Hi everyone, reasonable shade tree mechanic, new vag-com user here. I have a 2007 Audi A4 2.0T quattro cabriolet. I just changed the cooling flange (fun job) and the temperature sensor and sensor wiring harness clip. After the job I started getting P0118-002 signal too high. Coolant temperature reading is showing -40.0 C. Unfortunately I'd already tossed the old sensor so I swapped the new after market with a genuine Audi one with the same result. I checked the voltage at the harness, 4.71 volts, and the resistance of both of the temperature sensors, around 1640 at room temperature and they responded to changing temperatures. Other: engine temperature gauge work normally, car rough at startup, clear codes and they come back no matter if the car is hot or cold, temperature reading is -40.0C no matter if the engine is hot or cold. Car runs rough at startup, fans running at 88% duty cycle(!). Earlier this summer I did the time belt replacement including all the usual bits including the thermostat, all OEM parts. Any ideas based on this information? My only other thought is that -40C might be what shows up when the control module sees infinite impedance. Being I changed the clip (dealer OEM) could the sensor pins not be engaging the clip terminals? Any ideas how I could verify I'm getting proper engagement and completing the circuit? Thanks for any help, glad to be here and part of the group.
Can't figure out how to post the scan, so it's inserted below:
Sunday,03,December,2017,12:15:32:38656
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WAUDF48H87K036287 License Plate:
Mileage: 232700km-144593mi Repair Order: 123
Chassis Type: 8H (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
67 69 75 76 77
VIN: WAUDF48H87K036287 Mileage: 232700km-144593miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E1 910 115 HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0030
Revision: 5EH15--- Serial number:
Coding: 011C010A190F0120
Shop #: WSC 00672 785 00200
VCID: 5F9B5DD39B34ECFF020-800A
000280 - Engine Coolant Temp. Sensor (G62)
P0118 - 002 - Signal too High - MIL ON
Fault Status: 11100010
Mileage: 232697 km
Temperature: -40.0°C
Temperature: 22.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.446 V
Readiness: 0110 0101
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 8E1 910 156 K HW: 09L 927 156 B
Component: AG6 09L 2,0TFSI USA 0050
Revision: --H01--- Serial number: 4314580
VCID: 2F3BED13AB143C7FF20-807A
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Coding: 0004528
VCID: 2E05F017AC1E3577F96-807A
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00100
Shop #: WSC 00672
VCID: 6D87371B64888E6F80C-5118
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul USA 0907
Coding: 21023
VCID: 3D27C75B7468DEEF70C-4AA4
01503 - Bulb for 3rd Brake Light (M25)
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8H0-959-655-94.lbl
Part No SW: 8H0 959 655 F HW: 8H0 959 655 F
Component: Airbag 9.42 H10 1830
Revision: 92H10183 Serial number: 0037Z0008A6Q
Coding: 0132105
VCID: 3D27C75B7178DEEF70C-8068
Subsystem 1 - Part No: 8H0 910 339 B
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 00QKN
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332BRB4024B30F0Gÿ†63
Subsystem 5 - Serial number: B30F0Gÿ†6342BRB4024B30E1Hÿ†63
Subsystem 6 - Serial number: B30E1Hÿ†63729RB4024E032CKÿ†63
Subsystem 7 - Serial number: E032CKÿ†63829RB4024E0353Fÿ
Subsystem 8 - Serial number: E0353Fÿ
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 Q
Component: Lenksáulenmodul 0701
Coding: 03041
Shop #: WSC 00672
VCID: 41DFBBAB0890BA0F144-4AA4
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8H0 920 951 F HW: 8H0 920 951 F
Component: KOMBI+WFS 4 H14 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0007261
Shop #: WSC 03129 444 59299
VCID: 3039EE6FB63A2387EBA-50F4
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007261
Address 46: Central Conv. Labels:. 8E0-959-433-MAX.clb
Part No: 8H0 959 433 L
Component: Komfortgerát T7B 5542
Coding: 11788
Shop #: WSC 12398
Subsystem 1 - Part No: 8H1959801D
Component: Tõrsteuer.FS BRM 0205
Subsystem 2 - Part No: 8H1959802D
Component: Tõrsteuer.BF BRM 0205
Subsystem 3 - Part No: 8H0959801A
Component: Tõrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8H0959802A
Component: Tõrsteuer.HR BRM 0002
35-00 - -
35-00 - -
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000019
VCID: 290F030B95F0524F2C4-807C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H04 0020
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH04 0020
Part No SW: 8P0 862 335 J HW: 8P0 862 335 J
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005026437
Coding: 0001607
VCID: 3D27C75B7168DEEF70C-50D0
End----------(Elapsed Time: 05:00, VBatt start/end: 13.0V/12.7V)-----------
