Results 1 to 10 of 12
Thread: Coding problem ABS 5.7 Passat 3B
    Aug 2015
    Belgium
    We replaced the ABs module. The correct login according to the sticker in the boot is 08555 (see attached photo of sticker) The correct coding should be 04255
    When we login with 08555 VCDS suddenly takes a long time to do anything(it s stuck) and then says "no response from controller" and throws us out back to the main screen.Then we have to cycle the ignition to get comms again
    When we login with the standard 40168 for steering wheel adaptation it doesnt do this. However this obviously not the correct login for coding. Has anybody encountered this before?
    We also tried to do this with a different ABS module and we have the same problem. Attached also a full scan.
    Thank you for your input,
    Floris
    Monday,27,November,2017,13:44:29:07138
    VCDS Version: 17.8.0.1 (x64)
    Dealer/Shop Name: Floris
    Workshop Code: 123 12345 034566
    VIN: WVWZZZ3BZ5E071732   License Plate:
    VIN: WVWZZZ3BZ5E071732   Mileage: 211260km-131270miles
    Address 01: Engine        Labels: 038-906-019-AVB.lbl
       Part No: 038 906 019 KC
       Component: 1,9l R4 EDC G000SG  4896
       Coding: 00002
       Shop #: WSC 02763
       VCID: 62C027E5EE545356FC-4B00
       WVWZZZ3BZ5E071732     VWZ7Z0D0681421
    16955 - Brake Switch (F)
                P0571 - 35-00 - Implausible Signal
    18057 - Powertrain Data Bus
                P1649 - 35-10 - Missing Message from ABS Controller - Intermittent
       Part No: 4B0 614 517 G
       Component: ABS/ESP front       3428
       Coding: 00000
       VCID: 254A7CF9BFFAE46ED9-513C
                66-10 - Not Matched - Intermittent
                35-00 -  -
       Part No: 3B1 907 044 K
       Component: CLIMATRONIC B5GP    0010
       Coding: 17000
       Shop #: WSC 05311
       VCID: 295270C9D3E2C00EFD-515A
    00603 - Footwell/defroster Flap Positioning Motor (V85)
                35-10 -  -  - Intermittent
    01271 - Positioning Motor for Temperature Flap (V68)
    00532 - Supply Voltage B+
       Part No: 1C0 909 605 B
       Component: 0R AIRBAG VW51 04   0008
       Coding: 12370
       Shop #: WSC 05311
       VCID: 234E62E1B1CE1A5EB7-513C
       Part No: 3B0 920 829 A
       Component: KOMBI+WEGFAHRSP VDO V07
       Coding: 05115
       VCID: 244C61FDB4C01D66CE-5120
    01316 - ABS Control Module
       Part No: 6N0 909 901
       Coding: 00006
       Shop #: WSC 05311
       VCID: 70E45DAD30B8F1C67A-513C
       Part No: 1C0 959 799 B
       Component: 8S Komfortgerát HLO 0004
       Coding: 00258
       Shop #: WSC 05311
       VCID: 3668ABB5125C9FF660-4B18
       Subsystem 1 - Part No: 1C0959801
       Component: 8S Tőrsteuer.FS KLO 0202
       Subsystem 2 - Part No: 1C0959802A
       Component: 8S Tőrsteuer.BF KLO 0202
       Subsystem 3 - Part No: 1C0959811
       Component: 8S Tőrsteuer.HL KLO 0202
       Subsystem 4 - Part No: 1C0959812
       Component: 8S Tőrsteuer.HR KLO 0202
    7 Faults Found:
    01359 - Internal Central Locking Switch; Passenger Side (E198)
    End-------------------------(Elapsed Time: 05:20)--------------------------
    I don't think you read the Login section of the Wiki page correctly. Please try 09555.
    Aug 2015
    Belgium
    Hi Uwe,
    Thank you for your quick reply! Would you believe me if I said I overlooked this twice. I doublechecked the coding and failed 2 times to spot the mistake.... Just went to the car and coded everything. Job done in 5 min.
    Thanks again for your much appreciated help!
    Greeting from Belgium!
    Floris
  5. Likes Uwe, Jack@European_Parts liked this post
    Sep 2019
    Serbia
    paasat b5 3b abs bosch 5.7 coding
    hello team I'm new to the forum because someone can help me encode abs vw passat 1.9 tdi 96 kw variant manual transsmision, I don't know what my login and coding is for my car
    Saturday,14,December,2019,08:06:35:01603
    Dealer/Shop Name: Milosavljevic Boris
    VIN: WVWZZZ3BZ4E221308   License Plate:
    Mileage: 183510km-114027mi   Repair Order:
    PHOTO https://mega.nz/#!YQhVXQjB!hCJrAOlcv...qSfxacdYboUjyQ
    VIN: WVWZZZ3BZ4E221308   Mileage: 183510km-114027miles
    Address 01: Engine        Labels: 038-906-019-AVF.lbl
       Part No: 038 906 019 KE
       Component: 1,9l R4 EDC 0000SG  4898
       Coding: 00005
       Shop #: WSC 05314
       VCID: 6484BB46F65DFC6F23-4B1E
       WVWZZZ3BZ4E221308     VWZ7Z0C8634622
    18263 - Powertrain Data Bus
                P1855 - 35-00 - Software Version Monitoring
    Readiness: 0 0 0 1 1
       Coding: 00000
       VCID: 2502E642BDE74567F4-51CE
                35-00 - -
       Coding: 17000
       Shop #: WSC 05311
       VCID: 291AEA72D1FF6107D0-5184
       Part No: 1C0 909 605 C
       Component: 0E AIRBAG VW61 04   0003
       Coding: 12357
       Shop #: WSC 05311
       VCID: 2404FB46B6DDBC6FE3-513C
       Component: KOMBI+WEGFAHRSP VDO V04
       Coding: 05115
       Shop #: WSC 00050
       Coding: 00006
       Shop #: WSC 05311
       VCID: 70ACC71632A550CF57-513C
       Component: 7X Komfortgerát HLO 0003
       Coding: 00259
       Shop #: WSC 05311
       VCID: 3620310E10413EFF4D-4B1E
       Subsystem 1 - Part No: 1C1959801
       Component: 7X Tőrsteuer.FS KLO 0202
       Subsystem 2 - Part No: 1C1959802
       Component: 7X Tőrsteuer.BF KLO 0202
       Component: 7X Tőrsteuer.HL KLO 0202
       Component: 7X Tőrsteuer.HR KLO 0202
       Part No: 1J0 035 186 E
       Component:  Radio BNO         0006
       Coding: 05401
       Shop #: WSC 05311
       VCID: 271EEC4AC7EB5777C6-4B00
    End----(Elapsed Time: 04:29, VBatt start/end: 11.7V/11.7V. VIgn 11.6V)-----
    Nov 2017
    Latvia
    Have you ever opened wiki ross tech?
    Try 09595 and 04295
  8. Likes Uwe liked this post
  9. #6
    Sep 2019
    Serbia
    will not try it myself
  10. #7
    Sep 2019
    Serbia
    accept me only coding login 09555, coding04255 but when i exit the abs module and re-enter abs it returns the coding to 00000. Because you have some solution
  11. #8
    Quote Originally Posted by BBoriskg View Post
    As _Val suggested it would be worth you reading the Ross-Tech Wiki for details of those error codes
  12. #9
    Did you ever consider installing the correct parts and remove FOD and fix the communication error?
  13. #10
    Nov 2017
    Latvia
    Yes, my bad. Didn't notice T9J+1ZC combination
    engine 038906019KE (PR-0GZ; match)
    abs 4B0614517G => 4B0614517J (PR-1AT; match)
    cluster 3B0920829A => 3B0920829AX (for AVB, AVF, AWX; match)
    @Jack, I give up. Can't see FOD.
