Results 1 to 10 of 10
Thread: 2011 Skoda Octavia 1.6 TDI CAYC Control Module for All Wheel Drive (J492) dead?
    Mar 2017
    Norway
    We have a customer with a Scoda 4WD, that wil not work. It just stopped working one day.
    Codes it gives:
    Chassis Type: 1Z-SK35 (7N0)
    Scan: 01 03 08 09 15 16 17 18 19 22 25 42 44 46 52 55 56 62 69 72
              77
    VIN: TMBKT61Z0B2038870   Mileage: 177540km-110318miles
    22-AWD -- Status: Cannot be reached 1100
    Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
       Part No SW: 03L 906 023 FP    HW: 03L 906 023 AG
       Component: 1,6l R4 CR td H23 6921
       Revision: --------    Serial number:
       Coding: 00194016032600080000
       Shop #: WSC 73430 031 00999
       ASAM Dataset: EV_ECM16TDI02103L906023FP 003003
       ROD: EV_ECM16TDI02103L906023DB.rod
       VCID: 79F8697DF82B948ECD-802C
    9867 - Coolant Pump 2
              P261A 00 [237] - Open circuit
                        Mileage: 177538 km
                        Date: 2017.10.06
                        Time: 13:58:03
                        Engine speed: 2716.00 /min
                        Normed load value: 29.0 %
                        Vehicle speed: 86 km/h
                        Coolant temperature: 85 C
                        Intake air temperature: 29 C
                        Voltage terminal 30: 13.892 V
                        Coolant temperature at radiator outlet: actual value-TCO_2: 78 C
                        Battery voltage: 13.7 V
    9870 - Coolant pump 2
              P261B 00 [101] - Implausible signal
                        Mileage: 177544 km
                        Date: 2017.10.06
                        Time: 14:05:55
                        Engine speed: 2208.25 /min
                        Normed load value: 40.0 %
                        Vehicle speed: 48 km/h
                        Coolant temperature: 87 C
                        Voltage terminal 30: 13.779 V
                        Coolant temperature at radiator outlet: actual value-TCO_2: 87 C
                        Battery voltage: 13.8 V
       Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
       Revision: 00H31001
       Coding: 113B201C0A250002881304EB50190041340000
       Shop #: WSC 73430 790 00999
       VCID: 76E26241C135FBF6A0-8022
    01324 - Control Module for All Wheel Drive (J492)
                        Reset counter: 150
                        Mileage: 176131 km
                        Date: 2012.02.03
                        Time: 11:25:42
                        Count: 12800
                        Count: 8202
                        Count: 48640
                        Count: 65281
                        Count: 1279
       Part No SW: 3T0 907 044 BA    HW: 3T0 907 044 BA
       Component: Climatronic   H15 0401
       Revision: 00005001
       Coding: 0000000002
       ROD: EV_ClimaAutoBasis_SK35.rod
       VCID: 72EA5E51A55DE7D68C-8026
       Part No SW: 1K0 937 087 J    HW: 1K0 937 087 J
       Component: BCM PQ35  H   103 0615
       Revision: 00103 AD
       Coding: 40180AB8E00508C040080080110011E4427000AE726DA5605C0540000040
       VCID: 387EAC798BA14D8672-806C
       Subsystem 1 - Part No: 1Z1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 05091  22  0601
       Coding: 00D7B7
       Component: RLS 020910 05  54  0403
       Coding: 0730ED
       Component: Q6 AIRBAG VW8   020 2300
       Revision: 05020000    Serial number: 0038PC1ZW45$
       Coding: 0020790
       VCID: 3D70BD6D648368AEA1-8068
       Subsystem 1 - Serial number: 6332MSME5635777EP
       Subsystem 2 - Serial number: 6342MSME56355816B
       Subsystem 3 - Serial number: 6351HSME24236528%
       Subsystem 4 - Serial number: 6361HSME237D4539E
       Part No SW: 5K0 953 521 BL    HW: 5K0 953 569 C
       Component: LENKS.MODUL   009 0136
       Revision: FF010038    Serial number: 20100910301104
       Coding: 5080140000
       ASAM Dataset: EV_SMLSNGVOLWS A01004
       ROD: EV_SMLSNGVOLWS.rod
       VCID: 77FC6F45CE3F82FEBB-8022
       Part No SW: 1Z0 920 843 M    HW: 1Z0 920 843 M
       Component: KOMBI         H04 0406
       Coding: 110F01
       VCID: 428ACE91D57D1756DC-8016
    Address 18: Aux. Heat        Labels: 1K0-815-007.clb
       Part No: 1K0 815 007 BT
       Component: Standheizer     022 3907
       Revision: 00022000    Serial number: 09020188000000
       Coding: 0030012
       Shop #: WSC 59190 002 1048576
       VCID: 77FC6F45063F82FEBB-8022
    01412 - Glow-Plug with Flame Monitoring (Q8)
                        Fault Frequency: 6
                        Reset counter: 163
                        Mileage: 162611 km
                        Date: 2011.08.08
                        Time: 08:48:44
                            Start
                        Temperature: 78.0C
                        Temperature: 75.0C
    02251 - Heater Unit Locked
                000 -  -
                        Reset counter: 123
                        Mileage: 162839 km
                        Date: 2011.08.10
                        Time: 13:51:19
    Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 5603
       Revision:   H27       Serial number: 010910F1001041
       Coding: E9837F46000E0200002302
       VCID: 6DD04D2D7463382E51-8038
                        Fault Frequency: 59
                        Reset counter: 151
                        Mileage: 176131 km
                        Date: 2012.02.03
                        Time: 11:25:42
    Address 22: AWD
       Component: IMMO          H04 0406
       VCID: 6ADA46318D8D2F1634-803E
       Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
       Coding: 0000246
       VCID: 76E262410135FBF6A0-8022
    00131 - Outside Door Handle Illumination/mirror Light Driver Side
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 69     3001
       Revision: 00H17000
       VCID: 3168915DA8DB9CCE35-8064
       Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
       Coding: 0000246
       VCID: 489EDCB93B413D0602-801C
       Coding: 1507354
       Shop #: WSC 43060 001 1048576
       VCID: 3466984957C9A9E65E-8060
       Coding: 00000023
       Coding: 00000023
       Part No SW: 1Z0 035 161 G    HW: 1Z0 035 161 G
       Component: Radio-SWING   010 0033
       Revision: -----14S    Serial number: SKZ4Z2K1316147
       Coding: 050004000001
       VCID: 326A9E516DDDA7D64C-8066
    00856 - Radio Antenna
                        Fault Status: 01101011
                        Fault Frequency: 233
                        Reset counter: 189
                        Mileage: 162597 km
                        Date: 2011.08.08
                        Time: 08:29:14
       Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
       Coding: 0000144
       Shop #: WSC 73430 790 1012551
       VCID: 326A9E51ADDDA7D64C-8066
       Part No SW: 1K0 907 383 F    HW: 1K0 907 383 F
       Component: Anhaenger     H07 0100
       Revision: 3A001001    Serial number: 00000132301675
       Coding: 410D000100000000
       VCID: 306E945963D195C63A-8064
    02566 - Trailer; Left Turn Signals (M62)
                        Fault Status: 11101010
                        Reset counter: 120
                        Mileage: 174984 km
                        Date: 2012.01.15
                        Time: 16:07:39
       Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
       Coding: 0000144
       VCID: 33649B5552C7AEDE47-8066
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668542720
       Coding: 0200000000010110
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA.rod
       VCID: 326A9E5165DDA7D64C-8066
    End-------------------------(Elapsed Time: 02:52)--------------------------
    Log-NF45395-TMBKT61Z0B2038870-177540km-110318mi.txt
    Friday,06,October,2017,14:26:00:62150
    VCDS Version: 17.8.0.1
    VIN: TMBKT61Z0B2038870   License Plate: NF45395
    Mileage: 177540km-110318mi   Repair Order:
              77
                        Mileage: 177538 km
                        Date: 2017.10.06
                        Time: 13:58:03
                        Mileage: 177544 km
                        Date: 2017.10.06
                        Time: 14:05:55
       Revision: 00H31001
                        Reset counter: 150
                        Mileage: 176131 km
                        Date: 2012.02.03
                        Time: 11:25:42
                        Count: 12800
                        Count: 8202
                        Count: 48640
                        Count: 65281
                        Count: 1279
       Revision: 00005001
       Coding: 0000000002
       Revision: 00103 AD
       Coding: 00D7B7
       Coding: 0730ED
       Coding: 0020790
       Coding: 5080140000
       Coding: 110F01
       Coding: 0030012
                        Fault Frequency: 6
                        Reset counter: 163
                        Mileage: 162611 km
                        Date: 2011.08.08
                        Time: 08:48:44
                            Start
                        Temperature: 78.0C
                        Temperature: 75.0C
                000 -  -
                        Reset counter: 123
                        Mileage: 162839 km
                        Date: 2011.08.10
                        Time: 13:51:19
                        Fault Frequency: 59
                        Reset counter: 151
                        Mileage: 176131 km
                        Date: 2012.02.03
                        Time: 11:25:42
    Address 22: AWD
       Coding: 0000246
       Revision: 00H17000
       Coding: 0000246
       Coding: 1507354
       Coding: 00000023
       Coding: 00000023
                        Reset counter: 189
                        Mileage: 162597 km
                        Date: 2011.08.08
                        Time: 08:29:14
       Coding: 0000144
                        Reset counter: 120
                        Mileage: 174984 km
                        Date: 2012.01.15
                        Time: 16:07:39
       Coding: 0000144
       ROD: UHVNA.rod
    Secondary Pump is chaneged, error is no more - LITTLE TIP - if You get a code like that, change the pump, so the car will go out of Limp Mode, I didn't expect that an auxilairy pump can put the car in Limp mode, but it does..
    So what can I do with this 4x4 module? Cables and plugs look allright, the module itself looks ok from the outside, no leaks from the diff... ANY tips guys? Or is it a "change the part" kind of case??
    Regards,
    Daniel
    Change the module if all inputs are present..........
    At that point what does It hurt to take apart to have a look besides time?
    Be sure the CAN gateway is working.........
  3. Likes DanielR liked this post
    Mar 2017
    Norway
    This car has a history of 150+ fails on all modules, and the reason to it was the alternator. When I changed the alternator, all was ok, until now...
    I don't have experience with those 4x4 modules, but if the Gateway works, it should have some sort of communication with this module, right?
    Not always .........I would hook up directly on the CAN High/Low and see using WD.
  6. Likes DanielR liked this post
    Mar 2017
    Norway
    Well... I don't have acess to a scope right now :-/
    Not a scope.......... hook up direct with VCDS..............CAN high/low direct to module.
    NO PM please...... only in public..........
    The CAN can be accessed directly using WD.......make a bench or mobile harness or back probe the CAN high/low twisted pair at the 0x22 module by isolating pins.
    If you don't have access to books or SSP you can get scripts at ERWIN.
    https://erwin.skoda-auto.cz/erwin/showHome.do
  10. Likes DanielR liked this post
  11. #8
  12. #9
    Mar 2017
    Norway
    now THAT is an answer, thanks and bows to your knowledge :-)
  13. Likes Jack@European_Parts liked this post
  14. #10
    I'm just another asshole in the mix........... no one special here.............
  15. Likes Uwe liked this post
