Results 1 to 10 of 10
Thread: Coming home leaving home change (B9 A4)
    Nov 2017
    Ireland
    Hi could anyone help? I have a Audi A4 2017
    And would like to change the way the leaving home mode works. In long coding helper there no discription on the tick/untick boxes so I'm unsure what to tick.
    I want to have the leaving home to use the LEDs only. It's LEDs with low beem at the moment. I did this on my 2009 a4 ok but unsure how to do it in the 2017 can the low beem be turn off?
    Please post an Auto-Scan so people can see how your car is equipped and configured.
    Nov 2017
    Ireland
    yes here is my auto scan
    Monday,27,November,2017,23:22:18:10603
    VCDS Version: 17.10.0.2 (x64)
    Data version: 20171026 DS283.3
    VIN: WAUZZZF41HA086109   License Plate:
    Mileage: 14124km-8776mi   Repair Order:
    Chassis Type  F4-AU49 (4M1)
    Scan: 01 02 03 08 09 15 16 17 19 2B 42 44 52 5F 81 A5 AC BB BC
    VIN: WAUZZZF41HA086109   Mileage: 14124km-8776miles
    Address 01: Engine (J623-DEUA)       Labels: None
       Part No SW: 04L 906 026 T    HW: 04L 907 309 L
       Component: R4 2.0l TDI   H34 1981
       Revision: B1H34---
       Coding: 0A254032232405083408
       Shop #: WSC 06314 790 00001
       ASAM Dataset: EV_ECM20TDI01104L906026T 001005
       ROD: EV_ECM20TDI01104L906026FS.rod
       VCID: 3B7F036DB24CCBF2A9B-806E
    Address 02: Auto Trans (J217)       Labels:* None
       Part No SW: 8W0 927 155 F    HW: 0CJ 927 156
       Component: 0CK 20TDI RdW H03 0005
       Revision: --H03---    Serial number: 0000000215
       Coding: 000001
       ASAM Dataset: EV_TCMDL382021 002024
       ROD: EV_TCMDL382021_AU49.rod
       VCID: 42817E89D5A6BA3AEAD-8016
       Subsystem 2 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
       Component: V553 MTFP  002 0572
       Serial number: 75117071160271001219
       Part No SW: 8W0 907 379 G    HW: 8W0 907 379 J
       Component: ESP9 Plus     H06 0719
       Coding: 04AA1C9910AA0A9C119F489100865292E6A592203808508812004A4967A549
       Shop #: WSC 06324 790 00001
       ASAM Dataset: EV_ESP9BOSCHCMP 001001
       ROD: EV_ESP9BOSCHCMP_001.rod
       VCID: 499369A5E89069622B7-801C
       Part No SW: 8W0 820 043 F    HW: 8W0 820 043 F
       Component: Klima Zone 3  H32 0071
       Coding: 141800295544440D02000100880000000000000000000000000000000000
       Shop #: WSC 06325 790 00001
       ROD: EV_AirCondiBHTCAU491.rod
       VCID: 36691259896E169A565-8062
       Yes:
       Subsystem 2 - Part No SW: 4M2 820 021     HW: 4M2 820 021
       Component: J216 FLuftV  H05 0001
       Serial number: 00000000000001079064
       Subsystem 5 - Part No SW: 4H0 907 658 A    HW: 4H0 907 658 A
       Component: AQ_Hum_Sensor  H01 0005
       Serial number: AD098D4800PAG0MUFU02
       Part No SW: 8W0 907 063 CF    HW: 8W0 907 063 BF
       Component: BCM1 MLBevo   H13 0266
       Coding: 07501143E11800CD014487141B2C00B9110B3108000000000000000020001A810A450122025601
       ROD: EV_BCM1BOSCHAU736_018.rod
       VCID: 0103B18590206122B37-8054
       Yes:
       Subsystem 1 - Part No SW: 8W2 955 119     HW: 8V2 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS491 160806  043 0813
       Serial number: 89425300301621900868
       Coding: 5BC7F7
       Serial number: 20070983X81A955555A0
       Coding: 02005D
       Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
       Component: E1 - LDS  H06 0008
       Serial number: 22 06 2016  00437238
       Subsystem 7 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE103081611911085
       Coding: 210000
       Subsystem 8 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
       Component: J528-Dachele  H14 0130
       Serial number: B10277496
       Subsystem 19 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
       Component: SL-B9/Q5NF  H17 0010
       Serial number: 2616000116604002
    Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
       Part No SW: 8W0 959 655     HW: 8W0 959 655
       Component: Airbag10.44   H72 0086
       Serial number: 003M6007J21H
       Coding: AACCF0C00C800000585400F3C08C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 005012
       ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
       VCID: 0609A299B90E461A865-8052
       Subsystem 1 - Part No SW: -----------    HW: 442 061 209 16
       Serial number: 3577Y00AF1FB75D1E0BU
       Subsystem 2 - Part No SW: -----------    HW: 442 061 209 16
       Serial number: 3587Y00AB1FBD723C07K
       Subsystem 3 - Part No SW: -----------    HW: 442 0B1 809 16
       Serial number: 3517700B1218242422EX
       Subsystem 4 - Part No SW: -----------    HW: 442 0B1 809 16
       Serial number: 35277009F2182422925%
       Subsystem 5 - Part No SW: -----------    HW: 442 0C0 609 16
       Serial number: 3557500A32182432E0A+
       Front Sensor Passenger:
       Subsystem 6 - Part No SW: -----------    HW: 442 0C0 609 16
       Component: FrontSensor_P  1C5 014A
       Serial number: 35675009B218243273B3
       Pedestrian Protection Center:
       Subsystem 7 - Part No SW: -----------    HW: 442 0C0 609 16
       Component: PedP_Sensor_C  1C5 014A
       Serial number: 2307500C52172472A07X
       Subsystem 8 - Part No SW: -----------    HW: 442 433 008 16
       Component: PedPSensor_D2  256 0887
       Serial number: I0M9M009D1F9D0F454A/
       Subsystem 9 - Part No SW: -----------    HW: 442 433 008 16
       Component: PedPSensor_P2  256 0887
       Serial number: I0N9M009D1F9D0F4C1C4
       Part No SW: 4M0 907 129 HA    HW: 4M0 907 129 HA
       Component: Lenks.Modul   H11 0009
       ROD: EV_SMLSKLOAU736_006.rod
       VCID: 76E9D259C9EE569A965-8022
       Part No SW: 8W5 920 941 A    HW: 8W5 920 941 A
       Component: MMA4M17DIEUK  H06 0361
       Revision: 0361v1.0    Serial number:    SHLFMHV9S
       Coding: 24A550D028800600012069601000000000000000
       ASAM Dataset: EV_DashBoardAU736 001022
       VCID: 3E790A79A15EDEDA8E5-806A
    16777030 - Control unit for information electronics 1
              U1054 00 [008] - No Communication
                        Reset counter: 214
                        Mileage: 13330 km
                        Date: 2017.06.20
                        Time: 10:49:17
       Part No SW: 4M1 907 468 C    HW: 4M1 907 468 A
       Component: Gateway       H15 0098
       Revision: 4R040002    Serial number: 0244R02B516925
       Coding: 0301000100008E40410700000059001248100007000000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 002060
       ROD: EV_GatewCONTIAU736_002_AU49.rod
       VCID: 37771F5D8E64EF924D3-8062
       Subsystem 4 - Part No SW: 8W0 951 523 D    HW: 8W0 951 523 D
       Component: J453 MFL  H02 0002
       Serial number: 20160830095913 20885
       Subsystem 5 - Part No SW: 8S0 915 181 C    HW: 8S0 915 181 C
       Serial number: 6957111604
    8519683 - Energy Management Active
              U140B 00 [008] - -
                        Fault Frequency: 11
                        Reset counter: 197
                        Mileage: 13352 km
                        Date: 2017.10.30
                        Time: 07:23:23
                        EM_vehicle_state: 00 00
                        Static current shutdown level: Deactivation stage 1
                        Auxiliary heater activation restriction request-Parking heater: Permitted
                        Auxiliary heater activation restriction request-Allowed parking heater runtime: 0 min
       Part No SW: 3Q0 905 861 A    HW: 3Q0 905 861 A
       Component: ELV-MLBevo    H05 0032
       Serial number: 16000225583008
       Coding: 8800000000000000
       ROD: EV_ELVMarquMQBB.rod
       VCID: 32612E4965060ABA7AD-8066
       Part No SW: 8W0 959 593 G    HW: 8W0 959 593
       Component: TSG FS        005 0052
       Serial number: 0000220843576
       Coding: 001F8A204001000000001082
       ROD: EV_DCU2DriveSideMAXHCONT.rod
       VCID: 4E995AB911FE4E5A7E5-801A
       Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0407
       Coding: 09000380008000
       ASAM Dataset: EV_EPSZFAU49X 002015
       ROD: EV_EPSZFAU49X_002.rod
       VCID: 40857481DBAAA82AFC9-8014
       Part No SW: 8W0 959 592 G    HW: 8W0 959 592
       Component: TSG BFS       005 0052
       Serial number: 0000221538975
       Coding: 001F8A204001000000001080
       ROD: EV_DCU2PasseSideMAXHKLO.rod
       VCID: 4D9B5DB51CF8754207F-8018
    Address 5F: Information Electr. (J794)       Labels:* 8W0-035-MIB-HGS2.clb
       Part No SW: 8W0 035 192 A    HW: 8W0 035 192 A
       Component: MU-HS-LND-EU  045 0148
       Coding: 01940101FF0A000013111101000A00102F0001C601F00100CE
       ASAM Dataset: EV_MUHigScl6C3DELP 001011
       ROD: EV_MUHigScl6C3DELP_AU49.rod
       VCID: 346D28519F12048A681-8060
       Subsystem 2 - Part No SW: -----------    HW: -----------
       Component: -------------  --- ----
       Subsystem 3 - Part No SW: -----------    HW: -----------
       Subsystem 4 - Part No SW: V03 959 801 PC    HW: -----------
       Component: ECE 2016/2017  --- 0020
       Subsystem 7 - Part No SW: 8W2 919 604     HW: 8W2 919 604
       Component: AU49x_DU_STD  H40 0008
       Serial number: AUZ8Z9GBH00N7K
       Subsystem 8 - Part No SW: -----------    HW: -----------
       Subsystem 9 - Part No SW: -----------    HW: -----------
       Subsystem 10 - Part No SW: -----------    HW: -----------
       Subsystem 11 - Part No SW: -----------    HW: -----------
       Subsystem 12 - Part No SW: -----------    HW: -----------
       Subsystem 13 - Part No SW: 8W0 919 614 N    HW: 8W0 919 614 N
       Component: ControlUnit_B  H22 0134
       Serial number: APVAK102091600020476
       Subsystem 14 - Part No SW: -----------    HW: -----------
       Serial number: ----
    2562 - Navigation System
              U902650 F0 [008] - Navigation Database Faulty
                        Reset counter: 200
                        Mileage: 13340 km
                        Date: 2017.07.11
                        Time: 08:40:34
                        Voltage terminal 30: 12.2 V
       Part No SW: 8W2 713 041 J    HW: 8W2 713 041 J
       Component: GSM-LL        H09 0073
       Revision: 0L0D5012    Serial number: 20160928000348
       ROD: EV_GSMWaehlZFAU736.rod
    Address A5: Frt Sens. Drv. Assist (R242)       Labels:* None
       Part No SW: 8W0 907 217 B    HW: 8W0 907 217
       Component: BVS           H15 0042
       Coding: 0404090100000403024023A0A50000FC00F0C020C000
       ROD: EV_BVSMLBevKOSTAAU736.rod
    1123600 - predictive route data
              B1630 02 [008] - Signal Failure
                        Reset counter: 197
                        Mileage: 13358 km
                        Date: 2017.11.14
                        Time: 16:12:37
                        Control Module temperature: 20 C
                        Voltage terminal 15: 14.60 V
    1123601 - predictive route data
                        Reset counter: 198
                        Mileage: 13396 km
                        Date: 2017.11.20
                        Time: 17:53:11
                        Control Module temperature: 30 C
                        Voltage terminal 15: 12.60 V
    Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
       Part No SW: 4M0 907 355 B    HW: 4M0 907 355 B
       Component: SCR-Stg-G3H04 0005
       ASAM Dataset: EV_RDCMINERGAU736 005009
       ROD: EV_RDCMINERGAU736_VW53.rod
       VCID: 306524416B0A38AA0C9-8064
       Part No SW: 8W0 959 595 G    HW: 8W0 959 595
       Component: TSG HFS       005 0052
       Serial number: 0000221252743
       Coding: 000F88200001000000001080
       VCID: 50A544C10BCA58AA6C9-8004
       Component: TSG HBFS      005 0052
       Serial number: 0000221252843
    End-------------------------(Elapsed Time: 07:15)--------------------------
    was trying to change the brightness off the leds as well,
    I see somewere on here you go to
    "[09 Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    [Adaptation - 10] -> Channel 3
    Set between 5 and 100"
    but I cant see channels 3? has anyone done this? any help would be great
    Quote Originally Posted by Shanekk123 View Post
    "[09 – Cent. Elect.] [Security Access - 16] (enter security code. One of the default codes is- 20113)
    Those instructions definitely aren't applicable you your car. The CECM/BCM1 in your car uses the newer UDS protocol which doesn't support the old-school channel numbers.
    Nov 2017
    Ireland
    Ok I was thinking its was different is there anyway doing it?
    Jun 2017
    As you do not own a HEX-V2 or HEX-NET interface, you cannot make use of the experimental labels in VCDS that could unveil the right bits.
    There seems no adaptation channel for that
  7. #7
    Jan 2018
    Canada
    Any developments here, I'm interested in this to?
    Furthermore, I was wondering if the behaviour of the ''welcoming lights'' (exterior door's handle lights) could be change. Presently they are getting ON only when the lights switch is in AUTO position?
    My car A4 2018, Canadian model
    Tuesday,19,December,2017,20:31:10:29812
    VCDS Version: 17.8.1.0  HEX-V2 CB: 0.4407.4
    VIN: XXXXXXXX   License Plate:
    Mileage: XXXXX   Repair Order:
    Chassis Type: F4-AU49 (4M1)
    Scan: 01 03 08 09 15 16 17 19 22 2B 42 44 46 52 5F BB BC CA
    VIN: WAUNNAF44JA079477   Mileage: 1110km-689miles
    CA-Sunroof -- Status: OK 0000
    Address 01: Engine (J623-CYMC)       Labels: None
       Part No SW: 8W0 906 259 J    HW: 06L 907 425 C
       Component: 2.0l R4 TFSI  H15 0002
       Revision: --H15---
       Coding: 0A5900120326010E34000000000000000000000000000000
       ASAM Dataset: EV_ECM20TFS0208W0906259J 001003
       ROD: EV_ECM20TFS0208W0906259J.rod
       VCID: 48C9A6E99234BC07D21-801C
    Readiness: 0000 0100
       Part No SW: 8W0 907 379 K    HW: 8W0 907 379 J
       Component: ESP9 Plus     H10 0766
       Coding: 18AA409920A90A9F11A2409820844292E44184180204508802044249278221
       ASAM Dataset: EV_ESP9BOSCHCMP 002013
       ROD: EV_ESP9BOSCHCMP_002.rod
       VCID: 4DC797FD7D56592FE17-8018
       Part No SW: 8W0 820 043 T    HW: 8W0 820 043 T
       Component: Klima Zone 3  H55 0210
       Coding: 140805095544000D10000100880000000000000000000000000000000000
       Shop #: WSC 06335 790 00001
       VCID: 44D1B2D9AE1C98673E9-8010
       Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
       Component: J126 FLuftV  H08 0003
       Serial number: 00000000000001697963
       Component: AQ_Hum_Sensor  H02 0007
       Serial number: EEA1DEC800PAG0MUFU02
       Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
       Component: E265 Kli Fond  H40 0080
       Part No SW: 8W0 907 063 CB    HW: 8W0 907 063 BB
       Component: BCM1 MLBevo   H13 0267
       Coding: 8045956254080CCD05158714180C00BB100B3108000000000000000000001A0000600002001200
       VCID: 7DA7073D8D7629AF317-8028
       Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
       Component: WWS491 170911  043 0813
       Serial number: 89435300301725402063
       Coding: 5BC7F7
       Serial number: 20770056X81A955555A0
       Coding: 02005D
       Light switch:
       Subsystem 3 - Part No SW: 4M0 941 531 S    HW: 4M0 941 531 S
       Serial number: 28 07 2017  01056176
       Subsystem 4 - Part No SW: 8W0 857 511     HW: 8W0 857 511
       Serial number: GX1CE125071723310115
       Interior Light Module:
       Subsystem 5 - Part No SW: 8W0 947 135 AB    HW: 8W0 947 135
       Serial number: B00520320
       Subsystem 6 - Part No SW: 8W0 925 301 AT    HW: 8W0 925 301 AT
       Serial number: 2617000073864004
       Part No SW: 8W0 959 655 G    HW: 8W0 959 655 G
       Component: Airbag10.44   H05 0107
       Serial number: 003UQ001NX0U
       Coding: BFCCF0C000800000A0000033D24C00000000
       ASAM Dataset: EV_AirbaAU10BPAAU736 006016
       ROD: EV_AirbaAU10BPAAU736_006.rod
       Belt Pretensioner left:
       Subsystem 1 - Part No SW: 4M0 980 945 B    HW: 4M0 980 945 B
       Component: BeltPretRevFL  306 2033
       Serial number: 8W0857705G0277R01659
       Coding: 80000D
       Belt Pretensioner right:
       Subsystem 2 - Part No SW: 4M0 980 946 B    HW: 4M0 980 946 B
       Component: BeltPretRevFR  306 2033
       Serial number: 8W0857706J0278R00550
       Coding: 80000D
       Occupant Detection:
       Subsystem 3 - Part No SW: 4M0 959 339     HW: 4M0 959 339
       Component: BF-Gewichtss.  H11 0022
       Serial number: IBH0000J17000822H70N
       Subsystem 4 - Part No SW: -----------    HW: 442 061 808 17
       Serial number: 3577Y00C12474D44F362
       Subsystem 5 - Part No SW: -----------    HW: 442 061 808 17
       Serial number: 3587Y00B9249F6B4C34I
       Subsystem 6 - Part No SW: -----------    HW: 442 0B0 609 17
       Serial number: 3517700B9279CC41E3BW
       Subsystem 7 - Part No SW: -----------    HW: 442 0B3 008 17
       Serial number: 3527700B3279C243311$
       Subsystem 8 - Part No SW: -----------    HW: 442 0C1 607 17
       Serial number: 3557500B32665766412+
       Subsystem 9 - Part No SW: -----------    HW: 442 0C1 607 17
       Serial number: 3567500BF2711FF473BW
       Part No SW: 4M0 907 129 GB    HW: 4M0 907 129 GB
       VCID: 76B51811A8407AF770D-8022
    Address 17: Instruments (J285)       Labels:* 8W5-920-xxx-17.clb
       Part No SW: 8W5 920 740 B    HW: 8W5 920 740 B
       Component: MMA4M18BENRW  H07 0512
       Revision: 0512v1.0    Serial number:    86NFVHL9T
       Coding: 08A65191A08000080203A8401800000000000000
       ROD: EV_DashBoardAU736.rod
       VCID: 3C21CA39D6ECE0A7469-8068
       Part No SW: 4M1 907 468 E    HW: 4M1 907 468 E
       Component: Gateway       H22 0119
       Revision: 6X060004    Serial number: 0446X009917924
       Coding: 030100010000064029070000005900104C280000100000000100000000000000
       ASAM Dataset: EV_GatewCONTIAU736 003092
       ROD: EV_GatewCONTIAU736_003_AU49.rod
       VCID: 392FD32DD9DED58F5DF-806C
       Subsystem 1 - Part No SW: 8W0 951 523 E    HW: 8W0 951 523 E
       Component: J453 MFL  H04 0002
       Serial number: 20170920014719 20258
       Serial number: 6246475404
    Address 22: AWD (J492)       Labels:* None
       Part No SW: 8W0 927 755     HW: 0CJ 927 749
       Component: B9_ML4_N_SD4  H01 0004
       Serial number: 1622813262
       Coding: 31000000
       ASAM Dataset: EV_AWDCQUOD31 001048
       ROD: EV_AWDCQUOD31.rod
       VCID: 025D74C1F48856574C5-8056
       Serial number: 17000170892018
       Coding: 0000000000000000
       ROD: EV_ELVMarquMQBB_VW37.rod
       VCID: 323DE40104A826D79C5-8066
       Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
       Component: TSG FS        005 0125
       Serial number: 0000280340171
       Coding: 001F0B204000108000000082
       VCID: 4FFB8DF5775A6B3F93B-801A
       Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
       Component: EPS_MLBEVO_ZF H08 0410
       ASAM Dataset: EV_EPSZFAU49X 003023
       ROD: EV_EPSZFAU49X_003.rod
       VCID: 42DDB4C1B40896570C5-8016
       Part No SW: 8W0 907 064 DB    HW: 8W0 907 064 DB
       Component: BCM2 MLBevo   019 0366
       Coding: 012C00004F300080650780002201000033000000810022500F04000000040030001E0001000000
       ASAM Dataset: EV_BCM2HellaAU736 013013
       ROD: EV_BCM2HellaAU736_AU58.rod
       VCID: 7F5BFD35877A3BBF23B-802A
       Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
       Serial number: 000000000ZY172453P9E
       Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
       Serial number: 00000000000039462721
       Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
       Component: TSG BFS       005 0125
       Serial number: 0000280401693
       Coding: 001F0B204000108000000080
       VCID: 4EC590F17050623798D-801A
       Part No SW: 8W0 035 652 C    HW: 8W0 035 652 A
       Component: MU-HS-S-US    050 0158
       Coding: 01940100FF0A000013220001061A00002F0024C401F001040A
       VCID: 372BD515EFCAC3FFABB-8062
       Subsystem 1 - Part No SW: 8W0 919 604     HW: 8W0 919 604
       Serial number: AUZ8Z9HBG030XZ
       Multimedia Operating Unit:
       Subsystem 2 - Part No SW: 8W0 919 614 J    HW: 8W0 919 614 J
       Component: ControlUnit_B  H21 0134
       Serial number: APVAK110081700020389
       Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
       Component: TSG HFS       005 0125
       Serial number: 0000280973148
       Coding: 000F0B200000108040000080
       VCID: 51FF8B8D616E7DCF85F-8004
       Component: TSG HBFS      005 0125
       Serial number: 0000280972885
       Part No SW: 4M0 907 594 H    HW: 4M0 907 594
       Coding: 2A8000049100
       ROD: EV_SunRoofCONTIAU736.rod
       VCID: 3B23C925D3E2E79F4F3-806E
    End----------(Elapsed Time: 01:28, VBatt start/end: 12.3V/12.3V)-----------
  8. #8
    Jun 2017
    The only thing I can find is Byte 7 Bit 2 which tells that Coming Home should be started with the Driver Door. Unticking this bit might either activate CH after Ignition Off or even when you lock the car.
    Bit 4 and Bit 5 in Byte 7 are not documented. Perhaps these bits do anything about CH/LH Behaviour. I see them unticked in the car data I have.
  9. #9
    Maybe test Coding Byte 10 Bit 5 in 09-Cent. Elect.
  10. #10
    Jan 2018
    Canada
    thank you, but no changes whatsoever
