Results 1 to 4 of 4
Thread: 2008 VW Caddy 2.0 SDI BST stalling, misfire, difficult to start
    Mar 2017
    Norway
    We have a VW Caddy on the wallpaper currently, symptoms it gives are:
    - On cold start the engine starts, and then it "slows down" on idle, til it dies (not allways),
    - On warm engine difficult to start; when it starts, misfires on cylinder 3. You can hear that it works only on 3 cylinders,
    Codes and scans I got:
    Chassis Type: 2K (1K0)
    Scan: 01 03 08 09 15 16 17 19 25 42 46 52 56
    VIN: WV1ZZZ2KZ8X140837   Mileage: 187540km-116531miles
    Address 01: Engine        Labels: 03G-906-016-BDJ.clb
       Part No SW: 03G 906 016 LF    HW: 03G 906 016 DR
       Component: R4 2,0L EDC 0000SG  2977
       Revision: 12345678    Serial number: VWX7Z0H33N114C
       Coding: 0000071
       Shop #: WSC 00160 218 87304
       VCID: 72EA5E516D5DE7D68C-8026
    16787 - EGR Valve (N18)
                P0403 - 000 - Malfunction
                        RPM: 840 /min
                        Torque: 58.6 Nm
                        Duty Cycle: 18.7 %
                        Duty Cycle: 95.2 %
                        Absolute Pres.: 887.4 mbar
                        Temperature: 20.7C
    16687 - Cylinder 3
                P0303 - 000 - Misfire Detected
                        RPM: 840 /min
                        Torque: 46.4 Nm
                        Voltage: 14.06 V
                        Inj. Quantity: 2.96 mg/str
                        Temperature: 50.4C
                        (no units): 0.0
       Revision: 00H11001
       Coding: 0021205
       Shop #: WSC 35110 377 00155
       VCID: 73E45B551247EEDE87-8026
       Part No SW: 1K0 820 047 HM    HW: 1K0 820 047 HM
       Component: Climatic PQ35   142 1111
       Revision: 00142031    Serial number: 00000000000000
       VCID: 76E262410135FBF6A0-8022
       Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
       Revision: 00H54000    Serial number: 01000008242529
       Coding: 08884F030004100057000000000000000009FB075C000100000000000000
       Shop #: WSC 35110 377 08192
       VCID: 6FEC57257E6FCA3E63-803A
       Subsystem 1 - Part No: 2K1 955 119 C  Labels: 1KX-955-119.CLB
       Component: Wischer 260308 021  0501
       Coding: 00038805
       Shop #: WSC 35110
                        Reset counter: 23
                        Mileage: 182732 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 14.35 V
    00985 - Right Tail Light (M2)
                        Reset counter: 23
                        Mileage: 187360 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 10.95 V
                        Fault Status: 00101010
                        Reset counter: 44
                        Mileage: 185892 km
                        Date: 2005.09.13
                        Time: 31:63:63
                        Voltage: 12.70 V
    Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
       Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
       Component: 0A AIRBAG VW52  025 2400
       Revision: 06025000    Serial number: 0037TR004Y6O
       Coding: 0012353
       VCID: 7DF07D6D2403A8AEE1-8028
       Part No SW: 1K0 953 549 BK    HW: 1K0 953 549 BK
       Shop #: WSC 00160 218 76793
       VCID: 7CF670693F19A1A6D6-8028
       Part No SW: 2K0 920 844 C    HW: 2K0 920 844 C
       Component: KOMBIINSTRUMENT VDD 1222
       Revision: V0002000    Serial number: VWX7Z0H33N114C
       Coding: 0016101
       Shop #: WSC 42263 001 1048576
       VCID: 2B5483358AF7F61E0F-807E
       Component: J533__Gateway   H16 0210
       Revision:   H16       Serial number: 3400K09316062C
       Coding: A9801F06000202007400
       VCID: 377CAF4546BF42FE7B-8062
       Component: IMMO            VDD 1222
       Part No SW: 1T0 959 701 D    HW: 1T0 959 701 D
       Component: Tuer-SG         006 1205
       Coding: 0000048
       VCID: 387EAC794BA14D8672-806C
    00913 - Window Regulator Switch; Front Right Driver (E81)
    Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
       Part No: 1K0 959 433 CP
       Coding: 80890C087F2D8405484A036010C0
       VCID: 000E049953F1C5468A-8054
       Part No SW: 1T0 959 702 D    HW: 1T0 959 702 D
       Coding: 0000048
       VCID: 3978A97D70AB548E8D-806C
    Address 56: Radio
    End-------------------------(Elapsed Time: 01:34)--------------------------
    Address 01: DTCs cleared
    Control Module Part Number: 03G 906 016 LF    HW: 03G 906 016 DR
      Component and/or Version: R4 2,0L EDC 0000SG  2977
               Software Coding: 0000071
                Work Shop Code: WSC 00160 218 87304
    16688 - Cylinder 4
                P0304 - 000 - Misfire Detected - Intermittent
                        RPM: 819 /min
                        Torque: 95.2 Nm
                        Voltage: 14.29 V
                        Temperature: 27.0C
                        (no units): 0.0
    Readiness: 0 0 0 1 0
                    Address 01: Engine  (03G 906 016 LF)
    01:38:21 Group 013: Idle Stabilization (Injection Quantity Deviation)
      -1.48 mg/str  Injection Quantity Deviation Cyl. 1
      -1.65 mg/str  Injection Quantity Deviation Cyl. 2
      2.99 mg/str  Injection Quantity Deviation Cyl. 3
      -1.11 mg/str  Injection Quantity Deviation Cyl. 4
    Obviously, there is something going on with injector no.3, But can it be the cause of all problems? EGR fault did not come back after clearing errors. And one time I got a misfire on Cylinder 4...
    Boss already ordered a new injector, but I like to be sure before I change some expensive parts, that it solves the problem ;-)
    Regards,
    Daniel
    Hey Dan,
    Yeah I'd have a look at the cam and lifters on this for wear but yeah I think the injector is most likely done if the ramps are clean.
    Verify that some dumbass didn't alter the tappet gaps inducing FOD for lash.
  3. Likes DanielR liked this post
    Mar 2017
    Norway
    Thanks for the answer Jack, I will check for wear and FOD when I'm on it :-)
  5. Likes Jack@European_Parts liked this post
  6. #4
    Centurion........Report............?
