New to forum, just purchased a troubled A8L, and multiple problems that may be the cause. At this point, I'm stuck, as I can't release the EPB.
Bought the car few weeks ago, in Portland Oregon (current temp 40-50'F in the garage)... the heater doesn't work, and that's a problem as we are starting to reach freezing temp, but that's for another day. Parking warning light was always on, but I ignored it, as I was able to drive but couldn't set/release EPB (2 faults: 02443 Control Head, 012 - Electrical Fault in Circuit; and 02596 - Rear Brake Pads Worn).
Decided to attack the EPB issue, by checking to see how thin was the pad, and if EPB just needed to be reset. Followed the instruction per your website (http://wiki.ross-tech.com/wiki/index.php/Audi_A8_(4E)_Parking_Brake) except was unable to set/release brake (charger, 007, 006, Adoption, etc.). Was glad to hear the EPB retract (007), and was able to pull the pads off for inspection. While it was about 5mm, I didn't have replacement on hand, so decided to put it back for now. To clear the 02596, I set the pad thickness to 5 (instead of the 4 in memory). It accepted, and I proceeded to perform the Function Test... was unsure if the test completed successfully. Turned everything off, however, at end of adoption and test, the EPB got set, and won't release now. Parking Brake lights are on both dash and handle.
NOTE: While the external charger was on the battery, 13.5V at battery terminal, there was also Battery Regul. faults (5: 02276, 02274, 02277, 07723, 005320).
Any recommendation on how to get out of this dilemma? What do I fix first?
...Michael
...Michael
Sunday,10,December,2017,18:08:08:60507
VCDS Version: 17.8.1.0 (x64)
VIN: WAUML44E14N013027 License Plate:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E14N013027 Mileage: 182430km-113356miles
0F-Digital Radio -- Status: Not registered 0011
55-Headlight Range -- Status: Not registered 0011
65-Tire Pressure -- Status: Not registered 0001
Address 01: Engine Labels: 077-910-560-BFM.clb
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0C9526520
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F4D3A18CE5187BE88-804A
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
17985 - Right Engine Mount Solenoid Valve (N145)
P1577 - 004 - Open Circuit
P0300 - 001 -
16686 - Cylinder 2
P0302 - 001 - Misfire Detected
16690 - Cylinder 6
P0306 - 008 - Misfire Detected
Readiness: 0010 1101
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V USA 0110
Revision: 00000001 Serial number: 0022984
VCID: 244735F4E737A466D5-8070
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 12345 000 00000
VCID: 224B33ECFD23AA56A7-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0130
Revision: 01303703 Serial number: AUX3Z0C9526520
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58BF5104EBFF308689-800C
Subsystem 1 - Part No: 4E0 905 852 C
Component: ELV 1734
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940576
VCID: 234536E8E239A35EAC-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 G HW: 4E0 035 729
Component: Interfacebox H43 1070
Revision: 00000000 Serial number: 346JZ037506856
Coding: 0000103
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000001884
Subsystem 3 - Serial number: 0123.02.060000000100010042ÿ
Subsystem 4 - Serial number: 010042ÿ
Part No SW: 4E0 910 043 A HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 016 0260
Revision: 00000021 Serial number: 00000000028272
Coding: 1085889
VCID: 1B350E08DA499B9E64-804E
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H01 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H01 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO18102003065A000000000179ÿ†89
Subsystem 5 - Serial number: 000179ÿ†898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO18102003065A00000000
Subsystem 7 - Serial number: 65A000000000173ÿ
00797 - Sunlight Photo Sensor (G107)
009 - Open or Short to Ground
Fault Status: 01101001
Reset counter: 12
Mileage: 182430 km
Date: 2017.12.10
Time: 11:57:55
Reset counter: 12
Mileage: 182430 km
Date: 2017.12.10
Time: 11:57:55
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111113
VCID: 2A5BDBCC85137216EF-807E
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000255
Shop #: WSC 02311
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 13
Mileage: 182430 km
Date: 2017.12.10
Time: 18:04:57
Reset counter: 13
Mileage: 182430 km
Date: 2017.12.10
Time: 18:04:57
Part No SW: 4E0 910 111 E HW: 4E0 035 111
Component: CD-Changer H43 0430
Revision: 00000501 Serial number: AUZ5ZBC1025052
Address 0F: Digital Radio Labels: 4E0-910-593-XM.lbl
Part No SW: 4E0 910 593 A HW: 4E0 035 593 A
Component: SDAR XM
Serial number: AUZ4Z7D6017564
VCID: 254128F0EC0D5D6EC2-8070
00003 - Control Module
Fault Status: 00101110
Reset counter: 28
Mileage: 204483 km
Date: 2004.05.21
Time: 00:44:58
Reset counter: 12
Mileage: 182430 km
Date: 2017.12.09
Time: 20:10:16
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 A
Component: Airbag 8.4E+ H09 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H12 0040
Coding: 0012241
VCID: 65C168F0AC8D9D6E02-8030
Component: Lenkradmodul H03 0070
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H44 0080
Revision: D13 Serial number: AUDID3C9004647
Coding: 0016203
Shop #: WSC 26097 444 65048
VCID: 5CB74D149FC7DCA6AD-8008
Address 19: CAN Gateway Labels:. 4E0-910-468.clb
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0030
Revision: 07 Serial number: 0200503A020B2E
Coding: FCFE5BDC1B2304
VCID: 26432FFC910B5676CB-8072
Fault Frequency: 7
Reset counter: 13
Mileage: 182430 km
Date: 2017.12.09
Time: 20:25:33
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV 1734
4E0905852C ELV 1734
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
01583 - Leak in System Detected
Fault Status: 11100000
Reset counter: 13
Mileage: 182430 km
Date: 2017.12.10
Time: 18:04:56
01400 - Suspension Level Control
Reset counter: 53
Mileage: 182430 km
Date: 2017.12.10
Time: 14:51:58
Component: Sitzmemory FS H07 0060
Coding: 4071650
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H42 1100
Revision: 00000000 Serial number: 355JF037510130
VCID: 387FF1844BBFD08669-806C
Address 38: Roof Electronics Labels: None
Part No HW: 4E0 907 135 A
Serial number: 00000330900325
VCID: 55A15830FCED0DEE92-8000
02104 - Light Detection Sensor (G399)
Reset counter: 12
Mileage: 182428 km
Date: 2017.12.09
Time: 20:26:00
02282 - Sunroof Drive; Obstruction Detection
Reset counter: 52
Mileage: 182428 km
Date: 2017.12.09
Time: 20:26:00
02003 - Driver Identification Control Module (J589)
Fault Frequency: 15
Reset counter: 13
Mileage: 182428 km
Date: 2017.12.09
Time: 20:26:00
00447 - Function Limitation due to Over-Voltage
Fault Status: 00100001
Reset counter: 52
Mileage: 182428 km
Date: 2017.12.09
Time: 21:30:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0110
Coding: 0028196
VCID: 5EB3471C89DBCEB6C3-800A
Address 46: Central Conv. Labels:. 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040310170083
Coding: 0065150
VCID: 275D22F896014F7EF0-8072
Component: Heckdeckel H06 0060
Component: Neigungssensor H02 0020
02106 - Rear Window Shade Motor (V91)
Fault Frequency: 97
Reset counter: 13
Mileage: 163368 km
Date: 2003.06.30
Time: 19:43:30
01134 - Alarm Horn (H12)
Reset counter: 9
Mileage: 163368 km
Date: 2003.06.18
Time: 00:04:50
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 M HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0450
Revision: Dev_D01 Serial number: 00000000487089
Coding: 0000016
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000025026
Coding: 0010111
VCID: 1E33071CC95B8EB683-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T0EARE
Reset counter: 52
Date: 2023.06.06
Time: 00:00:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0110
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 26097 444 176071
VCID: 204F39E4F32FB846B1-8074
Fault Status: 01100010
Reset counter: 12
Mileage: 182424 km
Date: 2017.12.10
Time: 13:12:23
Voltage: 10.77 V
Count: 60
02443 - Control Head
012 - Electrical Fault in Circuit - MIL ON
Fault Status: 11101100
Reset counter: 12
Voltage: 11.70 V
Count: 40
Fault Status: 01111000
Reset counter: 12
Voltage: 11.59 V
Count: 61
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000004
VCID: 62CB73ECBDA3EA56E7-8036
Fault Status: 11100101
Reset counter: 12
Mileage: 182424 km
Date: 2017.12.09
Time: 20:26:58
02233 - Left Headlight Power Output Stage (J667)
Fault Status: 11100100
Reset counter: 13
Mileage: 182424 km
Date: 2017.12.09
Time: 20:26:59
Reset counter: 13
Mileage: 182424 km
Date: 2017.12.09
Time: 20:26:59
Part No SW: 4E0 910 541 F HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0480
Revision: 00000000 Serial number: 304JG037550601
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 A HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0230
Revision: 00000000 Serial number: 00000004849683
Shop #: WSC 26097 444 01213
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1310090086
Coding: 303030393135313035414B56413031333130303930303836
Shop #: WSC 00000 128 00289
Mileage: 182430 km
Date: 2017.12.10
Time: 14:47:28
02276 - Quiescent Current Stage 5
Mileage: 182430 km
Date: 2017.12.10
Time: 14:47:38
02274 - Quiescent Current Stage 3
Mileage: 182430 km
Date: 2017.12.10
Time: 14:47:56
Mileage: 182430 km
Date: 2017.12.10
Time: 14:48:06
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM005 0110
Coding: 0028196
VCID: 5DB1401084DDD5AEDA-8008
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: 5FCD7A188ED1C7BEC8-800A
01477 - System Switched Off
Fault Frequency: 12
Reset counter: 13
Mileage: 182430 km
Date: 2017.12.09
Time: 20:27:26
Temperature: 18.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM005 0110
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3005719
Coding: 0000005
VCID: 60CF79E4B0AFF846F1-5124
01531 - Emergency Battery
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001208
VCID: 60CF79E4B3AFF846F1-8034
02069 - Front Parking Aid Sensors
Reset counter: 12
Mileage: 182430 km
Date: 2017.12.10
Time: 14:50:35
End-------------------------(Elapsed Time: 03:27)--------------------------
