Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Audi A3 8V Cruise Control retrofit
    Sep 2014
    Norway
    Hi.
    I have now retrofitted a cruise control to my A3 8V 2015-model.
    I have coded it in the steering wheel coding, but long coding helper on the engine module dosen’t exist.
    Does anyone know what I can change the code to in the ECU to get the cruise control to work?
    Address 01: Engine (J623-CYVB) Labels: None
    Part No SW: 04E 906 027 CJ HW: 04E 907 309 AF
    Component: 1.2l R4 TSI H21 7798
    Revision: R5H21---
    Coding: 02250032240401082000
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_ECM12TFS01104E906027CJ 001005
    ROD: EV_ECM12TFS01104E906027CJ.rod
    VCID: 6EFD1B31B196504A3B-803B
    United States
    Try changing that from
    to
    02250032242401082000
    The Cruise Control Retrofitting (5G) page should apply.
  3. Likes Uwe liked this post
    Sep 2014
    Norway
    Thanks, but that did not work.
    I got an error with the start-stop function when I did that.
    Sep 2014
    Norway
    Do you have any other suggestions? I am eager to start using my CC...
    United States
    Post the Auto-Scan in the current condition and if you have one saved prior to any modifications please post it as well.
    Edit, also let us know if you retrofitted the Curise Control via Stalk/Lever -or- the Curise Control via Multi-Function Steering Wheel type. Pert numbers couldn't hurt is you have those handy.
    Sep 2014
    Norway
    I have retrofitted a cruise Control stalk.
    I get this error in the instruments panel when I change the coding:
    "Automatic start/stop: system fault! Function unavailable".
    Here are a full scan, after I have change the coding. I deleted all the fault codes before I changed the coding.
    Friday,19,September,2014,13:08:19:00341
    VCDS Version: 12.12.2.0 (x64)
    Data version: 20140212
    VIN: WAUZZZ8V0FA026843   License Plate:
    Chassis Type: 8V (5Q0)
    Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
       Revision: R5H21---
       Coding: 02250032242401082000
       ROD: N/A
       VCID: 6EFD1B31B196506E79B-803B
    No ASAM data for: "EV_ECM12TFS01104E906027CJ" (AU37)
    17158 - ROD - Unknown Error Code
              - 00 [047]
                        Fault Frequency: 7
                        Mileage: 750 km
                        Date: 2014.09.16
                        Time: 08:03:32
    17149 - ROD - Unknown Error Code
              - 00 [175]
                        Fault Frequency: 9
                        Mileage: 750 km
                        Date: 2014.09.16
                        Time: 08:03:32
       Part No SW: 0CW 300 047 S    HW: 0AM 927 769 K
       Component: GSG DQ200-MQB H43 5202
       Revision: 00043014    Serial number: CU501406255937
       Shop #: WSC 17734 418 534600
       ROD: EV_TCMDQ200021_AU37.rod
       VCID: 4BBBB2A5E2C445463E5-801E
    Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
       Part No SW: 5Q0 907 379 L    HW: 5Q0 907 379 G
       Component: ESC           H31 0471
       Revision: 00000000    Serial number: 61824000000195
       Coding: 12F16AA224221272017F060441C62548562448806082A4F2002100788608
       ROD: EV_Brake1UDSContiMK100IPB_AU37.rod
       VCID: 45AF849DC4A0B336E81-8010
    8291 - Databus
                        Fault Frequency: 18
                        Reset counter: 115
                        Mileage: 750 km
                        Date: 2014.09.16
                        Time: 08:03:30
    8314 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [008] - -
                        Fault Frequency: 9
                        Reset counter: 115
                        Mileage: 750 km
                        Date: 2014.09.16
                        Time: 08:03:32
       Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
       Serial number: 003M2R07F20Z
       Coding: 98CCC0000C0000005C5400CA004800000065
       Subsystem 1 - Part No SW: -----------    HW: 480 000 107 14
       Serial number: 357670000006DB49301W
       Crash sensor for side airbag; passenger side:
       Subsystem 2 - Part No SW: -----------    HW: 480 000 107 14
       Serial number: 3586700000039B49301Q
       Crash sensor for side airbag; rear driver side:
       Subsystem 3 - Part No SW: -----------    HW: 480 402 306 14
       Serial number: 3516502C71617D20B0EA
       Crash sensor for side airbag; rear passenger side:
       Subsystem 4 - Part No SW: -----------    HW: 480 402 306 14
       Serial number: 3526502BF169752480CH
       Subsystem 5 - Part No SW: -----------    HW: 480 401 505 14
       Serial number: 3556502B9157E9E1633N
       Pedestrian protection crash sensor; driver side:
       Subsystem 6 - Part No SW: -----------    HW: 480 400 207 14
       Component: PedP_Sensor_D  001 6149
       Serial number: 2286502A31697524411Z
       Pedestrian protection crash sensor; passenger side:
       Subsystem 7 - Part No SW: -----------    HW: 480 400 207 14
       Component: PedP_Sensor_P  001 6149
       Serial number: 2296502A31697521120U
       Center pedestrian protection crash sensor:
       Subsystem 8 - Part No SW: -----------    HW: 480 400 207 14
       Component: PedP_Sensor_C  001 6149
       Serial number: 2306502C5156E9E0D2FS
       Part No SW: 8V0 953 521 BM    HW: 5Q0 953 549 C
       Revision: --------    Serial number: 02071404400972
       Coding: A418
       ROD: EV_SMLSKLOMQB_AU37.rod
       VCID: 862DC3913926F82E21B-80D3
       Part No SW: 8V0 920 871     HW: 8V0 920 871
       Coding: 07A40A082B8000080100AA001000000000000000
       VCID: F9D7B86D78D887D65C9-80AC
       Part No SW: 5Q0 907 530 T    HW: 5Q0 907 530 F
       Component: GW MQB High   128 1188
       Revision: --------    Serial number: 0002164113
       Coding: 030100042F0864005B000248100B00000001010000000000000000000000
       ASAM Dataset: EV_GatewLear 011016
       ROD: EV_GatewLear_AU37.rod
       VCID: 42A59F81D58E840ECD3-8017
       Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
       Serial number: 24 06 2014  C0070782
       Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
       Component: J367-BDMHella  H03 8043
       Serial number: 7023143703
       Serial number: 20061406070851
       Coding: 00108F204000040000001002
       ROD: EV_DCUDriveSideEWMAXKLO.rod
       VCID: 40A19589DB82961EDB7-8015
       Component: EPS_MQB_ZFLS  122 1043
       Coding: 8103
       ROD: EV_SteerAssisMQB.rod
       VCID: 41A7908DD0889F16D49-8014
       Serial number: 21061404081506
       Coding: 001087204000040000001002
       ROD: EV_DCUPasseSideEWMAXKLO.rod
       VCID: 3FA39675A67CE9E6A2D-806A
       Part No SW: 8V0 035 842 B    HW: 8V0 035 842 B
       Component: MU-S-D-ER     041 0420
       Serial number: A7E00706142707
       Coding: 01730300FF0A000011111101000A00002F0001040100010002
       ASAM Dataset: EV_MUStd6C3PASE 002020
       ROD: EV_MUStd6C3PASE.rod
       VCID: 364DF351894628AE71B-8063
       Seat Adjustment Driver Side:
       Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
       Component: DU Std  H49 0013
       Serial number: AUZ8Z9EY304D5F
       Sound System:
       Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
       Component: ControlUnit_B  H41 0054
       Serial number: C1000010061400020005
    United States
    01-Engine:
    Quote Originally Posted by kimbr View Post
    OK, according to the limited #01 coding information that is available and the PR codes located by VIN (7L6 - Start/stop system with regenerative braking), the vehicle should have start-stop installed. Tweaking the CCS installed bit alone in the 01-Engine coding shouldn't cause Start/Stop issues but the fault code descriptions would be helpful, which leads me to the next concern..
    - 00 [047]
    - 00 [175]
    Release 12.12.2 isn't up to date which explains that missing ROD file in the engine and lack of fault codes descriptions. That wasn't an issue in the 1st post so I suspect you have a Beta release installed. It would be highly recommended to use Beta 14.8.1 for this retrofit so please post the current scan with it if you need further assistance.
    16-Steering wheel:
    I see 2 possible configurations in the #16 module coding:
    • Cruise Control controlled via Turn Signal Lever
    • Cruise Control controlled via Separate Lever
    You currently have the Separate Lever type enabled, is that the stalk type or do you have the Turn Signal Lever hardware installed instead? If you have a scan saved prior to any modifications please post it (or link us to it if you already have it posted online somewhere).
  9. Likes jyoung8607, Uwe liked this post
  10. #8
    Sep 2014
    Norway
    Hi.
    Here you have a full scan before and after with 14.8.1 beta.
    The steering wheel coding is ok, I have already change the coding there.
    I changed the coding from 02250032240401082000 to 02250032242401082000 in engine, as you suggested.
    Before:
    Thursday,09,October,2014,16:45:23:00341
    VCDS Version: 14.8.1.0 (x64)
    Data version: 20140905
    Mileage: 1294km-804mi   Repair Order:
    VIN: WAUZZZ8V0FA026843   Mileage: 1294km-804miles
       Revision: R5H21---
       VCID: 4BBBB2A5E2C445627C-801E
       VCID: 45AF849DC4A0B312AA-8010
    Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
       Component: AC Automat    H13 0052
       Revision: 20026000    Serial number: 00000000367118
       Coding: 03000004000000001000000000001000
       VCID: 334BCA459A343DA214-8066
       Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
       Component: BCM MQBAB H   H18 0134
       Serial number: 01011418501993
       Coding: 04041A46C24122FD43C44004001C07A80000000000000000000000000000
       ROD: EV_BCMBOSCH_AU37.rod
       VCID: 002155899B02563AD9-8055
       Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119
       Component: WWS370 140618  042 0580
       Serial number:         140625000958
       Coding: 0A47F7
       Subsystem 2 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B
       Serial number: 22848121
       Coding: 00006C
       Subsystem 3 - Part No SW: 8V0 941 531 L    HW: 8V0 941 531 L
       Serial number: 15 04 2014  00001141
    Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-283.clb
       Part No SW: 5Q0 919 283 E    HW: 5Q0 919 283
       Component: PARKHILFE 4K  H10 0051
       Revision: --------    Serial number: 39231418600162
       Coding: 0000050011
       ASAM Dataset: EV_EPHVA14AU3700000 002022
       ROD: EV_EPHVA14AU3700000_AU37.rod
       VCID: 3B5BE265B264F5E2CC-806E
       Pedestrian protection crash sensor; front passenger side:
       Coding: A418
       VCID: 062D4391B926780AE3-8053
       VCID: 79D7386DF8D807F29E-802C
    Address 19: CAN Gateway (J533)       Labels: Redir Fail!
       ROD: EV_GatewLear.rod
       VCID: 42A59F81D58E842A8F-8017
       VCID: 40A19589DB82963A99-8015
       Coding: 8103
       ROD: EV_SteerAssisMQB_AU37.rod
       VCID: 41A7908DD0889F3296-8014
       VCID: 3FA39675A67CE9C2E0-806A
    Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
       Coding: 018A000001000000
       ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
       VCID: 75CF345DD4C06392FA-8020
       VCID: 364DF3518946288A33-8063
       Sound System:
    End-------------------------(Elapsed Time: 03:00)--------------------------
    After:
    Thursday,09,October,2014,16:57:53:00341
       Revision: R5H21---
    17158 - Databus
                        Mileage: 1294 km
                        Date: 2014.10.09
                        Time: 16:53:20
    17149 - Check Coding of ECUs on Powertrain Data Bus
              P1647 00 [167] - -
                        Mileage: 1294 km
                        Date: 2014.10.09
                        Time: 16:53:21
    8291 - Databus
                        Reset counter: 163
                        Mileage: 1294 km
                        Date: 2014.10.09
                        Time: 16:53:19
              P1647 00 [008] - -
                        Reset counter: 163
                        Mileage: 1294 km
                        Date: 2014.10.09
                        Time: 16:53:20
       Coding: 0A47F7
       Coding: 00006C
       Coding: 0000050011
       Coding: A418
       Coding: 8103
       Sound System:
    End-------------------------(Elapsed Time: 03:01)--------------------------
  11. #9
    Tartu, Estonia
    Sorry, but i always wanted to do this
    The world is my oyster...
  12. Likes jakematic, kimbr, Uwe, jyoung8607, Bruce, Eric liked this post
  13. #10
    I'm so stealing that!
  14. Likes jyoung8607 liked this post
