WARNING about G17 Ambient Temperature Sensor, VW Golf MK7
VAG-Dave
Scotland
HC806344
A few days ago I drove my car (2015yr VW Golf MK7 Estate) out of the garage & noticed that the outside temperature reading was high (+8C) when I know it was less than +4C. During the drive (1hr) the reading got steadily higher & when I got to my destination it was showing +20C as the outside temperature, when there was snow on the ground!!
So obviously something wrong with the sensor, but did not have time to look at it properly until I got back home later that day. So removed the grille (two TX star bolts) & unplugged & removed the sensor (G17) along with the sensor bracket, as the bracket comes off easier to allow you to remove the sensor as getting the sensor off the bracket is quite tricky, & best done outside the car.
So a stone had hit the end/tip of the sensor splitting the outer plastic & revealing the inner white thermal paste & the bead itself. OK so order new sensor from dealers (couple of days to arrive as not a "line" stock item).
Here's the interesting part:-
Decided to remove the sensor & plastic bag the connector, as I thought its better to have no data than incorrect data being used. Now I knew it would throw fault codes for the 09 Central Electronics & the TPMS (03 ABS) modules...
Start car, warning message on dash re TPMS system error, ok that's fine...
Loud beep & parking sensors button blinking orange at me, ok that's strange...
Notice that the engine fans are at max speed due to noise, ..ok that's very strange...
Reverse car down driveway & fans are still at max speed & I know that the outside temp is +2C & the car is cold. So drive back into garage & fans still at max speed, lift bonnet,....yep both fans max speed. Switch of ignition, I ain't driving car like this!...:(
Refit the G17 Ambient temperature sensor, & everything behaves all ok, no flashing lights, no error messages & no engine fans at max speed.
So when the new sensor arrives I fit it & do an auto scan &........look at the all the fault codes!!! Now I had run a scan only a few weeks ago, so I know car was fine & ALL those faults have the same time stamps, so same creation date.
What gets me is how many modules rely on information via the data bus from that sensor!!! Some you expect, others are like WTF??
Anyway moral of the story, if your G17 Ambient (outside) Temperature Sensor is faulty or playing up, DO NOT unplug it, just order & fit a new one ASAP!!!
Wednesday,29,November,2017,15:09:22:64565
VIN: WVWZZZAUZFP55XXXX   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 47 52 55 5F
VIN: WVWZZZAUZFP55XXXX   Mileage: 19841km-12328miles
Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 F    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H10 7861
   Revision: WAH10---
   Coding: 01190072234405082000
   Shop #: WSC 00028 028 00070
   ASAM Dataset: EV_ECM14TFS01104E906016F 002011
   ROD: EV_ECM14TFS01104E906016F.rod
   VCID: 2514F89EC56EC57F08C-8070
7786 - Sensor for Ambient Air Temperature (G17)
          P0070 00 [032] - Malfunction
                    Mileage: 19791 km
                    Date: 2017.11.25
                    Time: 17:44:57
                    Coolant temperature: 21 °C
                    Intake air temperature: 16 °C
                    Voltage terminal 30: 12.298 V
                    Outside air temperature: 215 °C
                    Absolute intake pressure: 101 kPa abs
                    Engine torque: 0.0 Nm
                    Fuel level: 25.00 l
                    Oxygen sensor bank 1 sensor 1: specified value: 15.9998
Readiness: 0000 0001
   Revision: 00000000    Serial number: 62644000001579
   Coding: 04FA8AA12425296E0380060941C82920512494C0608294F3F4205078C009
   Shop #: WSC 00028 028 00067
   VCID: 45D4581E252E257F28C-8010
                    Reset counter: 48
                    Mileage: 19791 km
                    Date: 2017.11.25
                    Time: 17:45:07
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 02120004200400011005004200101000
   VCID: 73B0D6C63B3AEBCF568-8026
459527 - Databus
                    Reset counter: 48
                    Mileage: 19791 km
                    Date: 2017.11.25
                    Time: 17:44:58
   Part No SW: 5Q0 937 086 AA    HW: 5Q0 937 086 AA
   Component: BCM PQ37BOSCH 028 0106
   Revision: --------    Serial number: 86582509140616
   Coding: 03000A66C24122FB0BA44080B11C07281000000000000000000000000000
   Shop #: WSC 00028 028 00080
   ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
   ROD: EV_BCMBOSCH_013.rod
   VCID: 79ACE4EE1956919F1C4-802C
   Component: WWS    140828  042 0551
   Serial number:         140909221237
   Component: RLHS  037 0059
   Serial number: S4Y14M09D19H22M35S19
   Coding: 06A8EE
   Serial number: 000000000ZY1421702PK
   Serial number: 00000000000060620911
137217 - Outside temperature sensor
          B103F 1B [136] - Resistance Too High
                    Reset counter: 48
                    Mileage: 19791 km
                    Date: 2017.11.25
                    Time: 17:44:28
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39311424603534
   Coding: 0071151001
   VCID: 3D2430FE4DFE6DBF70C-8068
13637888 - Databus
                    Reset counter: 48
                    Mileage: 19791 km
                    Date: 2017.11.25
                    Time: 17:44:57
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 13091403211821
   Coding: 00000300FE0739
   VCID: 382A21EA62DC4897A3A-806C
1094 - Databus
                    Reset counter: 48
                    Mileage: 19791 km
                    Date: 2017.11.25
                    Time: 17:44:56
                    Control Module temperature: 8 °C
                    Voltage terminal 15: 12.3 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1095 - Databus
                    Reset counter: 48
                    Mileage: 19791 km
                    Date: 2017.11.25
                    Time: 17:44:55
                    Voltage terminal 15: 12.2 V
   Component: AirbagVW20    014 0386
   Serial number: 003MLR08TR8G
   Coding: 98FCC0C0000000005C5400CF00C800000065
   Shop #: WSC 00028 028 00065
   VCID: 7F580AF60772BFAF220-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169677B23091440735
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169676B22091441270
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 609 14
   Serial number: 35767000000BE799011.
   Subsystem 4 - Part No SW: -----------    HW: 480 002 209 14
   Serial number: 3586700000048A88111R
   Subsystem 5 - Part No SW: -----------    HW: 480 401 709 14
   Serial number: 3516502AB176A6B3702A
   Subsystem 6 - Part No SW: -----------    HW: 480 401 609 14
   Serial number: 3526502BB176A6B2C2DT
   Subsystem 7 - Part No SW: -----------    HW: 480 401 409 14
   Serial number: 3556502BD175A8D3137M
1054981 - Databus
                    Reset counter: 48
                    Mileage: 19791 km
                    Date: 2017.11.25
                    Time: 17:45:01
   Part No SW: 5G1 920 950     HW: 5G1 920 950
   Component: KOMBI         304 4270
   Coding: 27A411002F80A60001887E011400000000000000
   VCID: 6696BF9278E80E67C16-8032
13639936 - Databus
                    Reset counter: 40
                    Mileage: 19791 km
                    Date: 2017.11.25
                    Time: 17:44:56
End----------(Elapsed Time: 01:39, VBatt start/end: 12.5V/12.4V)-----------
Day-um. Why the heck is it that important for all those system to know the OAT?
And why can't they just use a reasonable substitute value like 20°C?
VAG-Dave
Scotland
HC806344
Exactly...my thoughts, which is why I thought I'd warn people...
My breakdown of what needs the sensor:-
01-Engine:- (no idea why it uses this as it has enough other air sensors like the MAF etc, but I can see it might need it)
03-ABS Brakes:- (TPMS yes it needs it as air pressure in tyres alters with ambient air temp)
08-Auto HVAC:- (ok maybe because it needs to "weather compensate" for outside air temp, like my house heating uses outside air sensor)
09-Cent. Elect.:- (the G17 sensor is wired to this so ok to throw a fault code)
10-Park/Steer Assist:- (really WTF does it need it for??)
13-Auto Dist. Reg:- (really WTF does it need it for??)
15-Airbags:- (really WTF does it need it for??)
17-Instruments:- (ok so the display is in the cluster)
There is weird stuff going on !!!
NZDubNurd
New Zealand
C?ID=230482
Ve are ze Chermans, and it must be korrect! (at least until we've finished fixing it under warranty!)
If they did that and it was really 36C, maybe the little TSI motors would melt pistons even earlier :D
Sorry.
MasterTommy
Amsterdam
C?ID=295586
Engine is the most important one here. Intake and outside air temperature are correction values for the fuel injection.
VAG-Dave
Scotland
HC806344
Ok I thought it might be the case...
Anyway,
15-Airbags:- Looking at the problems with the propellants of airbags & their sensitivity to air temp changes I recon this is required for various safety aspects inc force or lack off if air temp affects the propellant etc.
Still can't figure out why these need it:-
13-Auto Dist. Reg:
iichel
Netherlands, eastern part
C?ID=284912
Ordnung muss sein. Order must be.
I'm still a bit puzzled by the PDC and the ACC. Maybe they made the conductivity of the air for the ultrasound and radar signals a function of the ambient air temperature. I can see them do it.
VAG-Dave
Scotland
HC806344
Your guess is right!!
Got me thinking so I had a look in the VW ERWIN self study guides
No.494 Park assist steering
This covers various versions inc the radar & sensors...
& it states that G17 is used because "It has an influence on the calculation of measured distances to obstacles because the air density changes & consequently the propagation speed of ultra sound waves."
So that's it....ALL modules now explained as to why they rely on the G17 outside temperature sensor...
Larry Manton
C?ID=112505
There is a saying about German stuff. Why make it simple when we can make it so beautiful and complicated. But the air density makes sense in the long run, learn something new everyday, LOL.
Larimore
