Results 11 to 20 of 31
Thread: Audi A3 8V Cruise Control retrofit
    FoRT jyoung8607's Avatar
    Cincinnati, OH
    Sorry, but i always wanted to do this
    I try to avoid shooting newbies, particularly ones that may have language barriers, but I'm keeping this on file for repeat offenders.
    Jason
  2. Likes Sebastian, Dana, Eric liked this post
  3. #12
    United States
    Quote Originally Posted by kimbr View Post
    Hi.
    Here you have a full scan before and after with 14.8.1 beta.
    The steering wheel coding is ok, I have already change the coding there.
    I changed the coding from 02250032240401082000 to 02250032242401082000 in engine, as you suggested.
    Before:
    Address 01: Engine (J623-CYVB)       Labels: None
       Part No SW: 04E 906 027 CJ    HW: 04E 907 309 AF
       Component: 1.2l R4 TSI   H21 7798
       Revision: R5H21---
       Coding: 02250032240401082000
       Shop #: WSC 06314 790 00021
       ASAM Dataset: EV_ECM12TFS01104E906027CJ 001005
       ROD: EV_ECM12TFS01104E906027CJ.rod
       VCID: 6EFD1B31B196504A3B-803B
       Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 02071404400972
       Coding: A418
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 062D4391B926780AE3-8053
    After:
       Revision: R5H21---
       Coding: 02250032242401082000
    17158 - Databus
              U1123 00 [039] - Received Error Message
    17149 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [167] - -
       Coding: A418
    I looked through each of the scans but I wasn't able to spot a discrepancy. I however am not entirely sure if the new #16 module coding -or- #01 module coding directly caused the new faults.
    What was the original (pre-retrofit) coding of #16?
    If you code #16 back to the original value with the new (CCS) #01 coding and clear faults, do any of those reoccur?
  4. Likes Uwe liked this post
  5. #13
    Sep 2014
    Norway
    I removed the coding for CCS in #16, and entered your coding in #01, but I got the same error and fault codes.
    I'm pretty sure the coding in #16 is correct, since there is a drop down menu there, where I choose the correct CCS.
    It seems to me the new coding for #01 is wrong, and has something to do with the start/stop function.
    Since I get this error with the start/stop function in the instruments panel, and fault codes in #01 and #03 when I change it.
  6. #14
    United States
    01-Engine
    As far as I can tell the new 01 coding includes Cruise Control System (CCS - PR-8T2/8T6) installed and the old coding was Cruise Control System (CCS - PR-8T0) NOT installed. I do not have any alternative coding function suggestions.
    It looks like this controller supports Adaptation (or Long Adaptation) function: Activation of start-stop function so I would make sure it is ON/Activated with each 01 coding variant to rule out a conflict.
    16-Steering Wheel
    I'm not entirely clear on the original, or pre-retrofit, coding of 16. If you already confirmed the wiring is present at the connector (to/from the engine and/or GAN GW, whichever this vehicle happens to use) and the Adv. measuring values/Adaptation channels with GRA or gra are reporting correctly I would like to believe it is correct.
    Side note; It looks like factory installed CCS via the MFSW in NAR market MQB models do not use coding modifications due to the addition of that function in the 19-CAN Gateway. Our MQB A3 scan collection is limited but CCS would be standard equipment on those as well.
    You may want to send this one to the dealer for SVM configuration. If you go that route please post the final scan so we can see what we missed!
  7. Likes jyoung8607, Uwe liked this post
  8. #15
    Nov 2014
    San José, Costa Rica
    Hello!
    I just finished using VCDS for the first time on my 8V A3. That was a lot of fun.
    Newbie question: do I need to buy anything to activate cruise control through multifunction steering wheel? I'm understanding that cruise control may be used through the MFSW. If so, can you guide me through the coding process? I saw the 5G coding page but didn't really understand it.
  9. #16
    United States
    Quote Originally Posted by m_bolc View Post
    Hello!
    That depends on the factory wiring and installed module(s). Please post the complete Auto-Scan before any modifications here for review.
  10. Likes Uwe liked this post
  11. #17
    Nov 2014
    Hello Dana,
    Here is the auto scan:
    Thursday,27,November,2014,18:12:27:29892
    VCDS Version: 14.10.0.0 (x64)
    Data version: 20141022
    VIN: WAUZZZ8V2FA000583   License Plate: TBR043
    Mileage: 9198km-5715mi   Repair Order:
    Chassis Type: 8V (5Q0)
    Scan: 01 03 08 09 15 16 17 19 42 44 52 5F
    VIN: WAUZZZ8V2FA000583   Mileage: 9198km-5715miles
    Address 01: Engine (J623-CJZA)       Labels: 04E-907-309-V1.clb
       Part No SW: 04E 906 016 B    HW: 04E 907 309 A
       Component: 1.2l R4 TSI   H08 6387
       Revision: WAH08---
       Coding: 02110012230400082000
       ASAM Dataset: EV_ECM12TFS01104E906016B 001008
       ROD: EV_ECM12TFS01104E906016B.rod
       VCID: 2149CBAF30BD2E29405-8074
       Revision: 00000000    Serial number: 606040000015FD
       Coding: 10F16AA224200A6C017C060841C62508562450806082A4B2002100080608
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 7BF5D9C7F291A4F93A9-802E
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-047.clb
       Part No SW: 8V0 820 047 D    HW: 8V0 820 047 D
       Component: AC Manuell el H11 0052
       Revision: 20021000    Serial number: 00000000054640
       Coding: 00000004100000000000000000000000
       ASAM Dataset: EV_AirCondiFrontManAU37X 008018
       ROD: EV_AirCondiFrontManAU37X.rod
       VCID: 377D05F78E3940999E1-8062
    Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
       Part No SW: 5Q0 937 084 AC    HW: 5Q0 937 084 AC
       Component: BCM MQBAB M   H16 0124
       Serial number: 00011406500433
       Coding: 04040842C001027D03044004B30407000000000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 79F9C3CFF8AD96E9285-802C
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119
       Component: WWS370 140225  041 0580
       Serial number:         140227184035
       Coding: 0A47F7
       Subsystem 2 - Part No SW: 8U0 955 559 A    HW: 8U0 955 559 A
       Component: G397_RLS  H06 0002
       Serial number: 20143063
       Coding: 06885D
       Subsystem 3 - Part No SW: 8V0 941 531 Q    HW: 8V0 941 531 Q
       Serial number: 29 11 2013  00001158
       Serial number: 000000000ZY140231TB1
       Serial number: 00000000000058976888
       Serial number: 003M2R05LNY8
       Coding: 98CCC000000000005C540000004800000065
       VCID: 4B954907E2B1D479CA9-801E
       Subsystem 1 - Part No SW: -----------    HW: 480 001 702 14
       Serial number: 35767000000685500F0O
       Subsystem 2 - Part No SW: -----------    HW: 480 001 702 14
       Serial number: 35867000000885500F0R
       Subsystem 3 - Part No SW: -----------    HW: 480 400 703 14
       Serial number: 35165029F14D3E72E40M
       Subsystem 4 - Part No SW: -----------    HW: 480 402 802 14
       Serial number: 3526502C112F6291710.
       Subsystem 5 - Part No SW: -----------    HW: 480 400 702 14
       Serial number: 3556502C513013F3D10/
       Revision: --------    Serial number: 07031404220752
       Coding: 0408
       VCID: 0603B833B953E911557-8053
       Part No SW: 8V0 920 860 E    HW: 8V0 920 860 E
       Component: KOMBI         H02 2220
       Coding: 07850200228000080500BA00100000
       VCID: 3C771ADBB71F63C1733-8069
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       Part No SW: 5Q0 907 530 P    HW: 5Q0 907 530 E
       Component: GW MQB Mid    124 1164
       Revision: --------    Serial number: 0001674704
       Coding: 01010008200864005B000208000B00000001000000000000000000000000
       ROD: EV_GatewLear.rod
       VCID: 3E7310D3A10371D15D7-806B
       Subsystem 2 - Part No SW: 8U0 951 528     HW: 8U0 951 528
       Serial number: 20 02 2014  B1311502
       Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
       Serial number: 22021403110883
       Coding: 00100E20C100040100001002
       Coding: 0102
       ROD: EV_SteerAssisMQB_AU37.rod
       VCID: 41896B2FD0FD0E29205-8014
       Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
       Serial number: 04031403110700
       Coding: 00100620CD00040100001002
       VCID: 3D7117DFAC056AC944D-8068
       Part No SW: 8V0 035 840 B    HW: 8V0 035 840 B
       Component: MU-S--ER      040 0420
       Serial number: A3E00403140672
       Coding: 01730000FF0A000021220001001A00002F0001440100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       VCID: 346732FB9F4FAB81BB3-8061
       Seat Adjustment Driver Side:
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9DY301DHC
       Sound System:
       Subsystem 2 - Part No SW: 8V0 919 614 B    HW: 8V0 919 614 B
       Component: ControlUnit_B  H33 0037
       Serial number: C1000019021400010341
    End-------------------------(Elapsed Time: 02:47)--------------------------
    I'd like to know if there is a possibility to also enable start-stop.
  12. Likes Uwe liked this post
  13. #18
    Magdeburg, Germany
    No, you're missing too many vital components. So unless you plan on replacing a few control modules and add components to the car worth a 4 figure number of Euros's it's probably not worth it.
  14. Likes Dana liked this post
  15. #19
    Mar 2014
    Slovenia
    Has this retrofit coding been resolved and the cruise control worked?
  16. #20
    Feb 2016
    Czech Republic
    Hello
    Does anyone already retrofitted cruise control to Audi A3 8V ?
    I saw that Audi sell it like control switch and activating document.
    Is there any way to activate without document ?
    (I already have switch installed :-/ )
    Thank you
