Results 1 to 9 of 9
Thread: VCDS® HEX-V2/Auto-scan/Can not be reached 1100?
    Dec 2017
    Norway
    Hello
    I have a Audi A4 2008 (B8,diesel) and the yellow engine light will not go away,i had the car to nearest gas station and got diagnostics the car.Is was something with the Throttle body,but it was not entirely sure,so he recommended me to drive to Audi.
    Sow i have buy a new Throttle body to the car and a VCDS® HEX-V2.(i have not installed it yet,because i need to do a Auto-scan with VCDS to see if i get the same Fault code as gas station got)
    I have install VCDS Release 17.8 and registered the the unit.
    when i do a Auto-scan on the car i can't read engine module and other Module in the car (Cannot be reached 1100)
    when i clicking on the red text in the Gateway Installation List,Example ( 01-Engine -- Status: Cannot be reached 1100)
    I get up a window,but after 5-10 seconds the window close automatic and go back to Gateway Installation List?
    Is that something I'm doing wrong with VCDS® HEX-V2?
    Friday,15,December,2017,12:01:32:45403
    VCDS Version: 17.8.1.0  HEX-V2 CB: 0.4401.4
    Chassis Type: 8T0
    Scan: 01 03 05 08 09 10 15 16 17 19 42 46 47 52 53 55 56 62 69 72
       Mileage: 85170km-52922miles
    04-Steering Angle -- Status: Cannot be reached 1100
    10-Park/Steer Assist -- Status: Cannot be reached 1100
    15-Airbags -- Status: Cannot be reached 1100
    55-Headlight Range -- Status: Cannot be reached 1100
    Address 01: Engine
       Part No SW: 8K0 907 379 P    HW: 8K0 907 379 P
       Component: ESP8 front    H04 0180
       Coding: 168500
       Shop #: WSC 02399 823 56573
       VCID: 46D5A8ADC8ACF88720D-8012
       Part No SW: 8K0 907 064 AD    HW: 8K0 907 064 AD
       Component: BCM2 1.1      H71 0134
       Coding: 070100
       VCID: 72BD247D94A434275C5-8026
       Subsystem 1 - Part No SW: 8T0 959 754 K    HW: 8T0 959 754 K
       Component: FBSAUDIB8 IDG  H35 0052
       Serial number: 0508000004334004
       Subsystem 2 - Part No SW: 8K0 905 852 C    HW: 8K0 905 852 C
       Component: ELVAUDIB8  H35 0039
       Serial number: 0208000007369005
    00956 - Key 2
                        Fault Status: 01100101
                        Reset counter: 147
                        Mileage: 51281 km
                        Date: 2013.10.27
                        Time: 15:09:03
       Part No SW: 8T1 820 043 R    HW: 8T1 820 043 R
       Component: KLIMA 3 ZONEN H05 0120
       Revision: C1000000    Serial number: 0120.02.080462
       Coding: 34000000
       VCID: 40D9BEB5EA88D6B71A1-8014
                013 - Check DTC Memory
                        Fault Status: 01101101
                        Reset counter: 116
                        Mileage: 31003 km
                        Date: 2010.09.06
                        Time: 11:18:53
                        Reset counter: 116
                        Mileage: 31003 km
                        Date: 2010.09.06
                        Time: 11:18:53
                        Temperature: 23.0°C
       Part No SW: 8K0 907 063 D    HW: 8K0 907 063 D
       Component: BCM1 1.0      H21 0253
       Revision: 05021001    Serial number: 00000000093765
       Coding: 2600D0914014AF000001000300001D0D001C230800010141000000
       VCID: 3039EE755A284637EA1-8064
       Subsystem 1 - Part No SW: 8K1 955 119     HW: 8T1 955 119   Labels: 1KX-955-119.CLB
       Component: WWS 220208  H06 0060
       Serial number: SWFBIE 0001409
       Coding: 00FD11
       Component: RLS  H04 0003
       Serial number: 10064093
       Coding: 025028
       Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
       Component: E1 - LDS  H07 0070
       Serial number: 00000000002202081135
                        Fault Status: 00101100
                        Fault Frequency: 70
                        Reset counter: 206
                        Mileage: 83455 km
                        Date: 2017.09.09
                        Time: 12:07:00
                        Reset counter: 116
                        Mileage: 31003 km
                        Date: 2010.09.06
                        Time: 11:19:00
    Address 10: Park/Steer Assist
    Address 15: Airbags
       Component: Lenks.Modul   H11 0012
       Revision: --------    Serial number: 90304HBM000GQ
       Coding: 000016
       Shop #: WSC 00830 218 72025
       VCID: 3D27C7419D7ABB5F717-8068
       Part No SW: 8K0 920 900 C    HW: 8K0 920 900 C
       Component: KOMBIINSTR.   H14 0216
       Revision: 00100000    Serial number: 7VL223T28
       Coding: 0F04080002000008010000
       VCID: 2A0DFC1D7CF43CE7245-807E
       Part No SW: 8T0 907 468 D    HW: 8T0 907 468 D
       Component: GW-BEM 5CAN   H04 0084
       Revision: GA801030    Serial number: 3000G0821481CA
       Coding: 000003
       Shop #: WSC 02335 823 60104
       VCID: 42DDB4BDE484C4A70C5-8016
       Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
       Component: J367-BDM  H03 0150
       Serial number: 18008682130208
       Revision: 00002001    Serial number: 0109670796
       Coding: 01000E2000390441012001
    02615 - Fuel Tank Cap; Lock
                009 - Open or Short to Ground
                        Fault Status: 01101001
                        Fault Frequency: 15
                        Reset counter: 91
                        Mileage: 32900 km
                        Date: 2010.11.15
                        Time: 08:25:49
    02616 - Fuel Tank Cap; Unlock
                        Fault Frequency: 12
                        Reset counter: 91
                        Mileage: 32910 km
                        Date: 2010.11.15
                        Time: 16:39:29
    Address 47: Sound System (J525)       Labels:. 8T0-035-223-BOC.clb
       Part No SW: 8T0 035 223 S    HW: 8T0 035 223 B
       Component: DSP Prem      H13 0210
       Revision: 00013001    Serial number: 34833000713304
       Coding: 0203010301
       VCID: 3E25C04D907CA04768D-806A
    Address 52: Door Elect, Pass.
    Address 53: Parking Brake
    Address 55: Headlight Range
       Part No SW: 8T1 035 195 C    HW: 8T1 035 195 C
       Component: Symphony3     H13 0130
       Revision: 00000514    Serial number: AUZ5Z4H1008635
       Coding: 0003008001010500035B070000
       VCID: 372BD569BF46910FABB-8062
       Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
       Component: Display
    Address 62: Door, Rear Left
    Address 69: Trailer
    Address 72: Door, Rear Right
    End----(Elapsed Time: 00:55, VBatt start/end: 12.3V/12.2V. VIgn 0.0V)------
    Ignition turned on?
  3. Likes Santos, Dana, Uwe liked this post
    Lansdale, PA
    The ignition seems to be "off". Looking at
    . Have you tried scanning with the vehicle running at idle?
  5. Likes Uwe liked this post
  6. #4
    Dec 2017
    Norway
    I have never use a diagnostics before.
    what do you mean (Have you tried scanning with the vehicle running at idle)
    Do you mean to start the engine and connect the VCDS® HEX-V2 to the car?
    I have start/stop button,i never inserted the key)but the Key is inserted when i use VCDS® HEX-V2 sow Yes,Ignition turned on.
    Quote Originally Posted by Roar View Post
    To turn on ignition with start/stop button without starting engine, press start/stop button without pressing the brake.
    I don't remember what the ignition lock on a B8 is like. Just inserting the key may not be enough. You may have to turn it clockwise, again without your foot on the brake so that the engine doesn't start.
    But of course you can also do a scan with the engine running at idle to remove all doubt.
  8. Likes Dana liked this post
  9. #6
    Dec 2017
    Norway
    I have only try to inserting the key and then connect VCDS® HEX-V2 to the car.
    on Audi A4 B8 you can not turn the key clockwise.(just push it in and out)
    Just inserting the key may not be enough,sow i must press start/stop button without pressing the brake to turn on ignition,i will try that to tomorrow.
  10. Likes Dana liked this post
  11. #7
    Jun 2014
    Newcastle, England
    No worries. We'll get you through.
    Yes, it really helps to maintain the battery. My B8 sucks down over 10A with just the ignition on.
    I have a B8 with Start/Stop button too. However, just inserting the key unlocks the steering lock only. With you having a manual gearbox, normally you have to press the clutch pedal to start?
    Here's how to go ignition on without starting the engine if you'd like to do your scan like that. (If so, I'd advise connecting a battery charger...)
    Using Start/Stop button:
    Press button without pressing clutch. You should hear the Electronic Steering Lock disengage and the instrument cluster will light up. Check for MIL and ABS lights to make sure.
    Using key in dash recepticle:
    Insert key. You should hear the Electronic Steering Lock disengage. Press key once, without pressing the clutch pedal. Now the instrument cluster will light up. Check for MIL and ABS lights to make sure.
    Hit that Auto-Scan button.
  12. Likes Uwe liked this post
  13. #8
    Dec 2017
    Norway
    Yes,that is correct.
    I will try that to tomorrow.
    Thank you for all the help, Zenerdiode,Uwe,Santos and PetrolDave
  14. Likes Uwe liked this post
  15. #9
    Dec 2017
    Norway
    Have found out that you dont need to Insert the key,only push the Start/Stop button once time,without pressing the clutch pedal.
    Now everything works.
    Got up many Fault code.
    I have post an Auto-Scan at the car repair support.
  16. Likes Andy, Uwe liked this post
