I have done that. You actually answered before about this vehicle. key is not married to car but car should still turn over, it doesn't. So looking into module problems or water infiltration as will not come online. 05acc/start is online and scan shows no issue with it. There is no start button in this vehicle, so thanks for that info!
No man , when key is not programed to this car, ignition will not come on and you can not communicate with most of the modules including .
This car use Kessy system with Wake up CAN BUS on Terminal 15( Ignition 12V) , it is not regular mechanical ignition switch. Lets say you want to power up instrument cluster direct on table, on this car is not possible , This car use WAKE UP signal form CAN Gateway via Central convince module to turn cluster On.
I do not think you ever deal with this kind of stuff.
Form your older post:
Thank you! I do not have a start button, I will assume that it is still the kessy systemand if not still immobilizer 3. I incorrectly assumed that the car would turn over and then be shut down by the immobilizer. I also thought that computer would still be able to reach components. Enlightening, Thanks.
On this car Start/Stop button is just to have keyless start and keyless entry ,this car use Kessy system regardless is it have Start/Stop button or not . Since you do not have Start /Stop button you will not have antennae reader .
You have been dealing with this form June , wasting your time 5 moths, so many members over hear was telling you same thing over and over , and you do not believe it to no one. You came for help here , we give you solution but you going the way you think it is , I really do not understand that .
I think you misunderstanding , Kessy , and Keyless , your car has Kessy system with out keyless , maybe this will give you better view.
Simple solution is , Take car to dealer and program key .
