Hello all, first post so be kind. I have a 2017 VW T6 Transporter which I realised after buying does not have deadlocking i.e. the ability to be locked so that the van can’t be opened by pulling an internal door release. VW’s name for this is Safelock and I believe it’s not available in USA for regulatory reasons but it’s very handy for making the vehicle more secure, and annoyingly seems to be standard on virtually every T6 on the market.
Changing my van for another one is not an option so I set about trying to convert and tried to find out the differences that would enable it. It turns out the BCM and the door control modules in the window motors are the same, but the door lock actuators aren’t, so I got hold of actuators with the same part nos as Safelock vans for the two front doors and the sliding door and then activated Safelock with VCDS.
My problem is that when I activate it, I am then unable to lock the doors with the internal switch, they just bounce up unlocked immediately after locking. If I then disable Safelock, everything is back to normal and I can lock the doors using the internal switch. From what I can see, I’ve fitted compatible parts, the van recognises when the doors are open and shut as the courtesy light comes on and the correct door shows on the MFD. I’ve tried every combination I can think of in byte 00 and I’m stumped on where to go next. Would appreciate any shred of inspiration from people who know about these things. Enclose the autoscan with Safelock activated showing the door error messages I get.
Edit: Sorry I’ve only just seen the Retrofit section and I should have put it there.
Monday,20,November,2017,20:04:42:44671
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WV1ZZZ7HZHH048750 License Plate: 20THNOV17
Mileage: 9670km-6008mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 10 13 15 17 19 25 5F 61 0B
VIN: WV1ZZZ7HZHH048750 Mileage: 9670km-6008miles
Address 01: Engine (2D2D2-CXHA) Labels:. 04L-907-309-V2.clb
Part No SW: 04L 906 056 KG HW: 04L 907 445
Component: R4 2.0l TDI H02 3771
Revision: 23002001
Coding: 00254014436501090000
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ECM20TDI03004L906056KG 004004
ROD: EV_ECM20TDI03004L906056BM_004.rod
VCID: 7CA2FC4616618017072-8028
Readiness: N/A
Address 02: Auto Trans (J743) Labels:. 0BH-927-711.clb
Part No SW: 0BT 300 046 J HW: 0BH 927 711 G
Component: DSG DQ500-7F H11 5301
Revision: 00H11V01
VCID: 3D2431424DFB491F70C-8068
Address 03: ABS Brakes (J104) Labels:. 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 Q HW: 7E0 907 379 N
Component: ESC H06 0133
Revision: 00000000 Serial number: 42226000000264
Coding: 517E4098256684868A7C027BA48221D679F700
Shop #: WSC 02739 790 50316
ROD: EV_Brake1ESCCONTIVN75XGP2_011_VN35.rod
VCID: 40DA48B63A0924F71BA-8014
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 31081613470560
Coding: 01
ROD: EV_LWSKLOVW25X_VW25.rod
VCID: 7EA6F64E007D9207296-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 AC HW: 7E0 907 047 AC
Component: Climatic-T5 H22 0708
Revision: 00001002
Coding: 0000000003
ROD: EV_ClimaT5Basis.rod
VCID: 6B80CF1A630F17AF9E8-803E
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 B HW: 7E0 937 090
Component: BCM PQ25 Max4 H81 0744
Revision: B9081001 Serial number: 0982 247160737
Coding: E1A839BA0A61349280287D747E6D9EDD8FA4710F60CC4D60320400230840
Shop #: WSC 02737 022 186923
VCID: 2A0E0A1EACF5CEA725E-807E
Subsystem 1 - Part No SW: 7E0 959 801 Q HW: 7E0 959 801 Q Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 0653
Serial number: KU0KU030081662434740
Coding: 1400B1
Subsystem 2 - Part No SW: 7E0 959 802 Q HW: 7E0 959 802 Q Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 0653
Serial number: KU0KU030081662436077
Coding: 0400A1
Subsystem 4 - Part No SW: 7E0 959 442 A HW: 7E0 959 442 A Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H02 0103
Serial number: 29160001512780026341
Coding: B4FFFF
03301 - Response Closing Status of Drivers Door
Reset counter: 115
Mileage: 9674 km
Date: 2017.11.20
Time: 20:00:08
03302 - Response Closing Status of Passenger's Door
Reset counter: 115
Mileage: 9674 km
Date: 2017.11.20
Time: 20:00:08
03304 - Response Closing Status of Rear Right Door
Reset counter: 115
Mileage: 9674 km
Date: 2017.11.20
Time: 20:00:08
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 AA HW: 7N0 919 475
Component: PARKHILFE 8K H06 0212
Revision: -------- Serial number: 28261619402473
Coding: 10810C
ASAM Dataset: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BCDD724123FD7FA44-8024
Address 13: Auto Dist. Reg (J428) Labels:| 7N0-907-572.clb
Part No SW: 7N0 907 572 C HW: 7E0 907 572
Component: ACC Bosch PQx H03 0210
Serial number: 10081604391480
Coding: 00005000FE0779
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361_SK34.rod
VCID: 36362E6E68CD9A47B16-8062
Part No SW: 7E0 959 655 G HW: 7E0 959 655 G
Component: VW10Airbag021 H08 0018
Revision: -------- Serial number: 003V3001ZSZ7
Coding: 000000000000000000000000000000003231
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3A2E3A5E5CD57E2755E-806E
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 7E0 920 970 S HW: 7E0 920 970 S
Component: KOMBI H03 1104
Coding: 750F010300
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05733
ROD: EV_Kombi_UDS_VDD_RM09_005_VN35.rod
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H81 0744
Revision: B9081001
Coding: 042305
VCID: 688AB01672793CB7F3A-803C
Component: IMMO H03 1104
VCID: 6A8ECA1E6CF50EA7E5E-803E
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 1K8 035 150 H HW: 1K8 035 150 H
Component: MU-E--ER 055 7067
Serial number: 18081600010179
Coding: 065700003C00000041110001000000001F0000C60000010001
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW12.rod
VCID: 2A0E0A1EAC75CEA725E-807E
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001608151220
End----------(Elapsed Time: 01:24, VBatt start/end: 12.0V/12.2V)-----------
