- Joined
- Feb 25, 2014
- Messages
- 2,780
- Reaction score
- 4,490
- Location
- Cincinnati, OH
- VCDS Serial number
- C?ID=25607
I have a 2018 Atlas SEL Premium, with the 3.6L FSI V6. It comes with auto start-stop, like many cars these days. I seem to be part of a minority that actually likes the feature. Even though I know how to permanently disable it, I keep it on. But sometimes, start-stop doesn't kick in at a stop, and I don't clearly understand why, based on the reason given in the instrument cluster.
So my questions here are sort of the opposite of normal: how can I find out more about things that prevent start-stop from working?
Obligatory Auto-Scan:
- "System/power needs": See this frequently. Sometimes it's obvious why (high electrical consumption, accessory demand, trailer hooked up, etc). Sometimes it's not. HVAC has its own category and it's clear when it's a HVAC demand.
- "Traffic situation": See this every once in a while. Sometimes it's in stop-and-go traffic, but occasionally not. I can't figure out the criteria or inputs for this one. I feel like there has to be more than just too many back-to-back stops. Is there feedback from the forward camera for traffic, or traffic lights, or nav system intersection type feedback, or data from the nav's XM traffic data feed, or...?
Thursday,07,December,2017,19:37:07:43302
VCDS Version: 17.11.0.0 (x64) HEX-V2 CB: 0.4409.4
Data version: 20171026 DS285.1
Dealer/Shop Name: Southwest Ohio Luxobarge Rescue
Workshop Code: 444 08607 000001
VIN: 1V2NR2CA0JC502209 License Plate: 2018ATLAS
Mileage: 17064km-10603mi Repair Order: BETA17110
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 47 4B
52 5F 69 6C 6D 75 A5 CA D6 D7
VIN: 1V2NR2CA0JC502209 Mileage: 17064km-10603miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (0-32-CDVC) Labels: None
Part No SW: 03H 906 026 J HW: 03H 907 309 K
Component: VR6 3.6l FSI H20 4748
Revision: 52H20000
Coding: 012A003244740108B0000000000000000000000000000000
Shop #: WSC 07645 128 28888
ASAM Dataset: EV_ECM36FSI01103H906026J 001003
ROD: EV_ECM36FSI01103H906026J.rod
VCID: 2C020EDA7681A50113E7-8078
CAN Converter 01:
Address 02: Auto Trans (J217) Labels: None
Part No SW: 09G 927 158 A HW: 09G 927 158
Component: AISIN AQ8 206 3387
Coding: 0000000100000000000000000000000000000000
Shop #: WSC 09003 957 00200
ROD: EV_TCMAQ450031_VW27.rod
VCID: 313C1FAE51A3C8E920B1-8064
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 50697000000109
Coding: 44FC6B8D84201A6EC5790300A2CC6922D62158A3C045967E38415058C2AA4200002F641C12141A118DDB45506CC8CF
ROD: EV_Brake1UDSContiMK100IPB_036.rod
VCID: 77A8E1B6FF47D6D9AEF5-8022
Part No SW: 3Q0 959 435 E HW: 3Q0 959 435 E
Component: VWKESSYMQB 036 0811
Revision: 00036000 Serial number: 0430197433
Coding: 0F2000070F
ROD: EV_KessyHellaMQBAB.rod
VCID: 3C223E9A86E135818307-8068
Subsystem 1 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58006600
U1400 00 [008] - -
Reset counter: 4
Mileage: 16725 km
Date: 2017.12.02
Time: 15:13:43
Terminal_50_Kessy_specified_value: On
Terminal_50_Kessy_actual_value: On
ZAT_pressed: On
Park selector lever position: Not engaged and not locked
Control Module Voltage: 8.472 V
Vehicle speed: 0.0 km/h
Engine speed: 0.0 /min
Coding information: coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
14222592 - Databus
[Message ELV_01 missing]
Reset counter: 8
Mileage: 16833 km
Date: 2017.12.05
Time: 00:11:57
Terminal_15_Kessy_specified_value: OFF
Terminal_15_Kessy_actual_value: OFF
Terminal_15_central electric_actual_value: Timeout
Terminal_15red_Kessy_specified_value: OFF
Terminal_15red_Kessy_actual_value: OFF
Terminal_S_Kessy_specified_value: OFF
Terminal_S_Kessy_actual_value: OFF
Terminal_S_central electric_actual_value: Timeout
ZAT_pressed: OFF
Enabling immobilizer: Condition not met
Control Module Voltage: 12.319 V
Actuation to the inside: active
Driver door: closed
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 3CN 907 044 F HW: 3CN 907 044 F
Component: Climatronic H05 1802
Revision: 00001K01
Coding: 1602062620001400110411101210150C
Shop #: WSC 08607 444 00001
ASAM Dataset: EV_ACClimaBHBVW416 002007
ROD: EV_ACClimaBHBVW416.rod
VCID: 42DE4062E4054371C9CB-8016
Fresh Air Blower Back:
Address 09: Cent. Elect. (J519) Labels: None
Part No SW: 5Q0 937 085 BG HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H34 0236
Serial number: 7041011802ÿÿÿÿ
ROD: EV_BCMBOSCH_017.rod
VCID: 7F580996D777EE99E6A5-802A
Subsystem 1 - Part No SW: 5Q0 955 555 HW: 5Q0 955 555
Component: RLHSS 046 0120
Serial number: S6Y17M01D31H15M40S26
Coding: 00B86D
Subsystem 2 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H04 0050
Serial number: 0000009600335Z363302
Coding: 150000
Subsystem 3 - Part No SW: 3CN 959 719 HW: 3CN 959 719
Component: GTO BF H06 0007
Serial number: 8MW00117011700010527
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0163999
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0164122
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0182946
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0246621
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-298.clb
Part No SW: 5QA 919 298 B HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0038
Serial number: 000308417617023
Coding: 0271667151
ASAM Dataset: EV_EPHVA2CAU3700000 009032
ROD: EV_EPHVA2CAU3700000_009_VW37.rod
VCID: 4FF879562757BE195645-801A
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0620
Coding: 320007C959FFC728949C810530401600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002005
ROD: EV_ACCBOSCHVW416.rod
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Fault Frequency: 66
Reset counter: 18
Mileage: 16662 km
Date: 2017.11.30
Time: 11:53:17
Control Module temperature: 30 °C
Voltage terminal 15: 13.2 V
Velocity_vehicle_reference: 1.55 m/s
Longitudinal_acceleration_vehicle_reference: 0.27 m/s²
Part No SW: 3Q0 959 655 BC HW: 3Q0 959 655 BC
Component: Airbag VW21 004 0503
Revision: -------- Serial number: 003SUM49OKEP
Coding: 8CCCDC00000000005000001A420800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 005A8A6AAA8991619F5F-8054
Occupant Detection:
Component: Occ.Detection H13 0022
Serial number: IBH0000J170006OQEB0P
Coding: 303030
Subsystem 2 - Part No SW: ----------- HW: 454 001 601 17
Serial number: 35700000000E643DB12Q
Subsystem 3 - Part No SW: ----------- HW: 454 001 601 17
Serial number: 35800000000B843DB12Q
Subsystem 4 - Part No SW: ----------- HW: 454 801 002 17
Component: SideSensor_Dr 301 0148
Serial number: 35100BE8B0F0F000000/
Subsystem 5 - Part No SW: ----------- HW: 454 802 301 17
Component: SideSensor_Pr 301 0148
Serial number: 352009E26BE0E000000.
Subsystem 6 - Part No SW: ----------- HW: 454 802 812 16
Component: FrontSensor_D 304 0149
Serial number: 35500DCF80E0E0000003
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 454 802 812 16
Component: FrontSensor_P 304 0149
Serial number: 35600FAFB0E0E0000007
Part No SW: 5Q0 953 507 JF HW: 5Q0 953 549 D
Component: Lenks. Modul 004 0140
Revision: -------- Serial number: 11011704400586
Coding: 0C10
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 03508566BB9F8A79827D-8056
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 3CN 920 891 A HW: 3CN 920 891 A
Component: KOMBI 404 3192
Coding: 03A50F1DEF88CF0502887F0B5001000320000000
16777020 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_TEL_0x28 keine Kommunikation]
Reset counter: 6
Mileage: 16644 km
Date: 2017.11.30
Time: 11:32:59
Part No SW: 3Q0 907 530 C HW: 3Q0 907 530 C
Component: GW MQB High 515 5286
Serial number: 20021700840033
Coding: 0B0500347F087300FB0722581E0F00010000070000000000000000000000
ROD: EV_GatewNF_VW27.rod
VCID: 2F3819D64797DE193685-807A
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160001817810016366
Coding: 36FFFF
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 6858452904
Power Converter DC AC:
Subsystem 4 - Part No SW: 3CN 907 155 HW: 3CN 907 155
Component: U13DCAC H23 0860
Serial number: 0001255
Address 22: AWD (J492) Labels:* 0CQ-907-554.clb
Part No SW: 0CQ 907 554 H HW: 0CQ 525 130
Serial number: HA1-00002.12.16
Coding: 0301
VCID: 4ACE6842DC359B3101BB-801E
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000007942012
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BCDFAE912388E96031-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0021
Serial number: Y0006PL516752
Coding: 0010000000000500018280808080000000008100000000F400
ROD: EV_SeatMemorDriveSide_VW41.rod
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung --> funktionelle Einschränkungen aufgrund vorübergehender Unterspannung in der Versorgung.]
Reset counter: 7
Mileage: 16793 km
Date: 2017.12.04
Time: 19:29:29
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0427420305
Coding: 02012103
ROD: EV_HREntryHella_VW37.rod
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0427017983
Coding: 020121
Component: TSG FS 020 0041
Serial number: 27121606050HIT
Coding: 003F1B205200020000000000
VCID: 43D04566FB1F4A79C2FD-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005469691
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0001417184
Coding: 01010311004001
ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
VCID: 40DA4A6AEA095161DFDF-8014
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H30 0150
Revision: 00000001 Serial number: VWZ8Z1GBA02RF4C
Coding: 2214060002A00A2A000000000000
ASAM Dataset: EV_AMPMst12C3Gen2ALPI 001001
ROD: EV_AMPMst12C3Gen2ALPI.rod
VCID: 6D84C3DE8D1B6C094419-8038
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 001 0286
Serial number: 14021700840110
Coding: 000000070100135200010000000000000000000000000000000000000000
VCID: 72BED0A29425B3F1992B-8026
Component: TSG BFS 020 0041
Serial number: 221216060500N8
Coding: 003F13205E00020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000005472451
Coding: 091000
Part No SW: 3QF 035 876 HW: 3QF 035 876
Component: MU-S-NS-US 840 0755
Coding: 021406020000000051220002001808001F0500E401200005CE
Shop #: WSC 08607 444 00002
ROD: EV_MUStd4CDELP_VW27.rod
VCID: 074891768FA7A659DE15-8052
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H40 8074
Serial number: VWZ6ZDT0050741
Subsystem 2 - Part No SW: 3G0 919 866 BB HW: -----------
Component: NAR 2017 --- 0525
U11B8 00 [008] - No Communications
[USB - communication error]
Reset counter: 9
Mileage: 16833 km
Date: 2017.12.05
Time: 00:13:01
Voltage terminal 30: 11.8 V
Interface for external media: status-Status: Open circuit
Address 69: Trailer (J345) Labels:| 5Q0-907-383.clb
Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
Component: Anhaenger H27 0260
Revision: 8C001004 Serial number: 0430201804
Coding: 0200000200000000
Address 6C: Back-up Cam. (J928) Labels:* None
Part No SW: 5Q0 907 556 B HW: 5Q0 907 556
Component: Areaview 2 H13 0607
Serial number: C854707JG008159
Coding: 01140604A30F20000000400C
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
VCID: 382A228AB2D919A1676F-806C
Address 6D: Trunk Elect. (J605) Labels:| 5Q0-959-107.clb
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Coding: 0988
ROD: EV_DeckLidCONTIAU736_VW27.rod
VCID: 41DC4F6EE1035869D0D1-8014
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0570
Coding: 02140602C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3Q0-980-65X-A5.clb
Part No SW: 3Q0 980 654 G HW: 3Q0 980 654
Component: MQB_B_MFK H06 0231
Serial number: 15011712K20431
Coding: 000401060001020100221355C050890084000E200020
ROD: EV_MFKBoschMQBB_VW27.rod
VCID: 3B203D8683EF32B98A0D-806E
Address CA: Sunroof (J245) Labels:* None
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 013 0005
Coding: 00804074160C
ROD: EV_SunRoofCONTIAU736.rod
VCID: 3D24339E9DFB3C89B439-8068
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AA HW: 7P5 941 591 A
Component: LED1L H06 0003
ROD: EV_LED_PLUS_L_KEBODAVW416.rod
VCID: 7BA0FD86C36FF2B9CA8D-802E
0800 - Bulb for Low-Beam Headlamp
U4F5256 F6 [040] - Over-Temp Protection Active
Reset counter: 0
Mileage: 16602 km
Date: 2017.11.29
Time: 23:32:19
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0003
ROD: EV_LED_PLUS_R_KEBODAVW416.rod
Reset counter: 0
Mileage: 16602 km
Date: 2017.11.29
Time: 23:32:19
End----------(Elapsed Time: 02:21, VBatt start/end: 14.7V/14.7V)-----------
