A few days ago I drove my car (2015yr VW Golf MK7 Estate) out of the garage & noticed that the outside temperature reading was high (+8C) when I know it was less than +4C. During the drive (1hr) the reading got steadily higher & when I got to my destination it was showing +20C as the outside temperature, when there was snow on the ground!!
So obviously something wrong with the sensor, but did not have time to look at it properly until I got back home later that day. So removed the grille (two TX star bolts) & unplugged & removed the sensor (G17) along with the sensor bracket, as the bracket comes off easier to allow you to remove the sensor as getting the sensor off the bracket is quite tricky, & best done outside the car.
So a stone had hit the end/tip of the sensor splitting the outer plastic & revealing the inner white thermal paste & the bead itself. OK so order new sensor from dealers (couple of days to arrive as not a "line" stock item).
Here's the interesting part:-
Decided to remove the sensor & plastic bag the connector, as I thought its better to have no data than incorrect data being used. Now I knew it would throw fault codes for the 09 Central Electronics & the TPMS (03 ABS) modules...
Start car, warning message on dash re TPMS system error, ok that's fine...
Loud beep & parking sensors button blinking orange at me, ok that's strange...
Notice that the engine fans are at max speed due to noise, ..ok that's very strange...
Reverse car down driveway & fans are still at max speed & I know that the outside temp is +2C & the car is cold. So drive back into garage & fans still at max speed, lift bonnet,....yep both fans max speed. Switch of ignition, I ain't driving car like this!...
Refit the G17 Ambient temperature sensor, & everything behaves all ok, no flashing lights, no error messages & no engine fans at max speed.
So when the new sensor arrives I fit it & do an auto scan &........look at the all the fault codes!!! Now I had run a scan only a few weeks ago, so I know car was fine & ALL those faults have the same time stamps, so same creation date.
What gets me is how many modules rely on information via the data bus from that sensor!!! Some you expect, others are like WTF??
Anyway moral of the story, if your G17 Ambient (outside) Temperature Sensor is faulty or playing up, DO NOT unplug it, just order & fit a new one ASAP!!!
Wednesday,29,November,2017,15:09:22:64565
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WVWZZZAUZFP55XXXX License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 47 52 55 5F
VIN: WVWZZZAUZFP55XXXX Mileage: 19841km-12328miles
Address 01: Engine (J623-CHPA) Labels:. 04E-907-309-V1.clb
Part No SW: 04E 906 016 F HW: 04E 907 309 A
Component: 1,4l R4 TSI H10 7861
Revision: WAH10---
Coding: 01190072234405082000
Shop #: WSC 00028 028 00070
ASAM Dataset: EV_ECM14TFS01104E906016F 002011
ROD: EV_ECM14TFS01104E906016F.rod
VCID: 2514F89EC56EC57F08C-8070
7786 - Sensor for Ambient Air Temperature (G17)
P0070 00 [032] - Malfunction
Mileage: 19791 km
Date: 2017.11.25
Time: 17:44:57
Coolant temperature: 21 °C
Intake air temperature: 16 °C
Voltage terminal 30: 12.298 V
Outside air temperature: 215 °C
Absolute intake pressure: 101 kPa abs
Engine torque: 0.0 Nm
Fuel level: 25.00 l
Oxygen sensor bank 1 sensor 1: specified value: 15.9998
Readiness: 0000 0001
Part No SW: 5Q0 907 379 L HW: 5Q0 907 379 G
Component: ESC H31 0471
Revision: 00000000 Serial number: 62644000001579
Coding: 04FA8AA12425296E0380060941C82920512494C0608294F3F4205078C009
Shop #: WSC 00028 028 00067
VCID: 45D4581E252E257F28C-8010
16390 - Display for Tire Pressure Monitoring
C1146 02 [008] - Signal Failure
Reset counter: 48
Mileage: 19791 km
Date: 2017.11.25
Time: 17:45:07
Part No SW: 5G0 907 044 AN HW: 5G0 907 044 AN
Component: Climatronic H03 0907
Revision: 00001K08
Coding: 02120004200400011005004200101000
VCID: 73B0D6C63B3AEBCF568-8026
Air quality sensor:
459527 - Databus
Reset counter: 48
Mileage: 19791 km
Date: 2017.11.25
Time: 17:44:58
Part No SW: 5Q0 937 086 AA HW: 5Q0 937 086 AA
Component: BCM PQ37BOSCH 028 0106
Revision: -------- Serial number: 86582509140616
Coding: 03000A66C24122FB0BA44080B11C07281000000000000000000000000000
Shop #: WSC 00028 028 00080
ASAM Dataset: EV_BodyContrModul1UDSBosc 013004
ROD: EV_BCMBOSCH_013.rod
VCID: 79ACE4EE1956919F1C4-802C
Component: WWS 140828 042 0551
Serial number: 140909221237
Component: RLHS 037 0059
Serial number: S4Y14M09D19H22M35S19
Coding: 06A8EE
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1421702PK
Serial number: 00000000000060620911
137217 - Outside temperature sensor
B103F 1B [136] - Resistance Too High
Reset counter: 48
Mileage: 19791 km
Date: 2017.11.25
Time: 17:44:28
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39311424603534
Coding: 0071151001
VCID: 3D2430FE4DFE6DBF70C-8068
13637888 - Databus
Reset counter: 48
Mileage: 19791 km
Date: 2017.11.25
Time: 17:44:57
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 13091403211821
Coding: 00000300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001015
VCID: 382A21EA62DC4897A3A-806C
1094 - Databus
Reset counter: 48
Mileage: 19791 km
Date: 2017.11.25
Time: 17:44:56
Control Module temperature: 8 °C
Voltage terminal 15: 12.3 V
Vehicle speed: 0.00 m/s
Acceleration: 0.00 m/s²
1095 - Databus
Reset counter: 48
Mileage: 19791 km
Date: 2017.11.25
Time: 17:44:55
Voltage terminal 15: 12.2 V
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR08TR8G
Coding: 98FCC0C0000000005C5400CF00C800000065
Shop #: WSC 00028 028 00065
VCID: 7F580AF60772BFAF220-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B23091440735
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B22091441270
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 609 14
Serial number: 35767000000BE799011.
Subsystem 4 - Part No SW: ----------- HW: 480 002 209 14
Serial number: 3586700000048A88111R
Subsystem 5 - Part No SW: ----------- HW: 480 401 709 14
Serial number: 3516502AB176A6B3702A
Subsystem 6 - Part No SW: ----------- HW: 480 401 609 14
Serial number: 3526502BB176A6B2C2DT
Subsystem 7 - Part No SW: ----------- HW: 480 401 409 14
Serial number: 3556502BD175A8D3137M
1054981 - Databus
Reset counter: 48
Mileage: 19791 km
Date: 2017.11.25
Time: 17:45:01
Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
Part No SW: 5G1 920 950 HW: 5G1 920 950
Component: KOMBI 304 4270
Coding: 27A411002F80A60001887E011400000000000000
VCID: 6696BF9278E80E67C16-8032
13639936 - Databus
Reset counter: 40
Mileage: 19791 km
Date: 2017.11.25
Time: 17:44:56
End----------(Elapsed Time: 01:39, VBatt start/end: 12.5V/12.4V)-----------
