SW: 4H0 907 637     HW: 4H0 907 637
   Component: SARA 6D       H02 0015
   Revision: --------    Serial number: EJ1BPA31003HX80
   ASAM Dataset: EV_SARA 006014
   ROD: EV_SARA_006.rod
   VCID: 6C941238873022265D-8038
   Part No SW: 4H0 959 793 M    HW: 4H0 959 793 E
   Component: TSG FA        H02 0166
   Revision: --------    Serial number: 0000108726755
   Coding: 011F1E207E01060006040103
   Shop #: WSC 00092 106 131806
   VCID: 43C69984C22E0D5ECC-8016
   Revision: 00002001    Serial number: 0130785122
   Coding: 011B1E2010797581A03007B0400000000000000000000000000000000000
   Shop #: WSC 00092 106 182497
   Subsystem 1 - Part No SW: 3Y0 959 511     HW: 3Y0 959 511
   Component: GTO BF  H03 0070
   Serial number: 00000000000000012630
   Subsystem 2 - Part No: 8K0 951 177
   Subsystem 4 - Part No SW: 3Y0 947 811     HW: 3Y0 947 811
   Component: Dachelektroni  H63 0025
   Serial number: BY83X_OS_FRONT_00000
   Coding: 0F0000
   Part No SW: 3Y0 035 456     HW: 3Y0 035 456
   Component: Naim 3G BY    H03 0070
   Revision: 00003001    Serial number: 78802000147706
   VCID: 73A60944D20EFDDE9C-8026
00003 - Control Module
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 2608 km
                    Date: 2011.06.23
                    Time: 08:09:31
                    Voltage: 11.70 V
                    Voltage: 11.60 V
                    Temperature: 26.0°C
                    Temperature: 20.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
Address 48: Seat, Rear, DS (J876)       Labels: None
   Part No SW: 4H0 959 860 A    HW: 4H0 959 860 A
   Component: MEM-FS-Fond   H06 0153
   Revision: AA000000    Serial number: 00001002136777
   Coding: C02896808500010D090039000039000039003B3B000000
   VCID: 3228CC406D94B4D657-8066
03795 - Switch Module for Seat Adjustment
                    Fault Frequency: 9
                    Reset counter: 119
                    Mileage: 68013 km
                    Date: 2017.07.31
                    Time: 10:05:46
                    Fault Status: 00101110
                    Reset counter: 109
                    Mileage: 69171 km
                    Date: 2017.10.18
                    Time: 17:46:49
   Part No SW: 4H0 959 792 E    HW: 4H0 959 792 E
   Component: TSG BF        H02 0166
   Revision: --------    Serial number: 0000108723088
   Coding: 011F1E207E01060006040100
   VCID: 3A38E460B5E44C969F-806E
   Part No SW: 3Y0 907 801     HW: 4H0 907 801 A
   Component: EPB-4         H03 0001
   Revision: --------    Serial number: 00000000002572
   ASAM Dataset: EV_ParkiBrake 001015
   ROD: EV_ParkiBrake_BY83.rod
   VCID: 75A2375CD47AE3EEB2-8020
   Part No SW: 4E0 035 061 H    HW: 4E0 035 061
   Component: Radio U DAB   H46 0048
   Revision: AB001007    Serial number: 014G.0A7509387
   Coding: 010103010000000001
   VCID: 200C360833783646B1-8074
Address 5B: Seat,Rear,PS (J877)       Labels: None
   Component: MEM-BFS-Fond  H06 0153
   Revision: AA000000    Serial number: 00001002136798
                    Reset counter: 115
                    Mileage: 68110 km
                    Date: 2017.08.01
                    Time: 10:23:15
                    Reset counter: 119
                    Mileage: 68110 km
                    Date: 2017.08.01
                    Time: 10:23:19
   Part No SW: 3Y0 035 670     HW: 3Y0 035 670
   Component: H-BNT-EU      H43 0139
   Revision: --------    Serial number: 461IX0A7502518
   Coding: 010101000020F9EFE502030200000003F0000100
   Shop #: WSC 00083 790 00163
   VCID: 71AA034CA812CFCE6E-8024
   Subsystem 1 - Part No: 8R0 060 884 R
   Component: EUR 2010  1106
   Subsystem 2 - Part No SW: 3Y0 919 604     HW: 3Y0 919 604
   Component: DU8 BY83 SV  H41 0021
   Serial number: BYZ8ZDA160002L4
   Subsystem 3 - Part No SW: 3Y0 907 595 F    HW: 3Y0 907 595
   Component: E0380 Bedient  H07 0032
   Serial number: 00000000000561
   Component: CD-Database  1886
   Part No SW: 4H0 959 795 A    HW: 4H0 959 795 A
   Component: TSG HL        H04 0162
   Revision: --------    Serial number: 0000108732740
   Coding: 010F1E200201064006000104
   Shop #: WSC 00083 790 00172
   VCID: 393AFB6CB0E2478E96-806C
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 3Y0 907 273     HW: 3Y0 907 273
   Component: RDKBERU25     108 0710
   Serial number: 10000000002316
   ASAM Dataset: EV_RDKBERU25 003004
   ROD: EV_RDKBERU25_BY83.rod
   VCID: 78BC3E68C3689E86A9-802C
Address 6C: Back-up Cam.        Labels: None
   Part No SW: 3Y0 907 441     HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0040
   Revision: --H03---    Serial number: 525 PA8J08D097
   Coding: 2022004
   Shop #: WSC 00083 790 00202
   VCID: 75A2375C1C7AE3EEB2-8020
02203 - Audio / Video Input 1
                    Reset counter: 80
                    Mileage: 69931 km
                    Date: 2017.12.15
                    Time: 18:43:47
                        Reverse OFF
                    Count: 3
   Part No SW: 4G8 959 107 D    HW: 4G8 959 107
   Component: HDSG-Modul    H12 0036
   Revision: 11012001    Serial number: 272000203
   Coding: 0B0204C000
   Shop #: WSC 00083 790 00177
   ASAM Dataset: EV_HDSGBy831 001012
   ROD: EV_HDSGAu571.rod
   VCID: 3620F05089FCA8F67B-8062
   Component: TSG HR        H04 0162
   Revision: --------    Serial number: 0000108732662
Address 81: Gear Shift (J587)       Labels: 3Y0-927-731.clb
   Part No SW: 3Y0 927 731     HW: 3Y0 927 731
   Component: GSM-LL        H04 0778
   Revision: 0L0D4010    Serial number: SN100622  0059
   ASAM Dataset: EV_GSM2x3Mono 001012
   ROD: EV_GSM2x3Mono.rod
   Part No SW: 4H0 907 182 D    HW: 4H0 907 182 D
   Component: IVB           H03 0027
   Serial number: 00454376147401
   Coding: 314000
   ROD: EV_IVBDriveSideFrnt.rod
   VCID: 2B16D12442BEE51E14-807E
   Serial number: 00454376150601
   Coding: 314000
Address 8A: Multicont. Seat Rear,DS (J875)       Labels:* None
   Serial number: 00454376231001
   Coding: 314000
   ASAM Dataset: EV_IVBDriveSideRear 001003
   Part No SW: 3Y0 907 541 A    HW: 3Y0 907 541 A
   Coding: 2404010201
   ASAM Dataset: EV_AdaptCruisContr2BY83X 001004
   ROD: EV_AdaptCruisContr2BY83X_BY83.rod
   VCID: 373EFD548EF651FE60-8062
                    Reset counter: 123
                    Mileage: 68784 km
                    Date: 2017.09.06
                    Time: 16:23:10
                    Control Module temperature: 38 °C
                    Voltage terminal 15: 14.065 V
          U1112 00 [008] - -
                    Reset counter: 123
                    Mileage: 69476 km
                    Date: 2017.10.22
                    Time: 14:41:01
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 14.624 V
          U1113 00 [008] - -
                    Fault Frequency: 7
                    Reset counter: 123
                    Mileage: 67598 km
                    Date: 2017.07.27
                    Time: 12:26:06
                    Voltage terminal 15: 13.773 V
                    Velocity_vehicle_reference: 16.66 m/s
                    Longitudinal_acceleration_vehicle_reference: 1.06 m/s²
Address 8D: Multicont. Seat Rear,PS (J874)       Labels:* None
   Serial number: 00454376169501
   Coding: 314000
   ASAM Dataset: EV_IVBPasseSideRear 001003
End----(Elapsed Time: 02:48, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
Next the ECU 3 ABS ID Data
Monday,18,December,2017,16:03:42:48085VCDS Version: Release 17.8.1 (x64)
Control Module Part Number: 3Y0 614 517 A
Component and/or Version: ESP PREMIUM H09 0150
Software Coding: 22E1820044874100D300
Work Shop Code: WSC 00083
Advanced Identification/FAZIT
Identification: BPA-085
Revision: --------
Date: 10.08.10
Manufacturer number: 0035
Test stand number: 402F
Flash Status
Programming Attempts(application): 0/0
Programming Status: 00000000
Flash Date: 00.00.00
Software
BAP: 01.04.01
Unknown: 01.03.00
Generic Net Mgt: 02.07.00
FlexRay Net Mgt: 02.05.00
Unknown: 02.06.01
Prot Data Unit Router: 02.06.02
FlexRay Interf: 02.06.22
FlexRay Drv: 02.06.75
Misc.
Hardware number: 3Y0 614 517 A
Workshop System Name: J104
End of Line Equipment Level: ------------------
ASAM Dataset Revision: 004018
VCDS Info:
Labels: 3Y0-614-517.clb
Then the 14 Sterring wheel ECU ID:
Monday,18,December,2017,16:54:48:48085
Control Module Part Number: 4H0 953 568 A
Component and/or Version: Lenks.Modul H08 0007
Software Coding: 00003C
Identification: ----KO3
Revision: --------
Date: 13.09.10
Manufacturer number: 0001
Test stand number: 000U
Flash Status
Successful Attempts(application): 0
Flash Date: 2010.09.13
Flash Tool Code: 00000 000 00000
Software
CAN: 01.41.00
TP 2.0: 03.05.00
KWP2000: 03.00.01
OSEK-OS: 03.03.00
HiSpd Net: 01.12.01
OSEK-Com: 03.03.00
LIN 2.0: 00.01.31
Misc.
Hardware number: 4H0 953 568 A
Workshop System Name: J527
VCDS Info:
Labels: 4H0-953-568.CLB
mattylondon
United Kingdom
C?ID=219022
There's a right mixture of modules in the Mulsanne, mostly 4H and 3Y with the odd older 4E, 4F & 4G.
Does that mean the 6.75 twin turbo could be swapped into an A8 4H? :)
