Hello
I wanted to ask if you can un-program electric heating, dropping to an error :
19460 - Relay for Low-Output Preheating of Coolant (J359)
P3004 - 000 - Open or Short to Ground
19462 - Relay for High-Output Preheating of Coolant (J360)
P3006 - 000 - Open or Short to Ground
VCDS Version: Release 12.12.2
Data version: 20140212
Wednesday,13,August,2014,18:26:27:13054
Chassis Type: 4F (4F0)
Scan: 01 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 56 61 62
72 76
VIN: WAUZZZ4F05N067964 Mileage: 176610km/109740miles
Address 01: Engine Labels: 03G-906-016-BLB.clb
Part No SW: 03G 906 016 BF HW: 028 101 185 0
Component: R4 2,0L EDC G240SG 9553
Revision: 12345678 Serial number:
Coding: 0000072
Shop #: WSC 00652 210 81339
VCID: 68DF4C6E5B41255E337-803D
Torque: 0.0 Nm
Voltage: 12.08 V
Bin. Bits: 00101000
(no units): 0.0
Bin. Bits: 11011000
Torque: 0.0 Nm
Voltage: 12.08 V
Bin. Bits: 00101000
(no units): 0.0
Bin. Bits: 11011000
Readiness: 0 0 1 1 1
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 D HW: 4F0 614 517
Component: ESP8 front H03 0010
Coding: 0020855
Shop #: WSC 02327 785 00200
VCID: 2541055AECD3F836C81-8070
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: O9 «s öO> ó–?
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300087447
Shop #: WSC 00720 210 91851
VCID: E3C5DB422267C606665-80B6
Subsystem 1 - Part No: 4F0 910 131 D
Component: FBSAUDIC6 EZS H43 0070
Component: FBSAUDIC6 IDG H36 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F0 910 732 S HW: 4E0 035 729
Component: Interfacebox H43 5150
Revision: 00000000 Serial number: 350JQ047546325
Coding: 0000302
VCID: 3365EB0252079686565-8066
Component: Bedienteil MMIC6H09 0060
Subsystem 2 - Serial number: 00000001044534
Subsystem 3 - Serial number: 0107.04.080000000100010808?
Subsystem 4 - Serial number: 010808?
00003 - Control Module
Fault Status: 01100101
Reset counter: 234
Mileage: 176616 km
Date: 2014.08.13
Time: 18:23:00
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F1 820 043 J
Component: KLIMABETAETIGUNGH11 0160
Revision: 00000022 Serial number: 00000000041047
Coding: 0012296
Shop #: WSC 22021 444 101010
VCID: DBB5E3A21A17FEC62E5-808E
014 - Defective
Fault Status: 01101110
Mileage: 176616 km
Date: 2014.08.13
Time: 18:23:06
Temperature: 28.0°C
Part No SW: 4F0 910 279 E HW: 4F0 907 279 B
Component: ILM Fahrer H15 0190
Coding: 0000101
Shop #: WSC 00652 210 91751
VCID: 2B55F3628A37CE461E5-807E
Subsystem 1 - Part No: 4F1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H05 0150
Coding: 00062736
Shop #: WSC 00652
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Coding: 00216144
Shop #: WSC 00652
Part No SW: 4E0 910 110 E HW: 4E0 035 110 A
Component: MP3-Changer H47 0390
Revision: 00047003 Serial number: AUZ5ZBH8514270
VCID: 1A3B26A6D5AD47CE753-804F
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 D HW: 4F0 959 655 B
Component: 38 AIRBAG AUDI8RH29 0250
Revision: 05H29000 Serial number: 0037LD04FTJP
Coding: 0013112
VCID: 285F0C6E9BC1E55EF37-807D
Subsystem 1 - Serial number: 6332CSME070E010A-
Subsystem 2 - Serial number: 6342CSME06006B6D4
Subsystem 3 - Serial number: 6351HSME04660B0F9
Subsystem 4 - Serial number: 6361HSME04750B7AC
Subsystem 5 - Serial number: 6371VSME044C4725L
Subsystem 6 - Serial number: 6381VSME0426085DM
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026042900233
Coding: 0002041
Shop #: WSC 02323 785 00200
VCID: E6C3C256D155B32E81B-80B3
Component: Lenkradmodul H07 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 900 A HW: 4F0 920 950 L
Component: KOMBIINSTR. M73 H09 0630
Revision: 00300000 Serial number: 4M132DNA4
Coding: 0260143
VCID: 1E332AB6C9852BEE89B-804B
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 B
Component: Gateway H09 0030
Revision: 09 Serial number: 0800804A130535
Coding: ECEE53C41B0104
VCID: 275D0F5296DFEA26FAD-8072
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 E HW: 4F0 959 793 E
Component: TSG FA H12 0120
Revision: 00000000 Serial number: &s
Coding: 0001546
VCID: 2C57F07E8F39C97E17F-8079
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 E HW: 4F0 907 289 E
Component: Komfortgeraet H14 0090
Revision: 00900014 Serial number: 01001343090000
Coding: 0131315
Subsystem 1 - Component: Sounder No Answer
01134 - Alarm Horn (H12)
014 - Defective
Fault Frequency: 35
Reset counter: 209
Mileage: 160738 km
Date: 2005.02.01
Time: 12:02:18
Reset counter: 234
Mileage: 160758 km
Date: 2005.02.01
Time: 16:54:15
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 B HW: 4F0 035 223
Component: Amp.-ASK H09 0270
Revision: 16S00001 Serial number: 01410040039195
Shop #: WSC 02335 785 00200
VCID: 1D312DBAC48330F6901-8048
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000043106
Coding: 0001104
VCID: DEB3EAB60905EBEE49B-808B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
Component: TSG BF H10 0020
Revision: 00000000 Serial number: PP(
Coding: 0000538
VCID: 2959096A80CBDC56EC9-807C
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000111
VCID: DDB1EDBA0403F0F6501-8088
Part No SW: 4E0 910 541 C HW: 4F0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 352JY047573079
VCID: 204F144EF3F11D1EBB7-8075
Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
Component: ENERGIEMANAGER H11 0490
Revision: 00000000 Serial number: 00000000075454
Shop #: WSC 12345 384 00290
VCID: 23451B42E2E70606A65-8076
Subsystem 1 - Part No: 4F0 915 105 C
Component: von TU3 4410190799
Coding: 344630393135313035432054553334343130313930373939
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H09 0010
VCID: 2A5BF66685CDD74EE53-807F
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H09 0010
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0030
Revision: --.--.-- Serial number: 11720429901214
Coding: 0000006
VCID: E1C9D14A387BD416749-80B4
End ---------------------------------------------------------------------
