Results 11 to 20 of 27
Thread: U1121 Missing Message -- Yes but from what?
    Jun 2017
    Thank you for the reply Uwe makes things clearer now.
    right now it's just this single module on the test bench.
    Yes it will be multiple modules like ECU ABS etc.
    I have CAN matrix documentation for all the messages so i know all the details of the messages, that combined with a trace from a car enables me to simulate the module like the ECU and ABS.
    It would make it easier to know what module i am not simulating correctly if VCDS log tells me from which module the missing or implausible message is.
    Have to do more reading on UDS haven't done much with it yet.
    Is it possible that the Advances Measuring Values that are available in VCDS going to be expanded in updates?
  2. #12
    Why can't this be implented in vcds,?
    That's a very good question! Unfortunately, I don't have enough familiarity with the intricacies of the source data to be able to give you a meaningful answer.
  3. #13
    Quote Originally Posted by jeroenveer View Post
    I certainly won't say that it's impossible. But it all depends on what's available in the source data. Almost everything in a UDS module is "driven" by the data available for that module.
  4. #14
    16653 - Databus
    This one should be for the steering angle sensor.
    Still looking for the rest.
  5. Likes jeroenveer liked this post
  6. #15
    is there any way to get some more information from this i tried to look for the number in front of the fault ( 16653, 16655 ) but i can't find any links on those.
    Here ya go:
    16653 - Databus
    Lenkwinkelsensor -TO -- LWL_01
    16655 - Databus
    Bremsensteuergerät - TO -- ESP_02
    17468 - Databus
    Bremsensteuergerät - TO -- ESP_05
    17495 - Databus
    Bremsensteuergerät - TO -- ESP_07
    17471 - Databus
    Bremsensteuergerät - TO -- ESP_14
    17469 - Databus
    Bremsensteuergerät - TO -- ESP_19
    17470 - Databus
    Bremsensteuergerät - TO -- ESP_21
    16657 - Databus
    Motorsteuergerät - TO -- Mot_12
    17474 - Databus
    Motorsteuergerät - TO -- Mot_14
    16727 - Databus
    Motorsteuergerät - TO -- Mot_20
    Hat tip to Yanping for finding these, and yes, we are looking at putting this data in VCDS in a future version.
  7. Likes Dana, Jack@European_Parts, jyoung8607 liked this post
  8. #16
    Jun 2017
    Thank you Uwe for looking into it!
    very curious how you found it!?
    currently trying the simulation still no luck with any off the fault.
  9. #17
    Jun 2017
    you posted just before i wrote my message.
    awesome very big thanks to both of you!
  10. Likes Dana, Uwe liked this post
  11. #18
    Jun 2017
    VCDS only shows max of 10 fault codes is this correct?
    Can confirm the codes below:
    16653 - Databus
    16655 - Databus
    17468 - Databus
    17495 - Databus
    Managed to clear the above with simulation and some new faults appear:
    17501 - Databus
    17502 - Databus
    17472 - Databus
    17473 - Databus
  12. #19
    Incorrect.
    Address 01: Engine (J623-CPRA)       Labels:. 06K-907-425-V2.clb
       Part No SW: 06K 906 070 F    HW: 06K 907 425
       Component: Simos12.2     H09 6865
       Revision: --H09---    Serial number: 00000000000000
       Coding: 001A0012242400170000
       Shop #: WSC 00066 790 00012
       ASAM Dataset: EV_ECM18TFS02006K906070F 001010
       ROD: EV_ECM18TFS02006K906070F.rod
       VCID: 2D07F73BFD945999033F-8078
    49 Faults Found:
    19795 - EVAP System Leak Detection Pump Heater Control Circuit
              P240A 00 [035] - Open Circuit
    19798 - Control Circuit for EVAP Vent Control
              P0447 00 [035] - Open Circuit
    19791 - EVAP Leak Detection Pump Control Circuit
              P2400 00 [035] - Malfunction
    14964 - Coolant Fan Control Circuit 1
              P0480 00 [035] - Electrical Malfunction
    23096 - Intake Air Temp. Sensor (G42)
              P0113 00 [035] - Signal too High
    15313 - Engine Coolant Temp. Sensor (G62)
              P0118 00 [035] - Signal too High
    16837 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
              P2185 00 [035] - Signal too High
    21352 - Secondary. Air Inj. Sys. Flow/Pressure Sens Bank 1
              P2432 00 [039] - Short to Ground
                        Mileage: 48447 km
                        Time: 00:00:00
                        Vehicle speed: 255 km/h
                        Coolant temperature: -39 °C
                        Intake air temperature: -40 °C
                        Ambient air pressure: 0 mbar
                        Voltage terminal 30: 11.992 V
                        Engine: operating status: ES
                        STATE_LS_SAE[1]: INI
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 0 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.065 V
                        FAC_TPS_1_SAE: 0.000000 %
                        FUP_H_SAE: 28000.0 kPa
    15219 - Accelerator Position Sensor (G79)
              P2122 00 [167] - Signal too Low
                        Mileage: 48447 km
                        Time: 00:00:00
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 255 kPa
    15221 - Accelerator Position Sensor 2 (G185)
              P2127 00 [167] - Signal too Low
                        Mileage: 48447 km
                        Time: 00:00:00
                        T_AST_SAE: 0 s
    17791 - Coolant Pump Control Circuit
              P2600 00 [035] - Open
    23176 - Sensor for Ambient Air Temperature (G17)
              P0070 00 [035] - Malfunction
    14995 - Fuel Pump Control Module
              P025A 00 [035] - Electrical Fault
    15034 - Fuel Pressure Sensor (G247)
              P0190 00 [035] - Circuit Malfunction
    15376 - Fuel Pressure Regulator Valve (N276)
              P2294 00 [167] - Open Circuit
                        Mileage: 48447 km
                        Time: 00:00:00
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 0 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 2.061 V
    15211 - Oile Pressure Regulating Valve
              P164E 00 [035] - Electrical Malfunction
    15289 - Output for Starter Relay
              P0615 00 [035] - Open Circuit
    15293 - Control Circuit for Starter Relay 2
              P3049 00 [035] - Open Circuit
    14923 - Crash Shut-Down Activated
              P1609 00 [168] - -
                        Mileage: 48446 km
                        Date: 2024.14.11
                        Time: 23:15:26
    14969 - Radiator Fan (V7)
              P1950 00 [096] - Movement Restricted / Jammed
    15131 - Cylinder 3
              P0303 00 [096] - Misfire Detected
    15128 - Cylinder 2
              P0302 00 [096] - Misfire Detected
    15137 - Random/Multiple Cylinder Misfire Detected
              P0300 00 [096] - -
    15187 - Park/Neutral Switch Input Circuit
              P0850 00 [035] - Open or Short to Plus
    15197 - Intake Manifold Flap Position Sensor (Bank 1)
              P2014 00 [039] - Electrical Malfunction
                        Mileage: 48447 km
                        Time: 00:00:00
                        Voltage terminal 30: 12.031 V
                        T_AST_SAE: 0 s
                        MAP_MES_SAE: 0 kPa
                        Lambda probe voltage: bank 1: probe 1 (broadband probe): 3.013 V
    19802 - EVAP System
              P0457 00 [096] - Leak Detected  (Check Fuel Cap!)
    17753 - Implausible Data Received from HVAC Control Module (J301)
              U0424 00 [035] - -
    14875 - No Communications with Airbag Control Module
              U0151 00 [035] - -
    16499 - Steering Column Control Module
              U0212 00 [035] - No Communications
    16790 - Implausible Data Received from Transmission Control Module
              U0402 00 [035] - -
    16791 - Implausible Data Received from Instrument Panel Control Module
              U0423 00 [035] - -
    16795 - Implausible Data Received from Transmission Control Module
              U0402 00 [035] - -
    14898 - No Communications with Steering Angle Sender (G85)
              U0126 00 [035] - -
    14906 - No Communication with ABS Brake Control Module
              U0121 00 [035] - -
    16990 - Body Control Module (Central Electric)
              U0140 00 [035] - No Communications
    15015 - Turbocharger Bypass Valve Control Circuit
              P0033 00 [035] - Malfunction / Open Circuit
    16469 - Throttle Actuator Control Circuit
              P2100 00 [167] - Open Circuit
                        Mileage: 48447 km
                        Time: 00:00:00
                        T_AST_SAE: 0 s
    17758 - Implausible Data Received from Transmission Control Module
              U0402 00 [035] - -
    15113 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
              P0036 00 [035] - Malfunction / Open Circuit
    15116 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
              P0030 00 [035] - Malfunction / Open Circuit
    15120 - Manifold / Barometric Pressure Sensor (G71) / (F96)
              P0108 00 [035] - Signal too High
    15212 - Manifold Pressure / Boost Sensor (G31)
              P0238 00 [035] - Signal too High
    15270 - Camshaft Timing Adj. Bank1 (N205)
              P1528 00 [035] - Open Circuit
    17759 - Implausible Data Received from Transmission Control Module
              U0402 00 [035] - -
    24558 - Implausible Data Received from Instrument Panel Control Module
              U0423 00 [035] - -
    16807 - Implausible Data Received from Transmission Control Module
              U0402 00 [035] - -
    15423 - Turbocharger Boost Control Position Sensor Circuit
              P2565 00 [167] - Signal too High
                        Mileage: 48447 km
                        Time: 00:00:00
                        Charge air pressure control valve uncond voltage sensor: 4.9902 V
                        Charge air pressure control valve voltage: position closed: 3.6621 V
                        Charge air pressure control valve activation pulse duty factor: 0.00 %
                        Charge air pressure control valve position: actual value: 0.00 %
                        Charge air pressure control valve position: target value: 0.00 %
    15338 - Throttle Position Sensor (G69)
              P0122 00 [167] - Signal too Low
                        Mileage: 48447 km
                        Time: 00:00:00
                        T_AST_SAE: 0 s
    15340 - Angle Sensor 2 for Throttle (G188)
              P0222 00 [167] - Signal Too Low
                        Mileage: 48447 km
                        Time: 00:00:00
                        T_AST_SAE: 0 s
    . Maybe the limitation is in the haldex module?
  13. Likes Jack@European_Parts, Uwe liked this post
  14. #20
    Jun 2017
    Yes then the modules has memory for only 10
