Audi A4 B9 Virtual cockpit
phydaux
Australia
C?ID=93953
Is there any way to code a 2017 Audi B9 A4 virtual cockpit to displays like a S4 or RS4?
Dimu4
C?ID=317414
Bringing this up. I'm pretty sure everything that can be done with OBDEleven should be possible with vcds. Has anyone find a way to change to S/RS style?
rlarsen
Copenhagen, Denmark
C?ID=78998
First - I don't know the bits combination for S4 or RS4 - but you can try it out your self.
Below are some of the logo options:
[17 - Instruments]
[Coding - 07] -> [Long Coding Helper] -> Byte 9
A4 (small logo):        Bit 5 and 7 - Set these bit manually to "1"
A4 (large logo):        Bit 0, 5 and 7 - Set these bits manually to "1"
A4 L:                   Bit 1, 5 and 7 - Set these bits manually to "1"
A4 quattro:             Bit 0, 1, 5 and 7 - Set these bits manually to "1"
A4 g-tron:              Bit 2, 5 and 7 - Set these bits manually to "1"
A4 L quattro:           Bit 0, 2, 5 and 7 - Set these bits manually to "1"
A4 (large logo):        Bit 1, 2, 5 and 7 - Set these bits manually to "1"
A4 g-tron quattro:      Bit 0, 1, 2, 5 and 7 - Set these bits manually to "1"
