2015 Audi S4 (Headlight Problems)
mario01
C?ID=292756
>> Fixed all the other codes only have the below come up after I did a factory reset on the headlights thinking it would fix the auto adjusting issue. my initial problem was i had purchased the wrong light with adaptive steering, i got the light swapped out, but i still have the below codes come up. any help you can provide to help solve will be greatly appreciated.
-As mentioned before, there is something wrong still when you have a
[012 - Electrical Fault in Circuit] in the fault codes. Using the
Factory Repair Manuals and Wiring diagrams it will be necessary to
verify Powers, Grounds and wiring to these LED modules.
02895 - Supply Voltage for LED Module for DRL and Parking Light; Left
02897 - Supply Voltage for LED Module for DRL and Parking Light; Right
thank you for your response the auto scan came up clean only those issues still exist.
Please post it anyway. It shows what control modules are installed in the car.
mario01
C?ID=292756
Tuesday,14,November,2017,14:25:32:39527
VCDS Version: 17.8.0.1 (x64)  HEX-NET CB: 0.4407.4
VIN: WAUBGAFL9FA131388   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 3C 42 44 46 52 53 56 5F 62
          6C 72 A9
VIN: WAUBGAFL9FA131388   Mileage: 14560km-9047miles
Address 01: Engine (J623-CTUB)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 G    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0007
   Revision: --H07---
   Coding: 0A250034052600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551G 001007
   ROD: EV_ECM30TFS0218K5907551G.rod
   VCID: 3A38FE6DBDC5FE9684-806E
   Part No SW: 8K5 927 156 D    HW: 0B5 927 156 K
   Component: 0B5 30TFSINAR H03 0004
   Revision: --H03---
   Shop #: WSC 06325 000 00000
   ROD: EV_TCMDL501021.rod
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Coding: 291D1801
   VCID: 095A51A1A0A3250EDD-805C
   Part No SW: 8K0 907 064 KM    HW: 8K0 907 064 KM
   Component: BCM2 2.0      H15 0711
   Coding: 0D814040000000000000
   VCID: 05425D918CBB416EB9-8050
   Serial number: 3215000068858003
00955 - Key 1
            002 - Lower Limit Exceeded
                    Fault Status: 01100010
                    Reset counter: 214
                    Mileage: 14198 km
                    Date: 2017.11.03
                    Time: 07:59:30
   Part No SW: 8K1 820 043 AQ    HW: 8K1 820 043 AQ
   Revision: C1000000    Serial number: 01220420152414
   Coding: 6600228000
   VCID: 77BE2759C65723FEBB-8022
   Revision: 08016001    Serial number: 00001055265102
   Coding: 26000091863CAFE0010048C300003D0D0F9CD308A2090221000008004000030100000030000000
   Shop #: WSC 06325 123 12345
   VCID: 78BC2465CB492C86B2-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA250315  H19 0461
   Serial number: 1503190607933
   Coding: 004577
   Serial number: 20253716
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000604150785
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z01EB6811
   Serial number: B00944A7000000000001
                    Fault Status: 01101100
                    Reset counter: 232
                    Mileage: 14560 km
                    Date: 2017.11.14
                    Time: 14:19:35
                    Reset counter: 232
                    Mileage: 14560 km
                    Date: 2017.11.14
                    Time: 14:19:35
   Part No SW: 8K0 959 655 Q    HW: 8K0 959 655 Q
   Component: AirbagVW-AU10 H51 0812
   Serial number: 003NDD134Y7F
   Coding: 303844354730383131304A55304C384B3053
   ASAM Dataset: EV_AirbaECUVWAUDI010 003114
   VCID: 4BD6ABA9E25F771E2F-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R150000Q1MF
   Serial number: 6334MSME505D7727J
   Serial number: 6344MSME4F482F02O
   Serial number: 6352QSME38580248F
   Serial number: 6362QSME275A3978T
   Serial number: 63732SME5A6E565CJ
   Serial number: 63832SME215A3D742
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862ODK000WJ
   Coding: 000036
   VCID: 48DC94A5FB299C0602-801C
   Part No SW: 8K0 920 983     HW: 8K0 920 983
   Component: KOMBIINSTR.   H35 0567
   Revision: 00100000    Serial number: 63-71734G
   Coding: 8BB709000301D705020000
   VCID: 72A8164DAD3546D68C-8026
   Revision: 1Z120030    Serial number: 3041Z154140B2C
   Coding: 80C303FF00
   VCID: 4CD4A8B5EF51702626-8018
   Serial number: 8955916203
   Component: MEM-FS        H06 0077
   Revision: AA000000    Serial number: 00000143928467
   Coding: 00581B00000000000000
   VCID: 3B36FB69BAFFC79E9F-806E
   Serial number: 0366922831
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: 3FCE8F79A6E7DBBEB3-806A
   Component: SWA Slave  H05 0071
   Serial number: 0366547138
   Coding: 010211
   Component: TSG FA        H10 0305
   Coding: 011C13204E00410001
   VCID: 56E04ADD219D3AF680-8002
   Part No SW: 8K0 909 144 P    HW: 8K0 909 144 B
   Component: RCEPS         H43 0510
   Revision: 00001000    Serial number: 0007695021
   Coding: 100000010001
   ASAM Dataset: EV_RCEPSAU48X 008018
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3E30F27DA1EDD2B6B8-806A
   Revision: 00002001    Serial number: 0364787982
   Coding: 0106023A00FA400580B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000975108
   Subsystem 3 - Part No SW: 8K0 959 591 C    HW: 8K0 959 591
   Component: J245 PS051  H08 0043
   Component: TSG BF        H10 0305
   Shop #: WSC 06342 000 00000
   VCID: 55E24DD13C9B31EE89-8000
   Component: EPB-4         H02 0005
   Revision: --------    Serial number: 30000000365146
   ROD: EV_ParkiBrake_VW51.rod
   Component: Radio U SIRIU H66 0133
   Revision: AB001007    Serial number: 156DZ0F8255260
   Coding: 020007020100000001
   VCID: 2404201527419866CE-8070
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 G
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 523D30F7539548
   Coding: 110200000206A1EF55028B5E00000403140000000000000000
   Subsystem 1 - Part No: 8R0 060 884 CJ
   Component: NAR 2015  1102
   Component: DU7 High  H42 0104
   Serial number: A130DM0F3330527
   Serial number: 00000002208164
   Component: CD-Database  5950
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H08 0305
   Coding: 010C13204000210001
   VCID: 59FA41E15083158EAD-800C
   Revision: --H09---    Serial number: 525PA8-JA2908D
   Coding: 1000006
   VCID: 383CE4654BC9EC8672-806C
02203 - Audio / Video Input 1
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 2
                    Mileage: 14217 km
                    Date: 2017.11.04
                    Time: 08:18:02
                        Term 15 On
                        Reverse OFF
                    Count: 3
                    Fault Status: 00101011
                    Reset counter: 2
                    Mileage: 14217 km
                    Date: 2017.11.04
                    Time: 08:19:37
                        Term 15 On
                        Reverse OFF
                    Count: 3
   Component: TSG HR        H08 0305
   Component: SAS-GEN 2     H06 0006
   Serial number: 150407201034
   VCID: 72A8164DA53546D68C-8026
End----(Elapsed Time: 01:58, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
mario01
C?ID=292756
Any help or suggestions will be greatly appreciated. Thank you.
mario01
C?ID=292756
Audi S4 DRL issue
Fixed all the other codes only have the below come up after I did a factory reset on the headlights thinking it would fix the auto adjusting issue. my initial problem was i had purchased the wrong light with adaptive steering, i got the light swapped out, but i still have the below codes come up which came up after i did the factory reset as well only shows up when the headlights are turned on. DRL stay on when the headlights are off as they should, but turn off when the headlights are on, believe they should dim? any help you can provide to help solve will be greatly appreciated.
          6C 72 A9
  Revision: --H07---
  Revision: --H03---
  Coding: 291D1801
00955 - Key 1
                    Reset counter: 214
                    Mileage: 14198 km
                    Date: 2017.11.03
                    Time: 07:59:30
  Coding: 6600228000
  Coding: 004577
  Coding: 02005D
                    Reset counter: 232
                    Mileage: 14560 km
                    Date: 2017.11.14
                    Time: 14:19:35
                    Reset counter: 232
                    Mileage: 14560 km
                    Date: 2017.11.14
                    Time: 14:19:35
  Coding: 000036
  Coding: 80C303FF00
  Coding: 010211
  Coding: 010211
  Coding: 1000006
                    Reset counter: 2
                    Mileage: 14217 km
                    Date: 2017.11.04
                    Time: 08:18:02
                        Term 15 On
                        Reverse OFF
                    Count: 3
                    Reset counter: 2
                    Mileage: 14217 km
                    Date: 2017.11.04
                    Time: 08:19:37
                        Term 15 On
                        Reverse OFF
                    Count: 3
Please don't start multiple threads for the same problem in the same car.
Threads merged.
mario01
C?ID=292756
Sorry about that. Just didn't get any replys thought i was in the wrong forum. Is there any actual help here? Or are these forums just setup to catch users without a license to use your software??
I'm confident if someone had an idea what was up with your car, they would have posted.
What exactly is this "Factory Reset" that you did?
mario01
C?ID=292756
09-Central Elect, adaptation, channel-00, and saved settings which did factory reset. the DRL would dim when turning on the headlights prior to the factory reset, after factor reset DRL turns off when turning on the headlights, as well get the below error, which was not an issue prior to the factory reset. can you tell how i can get the DRL to dim vs turn off when turning on the headlights? i believe would fix the issue.
No, I've been through everything we have documented about this module and I don't see anything obvious.
Given that these are "Supply Voltage" codes, have you checked the supply voltage to that module with meter, and traced it back to see where it comes from?
mario01
C?ID=292756
it was in 09-Cent. Elect., Adaptation, Channel 00, and save which set it to factory settings.
prior to the factory reset my DRL would dim when the headlights were on, after the reset they turn off when the headlights are on. if some can help me set the DRL to dim and not turn off when the headlights are on it should fix the problem.
mario01
C?ID=292756
good evening everyone. still have the issue any help will be appreciated.
MasterTommy
Amsterdam
C?ID=295586
As Uwe said, did you check the voltage on the controller thats giving the 'low supply voltage' error? Anything else is pointless at this moment.
Dana
Western PA, USA
Right. At face value:
.. look like missing fuses or incorrect headlight parts. Those do not appear to be related to tweaks or basic settings.
Checking power with a DVOM should help clarify if you are missing power. If so, wiring diagram and the fuse arrangement schematics would be necessary.
mario01
C?ID=292756
I will check, but the odd part is that the DRL actually turn in the day as they should only when the headlights turn one then they turn off and the message comes on. What is a DVOM and where can I find the relay?
mario01
C?ID=292756
Fixed it, thank you.
