I started retro fit with following components and getting many errors in VCDS logs. Display and button console isn't powering up. Can you please check VCDS logs and help me? I dont want to go to dealer to remove CP with so many errors.
-HD radio 4G0035082G
-mmi 3g+ 8R1035746A
-can gateway 8R0907468H
-screen 8R0919604 H41
-Kufatec harness
Optical bus log - All components are snug connected.
Gateway log
Full log with many errors.
-mmi 3g+ 8R1035746A
-Kufatec harness
Sunday,19,November,2017,12:13:00:33734
VCDS Version: 17.8.0.1 (x64)
Dealer/Shop Name: SelfAudi
Control Module Part Number: 8R0 907 468 H
Component and/or Version: GW-BEM 4CAN-M H11 0051
Optical Bus Diagnostic : Standard
Controller Electrical Optical
19-CAN Gateway OK ERROR
5F-Information Electr. ERROR ERROR
0E-Media Player 1 ERROR ERROR
77-Telephone ERROR ERROR
47-Sound System ERROR ERROR
56-Radio ERROR ERROR
37-Navigation ERROR ERROR
0F-Digital Radio ERROR ERROR
Gateway log
Sunday,19,November,2017,11:54:08:33734
Address 19: CAN Gateway Labels: 8T0-907-468.clb
Control Module Part Number: 8R0 907 468 H HW: 8R0 907 468 C
Software Coding: 80C303FF00
Work Shop Code: WSC 06325 000 00000
VCID: 44870CC3C7181966EE-8010
8 Faults Found:
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:42
Bin. Bits: 11111
Voltage: 14.40 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:42
Bin. Bits: 11111
Voltage: 14.40 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:46
Bin. Bits: 11111
Voltage: 14.50 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
03619 - Control Module for Structural Accoustics
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:46
Bin. Bits: 11111
Voltage: 14.50 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:46
Bin. Bits: 11111
Voltage: 14.40 V
Count: 6
00384 - Optical Databus
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 17:57:39
Bin. Bits: 10000
Voltage: 12.50 V
Count: 7
Bin. Bits: 00000
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 17:57:43
Bin. Bits: 10111
Voltage: 12.10 V
Count: 6
Text: FF71742E00828104
Text: 0000000000000000
Raw, Form. N/A: 000 000 000
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 17:57:49
Bin. Bits: 10111
Voltage: 12.10 V
Count: 6
Text: 0200000000000000
Sunday,19,November,2017,11:45:51:33734
VIN: WA1LFAFP2CA096745 License Plate:
Mileage: 103630km-64392mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 36 42 44 46 47 52 53 55 56
5F 62 6C 6D 72 A9
VIN: WA1LFAFP2CA096745 Mileage: 103630km-64392miles
22-AWD -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Not registered 0001
5F-Information Electr. -- Status: Cannot be reached 1100
6C-Back-up Cam. -- Status: Cannot be reached 1100
6D-Trunk Elect. -- Status: Not registered 0001
A9-Struct. Borne Sound -- Status: Cannot be reached 1100
Address 01: Engine (0-----CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 P HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H20 0003
Revision: E1H20---
Coding: 0121010A290F0160
Shop #: WSC 22155 444 131269
ASAM Dataset: EV_ECM20TFS0118R0907115P 001004
ROD: EV_ECM20TFS0118R0907115P.rod
VCID: 418905D7D00A0C4EC5-8014
Readiness: 1110 0101
Address 02: Auto Trans (J217) Labels:| 0BK-927-156.clb
Part No SW: 8R0 927 158 T HW: 0BK 927 156 AJ
Component: 0BK 20TFSIUSA H16 1010
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002020
VCID: 4E932EEB1154E33648-801A
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 H HW: 8R0 907 379 H
Component: ESP8 quattro H06 0110
Coding: 121D18
Shop #: WSC 06334 000 00000
VCID: 458111C7CC22206EF9-8010
Part No SW: 8K0 907 064 FP HW: 8K0 907 064 FP
Component: BCM2 2.0 H10 0602
Coding: 0D854000000000000000
Shop #: WSC 06335 000 00000
VCID: 0305CFDF8296DE5E97-8056
Subsystem 1 - Part No SW: 8K0 905 852 E HW: 8K0 905 852 E
Serial number: 2312000027470002
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0180
Revision: C1000000 Serial number: 01060320120161
Coding: 64012000
VCID: 000FC0D39380C5468A-8054
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:51:43
Part No SW: 8K0 907 063 CE HW: 8K0 907 063 P
Component: BCM1 1.0 H30 0410
Revision: 10030001 Serial number: 00000001430823
Coding: 260018B1053CAF010000080300001D0D0F1C460802010161000000
VCID: 74E79C03D738E9E69E-8020
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 120222 H11 0050
Serial number: 90243014120218201533
Coding: 01DD13
Component: RLS H04 0003
Serial number: 20088584
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AS HW: 8K0 941 531 AS
Component: E1 - LDS H03 0031
Serial number: 00000000002702121181
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:00
Address 15: Airbags (J234) Labels:| 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Serial number: 003GPD907YXB
Coding: 303633313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 479D1BCFFE2E327E0B-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R1200007RW2
Serial number: 6334MSME6B613842E
Serial number: 6344MSME6C734953N
Serial number: 6352QSME051144664
Serial number: 6362QSME5B0D336EX
Serial number: 63732SME1611347CY
Serial number: 63832SME14111E72V
13697280 - Component Protection
U1101 00 [137] - Active
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:22
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90372LC1001HX
Coding: 000017
VCID: 3D717927A4F268AEA1-8068
Component: E221 - MFL H03 0004
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 950 K HW: 8R0 920 950 K
Component: KOMBIINSTR. H12 0261
Revision: 00100000 Serial number: N37228X2D
Coding: 8B1F22000300D705020000
VCID: 3E737E2BA9F473B6B8-806A
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:50:48
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:50:48
Part No SW: 8R0 907 468 H HW: 8R0 907 468 C
Component: GW-BEM 4CAN-M H11 0051
Revision: 1Y050025 Serial number: 2541Y1261305A2
Coding: 80C303FF00
Shop #: WSC 06325 000 00000
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790207572
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:42
Bin. Bits: 11111
Voltage: 14.40 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Address 22: AWD
Part No SW: 8R0 959 760 D HW: 8R0 959 760 B
Component: MEM-FS H07 0076
Revision: AA000000 Serial number: 00000024113305
Coding: 00581B00000000000000
VCID: 428B0ADBDD0C1756DC-8016
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:56
Part No SW: 8K0 959 793 P HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000025118450
Coding: 011D13205E00440004
VCID: 4D9129E71452D82E31-8018
Address 44: Steering Assist
Revision: 00002001 Serial number: 0171800429
Coding: 01260E3A20FA749587B0053200000000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000494006
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 47: Sound System
Part No SW: 8K0 959 792 P HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000025787600
VCID: 4C9724E3EF48D12626-8018
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000897119
VCID: 34675C0397B8A9E65E-8060
Fault Status: 11101101
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 17:53:55
Voltage: 14.50 V
Count: 80
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Address 55: Headlight Range (J431) Labels:| 8X0-907-357.clb
Part No SW: 4H0 907 357 B HW: 4H0 907 357 B
Serial number: 120221-0002-096
Coding: 1197A61010020400
ROD: EV_HeadlRegulBasic.rod
VCID: 2D5149677C92F82E11-8078
Address 56: Radio
Part No SW: 8K0 959 795 D HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000025708906
Coding: 010C13204000240004
VCID: 43850FDFC2161E5ED7-8016
Address 6C: Back-up Cam.
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H52 0330
Revision: -------- Serial number: 8R0827851B
VCID: 3B75773FBAE6669E9F-806E
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H52 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H01 0506
Revision: Serial number: 0000025708902
Address A9: Struct. Borne Sound
End-------------------------(Elapsed Time: 04:28)--------------------------
Sunday,19,November,2017,12:30:19:33734
Scan: 01 02 03 05 08 09 0E 0F 15 16 17 19 22 36 37 42 44 46 47 52
53 55 56 5F 62 65 6D 72 77 A9
0E-Media Player 1 -- Status: Cannot be reached 1100
0F-Digital Radio -- Status: Cannot be reached 1100
65-Tire Pressure -- Status: Cannot be reached 1100
Revision: E1H20---
Readiness: 0110 0101
Revision: --H16---
Coding: 000002
Coding: 121D18
Fault Status: 01101101
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 17:58:57
Hex Value: 0x0000
Hex Value: 0x0782
Hex Value: 0x0016
Hex Value: 0x0299
Hex Value: 0x00FF
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 17:57:40
Coding: 64012000
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:51:43
Coding: 01DD13
Coding: 024D25
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 18:31:00
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:00
Address 0E: Media Player 1
Address 0F: Digital Radio
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:22
Coding: 000017
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:50:48
Reset counter: 245
Mileage: 103632 km
Date: 2011.08.17
Time: 17:50:48
Coding: 80C303FF00
8 Faults Found:
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 18:05:14
Bin. Bits: 10111
Voltage: 12.00 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 18:05:14
Bin. Bits: 10111
Voltage: 12.00 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 31
Mileage: 103632 km
Date: 2011.08.17
Time: 18:05:18
Bin. Bits: 10111
Voltage: 12.00 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 18:05:18
Bin. Bits: 10111
Voltage: 12.00 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Reset counter: 246
Mileage: 103633 km
Date: 2011.08.17
Time: 18:34:03
Bin. Bits: 10111
Voltage: 12.40 V
Count: 6
Bin. Bits: 00000
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 18:13:47
Bin. Bits: 10111
Voltage: 11.90 V
Count: 6
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 18:13:49
Bin. Bits: 10111
Voltage: 11.90 V
Count: 6
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 18:19:40
Bin. Bits: 10111
Voltage: 11.90 V
Count: 6
Bin. Bits: 10000
Time: 25.40 s
Address 22: AWD
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 17:52:56
Address 37: Navigation
03219 - Access and Start Authorization
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 18:18:13
Reset counter: 246
Mileage: 103632 km
Date: 2011.08.17
Time: 18:17:19
Voltage: 11.90 V
Count: 80
Hex Value: 0x0273
Hex Value: 0x0001
Hex Value: 0x1010
Address 56: Radio
Address 65: Tire Pressure
Address 77: Telephone
