Hy frends,
Yesterday I installed on my Passat B8 2015 on dashboard, the AMBIENT LIGHT ornaments with RGB, and electrical connections was made in the following way :
Pin 1 (T3ex / T3ey) from RGB LED to Fuse Holder C (SC8)
Pin 2 (T3ex / T3ey) from RGB LED to pin 29 (T73c)
Pin 4 (T3ex / T3ey) from RGB LED to GROUND
Now my problem is (because the doors my car have AMBIENT LIGHT - NON RGB) :
Which of the following codings is correct to make it functional the AMBIENT LIGHT RGB from dashboard ?
Version 1
09 Central Electrics
16 Acces code 31347
10 Adaptations
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel: adapted to = active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig: adapted to = active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig: adapted to = active
Interior light, light configuration: Ambiente_Applikationsleisten_in_Instrumententafel: installed == (NOT FOUND ON MY ADAPTATION CHANELS)
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung: adapted to = installed
IDE09732-ENG126834-Interior light: light configuration--Dachkonsole lokal aktivierbar: adapted to = active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus: adapted from to = active
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen: adapted to = active
IDE09732-ENG02312-Interior light, light configuration: Ambient_Farbliste_HMI: active == (NOT FOUND ON MY ADAPTATION CHANELS)
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI: adapted to = installed
Ambientelicht Farbliste: Rotwert Farbe 1: 144
Ambientelicht Farbliste: Gruenwert Farbe 1: 24
Ambientelicht Farbliste: Blauwert Farbe 1: 28
Version 2
16 Acces code 31347
10 Adaptations
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus: adapted to = active
IDE11477-ENG128656-Indoor lighting Parameter-p_ambient_range_more_colour_HMI_2.... 1C == (NOT FOUND ON MY ADAPTATION CHANELS)
IDE11477-ENG128654-Indoor lighting Parameter-p_color_selection_HMI.... 1A == (NOT FOUND ON MY ADAPTATION CHANELS)
IDE11714-ENG126827-Ambientelicht Farbliste-Blauwert Farbe 1....255 (ALREADY ADAPTED)
IDE11714-ENG126826-Ambientelicht Farbliste-Gruenwert Farbe 1....150
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1: adapted to = 150 (ON MY CAR)
IDE11714-ENG126825-Ambientelicht Farbliste-Rotwert Farbe 1....2
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1: adapted to = 2 (ON MY CAR)
IDE11714-ENG126830-Ambientelicht Farbliste-Blauwert Farbe 2....64
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2: adapted to = 64 (ON MY CAR)
IDE11714-ENG126829-Ambientelicht Farbliste-Gruenwert Farbe 2....255 (ALREADY ADAPTED)
IDE11714-ENG126828-Ambientelicht Farbliste-Rotwert Farbe 2....175
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2: adapted to = 175 (ON MY CAR)
IDE11714-ENG126833-Ambientelicht Farbliste-Blauwert Farbe 3....0
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3: adapted to = 0 (ON MY CAR)
IDE11714-ENG126832-Ambientelicht Farbliste-Gruenwert Farbe 3....198
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3: adapted to = 198 (ON MY CAR)
IDE11714-ENG126831-Ambientelicht Farbliste-Rotwert Farbe 3....255 (ALREADY ADAPTED)
IDE09731-ENG125024-Int. light: 2nd generation- Farbwert Farbe 1: adapted to = 2
IDE09731-ENG125025-Int. light: 2nd generation- Farbwert Farbe 2: adapted to = 4
IDE09731-ENG125026-Int. light: 2nd generation- Farbwert Farbe 3: adapted to = 5
IDE09732-ENG115870-Innenlicht Luminaire configuration-Ambiente_Applikationsleisten_in_Instrumententafel
As you can see in VERSION 2 some channels from adaptations have a different IDE and only ENG is identical !!!
Which coding is correct ???
The coding of is 00959E66C2410AFF13844084B118172C1880000000000000000000000000
Thank you .
I wait some answers !!!
