Front OPS retrofit to Skoda Octavia Mk2 Problems with RNS 315 Nav Unit
kjrehsi
C?ID=287868
Hi Guys,
I recently installed front OPS to my Skoda Octavia Mk2 2012 and having strange behaviour with my RNS 315? :banghead:
Basically when I put the car into reverse the RVC comes on along with sensor guidelines and Once I switch to D the display on RNS changes to normal. One night I noticed there was sound coming from the radio and tried to change stations with no effect :( and also noticed i couldn't turn off my radio. In the MFD I could see the Navigation directions disappearing as when you would turn off the radio nav unit. However the screen display was still onn? I am not sure what may be going wrong? I have the sound back but similar issue where once i reverse the radio display wont switch off.
Lastly I also had to change my parking module from 4K to 8K so am not sure if I need to code the radio aswell?
Here is my autoscan
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 37 42 44 46 52 56 62 6C 72
VIN: TMBEH21Z3D2054264   Mileage: 78130km-48547miles
Address 01: Engine (CEG)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 RE    HW: 03L 906 022 GA
   Component: R4 2,0L EDC G000AG  5752
   Revision: 13H15---    Serial number:
   Coding: 0001078
   Shop #: WSC 73430 000 00000
   VCID: 79F8683F3006F48ED6-802C
   Part No SW: 02E 300 058 L    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3503
   Revision: 05551213    Serial number: 00001208031280
   Shop #: WSC 73430 790 00209
   VCID: 23446A57E20A5E5EAC-8076
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Coding: 163B601C092700FE680D06EA901D0082340800
   Shop #: WSC 28059 210 91019
   VCID: 7CF6712BFF34C1A6CD-8028
   Part No SW: 3T0 907 044 BR    HW: 3T0 907 044 BR
   Component: Climatronic   H19 0606
   Revision: 00001007
   Coding: 0010000002
   VCID: 03040AD78ACABE5E8C-8056
   Part No SW: 1K0 937 087 AD    HW: 1K0 937 087 AD
   Component: BCM PQ35  H   111 0709
   Revision: AC111709
   Coding: 46000AB8E06BB1C040080080310081EC47705BAE53658160808440040040
   VCID: 73E45A17D26A8EDE9C-8026
   Subsystem 1 - Part No: 1Z2 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 17081  26  0601
   Coding: 00DFB7
   Component: RLS 211209 05  54  0402
   Coding: 072BBB
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 175
                    Mileage: 78130 km
                    Date: 2017.12.10
                    Time: 06:02:49
                    Voltage: 12.05 V
                        Term 50 Off
   Part No SW: 5K0 919 475 C    HW: 5K0 919 475
   Component: PARKHILFE 8K  H07 0008
   Revision: --------    Serial number: 12941025802099
   Coding: 300001
   Shop #: WSC 00152 210 91233
   VCID: 3662A3038198DBF67B-8062
   Component: Q4 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2XSPHP
   Coding: 0020788
   VCID: 3D70BC2F64AE08AEBA-8068
   Subsystem 1 - Serial number: 6332MSME703328688
   Subsystem 2 - Serial number: 6342MSME70402E133
   Part No SW: 5K0 953 521 AT    HW: 5K0 953 569 B
   Revision: FF010041    Serial number: 20120815800189
   Coding: 189A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7EF27B23E128D3B6E3-802A
   Subsystem 1 - Part No SW: 3T0 959 537 A    HW: 3T0 959 537 A  Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 830000
   Part No SW: 1Z0 920 943 TX    HW: 1Z0 920 943 TX
   Component: KOMBI         H04 0607
   Coding: 110A01
   VCID: 224A6F5335105756A7-8076
   Part No SW: 7N0 907 530 R    HW: 7N0 907 530 H
   Component: J533  Gateway H42 1632
   Revision:   H42       Serial number: 160812F1000752
   Coding: 351303
   VCID: 3F8CC627AEA21ABEA8-806A
   Component: IMMO          H04 0607
   VCID: 6ADA47738DA04F162F-803E
   Part No SW: 3T0 035 192 G    HW: 3T0 035 192 G
   Component: RNS315-EU   H52 0319
   Serial number: SKZAZ2M9285932
   Coding: 000004410401000000000002
   Shop #: WSC 73430 031 00209
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 326A9F1365F0C7D657-8066
   Component: EUR_W_0038  0038
1048641 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 175
                    Mileage: 78130 km
                    Date: 2017.12.10
                    Time: 06:02:46
                    Correction for sound system: OK
                    Traffic sign display: OK
                    CD changer: OK
                    Status of antenna 2 for radio: OK
                    Digital radio (DAB): OK
                    Antenna diagnostic: OK
                    Telephone baseplate diagnostic: OK
                    Speaker status: OK
                    Rearview camera: ERROR
                    Telephone Transceiver: OK
   Part No SW: 1T0 959 701 N    HW: 1T0 959 701 N
   Component: Tuer-SG         008 2004
   Coding: 0004854
   VCID: 428ACFD31D507756C7-8016
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 74     3305
   Revision: 00H22000
   VCID: 377CAE07469222FE60-8062
   Part No SW: 1T0 959 702 N    HW: 1T0 959 702 N
   Coding: 0004854
   VCID: 4384CAD7024A7E5ECC-8016
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012544
   VCID: 326A9F13ADF0C7D657-8066
Address 6C: Back-up Cam.
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33649A1752EACEDE5C-8066
End-------------------------(Elapsed Time: 02:21)--------------------------
kjrehsi
C?ID=287868
Hi Guys,
Just to update you I have had some more play about with VCDS and it seems the problem is with the Rear view camera. Hence why when I put it in reverse and camera comes on it then prevents the radio from turning off. Only way it turns off is by taking the key out and after about 5 mins it goes off.
I have disabled the RVC now and the problem disappears. So I think I have the wrong coding
Here is what I have, so if I disable Byte 0 > Bit 5 the problem disappears. I feel Byte 2 might be where coding is wrong? There is no option for Skoda in Byte 2? :(
m87a
Bosnia and Herzegovina
C?ID=156900
do you have back up camera? why is it coded 6C unreachable and yet there is no error in gateway?!
in address 10 long coding turn off camera if you don't have it.
byte 2 leave alone it doesn't matter, you code shape of a car in rns 315
kjrehsi
C?ID=287868
Yes I have a Rear view camera so basically the camera is a aftermarket camera and I have retrofitted it using Kufatec kit which works plugs into the back of the RNS unit and switches to video when in reverse. So for it to work I had to enable 6C backup camera in the CANBUS installation list. Camera has been working for almost a year with no problem. It only started after i switch the parking module.
Here is the original parking module I had prior to
 Address 10: Park/Steer Assist (J446)       Labels: 5J0-919-475.clb
   Part No SW: 5J0 919 475 A    HW: 5J0 919 475 A
   Component: PARKHILFE 4K  H11 0005
   Revision: --H11---    Serial number: 32961224000475
   Coding: 30810F
   Shop #: WSC 13765 790 00209
   ASAM Dataset: EV_EPHVA14SKxxx0000 001001
   ROD: EV_EPHVA14SKxxx0000.rod
   VCID: 33649A179AEACED924-8066
m87a
C?ID=156900
go to adaptation of parking module and check for display try automatic or camera or OPS, cant recommend either since it's kufatec module so I don't know how it behaves
kjrehsi
C?ID=287868
I think the coding for the rear view camera is wrong. As Address 10 is not very helpful with Long coding helper :(
Anybody on here have a 5K0 919 475 C module with Rear view camera / backup camera please share your coding
