Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: VCDS HELP (Ambient Lighting Color Selection)
  1. #21
    Jun 2017
    Try setting Color 1 to valid RGB values and try to avoid using zero as a numeric value and reset again.
    Which unit / model year is this?
  2. #22
    Aug 2016
    Ormond Beach, FL
    Will give that a try and see what results.
    MY16 NAR Golf Variant 1,8 tsi with the MIBII (non navigation). Vehicle build date is 01/26/16.
    2019 Golf 7.5 GTI Rabbit Edition Pure-Weiß 2016 Golf 7 Variant R-Line Pure-Weiß 2011 Golf 6 TDI BLUEMOTION Highline Candy-Weiß 2008 Golf 5 .:R32 Deep Blau Perleffekt DSG 4-MOTION 2006 Golf GTI DSG Tornadorot 2002 Indigo Blau Perleffekt Passat 3BG Trendline. I Euro-spec Mods!
  3. #23
    Verified VCDS User @DRI@N's Avatar
    Nov 2017
    Romania
    Is anybody here who did retrofit from AMBIENT LIGHT 1 (all doors only) to AMBIENT LIGHT 2 (all doors and dashboard) on Passat B8 2015 ?
    I buyed the ornaments for dashboard with AMBIENT LIGHT but I don't know where to conect the electric instalation and what codding I ned to make with VCDS .
    We have colleagues here who have ELSA and who can and will to tell me where to connect these ornaments (an electrical scheme) ?
    Thanks !!!
  4. #24
    Jul 2018
    Australia
    hi all,
    I have managed to change the 10 colours on the dash on my MY16 passat, but cannot change the LED door lights. Cant work out whether I have missed a step or its just no possible on the car. Any help would be great. I can provide any extra info too.
    Thanks in advance
  5. #25
    Dec 2016
    can someone post an admap from a Passat B8 with color ambient lighting?Iam currently trying to retrofit in my own car but no light..
    put wire in p29 in plug C in the BCM, made testwire with 12v cig plug
    p1 12v
    p2 connected to p29 plug c bcm
    p3 empty
    p4 ground
  6. #26
    Nov 2017
    Romania
    Hy frends,
    Yesterday I installed on my Passat B8 2015 on dashboard, the AMBIENT LIGHT ornaments with RGB, and electrical connections was made in the following way :
    Pin 1 (T3ex / T3ey) from RGB LED to Fuse Holder C (SC8)
    Pin 2 (T3ex / T3ey) from RGB LED to BCM pin 29 (T73c)
    Pin 4 (T3ex / T3ey) from RGB LED to GROUND
    Now my problem is (because the doors my car have AMBIENT LIGHT - NON RGB) :
    Which of the following codings is correct to make it functional the AMBIENT LIGHT RGB from dashboard ?
    Version 1
    09 Central Electrics
    16 Acces code 31347
    10 Adaptations
    IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel: adapted to = active
    IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig: adapted to = active
    IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig: adapted to = active
    Interior light, light configuration: Ambiente_Applikationsleisten_in_Instrumententafel: installed == (NOT FOUND ON MY ADAPTATION CHANELS)
    IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung: adapted to = installed
    IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar: adapted to = active
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus: adapted from to = active
    IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen: adapted to = active
    IDE09732-ENG02312-Interior light, light configuration: Ambient_Farbliste_HMI: active == (NOT FOUND ON MY ADAPTATION CHANELS)
    IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI: adapted to = installed
    Ambientelicht Farbliste: Rotwert Farbe 1: 144
    Ambientelicht Farbliste: Gruenwert Farbe 1: 24
    Ambientelicht Farbliste: Blauwert Farbe 1: 28
    Version 2
    16 Acces code 31347
    10 Adaptations
    IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus: adapted to = active
    IDE11477-ENG128656-Indoor lighting Parameter-p_ambient_range_more_colour_HMI_2.... 1C == (NOT FOUND ON MY ADAPTATION CHANELS)
    IDE11477-ENG128654-Indoor lighting Parameter-p_color_selection_HMI.... 1A == (NOT FOUND ON MY ADAPTATION CHANELS)
    IDE11714-ENG126827-Ambientelicht Farbliste-Blauwert Farbe 1....255 (ALREADY ADAPTED)
    IDE11714-ENG126826-Ambientelicht Farbliste-Gruenwert Farbe 1....150
    IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1: adapted to = 150 (ON MY CAR)
    IDE11714-ENG126825-Ambientelicht Farbliste-Rotwert Farbe 1....2
    IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1: adapted to = 2 (ON MY CAR)
    IDE11714-ENG126830-Ambientelicht Farbliste-Blauwert Farbe 2....64
    IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2: adapted to = 64 (ON MY CAR)
    IDE11714-ENG126829-Ambientelicht Farbliste-Gruenwert Farbe 2....255 (ALREADY ADAPTED)
    IDE11714-ENG126828-Ambientelicht Farbliste-Rotwert Farbe 2....175
    IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2: adapted to = 175 (ON MY CAR)
    IDE11714-ENG126833-Ambientelicht Farbliste-Blauwert Farbe 3....0
    IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3: adapted to = 0 (ON MY CAR)
    IDE11714-ENG126832-Ambientelicht Farbliste-Gruenwert Farbe 3....198
    IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3: adapted to = 198 (ON MY CAR)
    IDE11714-ENG126831-Ambientelicht Farbliste-Rotwert Farbe 3....255 (ALREADY ADAPTED)
    IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1: adapted to = 2
    IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2: adapted to = 4
    IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3: adapted to = 5
    IDE09732-ENG115870-Innenlicht Luminaire configuration-Ambiente_Applikationsleisten_in_Instrumententafel
    As you can see in VERSION 2 some channels from adaptations have a different IDE and only ENG is identical !!!
    Which coding is correct ???
    The coding of BCM is 00959E66C2410AFF13844084B118172C188000000000000000 0000000000
    Thank you .
    I wait some answers !!!
  7. Likes LoLo46 liked this post
